Hi there,
We're attempting to build a continuous integration pipeline and for that we need to have an automated build system for the ADSP-2156x. We have followed instructions to download CrossCore Embedded Studio in Linux (debian distro) from this document. However, the command to build a project from command line (using ccesc.exe) is not available in the Linux install. For reference, I am attempting to use the below command as per this FAQ article here:
> C:\analog\cces2.7.0\Eclipse\ccesc -nosplash -consoleLog -application com.analog.crosscore.headlesstools \
-data C:/path/to/workspace -project C:/path/to/project -build all
As I said above when entering this command in Debian, the following error message is given:
-bash: ccesc.exe: command not found
Indeed, upon inspecting the /Eclipse directory there doesn't seem to be a ccesc.exe file in the directory (as is the case in Windows).
Please could you provide an alternative command that we can use in the Linux command line to build a project from source?
Thanks very much in advance.
