BF547  - Configuring SPORT0 Primary & Secondary to work with AD73311L x 4
I'm trying to work with SPORT0(Bf547) connected to four AD73311L. The primary ch' of the SPORT is connected to 2 AD73311Ls in cascade,and the secondary ch' of the SPORT is connected to the other 2 AD73311Ls.from an older code of mine (where I use only the Primary and only to codecs in cascade ), I took the control word that I send to the codecs ,and duplicate it(word for primary , word for secondary, and so on ).it seems like the codecs are not configured Properly . do you have any suggestions ? Any  insight? Any advices?
Thanks in advanced
Alon
lon
  • Hi
    Do you actually see dat / clk / fs coming on the lines at the device probing end (so there are no MUX related to board level issues)? Can you post the SPORT configuration, and a connection block diagram? Do the devices connected to primary work, when primary alone is turned on, with data in consecutive locations? How do you see that these devices actually fail? Instead of relying on their analog end, is there a way to read back the programmed control data?
    Regards
    Prasanth.
  • Hi Prasanth
    Sport configuration :
    _InitSport0:
        link 4;
        P0.H = HI(SPORT0_RCR1);
        P0.L = LO(SPORT0_RCR1);
        R0 = 0x0400;
        W[ P0 ] = R0.L;
        ssync;
        P0.L = LO(SPORT0_RCR2);
        R0 = SLEN_16_ENSEC; // SPORT WORD length = 16 & Enable Secondary side of Sport
        W[ P0 ] = R0.L;
        ssync;
        P0.L = LO(SPORT0_TCR1);
        R0 = 0x400;
        W[ P0 ] = R0.L;
        ssync;
        P0.L = LO(SPORT0_TCR2);
        R0 = SLEN_16_ENSEC;// SPORT WORD length = 16 & Enable Secondary side of Sport
        W[ P0 ] = R0.L;
        ssync;
        p0 = [fp+4];
        unlink;
        jump(p0);
    _InitSport0.END:
    The  words for the control registers of the codecs are :
        #define ZER_CH2   0x0000
        #define ZER_CH1   0x0000
        #define CRS_CH2   0x8880
        #define CRS_CH1   0x8080
        #define CRA_CH2   0x8813    //mixed mode
        #define CRA_CH1   0x8013    //mixed mode
        #define CRB_CH2   0x890f
        #define CRB_CH1   0x810f
        #define CRC_CH2   0x8A79
        #define CRC_CH1   0x8279
        #define CRD_CH2   0x8B00
        #define CRD_CH1   0x8300
        #define CRE_CH2   0x8C34
        #define CRE_CH1   0x8434
        #define CRF_CH2   0x8D80
        #define CRF_CH1   0x8580
       segment("data3")short Codec1TxRegs_SEC_PRI[32] =
                            CRS_CH2/*Pri*/,CRS_CH2 /*Sec*/,CRS_CH1/*Pri*/,CRS_CH1 ,/*Sec*/ //reset
                            CRF_CH2/*Pri*/,CRF_CH2 /*Sec*/,CRF_CH1/*Pri*/,CRF_CH1,/*Sec*/ //,CRF_CH1/*Pri*/,CRF_CH1 /*Sec*/,
                            CRE_CH2/*Pri*/,CRE_CH2 /*Sec*/,CRE_CH1/*Pri*/,CRE_CH1,/*Sec*/ //,CRE_CH1/*Pri*/,CRE_CH1 /*Sec*/,
                            CRD_CH2/*Pri*/,CRD_CH2 /*Sec*/,CRD_CH1/*Pri*/,CRD_CH1,/*Sec*/ //,CRD_CH1/*Pri*/,CRD_CH1 /*Sec*/,
                            CRC_CH2/*Pri*/,CRC_CH2 /*Sec*/,CRC_CH1/*Pri*/,CRC_CH1,/*Sec*/ //,CRC_CH1/*Pri*/,CRC_CH1 /*Sec*/,
                            CRB_CH2/*Pri*/,CRB_CH2 /*Sec*/,CRB_CH1/*Pri*/,CRB_CH1,/*Sec*/ //,CRB_CH1/*Pri*/,CRB_CH1 /*Sec*/,
                            CRA_CH2/*Pri*/,CRA_CH2 /*Sec*/,CRA_CH1/*Pri*/,CRA_CH1, /*Sec*/ //,CRA_CH2/*Pri*/,CRA_CH2 /*Sec*/,
                            0,
                            0,
                            0,
                            0
    When I change the control word for the control register F (CRF) from common mode of work to analog loop back , compile and load , the funcionality of my code doesn't change.
    This is just one example of how the funcionality of the codecs doesn't change
    thanks for your support
    Regards ,
    Alon
  • Hi Alon
    Apologies for the delay.
    Your configuration appears simple. It looks like clock and framesync for both transmitter and receiver are fed externally.
    Have you had chance to explore other debugging tips I mentioned earlier? Probing and reading back written-data might throw something.
    Regards
    Prasanth.
    Thank you,
    EZ Admin
