LwIP fileserver project error
I'm working with  EzKit Lite for BF609 processor (rev 0.0 and 0.1 )
After running the example fileserver, the console shows:
Configuring switches for the ethernet operation
lwip_system_init: failed to enable EMAC
lwip_sysboot_task: Failed to initialize system
I tried to debug, but the error is within a function "adi_ether_EnableMAC" .
Any idea to to solve the problem?
Thanks
Parents
    on Dec 19, 2013 3:25 PM
    Thanks for sending the example. This works fine on my target here. A side note; under the pin multiplexing you should have checked every box between A03 and A23 under SMC0, that is A03, A04, A05...A22, A23. It's unlikely to make a difference (as the code works here) but could I ask you to correct that and try again.
    Are you running the exact same DXE on your Finboard, with the same ethernet cable, etc?
    As I mentioned earlier this typically occurs when DHCP is not available, but can also occur when DHCP cannot be established. The latter can occur when there is no MAC address. While I would expect the dummy mac address approach above to fix this, there is something you can try to ensure there is a correct MAC address in flash.
    In the attached zip is a batch file I would like you to use. First, open it in a text editor, and you will see it is just a series of calls to the Command Line Device Programmer in CCES. Ensure that the CCES path is in your PATH environment variable, and edit the "-emu hpusb" switch to match your configuration (e.g. "-emu kit" if you are using an EZ-KIT Lite via SADA board, or "-emu usb" if you are using a USB-ICE).
    Then, call the batch file as per the command line below, passing the last 4 characters of the MAC address printed on the underside of your board, instead of 0x1234.
    c:\<path>\Mac_Update.bat  0x1234
    This will program the complete MAC as 00:E0:22:FE:12:34. So, replace those last 4 digits and you will reprogram your MAC address.
    You then, of course, need to add the "if..." back into the "get_mac_address" function. Try running the code again - check that it reports the correct mac address for your target.
    I notice also that you example contains a large number of additional Add-Ins - have you tried using just the basic File Server application, as provided in the Board Support Package? Does it behave the same way?
    Craig.
    MACUPDATE.zip
Reply
    Craig.
    MACUPDATE.zip
Children
No Data
