I cannot rotate the Labet Net the Key Ctrl R and Ctrl E do not opérate
Edit Notes
Removed "Contains AI Generated Content"[edited by: MStokowski at 9:39 PM (GMT -4) on 15 Oct 2026]
Strong EMC design
LTspice
Production
LTspice® is a powerful, fast, and free SPICE simulator software, schematic capture and waveform viewer with enhancements and models for improving the simulation...
LTspice on Analog.com
Hi chsimon ,
Correct. Net labels will attach as vertical text to the ends of vertical wires and anywhere along a vertical wire; and as horizontal text to the ends of horizontal wires. along horizontal wires, and to wire corners. You can use Ctrl+R to (appear to) change the attachment point, but the result is the same: LTspice will return to the default behavior.
mike
Thanks for your reply. I'm starting by adding the Net labels and then the links, which is why the orientation is incorrect.
In older versions, rotation worked like other components; it was more logical and faster.
I hope the newer versions will fix this.
