what is the difference between BInary and Intex hex loader file?
Can anyone tell me the difference between binary and intel hex loader file?
Additionally, to program the code into the flash which format i should choose?
Benix.
    Benix.
    Hi Benix,
    The main difference between the Intel HEX32, industry-standard PROM-file format we use as our default loader file format and the ASCII/INCLUDE/BINARY formats is that the Intel HEX32 contains PROM target address entries for each record, upper order (secondary) PROM address records, end-of-file records, individual record checksums, record type and size information, etc.  None of this information is present in the (unformatted) loader file types of ASCII/INCLUDE/BINARY.
    These other formats are designed for PROM burners that do not support the default Intel HEX32 format.  The data contained in these files is still encoded as a linked list of blocks, each containing a block header (reflecting target address, size and flag information) and block data (payload) as described in our documentation (see VisualDSP++ Loader and Utilities Manual).  Of particular import is to know that the ASCII/INCLUDE/BINARY formats are devoid of PROM address information.
    These lesser formats basically contain the byte-oriented loader data as width-adjusted hex-encoded characters (ASCII), hex-encoded characters separated by commas (INCLUDE) or raw binary data (BINARY).
    Regarding your second question, as i mentioned above, we support a number of loader file formats (S-RECORD, ASCII, INCLUDE, BINARY and Intel HEX32 format), all of which are documented and discussed in more detail in the VisualDSP++ Loader and Utilities Manual. Which format to use is entirely up to you.
    You can check which file format is available for a specific processor by checking the 'Format' Section under the 'Load:General' section of the 'Project Options', available from the Project file menu within VisualDSP++.
    We have several Application Notes which may be of interest to you. EE-240 - "ADSP-BF533 Blackfin(r) Booting Process" and EE-239 - "Running Programs from Flash on ADSP-BF533 Blackfin(r) Processors".  Both of these, and others, are available from our website at the following location: www.analog.com/eenotes
    David.
    Thank you,
    EZ Admin
