Custom non-interruptible System Event Controller (SEC) interrupt dispatcher
the __sec_int_dispatcher is installed as the handler for IVG11 and also referred to as SEC interrupt dispatcher.
I am currently facing issues when an interrupt is interrupted by another interrupt (i.e. nested interrupts).
I'd like to disable interrupts during the handling of the SEC.
Is this
  • possible,
  • a good idea?
What would be the way to do it? I was thinking about writing a custom SEC interrupt dispatcher as a "wrapper".
  • It disables interrupts and stores the IMASK value in a register and disable interrupts (CLI).
  • The register is previously stored on the stack.
  • Call the original SEC interrupt dispatcher.
  • Restore IMASK via the register and re-enable interrupts (STI).
  • Restore the register.
The handler would look like this:
__sec_int_dispatcher_custom:
[--SP]=R2;
CLI R2;
[--SP]=P1;
P1 = [__sec_int_dispatcher];
CALL (P1);
P1=[SP++];
STI R2;
R2=[SP++];
I'd either have to replace the symbol in app_startup.s or call register_handler() to hook the new handler to IVG11.
Two issues here:
  • Let's say there's an interrupt directly after the "STI R2" instruction which leads to context-switching code.
    R2 may never be restored. Is there a way around it?
  • I couldn't manage to use the symbol __sec_int_dispatcher_custom and am getting linker errors. Can this be fixed?
The CEC internally uses/calls EX_DISPATCHED_HANDLER_NESTED(_adi_osal_stdWrapper, iid, index, arg). If I get it right it may be too late to disable and re-enable interrupts here, as the code before the call could be interrupted, right?
Matthias
