why simulation voltage big than the power supply?
Contains AI Generated Content
Product Number: LTspice
Software Version: LTspice 24.1.9
Use LTspice 24.1.9 ,Transient simulation the OP113 ,the voltage is big than the power +/-6V ;almost 200V ...
  • I ran into the similar issues with some TI Op-Amps too. While I am still learning the truth, the likely cause of this kind of behavior seems to be that the spice model you are using is not fully compatible with LTspice.
    WL
  • Hello ,
    I assume you used the Spice Macro modell for OP113  found on the TI homepage. As a macro model, it does not describe  the behaviour of the chip by modelling each individual transistor. Instead it uses e.g. a current source to model the input offset current of the opamp.
    "IOS 2 3 25E-9" in the modell describes a typical 25nA offset current flowing from the inverting input to the noninverting input. The inverting input is kept at "reasonable" voltages in your simulation. Therefore the 25nA will have to charge up C3 to non reasonable voltages.
    You did not attach the model or the simulation file (would have been helpful to answer your question). And though your screenshot is huge, which makes it uncomfortable to read on lower resolution monitors, it does not show the time axis of your simulation. But you may yourself check the slope of V(n007): does it correspond to a current of 25nA to 100pF? Or maybe it's something like 650nA to 100pF (because 650nA is the maximum input bias current).
    Now this charging behaviour is of course not realistic: in real world the inputs of the opamp show a current source behaviour only as long as the inputs are in normal operating range, it will not drive the inputs beyond the operating voltage.
    On the other hand this behaviour does show you that your circuit will not work in real life just as it doesn't work in simulation: You must allow some DC-current to flow from the opamp-inputs to GND. In your circuit this current has to flow through C3 and will charge up C3. In the simu up to 230V, in real word just close up to one of the supplies. But in either case, the circuit will not work.
    You may add a high-value resistor from the non inverting input to GND. Then the circuit may work in real life, and maybe it also works correctly in your simulation then.
    best regards
    Achim
