A doubt about pin multiplexing
The user encountered a pin multiplexing conflict between the RSI function and EMAC1 function on the BF607. The final answer confirms that both functions cannot be used simultaneously on the same GPIO pins, and suggests selecting non-conflicting RSI pins based on the chosen EMAC mode.
Product Number: ADSP-BF607
Hello
I found a pin multiplexing conflict between RSI function and EMAC1 function in BF60x manual:
it means that we cannot use these two functions in one time in BF607, is it?
    Yes, your understanding is correct. Since the port pins for EMAC and RSI are multiplexed on the same GPIO pins, it is not possible to use both peripherals (EMAC and RSI) on the same GPIO pin simultaneously.
    You need to determine which mode you will be using for EMAC and then select the appropriate RSI pins that do not conflict.
    Nandini C
