ADUCM3029 pinmux document
Can you point me to a document that describes how pinmux assignments are made for the ADUCM3029?  I see the bit shifting in the sample code, but it's not clear how those bits map to the physical I/O pins of the IC and I don't see a description of the pinmux register anywhere.
Matt
  • Hi Matt,
    If you are using the Cross Core IDE the pin muxing is located in the system.svc file at the bottom of your project assuming you already installed pin multiplexing add-in. By this add-in, you just simply select the peripherals to enable and this component will generate the C code necessary to configure the peripherals.
    Kim
