PADS_PCFG1 register in ADSP-SC59x processor has ‘select secondary inputs to timer’ bit field. What is the use of this bit-field?
  • For the ADSP-SC59x set of processors, the GP Timer pins, TIMER0_CLK, TIMER0_ACI0, TIMER0_ACI1, TIMER0_ACI2, TIMER0_ACI3, TIMER0_ACI4, TIMER0_ACLK1, TIMER0_ACLK2, TIMER0_ACLK3 and TIMER0_ACLK4 are available as input tap at two places in the pinmux (from datasheet). The input to these signals can be selected from either of the two locations. The ‘select secondary inputs to timer’ bit field in the PADS_PCFG1 register enables us to select the input tap to these signals.
    The table below shows the PADS_PCFG1 register bit and Timer signal mapping and the input tap selected when the bit is '0' and bit is '1' on each of the Timer pins.
    Bit position in PADS_PCFG1 register Timer signal Input tap selected when the bit is ‘0’ Input tap selected when the bit is ‘1’
    16 TIMER0_CLK PB_01 PF_05
    17 TIMER0_ACI0 PA_07 PD_08
    18 TIMER0_ACI1 PA_14 PD_04
    19 TIMER0_ACI2 PB_11 PD_10
    20 TIMER0_ACI3 PB_00 PG_04
    21 TIMER0_ACI4 PA_11 PF_15
    22 TIMER0_ACLK1 PA_06 PG_09
    23 TIMER0_ACLK2 PA_08 PI_05
    24 TIMER0_ACLK3 PA_02 PG_10
    25 TIMER0_ACLK4 PB_02 PE_03
