the call of printf cause my program crushed
when my program run into printf ,  the code will be crushed, if i delete the printf call,  my code runs
safely, that why ?
    The call stack suggests that the exception may have come from a failed malloc (stdio mallocs buffers from the heap, with which it performs the IO).
    You can debug your Heap usage as documented under 'Help: Contents: CrossCore Embedded Studio 1.0.1: C/C++ Compiler and Library Manual for Blackfin Processors: 2 Achieving Optimal Performance From C/C++ Source Code: Analyzing Your Application'.
    Let us know if that turns anything up.
    Craig.
    on Aug 2, 2018 4:52 PM
    Thank you,
    EZ Admin
