EMDMA CTL.DMAS1 bit stuck.
Product Number: ADSP-21584
Hi there,
We're using the EMDMA feature in a product, and are experiencing an obscure bug that happens occasionally when trying to reset the EMDMA.
We are using the EMDMA in the Scatter/Gather mode. During certain user interactions, we need to reset the EMDMA, setting up new TCBs. The code we use for resetting the EMDMA is as follows (simplified for the sake of the example):
// Wait until EMDMA isn't busy anymore
bool emdmaBusy = true;
while(emdmaBusy)
	int ctl = (_configuration._deviceNum == EMDMAConfiguration::DeviceNumber::eEMDMA0) ? *pREG_EMDMA0_CTL : *pREG_EMDMA1_CTL;
	emdmaBusy = ((ctl & (BITM_EMDMA_CTL_DMAS0 | BITM_EMDMA_CTL_DMAS1)) != 0);
// Reset DMA
*pREG_SPU0_SECUREP158 = 0x2; // security unlock both emdma channels
_firstTcb = nullptr;
_lastTcb = nullptr;
*pREG_EMDMA0_CTL = 0;
*pREG_EMDMA0_INDX1 = 0;
*pREG_EMDMA0_MOD1 = 0;
*pREG_EMDMA0_CNT1 = 0;
*pREG_EMDMA0_INDX0 = 0;
*pREG_EMDMA0_MOD0 = 0;
*pREG_EMDMA0_CNT0 = 0;
*pREG_EMDMA0_CHNPTR = 0;
*pREG_EMDMA0_BASE = 0;
*pREG_EMDMA0_TPTR = 0;
*pREG_EMDMA0_BUFLEN = 0;
*pREG_EMDMA0_TCNT = 0;
*pREG_EMDMA0_CTL =  BITM_EMDMA_CTL_EN        // enable
				  | BITM_EMDMA_CTL_CHEN    // chaining enable
				  | BITM_EMDMA_CTL_CBEN    // circular buffer enable
				  | BITM_EMDMA_CTL_TLEN    // tab-list enable
				  | BITM_EMDMA_CTL_OFCEN;  // on-the-fly control loading
// Add new TCBs...
Usually, this goes well. However, very rarely, we experience that we never move past the emdmaBusy-check, as the DMAS1 bit of the corresponding CTL register keeps being 1.
We have tried also checking the status of the CHS bit in the CTL register in addition to the DMAS0 and DMAS1 bits, but that unfortunately does not help.
As mentioned, this happens very sporadically, leading me to suspect that it is somehow related to timing.
Does anyone have a clue what we might be doing wrong? Or has anyone experienced something similar?
BR,
Mathias.
  • Hi Mathias,
    If possible, could you please share a simple project file with us that simulates your issue on the ADSP-SC584 EZkit?
    Ranjitha.
  • Hi Ranjitha,
    While I would love to do so, I will unfortunately not be able to find the time to do such a thing in the foreseeable future. I understand that that makes it harder to give a qualified answer to my question, but I was hoping that someone would have experienced something similar.
    BR,
    Mathias
  • Hi Mathias,
    Can you please refer the below FAQ link which talks about "ADSP-SC58X How to configure EMDMA Gather mode" and contains example code.
    ez.analog.com/.../adsp-sc58x-how-to-configure-emdma-gather-mode
    Please use this as a reference and modify as per your requirement.
    Ranjitha.R
  • I'm experiencing the same behavior with the DMAS1 bit not clearing, even though the copied data is verified to be completed and correct. This issue occurs sporadically after many successful transactions. This happens for chained and non-chained transactions.
    As a workaround, I've implemented a check for REG_EMDMA0_CNT0 == 0 instead of relying on BITM_EMDMA_CTL_DMAS1. Besides that I'm still checking BITM_EMDMA_CTL_CHS and BITM_EMDMA_CTL_DMAS0.
    The MDMA registers don't exhibit any stuck bit behavior and provide better performance, so I recommend migrating to MDMA. However, it would be nice if the underlying EMDMA issue could be investigated.
    To assist you better, could you please share a simple project that replicates your issue on the ADSP-SC58x board?
    Nandini C
