Error_Failed to connect to processor: Launch sequence 0x8004804a
Hi !
Error: 0x8004804a
Error Description: Detected number of device does not match settings
also in new Crosscore 2.0 !!
We connect for the very first time our custom board based on a BF607 processor
So i don't exactly know if it works correct.
i've checked the ICE Test and therefore there is no error ! -> 1JTAG device detected
on target configurator i've created a new platform for the used ICE-2000 Emulator
and under devices if create Device 0 ,type=BF607)
but if i want to start the Debugging session i get an error on launching the Project.
The first 4 Errors are Java.lang.NullPointerException errors
the last error is :
org.eclipse.core.runtime.CoreException: [TpsdkServer] Failed to connect to processor.
Error: 0x8004804a
at org.eclipse.cdt.dsf.concurrent.Query.get(Query.java:114)
at com.analog.crosscore.debug.launch.LaunchDelegate.createSession(LaunchDelegate.java:633)
at com.analog.crosscore.debug.launch.LaunchDelegate.launch(LaunchDelegate.java:283)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:854)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:703)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:937)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1141)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
How can i determine if my JTAG Connection and DSP is working properly ???
I'm new in CrossCore , i've worked over years with the VDSP so i dont exactly know how to Setup
a custom board correctly. ???
regards
