ADSP-BF538F SPI0 INTEFACING
Hello guys,
I am working on configuring a slave device with ADSP-BF538F and I am able to generate SPI clock and Slave select. The isssue is that I find no signal getting generated on the MOSI pin. I checked the return value of submitbuffer function which is not zero, so I feel probably submitbuffer is the culprit.
Here is the code any valuable suggestions would be of great help.
Wishing you a beautiful day ahead
Thank you.
K.Ketan
int SPI0(void)
    /* flag indicating that a SPI transceiver is available */
    static bool bAvailable = false;
    /* pointer to store transceiver */
    ADI_SPI_TRANSCEIVER *pTrans;
    /* SPI driver handle */
    ADI_SPI_HANDLE hSPI0Device;
    /* SPI driver memory */
    uint8_t driverMemory[ADI_SPI_INT_MEMORY_SIZE];
    /* driver API result code */
  ADI_SPI_RESULT result;
  /* transceiver buffers */
  uint8_t Prologue[4]  = {0x00, 0x01, 0x02, 0x03};
  uint8_t TxBuffer[8]  = {0x00, 0x01, 0x02, 0x03, 0x00, 0x01, 0x02, 0x03};
  uint8_t RxBuffer[8];
  /* transceiver configurations */
  ADI_SPI_TRANSCEIVER Transceiver1  = {&Prologue[0], 4, &TxBuffer[0],8, NULL, 0};
  ADI_SPI_TRANSCEIVER Transceiver2  = {NULL,         4, &TxBuffer[0],8, NULL, 0};
    /* open the SPI driver */
    result = adi_spi_Open(0, driverMemory,ADI_SPI_DMA_MEMORY_SIZE, &hSPI0Device);
    /* Set master */
    result = adi_spi_SetMaster( hSPI0Device,true);
    /* Set slave select using hardware*/
    result = adi_spi_SetHwSlaveSelect( hSPI0Device, true);
    /* Selecting slave1 as the device*/
    result = adi_spi_SetSlaveSelect( hSPI0Device,ADI_SPI_SSEL_ENABLE1);
    /* Setting the word size of 8 bytes*/
    result = adi_spi_SetWordSize( hSPI0Device, ADI_SPI_TRANSFER_8BIT);
    /* Setting the clock frequency of spi   The frequency of the SPI clock is calculated by SCLK / 2* (Baud=3)*/
    result = adi_spi_SetClock( hSPI0Device, 20);
    /* No call backs required*/
  result = adi_spi_RegisterCallback(hSPI0Device, NULL, NULL);
    /* Disable DMA */
  result = adi_spi_EnableDmaMode(hSPI0Device, false);
    /* submit the SPI transceiver's buffers */
  result = adi_spi_SubmitBuffer(hSPI0Device, &Transceiver1);
  //result = adi_spi_SubmitBuffer(hSPI0Device, &Transceiver2);
  //result = adi_spi_ReadWrite(hSPI1Device, &Transceiver1);
  /* wait here until a transceiver is available */
  while(bAvailable == false)
  result = adi_spi_IsBufferAvailable(hSPI0Device, &bAvailable);
  /* fetch the transceiver buffer just processed */
  result = adi_spi_GetBuffer(hSPI0Device, &pTrans);
  /* close the SPI driver */
  result = adi_spi_Close(hSPI0Device);
    return 0;
