Audio Processing using BF537
Hi all,
   I am new to DSP,just started learning one month back.
I have been given the task of audio processing in BF537 .
1) Audio filter design(DNR-dynamic noise reduction)
2)VOX implementation
3)cahnnel filters of 12.5khz and 2 KHz....
4)Scrambler and Descrambler.
i am not understanding from where to start.
Please someone help me out, i need guidence.
I have deadline on july last week.
    on Jun 28, 2010 10:51 AM
    I believe its better to start from scratch with Blackfin processors in general rather than jumping into audio processing tasks (where I cannot help you in detail).
    First of all, what hardware and software do you have?
    Are you using an ADSP-BF537 EZ-KIT Lite or a custom board?
    Are you using an ICE/Emulator?
    Are you using VisualDSP++?
    Are you already able to create and run simple test programs or example code?
    -> Are you familiar with the tool chain as you mentioned that you just started with our processors.
    Regards
    Andreas
    on Jun 29, 2010 4:12 AM
    with tool chain I just mean the hard/software that you are using and how it works. But I think we can skip these basics by now.
    I have attached you a UART example code. This is for connecting a PC terminal program to the EZ-KIT and do some UART loopback. See EE-347: http://www.analog.com/static/imported-files/application_notes/EE-347_rev.1pdf.pdf
    You will find the functions you need in ADSP-BF534-UART.c / ADSP-BF534-UART.h
    The ISRs use macros (e.g. ERROR(1,"...") ) instead of a standard printf functions, just to let you know...
    One additional hint as you have created your own definitions:
    \Blackfin\include\defBF537.h
    \Blackfin\include\defBF534.h
    contain these register mask definitions already. Usually you just need to include blackfin.h.
    Regards
    Andreas
  • Hi Andreas,
    Thanks for the replay.
    I am using ADSP-BF537 EZ-KIT Lite and VDSP++ Software.
    I know i cannot directly jump for audio without knowing basics,
    so i have started with simple UART program(still working on that).
    Yes,i am able to create and run the  test programs without using the board.
    And i didn't get this sentence..
    "Are you familiar with the tool chain as you mentioned that you just started with our processors."
    I am facing some problem in UART program,
    Confusion in setting the interrupts and Calculating the divisor.
    I am attaching the c file,plz see to it,
    possibly i am wrong somewhere.
    on Jul 29, 2010 4:15 AM
    I'm sorry, but most of us here are not familiar with the uclinux toolchain, we use VisualDSP++ instead.
    For any linux related questions, please go to the uclinux website use the forum there: http://blackfin.uclinux.org
    Regards
    Andreas
  • Hi.
    Thanks for the support and help.
    Now my work is to port linux on Blacfin 537.But i am very new to linux too.
    Can u guide me how to start with this?
    bootloaders,crosstool chain ,got confused,,,,
    plz help
