L1 data SRAM after software reset through watchdog in BF70x
I have implemented a second stage bootloader and want to use a shared variable in L1 RAM. This variable will be shared with the main application.
Therefore I created a section in both ldf-files with NO_INIT
      L1_data_b_shared_variable NO_INIT
         INPUT_SECTIONS( $COMMAND_LINE_OBJECTS(SHARED_UPDATEVAR))
      }>MEM_L1_DATA_B_SHARED_VARIABLE
 and I define the variable
#pragma section ("SHARED_UPDATEVAR", NO_INIT)
  volatile unsigned char Update_Req;
My software in the main application write to the variable Update_Req and performs an software reset through watchdog like in https://ez.analog.com/dsp/blackfin-processors/bf70x/f/q-a/12908/how-to-enable-h-w-reset-when-watch-dog-timer-expired.
Always when my second stage bootloader starts after the watchdog reset and want to read the variable Update_Req in L1 RAM the variable is zero.
So my question is what is the status of L1 SRAM after a watchdog reset?  Does it retain the data it held before the reset or is it indeterminate?
I implemented the same in the BF534 an it works but not with my BF707.
Michael
  • Hi Michael,
    Apologies for delayed response. From your mail, I could understand that you are looking for preserving L1 SRAM after watchdog reset. Please correct if my understanding is wrong.
    I've taken a look at your shared snippet and it seems fine. I also understand that you are performing Second stage loaders. Can you let me know how you are confirming that L1 data is not preserved?
    If possible can you share a minimal project that replicates the issue on ADSP-BF707 Ezkit?
    Anand Selvaraj.
  • Hi Anand,
    yes your understanding is correct. After a watchdog reset my second stage bootloader starts and want to read out data from L1 SRAM.
    For debugging I send the variable in L1 SRAM via a CAN Message. The variable has always the value zero.
    My projekt runs not on the ADSP-BF707 Ezkit but if you think it would be helpful I can share a minimal project. These are two projects , one for the application and on for the second stage bootloader.
    If it's possible i wouldn't like to share the project in the forum, so could you give me a contact or email. Please let me know.
    Regards, Michael
  • Hi Michael,
    Can you please send a mail to processor.support@analog.com? Please refer this thread link while you send the project. A minimal project replicating the issue on ADSP-BF707 EZkit is enough.
    Anand Selvaraj.
