I want to extend the timer
Product Number: ADSP-21565
Software Version: CrossCore Embedded Studio 2.11.0
Hi.
I am waiting for the filter to settle using a timer. While the timer was running, a change occurred in the filter. I want to reset the timer to allow time for the modified filter to settle.
How can I extend the duration of a timer while it is running?
What should I do?
I'm starting Timer like this.
*pREG_TIMER0_TMR1_WID=TIMER_WIDTH_10*WAITCOEF_GEQ[0];
*pREG_TIMER0_RUN=((1 << BITP_TIMER_RUN_TMR01) & BITM_TIMER_RUN_TMR01); // Enable the timer
Here are the timer settings
// Open the timer
adi_tmr_Open(GEQ_TIMER_NUM, TimerMemory01, ADI_TMR_MEMORY, TimerHandler_GEQ, NULL, &ghTimer01);
// Set the mode to PWM OUT
adi_tmr_SetMode(ghTimer01, ADI_TMR_MODE_SINGLE_PWMOUT);
// Set the timer width
adi_tmr_SetWidth(ghTimer01, TIMER_WIDTH_10);
// Set the timer_delay
adi_tmr_SetDelay(ghTimer01, TIMER_DELAY);
adi_tmr_EnableGracefulStop(ghTimer01, true);
adi_tmr_SetClkInSource(ghTimer01, ADI_TMR_CLKIN_SYSCLK);
adi_tmr_SetPulsePolarity(ghTimer01, false);
adi_tmr_DisableOutput(ghTimer01, true);
adi_tmr_SetEmuRun(ghTimer01, true);
adi_tmr_SetIRQMode(ghTimer01, ADI_TMR_IRQMODE_WIDTH_DELAY);
// Open the timer
Thanks & Best Regards,
YAMAMOTO
    Unfortunately, you cannot extend a timer’s duration while it is running in ADI_TMR_MODE_SINGLE_PWMOUT mode. However, if you use ADI_TMR_MODE_CONTINUOUS_PWMOUT, you can modify the Period/Width parameters while timer is running, and it will reflect in next cycle.
    Nandini C
