tigersharc adsp-ts201s link port boot
Hi ,
I got the following  link for link port boot in C
https://ez.analog.com/dsp/otherdsp/f/q-a/60348/link-boot.
But in this program , Master and slave are having exactly same code and transmitting LED blinking code  through link port 3
I need to send this code through link port 1
so I made some changes as below
Processor_A.c:
#include <defts201.h>
#include <signal.h>
#include <sysreg.h>
#include <builtins.h>
#define COUNT 512
#define MODIFY 4
#define m_linkNo 1
typedef struct tcb_block
long DI;
long DX;
long DY;
long DP;
}tcb_block;
#pragma align _QUAD
int source[] = {
#include ".\Debug\Blink_LED.ldr"
int tx_done = 0;
volatile int tx_dma_result=0;
void link_transmit_isr(int dummy);
#pragma align _QUAD
tcb_block transmit_tcb;
union
unsigned long long dmablWord;
unsigned long vWord[2];
} dmastat;
dmastat.dmablWord = __builtin_sysreg_read2(__DSTAT);
tx_dma_result = (dmastat.vWord[0] >> (m_linkNo * 3 + 12)) & 0x7;
void main()
int i;
int dummy;
volatile __builtin_quad tcb_clr;
volatile __builtin_quad tcb_set;
//interrupt(SIGDMA4, link_transmit_isr);
__builtin_sysreg_write(__LTCTL0,0);
__builtin_sysreg_write(__LTCTL1,0);
__builtin_sysreg_write(__LTCTL2,0);
__builtin_sysreg_write(__LTCTL3,0);
__builtin_sysreg_write(__LRCTL0,0);
__builtin_sysreg_write(__LRCTL1,0);
__builtin_sysreg_write(__LRCTL2,0);
__builtin_sysreg_write(__LRCTL3,0);
dummy = __builtin_sysreg_read(__LTSTAT0);
dummy = __builtin_sysreg_read(__LRSTAT0);
dummy = __builtin_sysreg_read(__LTSTATC0);
dummy = __builtin_sysreg_read(__LRSTATC0);
// Open global interrupt enable
__builtin_sysreg_write(__SQCTLST, SQCTL_GIE);
tcb_clr = __builtin_compose_128((long long)TCB_DISABLE << 32, 0);
__builtin_sysreg_write4(__DC5, tcb_clr);
__builtin_sysreg_write(__LTCTL1,LTCTL_TEN | LTCTL_TCLKDIV4 );
for(i = 0; i < 100000; i++ ) // delay for receiver to get ready
asm("nop;;");
transmit_tcb.DI = (int)source;
transmit_tcb.DX = (COUNT << 16) | MODIFY;
transmit_tcb.DY = 0;
transmit_tcb.DP = TCB_INTMEM | TCB_QUAD | TCB_INT | TCB_DMAR;
tcb_set = __builtin_compose_128(((long long)transmit_tcb.DX << 32) | transmit_tcb.DI, ((long long)transmit_tcb.DP << 32) | transmit_tcb.DY);
__builtin_sysreg_write4(__DC5, tcb_set);
//__builtin_sysreg_write(__LTCTL0,LTCTL_TEN | LTCTL_TCLKDIV4 );
asm("nop;nop;nop;idle;;");
while(1)
asm("nop;;");
Processor_b.c  ;
#include <signal.h>
#include <sysreg.h>
#define COUNT 512
#define MODIFY 4
#define m_linkNo 1
long DI;
long DX;
long DY;
long DP;
}tcb_block;
#pragma align _QUAD
int source[] = {
int des[1000];
int tx_done = 0;
volatile int rx_dma_result=0;
void link_receive_isr(int dummy);
#pragma align _QUAD
union
} dmastat;
rx_dma_result = (dmastat.vWord[1] >> (m_linkNo * 3)) & 0x7;
void main()
int i;
int dummy;
// interrupt(SIGDMA8, link_receive_isr);
__builtin_sysreg_write4(__DC9, tcb_clr);
__builtin_sysreg_write(__LRCTL1,LRCTL_REN | LTCTL_TCLKDIV4 );
asm("nop;;");
//transmit_tcb.DI = (int)des;
transmit_tcb.DI = 0x0;
__builtin_sysreg_write4(__DC9, tcb_set);
//__builtin_sysreg_write(__LRCTL0,LRCTL_REN | LTCTL_TCLKDIV4 );
while(1)
asm("nop;;");
so this code not working
I am able to send code in des[] array ... but  in this case (transmit_tcb.DI = 0x0 ) ...it LED corresponding to processorB is not blinking.
I am new to tigersharc. so can somebody send me the working code?
