Low Volume Level at output of BF537
I have compiled and executed the C_Talkthrough_I2S.dpj example in the ADSP-BF537 EZ-Kit Lite folder included with the BF537 evaluation board and I don't get the same level as I'm putting in.
Using a D-scope I am measuring a 1.4dB loss at the output.
Can anyone explain why this is happening?
attachment.zip
Parents
  • I'm using the analogue output on the dScope to generate a 0dBu sinewave. This is being fed into one channel of the BF537 via the AD1854. I'm then using the simple C_Talkthrough_I2S.dpj to pass the encoded signal straight back into the DAC(AD1854) without, as far as I can tell, any modification to the input. I'm then using the dScope to look at the output of the DAC. This is where I measure -1.4dBu at the output. 0.1% THD+N at the output under these conditions.
    If I generate a 0dBFS sinewave I measure -4.2dBFS at the output. I'm measuring 18.1% THD+N at the output under these conditions.
    I am not able to access the digital data between the ADC and DAC. I have attached a guide to the BF537 with schematics. Page 78 shows the ADC while page 79 shows DAC serial interface pins shorted to ground.
    Thanks for your assistance with this.
Reply
Children
No Data
