Parity error in L1 instruction bank C cache
Here I met a error in my project when the code runs into the first function adi_initComponents(), this function is generated automatically I didn't change anything. The project compiles and builds successfully.
The Help in CCES doesn't give me much information about how this error is caused, and how to solve this problem. Could you please help on this?
  A fatal error or exception has occurred.
  Description:   Parity error in L1 instruction bank C cache
  General Type:  ParityError
  Specific Type: InstrBankCCache
  General Code:  0xa
  Specific Code: 0x142
  Error Value:   0x00000020
  Error PC:      0xc80935b8
Daniel
    I assume you are using silicon revision 0.1 of the BF60x. The CCES 1.0.2 Release Note covers this behaviour in detail:
    The CCES 1.0.2 toolchain provides support for silicon revision 0.1 of the ADSP-BF60x part family. This support includes a change to the startup code, which was necessary to avoid “Parity Error” exceptions seen when running on revision 0.1 hardware. This change is incorporated automatically when the generated startup code is regenerated and is already present in the various pre-built default basiccrt crt.doj files. If you are using a custom startup source or have disabled regeneration of the generated files you will need to add the following BITSET instruction before accessing the ITEST_COMMAND or DTEST_COMMAND registers:
    #include <sys/platform.h>
    BITSET(R7, BITP_ITEST_COMMAND_PARCTL);
    For example:
    // Zero the ITEST_COMMAND and DTEST_COMMAND registers
    // (in case they have unintialized values in them that
    // cause a write somewhere when we enable cache).
    I0.L = LO(ITEST_COMMAND);
    I0.H = HI(ITEST_COMMAND);
    I1.L = LO(DTEST_COMMAND);
    I1.H = HI(DTEST_COMMAND);
    [I0] = R7;
    [I1] = R7;
    CSYNC;
    Note that any executable built with CCES 1.0.0.x or 1.0.1.x will need to be re-linked with an updated crt object before being used with 0.1 hardware.
    If you have not already applied the 1.0.2 update, please do so:
    http://www.analog.com/cces
    Craig.
  • Hi Craig,
    Thanks for your timely reply, I'm using silicon version 0.0, CCES 1.0.1.
    The issue was caused and resolved in an accidental way. Actually the project is based on BF609EZKIT+Video decoder EI3 extender board+Video encoder EI3 extender board, the run-time error pumps when I run the project only on BF609EZKIT( disconnected with extenders), after I mounted two extenders, rebuild the project and run again, everything is fine.
    Daniel
  • Thanks for clarifying Daniel. Glad you were able to resolve the issue.
    Craig.
    on Aug 2, 2018 4:53 PM over 2 years ago
    Thank you,
    EZ Admin
