bf609 eppi2 transmit data
hello, i want to transmit data through eppi2 with internal clock and sync, but my code could't get correct result.
my code is like this:
void EPPI2_CH0_HANDLER(uint32_t iid, void *handlerArg)
          *pREG_DMA31_STAT = ENUM_DMA_STAT_IRQDONE;
void initPPI2(void)
          *pREG_EPPI2_CTL = ENUM_EPPI_CTL_PACK_EN |     //pack enable
                                                    ENUM_EPPI_CTL_SWAP_EN |     //fist data on MSB data
                                                    ENUM_EPPI_CTL_DLEN08 |      //8bit transmit
                                                    ENUM_EPPI_CTL_FS1HI_FS2HI | //data valid on high level
                                                    ENUM_EPPI_CTL_POLC11 |      //sample data and sync signal on rising edge
                                                    ENUM_EPPI_CTL_SYNC2 | // 2 FS mode
                                                    ENUM_EPPI_CTL_INTFS | // internal frame sync
                                                    ENUM_EPPI_CTL_INTCLK | // internal clock
                                                    ENUM_EPPI_CTL_NON656 | // GP mode
                                                    ENUM_EPPI_CTL_TXMODE; // transmit mode (write memory)
          *pREG_EPPI2_CLKDIV = 0x3;
          *pREG_EPPI2_LINE = COL;
          *pREG_EPPI2_FRAME = ROW;
void initPPI2DMA(void)
          *pREG_DMA31_ADDRSTART = (void*)g_txBuffer;
          *pREG_DMA31_XCNT = COL / 32;
          *pREG_DMA31_XMOD = 32;
          *pREG_DMA31_YCNT = ROW;
          *pREG_DMA31_YMOD = 32;
          *pREG_DMA31_CFG = ENUM_DMA_CFG_MSIZE32 | ENUM_DMA_CFG_PSIZE04
                              | ENUM_DMA_CFG_ADDR2D | ENUM_DMA_CFG_YCNT_INT | ENUM_DMA_CFG_SYNC
                              | ENUM_DMA_CFG_READ | ENUM_DMA_CFG_AUTO;
          adi_int_InstallHandler(INTR_EPPI2_CH0_DMA, EPPI2_CH0_HANDLER, 0, true);
void enableEPPI2(void)
          *pREG_DMA31_CFG |= ENUM_DMA_CFG_EN;
          ssync();
          *pREG_EPPI2_CTL |= ENUM_EPPI_CTL_EN;
          ssync();
void disableEPPI2(void)
          *pREG_DMA31_CFG &= ~ENUM_DMA_CFG_EN;
          ssync();
          *pREG_EPPI2_CTL &= ~ENUM_EPPI_CTL_EN;
          ssync();
int main(void)
          adi_initComponents();
          adi_pwr_Init(25 * MHZTOHZ, 500 * MHZTOHZ, 125 * MHZTOHZ, 72 * MHZTOHZ);
          initPPI2();
          initPPI2DMA();
          enableEPPI2();
          while(1);
          return 0;
when i call enableEPPI2 function after init ppi and dma, the dma didn't send data to peripheral device.
