Even after erasing the flash memory, I am able to see the fault LED still On, any particular reason for that?
Thanks
Raj
Thanks
Raj
That is an indication that the flash erase or programming is completed.
But this only happens in Boot mode 1, when I switch to boot mode 3, (Communicating with serial port) and then if I erase the memory through crosscore serial flash programmer, the red led does not light up. why?
