BF514 bfrom_SpiBoot fails to boot Firmware from SPI Flash
I have a strange problem the Boot mechanism of the BF514 DSP.
I use a custom bootloader to update my firmware. The bootloader loads the firmware
into the external SDRam checks the CRC and then writes the Firmware into the Flash (Spansion S25FL116K).
After that I read the firmware that it was just written and compare it, to make sure that writing in flash was correct.
If it is correct that I boot the application from Flash by calling bfrom_SpiBoot. The problem is that this worked until now.
I have to make some changes i the Firmware and when I do this changes and flash the firmware into the BF, the device
is not booting anymore and it stuck in the bfrom_SpiBoot function. If I revert this changes it works again .
I already debugged throw the bfrom_SpiBoot function and I saw that the at a moment, the DMA is configured to receive data from SPI and
after that the SPI controller set the bit RBSY. After that nothing work anymore.
#define SPI0_BAUDRATE                 5000
Spi0_Init(SPI0_BAUDRATE);
bfrom_SpiBoot( 0x1A000,
      BFLAG_PERIPHERAL | BFLAG_TYPE | BFLAG_NOAUTO | BFLAG_FASTREAD | 0x04,
      0,
      NULL);
void Spi0_Init(unsigned long const baudrate)
  // SCK frequency = (peripheral clock frequency SCLK)/(2 × SPI_BAUD)
  unsigned short baudDiv = (SCLK_MHZ*500000)/baudrate;  // 40 ... f_spi = 1MHz bei SCLK = 80MHz
  *pSPI0_CTL    = 0x00;
  // Enable peripheral function
  *pPORTG_FER   |= (SPI0_SCK|SPI0_MISO|SPI0_MOSI);//|SPI0_SSEL2);
  *pSPI0_BAUD = baudDiv;
  *pPORTFIO_DIR |= SPI0_SSEL1;
  *pPORTGIO_DIR |= SPI0_SSEL2;
  *pPORTHIO_DIR |= SPI0_SSEL3;
  Spi0_DisableSlave();
  *pSPI0_STAT |= TXE | RBSY; // clear spi error flags
  *pSPI0_CTL = 0;
  *pSPI0_STAT &= ~MODF; // reset mode fault flag
  // enable spi in master mode and set transfer initiation to rdbr read
  *pSPI0_CTL = (SPE | MSTR | 0x01);
  ssync();
