ADSP-21479 InitPLL Does Not Work Any feedback please?
//**************** InitPLL.asm *******************
#include <def21479.h>
//#define PLLD4_SDCKR4 // Uncomment if final PLLD=SDCKR=4..
.global InitPLL;
.extern start;
.section/pm seg_pmco;
InitPLL:
 // PLL Programming Sequence by ODemirci
 // CLKIN=16.625MHz for ADSP-21479 EZ-KIT
 // FCCLK=(CLKIN*2*PLLM)/(PLLD*D)  where INDIV=0-->D=1 OR INDIV=1-->D=2
              // Step 1
               ustat1 = dm(PMCTL);
               bit clr ustat1 BIT_6|BIT_7; // PLLD=2
               bit set ustat1 BIT_6|BIT_9; // DIVEN=1
               dm(PMCTL) = ustat1;
               // Step 2 (Wait at least 16 CCLK cycles)
               lcntr=20, do first_div_delay until lce;
               first_div_delay: nop;
               // Step 3
               ustat1 = dm(PMCTL);
               bit clr ustat1 BIT_9;          // DIVEN=0
               bit set ustat1 BIT_8|BIT_15;   // PLLBP=1
               dm(PMCTL) = ustat1;
               // Step 4 (Wait at least 4096 CCLK cycles)
               lcntr=5000, do first_bypass_delay until lce;
               first_bypass_delay:nop;
               // Step 5
               ustat1 = dm(PMCTL);
               bit clr ustat1 BIT_15; // PLLBP=0
               dm(PMCTL) = ustat1;
               // Step 6 (Wait at least 16 CCLK cycles)
               lcntr=20, do second_div_delay until lce;
               second_div_delay:nop;
               // Step 7
               ustat1 = dm(PMCTL);
               bit clr ustat1 BIT_0|BIT_1|BIT_2|BIT_3|BIT_4|BIT_5|BIT_8;  // PLLM=0 & INDIV=0
               bit set ustat1 BIT_0|BIT_1|BIT_2|BIT_3|BIT_15;             // PLLM=15 & PLLBP=1
               dm(PMCTL) = ustat1;
               // Step 8 (Wait at least 4096 CCLK cycles)
               lcntr=5000, do second_bypass_delay until lce;
               second_bypass_delay:nop;
               // Step 9
               ustat1 = dm(PMCTL);
               dm(PMCTL) = ustat1;
               // Step 10 (Wait at least 16 CCLK cycles)
               lcntr=20, do third_div_delay until lce;
               third_div_delay:nop;
               // Step 11
               ustat1 = dm(PMCTL);
               bit clr ustat1 BIT_6|0x1C0000;                 // PLLM=0 & ?
               bit set ustat1 0x00000000|0x00000000|BIT_19;   // ? & ? DIVEN=1
               dm(PMCTL) = ustat1;
               // Step 12 (Wait at least 16 CCLK cycles)
               lcntr=20, do forth_div_delay until lce;
               forth_div_delay:nop;
InitPLL.end: rts;
