Hello ereryone, i'm a freshman about bf533.now i'm faced a problem which confule me about one weeked. that is: I want use the sport0'Rx and spi'Rx port to receive two group of datas. then employ subtraction on these two group datas after the two group data was normalizated. in order not to lose data, i use pingpong method. the bf533 EZ-KIT Lite has 4 input jarks and 6 output jarks. now my queston is how i can discriminate the input jarks. how i konw the spi input jack and sport0 input jark. i has read the visul dsp++'s example ,the project is C_Talkthrough_TDM. what functon about iChannel0LeftIn iChannel0RightOut in project. hope have explain the problem clearly .who can help me,thank you vevy much.
I assume you have gone through EZ-KIT schematic. The codec (which receives Audio signals from input Jacks) provides the digitized data through SPORT Rx peripheral.
SPI is used to program the codec registers. It is not used to receive the ADC data (nor used to transmit DAC data).
thank you prashant ,because i have to receive two group of datas on EZ-KIT in my project, how i should to do? do sport0'Rx receive two group datas ?then receive A in high level ,receive B in low level. another question,if i only use the sport0'RX ,then how i can discriminate the 4 input jarks. if you have the ralated examples which not privacy,would you send one to me ? thank you again.
Hi wumo,
Sorry for delay in getting back to you.
As mentioned in Datasheet, 'There are four ADC channels in the AD1836A which can be configured as two independent stereo pairs (two stereo ADCs)'. So, you can receive two groups of stereo data. ADC1 outputs it's data on primary Data channel while ADC2 outputs on secondary data channnel. So, enable both data channels of your SPORT.
Regarding example code, I think you might be aware of Example Projects available in VDSP installation directory.
'Audio Codec Talkthrough - I2S' project is actually capable of receiving two audio streams.
One path:
Audio-Out Audio In
White OXO XO
Red OOX OX
other path:
White OOX OX
Red OXO XO
If you have any doubts, please feel free to ask.
Prashant
Hi Wu,
Sorry.. I messed up the things by looking at Readme file of BF561's Audio_Talkthrough project.
Your are correct that paths I have sugegsted will not work on BF533 EZ-KIT.
The Audio Input Output Jacks of BF533 Ez-KITs are as follow:
So, the two stereo paths can be realised on BF533 EZ-KIT are as follow:
1] One path (using ADC1 and DAC1 of codec):
White(Left-channel) OOX XO
Red (right-channel) OOX XO
2] other path (using ADC2 and DAC2 of codec):
White(Left-channel) OXO OX
Red (right-channel) OXO OX
So, your first set-up would also work (using one channel from each ADCx/DACx). But try to use set-up as explained above.
However, I am little confused over your second set-up.
Audio-Out Audio In Audio -out Audio in 3 2 1 1 2 3 2 1 1 2 White OSO OA SSO AO Red SSO BO OOO OB
3 2 1 1 2 3 2 1 1 2
White OSO OA SSO AO
Red SSO BO OOO OB
Could you please explain it in details?
[FYI, you can't use DAC3 of AD1836 codec in your application, because DSDATA3 pin of codec (which is feeding DAC3) is unconnected.
But as shown in EZ-KIT manual, for testing purpose you can route input received on ADC2 to DAC3 by making SW1.5 and SW1.6 switches ON. ]
thanks prashant.
i still is confused,now i state my question in another way: i want input two audio streams, one is A, another is B. then C=A-B, a series signal processing operation on C, finally get S. the output signal also is S. how i should do?
your ideas is:
One path: two path
Audio-Out Audio In Audio-out Audio in
White OXO XO OOX OX
Red OOX OX OXO XO
my ideas is:(i can't sure if i am wrong or right)
White OXO OX OOX XO
Red OOX XO OXO OX
(the output signal S ,can export hrough any jark form the 6 output jarks,is this ideas right?)
could you tell me how i should do . thank you again.
