In our application we are using link ports to transfer data between an FPGA and the DSP at periodic intervals. We setup link port 1 (LP1) in DMA receive mode as prescribed in the HRM (pages 15-15, 15-16). After the data is received, LP1 and it's DMA are disabled so that they can be enabled in the ISR (see below) to handle the receive request (LRRQ) interrupt as shown below
// Step 1: clear LRRQ bit ustat1 = dm(REG_LP1_STAT); bit set ustat1 BITM_LP_STAT_LRRQ; // set LRRQ bit dm(REG_LP1_STAT) = ustat1; // W1C LRRQ // Step 2: enable Link Port DMA ustat1 = dm(REG_DMA36_CFG); // LP1 DMA is DMA36 (see HRM 38-5) bit set ustat1 BITM_DMA_CFG_EN; // set enable bit dm(REG_DMA36_CFG) = ustat1; // enable LP1 DMA // Step 3: enable Link Port ustat1 = dm(REG_LP1_CTL); bit set ustat1 BITM_LP_CTL_EN; // set enable bit dm(REG_LP1_CTL) = ustat1; // enable LP1
However, I'm running into issues where enabling the link port (Step 3) appears to advance the DMA start address and X count by 1 word. See the following snips of the LP1 and DMA36 regs.
On entry into the ISR
After Step 1: clear LRRQ bit
After Step 2: enable link port DMA (in Stop mode)
After Step 3: enable link port
note that ADDR_CUR has advanced by 4 bytes (1 word) and the XCNT_CUR decreased by 1
I haven't been able to figure out what's causing this and haven't come across any reference to this behavior in the HRM. I have tried using DMA in autobuffer mode and see the same behavior. Any information on what's going on will be very much appreciated.
Best regards
AG
