ts201
HI!
QUESTION 1:
I use TS201 IRQ0 interrupt, sometimes I find that when using the RTI out of the interrupt, the corresponding PMASK hasn't been cleared,SO the
programs cannot into the interrupt again.
QUESTION 2:
I use  link port of two DSP and
Procedures used were used to link two DSP  through the dedicated DMA channels to receive the same data from FPGA, in order to keep the synchronization of the receiving, I AND the two LXACKO signals as FPGA transmit enable signal, but the result is a DSP success, another DSP ONLY received a portion of the data.
THANK YOU
    on Feb 12, 2013 4:57 AM
       Sorry for the delay in getting back on your questions. Please see my answers as below:
    QUESTION 1:
    Ans >> It will be good if you can share the code which you have used for this testing.
    QUESTION 2:
    Ans >> From the description I understand that the FPGA sends the data to link ports of two processors simultaneously. Since the link port communication depends on the handshake between transmitter and receiver I am not sure on whether ANDING the LxACKO signals will violate the timings needed for link ports. Have you verified on whether the link port communication works fine individually between the DSP's link port and FPGA for both the processors. If the problem happens only when both the processors are used simultaneously, can you probe the link port signals and see whether they look as expected.
    Since the same data is received by both the processors, you can think of the below approach:
    1. use one link port to receive the data and place it in common external memory or internal memory of the processor
    2. Use multiprocessor feature to inform the other link port once the transfer is completed. Or send the data using another link port to the other processor.
    Best Regards,
    Jeyanthi
    on Aug 2, 2018 4:46 PM
    Thank you,
    EZ Admin
