BF548M SPI1 and SPI2 with DMA for rx and tx
In my project  I want communication between BF548M processors using both SPI1(slave) and SPI2(Master) with DMA tx and rx both sides.
I have tested SPI1 and SPI2 individually both are working fine . But if I enable then together one of the SPI will not work.
I am attaching the code for SPI interface which i am using for testing .
Guys plz help me with the issue ?
// SPI_driver.c
#include <stdio.h>
#include <blackfin.h>
#include <sys/exception.h>
uint8_t receive_data[SPI_RX_BUFFER_SIZE];
extern uint8_t SPI_rx_data_port1[SPI_RX_BUFFER_SIZE] , SPI_rx_data_port2[SPI_RX_BUFFER_SIZE];
volatile int SPI_tx1_cnt , SPI_tx2_cnt ,SPI_rx1_cnt, SPI_rx2_cnt;
extern volatile  unsigned int SPI_tx_flag1,SPI_tx_flag2,SPI_rx_flag1 , SPI_rx_flag2 ;
* SPI0
SPI0SCK 	PE0
SPI0MOSI   PE2
SPI0MISO   PE1
SPI0SS     PE3
SPI0SEL1 	PE4     //For Master
SPI0SEL2 	PE5		// M
SPI0SEL3 	PE6		// M
* SPI1
SPI1SCK 	PG8
SPI1MOSI   PG10
SPI1MISO   PG9
SPI1SS     PG11
SPI1SEL1 	PG5
SPI1SEL2 	PG6
SPI1SEL3 	PG7
* SPI2
SPI2SCK 	PB12
SPI2MOSI   PB13
SPI2MISO   PB14
SPI2SS     PB8
SPI2SEL1 	PB9
SPI2SEL2 	PB10
SPI2SEL3 	PB11
void SPI_pin_multiplex(uint8_t port , uint8_t mode)
	switch(port)
	case 0:  // SPI0
		if(mode == 0)    // Slave
			*pPORTE_FER |= 0x000f;
			*pPORTE_MUX &= 0xffff0000;
		else if(mode == 1)  //Master
			*pPORTE_FER |= 0x001f;
			*pPORTE_MUX &= 0xfffc0000;
	break ;
	case 1:   // SPI1
			*pPORTG_FER |= 0x0f00;
			*pPORTG_MUX &= 0xff00ffff;
		else if(mode == 1) // Master
			*pPORTG_FER |= 0x0f20;
			*pPORTG_MUX &= 0xff00f3ff;
	break ;
	case 2:  // SPI2
		*pPORTB_FER |= 0x7100;
		*pPORTB_MUX &= 0xc0fcffff;
		else if(mode ==1)   // Master
			*pPORTB_FER |= 0x7300;
			*pPORTB_MUX &= 0xc0f0ffff;
	break ;
	default:
				printf("Invalid port number\n");
						break ;
void SPI_Config(uint8_t port ,uint8_t mode , uint32_t spi_baud_rate , SPI_transfer_mode trans_m)
	switch(port)
		case 1:        //SPI1
			*pSPI1_FLG = 0xFF02;    // Slave select enable 1
			*pSPI1_BAUD = spi_baud_rate;	 // SPI SCK frequency = SCLK / (2 X SPIx_BAUD)
			*pSPI1_CTL = 0;
			if(mode == 1)
				*pSPI1_CTL = MSTR|EMISO|GM|SZ|trans_m;
			else if(mode ==0)
				*pSPI1_CTL = EMISO|PSSE|SZ|GM|trans_m;
		break ;
    	case 2:			// SPI2
    		*pSPI2_FLG = 0xFF02;    // Slave select enable 1
			*pSPI2_BAUD = spi_baud_rate;		 // SPI SCK frequency = SCLK / (2 X SPIx_BAUD)
			*pSPI2_CTL = 0;
			if(mode == 1)
				*pSPI2_CTL = MSTR|EMISO|GM|SZ|trans_m;
			else if(mode == 0)
				*pSPI2_CTL = EMISO|PSSE|SZ|GM|trans_m;
		break ;
    	default:
    						break ;
EX_INTERRUPT_HANDLER(IsrSPI_withDMA_TX)
	if(*pDMA5_IRQ_STATUS & DMA_DONE)       //port1 tx
			SPI_tx1_cnt++;
			while(*pDMA5_IRQ_STATUS & 0x0008);  		//poll on DMA_RUN bit
			*pDMA5_IRQ_STATUS |= 0x0001;
			while(*pSPI1_STAT & 0x0008);					//Check for Tx Buffer Empty
			while(!(*pSPI1_STAT & 0x0001));				//Check for SPIF
			SPI_tx_flag1 = 1;
			//*pSPI1_CTL &= ~SPE;							//Disable SPI
	if(*pDMA23_IRQ_STATUS & DMA_DONE)     // port2 tx
			SPI_tx2_cnt++;
			while(*pDMA23_IRQ_STATUS & 0x0008);  		//poll on DMA_RUN bit
			    *pDMA23_IRQ_STATUS |= 0x0001;
			    while(*pSPI2_STAT & 0x0008);					//Check for Tx Buffer Empty
			 	while(!(*pSPI2_STAT & 0x0001));				//Check for SPIF
			 //	*pSPI2_CTL &= ~SPE;							//Disable SPI
			 	SPI_tx_flag2 = 1;
EX_INTERRUPT_HANDLER(IsrSPI_withDMA)
	if(*pDMA5_IRQ_STATUS & DMA_DONE)       //port1 rx
		SPI_rx1_cnt++;
		*pDMA5_IRQ_STATUS |= DMA_DONE;
		*pSPI1_CTL &= ~SPE;
		SPI_rx_flag1 = 1;
	if(*pDMA23_IRQ_STATUS & DMA_DONE)     // port2 rx
		SPI_rx2_cnt++;
		*pDMA23_IRQ_STATUS |= DMA_DONE;
		//*pSPI2_CTL &= ~SPE;
		SPI_rx_flag2 = 1;
void SPI_DMA_Config(uint8_t port , uint8_t *buff  , SPI_dir dir)
	if(port == 1)
	{		*pDMA5_CONFIG = 0x0;
			*pDMA5_START_ADDR= &buff[0];
			*pDMA5_X_COUNT = SPI_RX_BUFFER_SIZE;
			*pDMA5_X_MODIFY = SPIWdSize/8;
			*pDMA5_Y_COUNT = 0;
			*pDMA5_Y_MODIFY = 0;
			if(dir == SPI_RX)
				*pDMA5_CONFIG =  (0x0<<12)|(0x0<<8)|DI_EN|WNR;
			else if(dir == SPI_TX)
				*pDMA5_CONFIG =  (0x0<<12)|(0x0<<8)|DI_EN;
	else if(port ==2)
		*pDMA23_CONFIG = 0x0;
		*pDMA23_START_ADDR= &buff[0];
		*pDMA23_X_COUNT = SPI_RX_BUFFER_SIZE;
		*pDMA23_X_MODIFY = SPIWdSize/8;
		*pDMA23_Y_COUNT = 0;
		*pDMA23_Y_MODIFY = 0;
		if(dir == SPI_RX)
			{*pDMA23_CONFIG =  (0x0<<12)|(0x0<<8)|DI_EN|WNR;
			*pDMA23_CONFIG =  (0x0<<12)|(0x0<<8)|DI_EN;
void SPI_Init_Interrupt(uint8_t SPI_num , SPI_DMAType mode)
	if(SPI_num == 1 && (mode == SPI_WithoutDMA))
		SIC_EnableIntr(SIC_IRQ_SPI1_DMA5);
		register_handler(ik_ivg10,IsrSPI);
	else if(SPI_num == 2 && (mode == SPI_WithoutDMA))
		SIC_EnableIntr(SIC_IRQ_SPI2_DMA23);
	else if(SPI_num == 1  && (mode == SPI_WithRXDMA))
		register_handler(ik_ivg10,IsrSPI_withDMA);
		*pDMA5_CONFIG|=DMAEN ;   // enable DMA channel
	else if(SPI_num == 2 && (mode == SPI_WithRXDMA))
		*pDMA23_CONFIG|=DMAEN ;  // enable DMA channel
	else if(SPI_num == 2  && (mode == SPI_WithTXDMA))
					register_handler(ik_ivg10,IsrSPI_withDMA_TX);
	else if(SPI_num == 1  && (mode == SPI_WithTXDMA))
