ADC sampling rate
Product Number: ADSP-CM403F
Hi everyone.
I'm running the ADC Circular example to get familiar with the ADC and i had read the Hardware reference and the EE365 but i can't figure out how to change the sample rate.
I'm using a 1 kHz tone as test signal and System View from Elanix to get the sampled signal and recontruct it.
1.- If i change the SYSCLK from 96 MHz to, say, 90 MHz, the samples seem to be at correct timing, but if i use 100 MHz, the sampled frequency is totally off.
2.- How can i calculate the sample rate (or even better, change it) for that example?
Btw, it seems the sampling frequency is SYSCLK/NUMSAMPLES = 96 MHz/1000 = 96 kHz
3.- I've tried to change the tcscs, tcsck and NCK without any change on the sampled signal.
Thanks in advance.
    We are checking on this and we will get back to you as soon as possible.
    Nandini C
  • Hi, thanks. I've worked out one of the issues. SYSCLK and CORECLK has to be multiples, i mean, zero remainder, otherwise the example will approach the best multiples and get a coefficient. If that happens, the sampling rate on ADC behaves erratic.
    Having solved that, i'm still wandering how to change the sample rate of the ADC without having to change the SYSCLK frequency.
    Again, thanks in advance.
  • UPDATE: i've managed to change the sampling rate. To do so, you need to change the period of the GP timer. The sampling rate of the ADC comes out from the division between the sistem clock (SYSCLK) and the GP Timer period (PER). From my point of view, it doesn't make any sense, since the GP Timer provides the trigger source for the ADC and is not part of the ADCC. Besides, this isn't mentioned in any of the documents (Datasheet or HW reference). The only logical explanation i can think of is that the samples are equally spaced along the period of the GP Timer at SYSCLK rate.
