Plotting JFET source follower input capacitance in the function of frequency
The user seeks to plot the input capacitance and resistance of a JFET source follower circuit (2N4416) over a frequency range of 1 MHz to 10 MHz. The final answer provides a method to calculate the input capacitance using the formula Ig(J1)/(V(ugs)*2*3.1454*frequency), resulting in 16.2 pF at 1 MHz. However, the user notes that this value seems high compared to the datasheet, which specifies Cgs as 2.41 pF and Cgd as 1.6 pF.
Software Version: LTspice (x64): 26.0.2
I would like to plot the input capacitance (and the input resistance) of a jfet source follower circuit in the function of frequency .   The input impedance is complex of course in the frequency range involved between 1 MHz and 10 MHz but I need help in doing this.
I used the 2N4416 jfet model and its input capacitance is known from data sheet (which is about 3-4 pF) but I wish to see it plotted on the vertical axis while the horizontal axis shows the frequency range.
Here is the schematic I use for simulation, together with the small signal AC simulation plot on the voltage output and I attached the asc circuit file too
JFET source follower tests 1.asc
Thanks for any help in advance.
Gyula
