cces
Hi all,
Will ADSP-CM4xxx series processor be supported in CCES in the near future?
Best regards
Peter
  • Hi Peter,
    At time of writing, there is no plan to support ADSP-CM4xx processors in CCES.
    Although both ADSP-CM40x and ADSP-CM41x have CMSIS packs available, and CCES supports CMSIS packs, OpenOCD within CCES does not know how to access the Cortex-M cores on these parts, and the packs do not contain the necessary GNU linker scripts and other related files.
    steve
  • Hello Steve,
    Thanks for your prompt reply.
    Searching various websites I can only find the IAR and Keil compiler supporting ADSP-CM4xx, but neither are really good when it comes down to supporting Eclipse.
    Are you aware of a compiler/tool vendor that both supports ADSP-CM4xx and uses the Eclipse IDE as basis for there tool set?
    With kind regards.
    Peter
  • > Are you aware of a compiler/tool vendor that both supports ADSP-CM4xx and uses the Eclipse IDE as basis for there tool set?
    Not at present, sorry.
    steve
