Setting Registerbits for Saturation Arithmetic
I´m using the ADSP-SC584 with the respective Evaluationboard and Cross Corse 2.8.3.
I wanted to use Saturatioan Arithmetic to preventing my Data from overflowing.
In the Document "SHARC+ Core Programming Reference" I found the following:
  ALU Saturation
When the REGF_MODE1.ALUSAT bit is set (= 1), the ALU is in saturation mode. In this mode, positive fixedpoint overflows return the maximum positive fixed-point number (0x7FFF FFFF), and negative overflows return the maximum negative number (0x8000 0000). When the REGF_MODE1.ALUSAT bit is cleared (= 0), fixed-point results that overflow are not saturated, the upper 32 bits of the result are returned unaltered.
I´m pretty new to this topic and dont know how to set this bit. And also I´m confused about the fact that the saturation is for fixedpoint numbers. The ADSP-SC584 is a floating-point DSP, will this work with floating-point too?
Looking for help
Regards
Viktor
  • Hello,
    Regarding,"I´m pretty new to this topic and dont know how to set this bit."
    >>The below assembly Bit set instruction is used to set the ALUSAT bit from the MODE1 register of ADSP-SC58x Processors.
    asm("BIT SET MODE1 0x00002000;");
    >>The below assembly Bit Clear instruction is used to set the ALUSAT bit from the MODE1 register of ADSP-SC58x Processors.
    asm("BIT CLR MODE1 0x00002000;");
    You can use the above instructions when programming the ADSP-SC58x Processors via CCES software.
    Regarding,"And also I´m confused about the fact that the saturation is for fixedpoint numbers. The ADSP-SC584 is a floating-point DSP, will this work with floating-point too?"
    >> The fixed point and floating point overflow has a exception/interrupts to handle. In addition fixed point overflows can be prevented by using ALUSAT bit.
    Hope this helps.
    Lalitha
