All conditions that occur /SYS_FAULT assert
What art All conditions that occur /SYS_FAULT assert in the system using ADSP-21569?
I can't find above in the ADSP21-5xx HRM.
    Apologies for delay in response.
    Here are the few examples for SYS_FAULT assert,
    1. SYS_FAULT -Active, High, Fault Output. Indicates internal faults or senses external faults depending on the operating mode.
    2.SYS_FAULT - Active, Low, Fault Output. Indicates internal faults or senses external faults depending on the operating mode.
    3.The CGU_OSCWDCTL register configures the CGU to allow the detection of the absence of input clock transitions and provides a fault warning via the SYS_FAULT pin.
    4.The CRC peripheral can enable certain CRC status operations to generate an interrupt event to the system event controller. There, a CRC error can be qualified as a system fault.
    System event controller (SEC) further supports fault management, including fault action configuration as timeout, internal indication by system interrupt, or external indication through the SYS_FAULT pin and system reset.
    For further Clarrification on Fault management please refer System Fault Interface (SFI) in Pg No: 187 in ADSP-21569 HRM.
    www.analog.com/.../adsp-2156x_hwr.pdf
    Anand Selvaraj.
