sport1 tx on bf533
hello,
i have a project using bf533.
sport0 is communicating in duplex with an audio codec (ad1836 but we are migrating to the newer one [ad1839?]), with the codec as clock source, and this is working fine.
now i am trying to get sport1 transmitting with internal clock to a daisychain of auxiliary DACs / shift registers, but without success. i'm sure i'm misunderstanding something fundamental about how this is supposed to work, but haven't been able to find a relevant example project.
i'm using both a BF533 EZ-KIT lite and our own board, and a recent release of the GCC toolchain. (sorry, i know it's not officially supported at AD...)
i'm trying to transmit a simple 32-bit data for testing, but eventually will need slightly more complex data format. the test is producing a generic DMA error interrupt.
i've attached the relevant initialization/runtime code fragments. perhaps someone can easily spot the error, as it is likely quite naive...
many thanks for your time and attention!
- ezra b
bf533_sport1_tx_question.c.zip
  • Hi Ezra,
    I think, in order to interface Blackfin SPORT's to codec's in daisy chain fashion, you need to use multichannel (TDM) mode of SPORT. There is one example code available in VDSP installation directory which shows how Blackfin SPORT communicates with AD1836 in TDM mode. I am attaching that project. Hope it helps.
    attachment.zip
