TFT LCD
I am trying to configure a TFT LCD "EA TFT028-23AI" on evaluation board "ADSP-BF706_EZ_KIT_Mini". The LCD is included with a ST7789v controller and it has to be initialise in SPI mode with special commands before I can use RGB mode.
Anyone can explain to me the way I have to use to initialise the controller?
I suppose I have to install the driver for the controller and include the libraries in my project, how?
An example of the similar issue can be very helpful.
Thank you.
  • Anyone can please comment on following points:
    - To initializing the ST7789 controller SPI, I need CS clock and MOSI. But I am not sure to use SPI1 or SPI2.
    - It is maybe easier to use SPI1 regarding connection to the LCD, because there is a P5 interface for SPI1 on the BF706 kit board and I can just connect SCL and SDA from LCD to SCL and SDA on the board.
    - If I want to use 4-Wire SPI interface, what does it mean?
    I suppose the connection between LCD and BF706 kit board is:
    SPI1_CLK  --> SCL
    SPI1_MISO  ---> SDA
    SPI1_MOSI  ---> SDO
    SPI1_SS  ---> CS
    Is it correct?
    And I need an additional line to switch between data and command.
    Thank you.
    on Sep 25, 2020 12:52 PM 2 months ago in reply to SVA
    This issue is already handled through private support. To avoid duplication of efforts, you can continue the discussions through private support.
    Anand Selvaraj.
