Write into flash
BF706 series with w25q32bv
To write a .ldr file into a flash, I am using below command.
 cldp -proc ADSP-BF706 -emu 1000 -driver "C:\Analog Devices\ADSP-BF706_EZ-KIT_Mini-Rel1.1.0\BF706_EZ-Kit_MINI\Blackfin\Examples\Device_programmer\bf706_w25q32bv_dpia.dxe" -cmd prog -erase all -offset 0 -format hex -file "C:\Users\Test\Debug\Test.ldr"
The .ldr will be write into flash at adresse 0x40000000 (SPI2 memory)
My question is, what if I want to use Write_flash_page() function to write a .ldr file to flash at the addresse 0x40001000. The Write_flash_page() function is:
void Write_flash_page(unsigned int PAGE_ADDR, unsigned char* flash_page_data_buff, unsigned short page_data_count)
*pREG_SPI2_SLVSEL &= ~ENUM_SPI_SLVSEL_SSEL1_HI ; // selct_flash;
flash_byte_access(FLASH_WR_EN); // send write enable command
*pREG_SPI2_SLVSEL |= ENUM_SPI_SLVSEL_SSEL1_HI ; // deselct_flash;
wait_for_flash_status(WEL, 1);
flash_byte_access(FLASH_PG_PRM); // send page program command
flash_byte_access(PAGE_ADDR >> 16);
flash_byte_access(PAGE_ADDR >> 8);
flash_byte_access(PAGE_ADDR);
int i;
for(i=0; i<page_data_count; i++)
flash_byte_access(*flash_page_data_buff++);
wait_for_flash_status(WIP, 0);
Can I just call the above function like this:
Write_flash_page(0x40000000, unsigned char* flash_page_data_buff, unsigned short page_data_count);
Anyone can please help me.
    on Mar 6, 2020 2:17 PM 7 months ago
    Yes, you can use this approach to load the .ldr into flash.
    BTW, I'm attaching a simple project that can write loader into flash. This was tested on ADSP-BF707 EZ-kit. Please use this as a reference and modify for ADSP-BF706 accordingly.
    Anand.S
    SPI_Flash_test.zip
  • Hi Anand,
    Thank you for your reply.
    I want to ask you some more question here.
    1. After I am finished with writing into flash, the controller has to be power off and then on to run the application. To avoid power off/on, I want to boot the rom or make a watchdog. But nothing happens.
    I am using:
    *pREG_L1IM_ICTL = 0;
    adi_rom_Boot(0x40000000, 0, 0, 0, 0x207);
    To boot from flash address 0x00
    And the watchdog code is:
    /*SEC configuration for WDOG to issue FAULT*/
    *pREG_RCU0_BCODE = 0x0;
    *pREG_RCU0_CTL |= BITM_RCU_CTL_SRSTREQEN;
    *pREG_SEC0_GCTL = ENUM_SEC_GCTL_EN;
    *pREG_SEC0_SCTL3 = BITM_SEC_SCTL_FEN | BITM_SEC_SCTL_SEN;
    *pREG_SEC0_FCTL = BITM_SEC_FCTL_EN | BITM_SEC_FCTL_SREN ;
    *pREG_WDOG0_CNT = 0x1312D00;
    *pREG_WDOG0_CTL = 0x01;
    I put these codes right after when I have checked the result for flash "check_result()".
    Would you please tell me, what I am doing wrong?
    2. I assume that your .ldr file is in include format. But mine is in hex format, so I parse the overheads and then I write hex data into the flash.
    The .ldr file looks here:
    1. :020000040000FA (this line is overhead)
    2. :10000000015018AD0000A011000000002470010094 (0x10 is the size of the line, 0x0000 is the start address in flash, 0x00 is last, and 01, 50, 18, AD, 00, 00, A0, 11, 00, 00, 00, 00, 24, 70, 01, 00  are the code hex data which they will write to flash, correct?)
    3. :20001000010094AD00200008100000000000000004200008000000000C20000800000000F6
    4. :20003000010084AD1020000810000000000000004D6F64655F546573742E64786500000043
    5. :200050000100EEAD20200008D49E00000000000000E80300F9B0B8B0616071C2012001DA4E
    1. :20FFA40000D8B011E808000200D8B011F8120000F1B9FFE37EDB00D8B011E0080002012086
    2. :20FFC400422000D8B01138094004080C3C1000D8B0113A094004000C181421E10002006081
    3. :1CFFE40000DE00081275000000D8B0119408000221E14000006000DE000812754E
    4. :020000040001F9
    5. :20000000000000D8B011940800021E2000D8B0113A094004080C181400D8B011FC12000064
    6. :200020000960FFE348DB00D8B011E408000200D8B011041300000960FFE33DDB00D8B0111F
    7. :20004000EC0800020120012000E22A131899080C0218682300D8B0119208050A00D8B01104
    8. .......
    9. :1070240001809DAD0000A0110000000000000000E0
    10. :00000001FF
    The .ldr starts with an overhead ":020000040000FA" and next line indicates the start address 0x0000 into the flash. The hex data will be written to the flash until address 0xFFE4, which the last hex data 0x75 (line 8) will be write into the flash. Then at line 9, there is again an overhead ":020000040001F9", and the next line indicates start address 0x0000 for the flash.
    Why are there two overheads?,
    How can I deal with two overhead?
    I assume, line 10 start address is not 0x0000, and it has to be 0x10004, correct?
    All the overheads have to be parsed and only the hex data have to be written to the flash, correct?
     I have studied the EE-240 paper but I need more understanding for ldr format, and if you can explain it to me in a simple way, I will be happy.
    Thank you.
    on Mar 13, 2020 12:36 PM 7 months ago in reply to SVA
    I've tested the code with adi_rom_Boot and it works fine. However, as you mentioned we tested it using Include format. Can you let me know why you are very specific in using HEX format? Did you get a chance to test it using Include format?
    Can you also elaborate on what you mean by overheads?
    Anand Selvaraj.
  • Hi Anand,
    I don't understand how can it will be effected on adi_rom_Boot if I use ldr file in include format or hex format.
    adi_rom_Boot(0x40000000,0,0,0,0x20210202);
    I want to boot from address 0x40000000 which it is flash address.
    What is your command?
    Regarding hex overhead EE-240:
    Best Regards
    SVA
  • Any idea?
    I want to read data from flash, how can I do that according to your attaching project?
    Lets assume I want to read data from address 0x10 (0x40000010), then how can I do it?
    Read_flash (RD_Block_ID, Read_BUFF,  sizeof(Read_BUFF));
