adi_mdma_IsCopyInProgress() always returning true on adi_mdma_CopyList() with source XMODIFY = 0
The user is experiencing an issue with MDMA descriptors list mode where adi_mdma_IsCopyInProgress() returns true indefinitely when trying to clear a 4096-byte SDRAM buffer using a 32-byte zero-filled source buffer. The solution involves setting the source XCount to 32 and XModify to 0 to ensure 32 transfers of 32 bytes each, matching the destination XCount and XModify settings. This configuration prevents the DMA from stalling and completes the buffer clearing process.
Product Number: ADSP-21569
I'm unsuccessfully trying to clear a big size SDRAM buffer using MDMA descriptors list mode by pointing to a 32-bytes buffer (since I'm using MSIZE = 32 bytes) filled with zeros as source buffer, and setting XCOUNT = 1 and XMODIFY = 0 in source descriptor.
The problem I'm experiencing is basically that after starting a list descriptors copy with using such descriptors, adi_mdma_IsCopyInProgress() is returning true forever.
My current project code is based on MemCopyListMode sample code, which I modified as follows.
Added MEMCOPY_XMODIFY_BYTES definition in header:
Source data buffer resized to MSIZE and number of src/dst descriptors doubled (see comment in code):
PrepareDataBuffers() adapted:
Modified PrepareDescriptors():
Resulting behavior is that main() is looping forever here in this loop:
This is DMA8 and DMA9 registers content when the DSP is looping forever in while loop above, nothing looks out of place from my point of view:
Thanks in advance to everybody would like to contribute
BR
Edit Notes
missing part
[edited by: SpoonMan999 at 8:57 AM (GMT -4) on 29 Jul 2025]
    From your description we understand that you are using MDMA copy in descriptor list mode to clear 4096 bytes (4 descriptors × 1024 bytes) of SDRAM. A small 32-byte zero-filled buffer is used as the source. The intent is to repeatedly copy the 32-byte zero buffer across the full 4 KB region. Please confirm our understanding.
    If it's correct, please refer the attached project which copy the data correctly.
     MemCopyListMode.zip
    Initially, the configuration had:
    Source XCount = 1, XModify = 0
    Destination XCount = 32, XModify = 32
    This caused only 32 bytes to be transferred, and the DMA stalled. Each MDMA descriptor is configured to transfer 1024 bytes (i.e., MEMCOPY_BYTES_PER_DESC = 1024). Since the MSIZE is 32 bytes, that means:
    1024 bytes / 32 bytes-per-transfer = 32 transfers
    To match this, the source must perform 32 transfers of 32 bytes each. Setting XCount = 32, XModify = 0 tells MDMA to read the same 32-byte source buffer repeatedly without incrementing. The destination will receive 32 transfers, filling 1024 bytes with repeated 32-byte data.
    If XCount is incorrectly set to 1 in the source, only 1 transfer of 32 bytes is initiated. The destination waits for 32 transfers leads to DMA hang issue.
    Nandini C
  • Thank you Nandini, problem solved.
    The error was in XCount value for the source descriptor, which must not reflect the size of the 32-byte buffer but the total number of MSIZE transfers that need to be performed by the DMA controller from source to destination.
