I try to use two interfaces to work together: UART and SPI-slave.
For the B core, I have UART initialization:
void uart_init(unsigned int divisor)
packet_ready = false;
com_init(divisor);
*pILAT = *pILAT | EVT_IVG8; // clear pending IVG7 and IVG8 interrupts
*pSICB_IAR3 = Peripheral_IVG(
28,
8);
*pUART_IER = ETBEI | ERBFI;
asm("ssync;");
register_handler(
ik_ivg8,
ISR_UART_receive);
*pSICB_IMASK0 |= SIC_MASK(28);
For the A core, I have define-switched SPI-slave initialization:
void vovka_spi_slave_init_a(void)
*pSPI_CTL &= (~SPE); // disable SPI
*pSPI_STAT = TXCOL | RBSY | MODF | TXE;
*pSPI_FLG = 0;
*pSPI_BAUD = SPI_BAUD_RATE_DIVISOR;
*pSPI_CTL = CPOL | PSSE | EMISO;
asm("ssync;");
*pSPI_CTL |= SPE; // enable SPI
register_handler(
ik_ivg11,
SPI_Interrupt);
*pSICA_IAR3 = Peripheral_IVG(
27,
11);
*pILAT |= EVT_IVG11;
asm("ssync;");
*pSICA_IMASK0 |= SIC_MASK(27);
asm("ssync;");
Analogously, I have define-switched SPI-slave initialization for the B core:
void spi_slave_init_b(void)
*pSPI_FLG = 0;
asm("ssync;");
register_handler(
ik_ivg11,
SPI_Interrupt);
27,
11); // DMA2 Channel 4 interrupt (SPI) 27 IVG9 27
*pILAT |= EVT_IVG11; // clear pending IVG9 interrupts
asm("ssync;");
*pSICB_IMASK0 |= SIC_MASK(27);
asm("ssync;");
And i see the next behavior:
- when I switch my defines to use the A-core SPI, both UART and SPI work;
- when I switch to the B-core SPI, UART works and SPI fails, and
- when I use the B-core SPI without UART setup, SPI works.
The same thing could be seen when i try to compose SPI and SPORT in one core.
What should I add/change to make UART and SPI to work in the B-core?
Or maybe there is a fundamental restriction that prevents any two non-DMI interfaces to work together in one core?
