BV input sources
Product Number: LTSP
Software Version: 26.1.1
I have made a symbol type X´that is a transistor with 3 pins called u1
When I try to use BV with Ix(u1:2) it is not possible can not find instance.
The trace window show alternatives Ix(u1:2) but i can not use it in the schematics
It is not a big issue for me but I tell it
  • Hi  ,
    Pin currents cannot be called on by behavioral sources. B sources, in simulation, have access to time-stepped node voltages and (two-pin) device currents. A pin is neither a node, nor a device. There is a trick, though: add a 0V voltage source at the pin as a current probe and reference its current I(V1) in your B source. You can rotate the polarity of the 0V source to produce the signed current as desired.
    mike
