CM408 A/D Converter init
I'm try to run the AD converter of the CM408F without success.
I use GCC and I can't use your API, but I have translated it in the attached file.
The used TIMER 1 work and its interrupt run but I always found a zero value in my array.
Also this code run on a board that I have specifically developed and all related signals are ok.
I have written all necessary driver for all peripherals that I use but I find a great obstacle with the AD converter.
Can you help me? Attached you can find a portion of use code ....
Any suggestions or help is very appreciated.
Regards
attachments.zip
