KCC's Quizzes AQQ306 about a fish stick challenge
1. First the quote of the month: " I am so clever that sometimes I don't understand a single word of what I am saying" - Oscar Wilde
2. New quiz AQQ306 about a fish stick challenge:
Here below is a pseudo fish diagram swimming to the right.
Question
Strong EMC design
DS2485
Production
The DS2485 is a 1-Wire® master that performs protocol conversion between the I2C master and any attached 1-Wire slaves. For 1-Wire line driving, internal...
Datasheet
DS2485 on Analog.com
DS28E18
Production
The DS28E18 is a simple communications bridge that resides at a remote SPI or I2C sensor and allows the sensor to be controlled by just two wires coming...
Datasheet
DS28E18 on Analog.com
This is my slave device's circuit,which has DS28E18, ADS1115 and the PTC. I want to read lots of slave devices,but the voltage from ADS1115 is lower than only one slave device working‘s. Sometimes even can't read the data of Slavce devices. I have tried to add the Pull-up resistor with any resistance,but it’s of no avail.So I want to know any other problem will be ameliorate this situation.
Sincerely hope your help!!Thanks!!!
The ADS1115 does not have a "1-Wire" connection it has "I2C interface" The purpose of the DS28E18 is to convert "I2C interface" (SCA/SDL) to "1-Wire" and its "1-Wire" that can be daisy chained. The DS2450 1-Wire Quad A/D Converter would daisy chain to the "1-Wire" bus made by the DS28E18. Its easy to get confused but check what the devices you are using actually can do, get datasheets for each device.
So you are connecting the ADS1115 as remote to the DS28E18 by I2L signals SDA and SCK. The DS28E18 is communicating by 1-wire to the DS2485 which is being controlled by a microcontroller. You are saying "but the voltage from ADS1115 is lower than only one remote device working‘s" I don't understand this? which signal line is too low please? Remember that yoy have to send an address to U2 or it will not output anything.
" The ADS111x have one address pin, ADDR, that configures the I2C address of the device. This pin can be connected to GND, VDD, SDA, or SCL, allowing for four different addresses to be selected with one pin, as shown in Table 7-2. The state of address pin ADDR is sampled continuously. Use the GND, VDD and SCL addresses first. If SDA is used as the device address, hold the SDA line low for at least 100 ns after the SCL line goes low to make sure the device decodes the address correctly during I2C communication. Table 7-2. ADDR Pin Connection and Corresponding Target Address"
This is a complicated setup you are using! Why not use a DS2450 (or similar) 1-wire ADC instead of connecting a DS28E18 and ADS1115 together.
Thank you for your professional reply!!!!
As for why I didn't use the DS2450 ,it's because that our lab is more convenient to use the ADS1115.And it's the last engineer's work,I must takeover it.
The most important is the number of the ADS1115 will be lower than the theoretical situation,because the slave device is powered by the Sense_VDD Pin of the DS28E18,but when I test the Pin's voltag,I found it just ~2.5V(It should be 3.3V).I don't know how to solve this problem.
I appreciate your offer the new chips for me,I will consider replacing the DS28E18 and ADS1115 with the DS2450.
OK I understand, 3V3_Slave depends on the 1-Wire voltage and 1_Wire ability to provide enough current to all your sensors.
Its not only DS2450, several Analog Devices IC's would work for this with direct 1-Wire.
Its not shown on the datasheet but a 10uF 6.3V Tantalum decoupling capacitor between 3V3_Slave and Ground might be a good idea. A circuit like below can put some extra current into the 1-Wire, even by choice of Rp3 on previous drawing or Rpup on the drawing below, all the current has to come from Vcc.
If you use U2 remember please that you have two "not great" ideas a) more IC's than you need and b) supplying power to lots of IC's over 1-Wire. You will have to count up carefully all the current needed by your sensors IC's.
Good luck with your project.
