Hi everyone, thanks Craig for help.
I try to use UART0 interrupts. I initialize EVT8 as isr_uart0_rx, EVT10 as isr_uart0_tx. I use Terminal program to send and receive bytes from PC to my target board. I send one byte to target board, isr_uart0_rx works correctly, everything is ok, but when I try to send this byte to PC I have a problem. In my dispatcher I send this byte to uart0_thr register, then interrupt isr_uart0_tx generates in this interrupt I read uart_iir register and after rti command my program return to wrong place (my program return to command send byte in dispatcher and I send this byte once more). I control send and receive bytes with oscilloscope.
Does anybody know what's wrong?.
Thanks for help.
Couple of ideas:
- Insert break point at RTI instruction.
- Look at RETI contents.
- Look at Stack Pointer & check for any corruption.
- Check for proper push and pop of RETI contents inside RE-ENTRANT ISRs.
- Prasanth.
