Strange hardware failure with looping output audio
Product Number: ADSP-21569
Hello!  We have a strange failure with our ADSP-21569 + DDR3 audio product in the R&D phase.
For software, we have a simple project that simply passes the audio data on the input of one SPORT to the output of another (passthrough).  We are loading this from a host processor over SPI.
On several boards now, we have seen the failure where the software downloads ok and the firmware starts to run.  However, it appears the DSP crashes, but the audio that was on the input previously continues to output, but just loops over and over, i.e. further changing the audio input does not change the output -- it continues to repeat whatever the input signal was at program start.
This seems like a hardware issue to us because most PCBs do not have any issue, and once a PCB is in this state, it cannot be recovered.
We were wondering if this failure mode has been seen before by anyone else, and where may be a good area/method to start to look for the issue?
Thanks!
  • Hi Peter,
    We understand that you are facing issue in SPI slave booting in ADSP-21569. Please confirm whether our understanding is correct.
    Please provide your comments on below questions to narrow down the issues
    1. Please let us know the silicon revision of both working and non-working board.
    2. How many boards have you tested and how many of them shows this issue?
    3. Can you please send us the fault ratio?
    4. Please share more information about the Host.
    5. Are you using INIT code while creating the loader file?
    6. Is it possible for you to test with simple LED blink application and check whether the issue persist?
    7. Did you already aware of the application note(EE-418) which talks about "ADSP-2156x Board Design Guidelines for Dynamic Memory Controller". If not please refer the below link and check whether it helps.
    https://www.analog.com/media/en/technical-documentation/application-notes/ee418v02.pdf
    Nandini C
  • Hello Nandini, thank you for you fast reply Slight smile
    Answers to your questions:
    The part markings seem identical see the attached photos
    We have built 33 boards, and 3 so far have failed with this issue.
    Note the 3 that failed initially are working ok, and failed after some use.
    3/33 = 9% failure rate in 3 months of use.
    The host is a TI ARM CPU running Linux and communicating to the '569 over SPI.
    Yes, we are using the 2156x_init project.
    The simple LED blinking example application seems to run normally, it is only our audio application using SigmaStudio+ that seems to have the issue on these 3 boards.
    By the way, is there available any kind of DDR3 validation example app for '569?
    Something that similar to memtester in Linux that would test the full DDR chip for read/write operations.
    www.analog.com/.../ee418v02.pdf
    Unfortunately, the engineer who designed the DDR I/F for this board is no longer at the company, however a quick look at the design and it seems to follow the guidelines well.
    The DDR3L is a common Micron part MT41K64M16TW-107:J run at 1.39V
    There is a 0.69V VTT termination LDO power supply using TPS51206.
    All address and control lines are terminated there through 47 ohm resistor.
    Trace lengths seem short and well matched.
    Anyway, each of the boards did work for a while but then failed, so seems unlikely it is a design issue on the DDR.
    Thanks!!
  • Hi Peter,
    Can you please refer the DDR sweep test, which is in POST example of 21569. We suggest you to take this code as a reference and modify it according to your external memory configuration.
    Please find the below link for the ADSP-2156x Board support package.
    download.analog.com/.../ADI_EV-2156x_EZ-KIT-Rel3.0.0.exe
    Once Installed, you can find the example from the below mentioned path.
    [Installation path]: \Analog Devices\EV-2156x_EZ-KIT-Rel3.0.0\EV-2156x_EZ-KIT\Examples\Power_On_Self_Test
    Nandini C
  • In the end, seems we are able to resolve this issue by reflowing solder on the DSP.
    So seems it is some kind of cracked solder issue.  If there is any special application note on soldering of the BGA package for this part, let me know.  But we can mark this issue as resolved.
  • Hi Peter,
    Glad to know that the issue got resolved and thanks for the update.
    Unfortunately, we don't have any application note available for soldering of the BGA package.
    Nandini C
