Hi
I am trying to enable software exception interrupts on a TS201 processor, without success.
I specifically want interrupts on floating-point errors (e.g. div-by-zero).
I enabled global interrupts, unmasked the bits in the XSTAT/YSTAT registers, and unmasked the bit in the SQCTL register, but my ISR is still never executes.
The following is an extract from my test code:
int swErrCnt = 0; void SWerrorISR(int signal) { swErrCnt++; } void TestSWinterrupt(void) { __builtin_sysreg_write(__SQCTLST, 0x0004); // Global interrupt enable interrupt(SIGSW, SWerrorISR); // Register interrupt handler //Unmask S/W interrupts: asm("R0 = STAT;;"); asm("R1 = 0x700000;;"); //IVEN (invalid floating-point), OEN (overflow), UEN (underflow) asm("R0 = R0 or R1;;"); asm("STAT = R0;;"); __builtin_sysreg_write(__SQCTLST, SQCTL_SW); // Unmask S/W exception interrupts in SQCTL register. // Force floating-point error volatile float aa = 1.0, bb = 0.0, cc; cc = aa/bb; // Divide by zero printf("S/W IRQ count: %d", swErrCnt) }
Any help will be appreciated!
Thanks
Thinus Viljoen
