Help: Reading ADAU1797A over SPI with Aardvark (Control Center)
Product Number: adau1797a
I’m running a custom algorithm on the ADAU1797A and want to build a tuning tool that updates parameters at runtime.
Setup
  • Hardware: ADAU1797A, Aardvark adapter on SPI (J1).
  • Firmware: I created a dedicated memory region in the linker script so the tuning data lives at a fixed address. I can read/write this region fine with the debugger.
Issue
  • Using the Aardvark + Total Phase Control Center to read that address over SPI returns all zeros.
What I’ve tried
Request
Could someone share a minimal example of performing SPI reads from the ADAU1797A using an Aardvark, ideally in C# (Aardvark API) or a Control Center batch script? A snippet that:
  1. switches the ADAU1797A from I²C to SPI,
  2. performs a register/memory read (including the correct address format and R/W bit handling),
  3. shows expected SPI mode, clock polarity/phase, bit order, and chip-select behavior
…would be hugely appreciated.
