The PINT section on BF706 HW manual is not clear and just a single block diagram would have cleared many confusions.
Is this roughly how input pin is routed to PINT and beyond?
Typo
[edited by: dandikain at 10:20 PM (GMT -5) on 18 Nov 2021]
Sorry if the explanation is unclear. You can refer ADSP-SC58x hardware reference manual(Pg. No.: 579/3973) for detailed explanation. The underlying concepts for ADSP-BF70x and ADSP-SC58x are similar. The ADSP-SC58x HRM can be downloaded from the below link.
www.analog.com/.../SC58x-2158x-hrm.pdf
Anand Selvaraj.
Thanks, but still lacks where different blocks are located. Can you confirm the block diagram I posted represents the order of Polarity and Inverter blocks?
Apologies for the delayed response.
The block diagram you have shared shows the basic outline of the PINT and is partially correct. For all PINT functionalities, I would suggest to refer the HRM. BTW, are you facing any issues when using the PINT? If so, can you please elaborate on the same.
Anand Selvaraj.
