Discrepancy in TWI section of Hardware Reference
I've been going through the ADSP-BF51x Blackfin Processor Hardware Reference and I found what I think is a discrepancy.
1) On page 16-12, it instructs the user to write data to the TWI_XMT_DATA register before enabling the TWI.
2) In Figure 23-13, it instructs the user to first enable the TWI, and then wait for the XMTSERV interrupt before writing data to the TWI_XMT_DATA.
It seems to me that 1) is correct. Can anyone with experience with the TWI module shed some light on this?
Steve.
  • Steve,
    Without looking at the HRM, I think both of these might be valid, depending on context.  In the case where you are first enabling a TWI transfer, 1) is correct, but if you are in the middle of a multiple byte transfer then 2) is correct.  Here is a simple TWI routine that transfers two bytes of data that demonstrates this (note that this routine was written for 52x processor):
    void TWI_WRITE_2 (unsigned char addr, unsigned char MMR, unsigned char data)
    int poll_timeout = 0;
    *pTWI_MASTER_ADDR = addr;//set slave address
    *pTWI_XMT_DATA8 = MMR;  //set MMR of the target chip
    *pTWI_MASTER_CTL = 0x0081; //specify num bytes (2), start xfer by writing 1 to en bit
    while (*pTWI_FIFO_STAT == XMTSTAT)//from twi.c
       asm("nop;");
       poll_timeout++;
       if (poll_timeout > MAX_POLL)
       { break;                }    //add error code here
    *pTWI_INT_STAT = XMTSERV; // clear status
    *pTWI_XMT_DATA8 = data;
    //now, start polling to see if xfer complete
    while (!(*pTWI_INT_STAT & MCOMP))
      {  asm("nop;");  }
    *pTWI_INT_STAT = ( XMTSERV | MCOMP ); // service TWI for next transmission
    Hope this helps,
    Ethan
