'AudioLoopBack' and 'RotaryCounter' examples that are not working fine together
Hi All,
I'm actually work with ADSP-BF527 EZ-KIT Lite board and CCES IDE.
So, after practice on 'AudioLoopBack' example, I want to insert a volume control that use the Encoder (I looked to 'RotaryCounter' example).
The volume control work fine but, when I push the encoder for rewrite the 32-bit counter at the default volume level the API fail to perform this!
The program running on a while loop in the fuction main() on 'loopback' program:
1- Receive interrupt from encoder (push) ad handle it by simple set true a control variable.
2- Inside the main() on loopback program at the end the loop I have insert a control as follow:
if (bShaft == true) {
     PresetShaftEncoder(ADC_VOL_LEVEL);          //     Preset Rotary Counter and Volume to default 50% value!
     VolumeLevelADC_0_100 = ADC_VOL_LEVEL;
      bShaft = false;
void PresetShaftEncoder(unsigned char PreVal) {
ADI_COUNTER_RESULT  eResult;
if((eResult = adi_counter_SetControlReg(hDevice, ADI_CNT_COUNTER_REG, PreVal)) !=ADI_COUNTER_SUCCESS )
     printf("Failed to write '%d' during Preset-Pushbutton: 0x%04X \n", PreVal, eResult);
On a Console -> 'Failed to write '50' during Preset-Pushbutton: 0x0002'
After this message the program is still running further but without sound in output and volume control.
Is there anyone that suggest me about this?
Mauro
