Error installing 26.0.2
Product Number: LTspice
Software Version: 26.0.1 current
I tried to install LTSpice v26.0.2 via update in the app, and then again via the full installer.
I am installing as a user, not as an admin.
I got the following error:
I went tot he directory while the installer was still running and the error was still posted and saw this:
I could install as admin but prefer not to. This has never happened before.
I use LTSpice for my work because it has worked well for me and I can leave a copy with my clients (which I can not do with PSpice).
Thank you for your help,
Morty Tarr
MTarr Consulting LLC
  • Hello MTarr, All assigned engineers are out of office currently. MStokowski will be back in the week of 9/21/2026 to answer your question!
  • Hi  ,
    Sorry about the delay. Yes, that is interesting in that clearly the install was able to write to that directory, except for the Remove.exe app. Let me look into this.
    mike
  • Hi  ,
    You might try installing for "Everyone" and see if that works. Also, you could give us a verbose install log by using this command in the command line, replacing paths as needed:
    msiexec /i "C:\MyPackages\LTspice64.msi" /L*V "C:\Logs\InstallerLog.log
    mike
  • Hi Mike,
    I'll try it and send the log file. My command would be:
    msiexec /i "E:\LT Spice\Installer 2026-08-24  v26.0.2\LTspice64.msi" /L*V "C:\Logs\InstallerLog.log"
    My installers are on the E: drive. If the command line does not look correct, please advise.
    Thanks for your help,
    Morty
  • Hi Mike,
    I sent this earlier today but it's not showing up. I had to create the Logs directory and the log file for the command to work. My command line is:
    -Morty
    I tried to insert the log file inline but the ADI words matter rejected it. Hopefully it is acceptable this way.
    Here's the log file inserted as code (too bad there's not an option to attach the file):
    === Verbose logging started: 9/25/2026  10:42:27  Build type: SHIP UNICODE 5.00.10011.00  Calling process: C:\Windows\SysWOW64\msiexec.exe ===
    MSI (c) (40:58) [10:42:28:009]: Font created.  Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
    MSI (c) (40:B0) [10:42:28:029]: Resetting cached policy values
    MSI (c) (40:B0) [10:42:28:029]: Machine policy value 'Debug' is 0
    MSI (c) (40:B0) [10:42:28:029]: ******* RunEngine:
               ******* Product: E:\LT Spice\Installer 2026-08-24  v26.0.2\LTspice64.msi
               ******* Action:
               ******* CommandLine: **********
    MSI (c) (40:B0) [10:42:28:039]: Machine policy value 'DisableUserInstalls' is 0
    MSI (c) (40:B0) [10:42:28:055]: Access database with Impersonation
    MSI (c) (40:B0) [10:42:28:056]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'E:\LT Spice\Installer 2026-08-24  v26.0.2\LTspice64.msi' against software restriction policy
    MSI (c) (40:B0) [10:42:28:056]: SOFTWARE RESTRICTION POLICY: E:\LT Spice\Installer 2026-08-24  v26.0.2\LTspice64.msi has a digital signature
    MSI (c) (40:B0) [10:42:28:225]: SOFTWARE RESTRICTION POLICY: E:\LT Spice\Installer 2026-08-24  v26.0.2\LTspice64.msi is permitted to run at the 'unrestricted' authorization level.
    MSI (c) (40:B0) [10:42:28:231]: Cloaking enabled.
    MSI (c) (40:B0) [10:42:28:231]: Attempting to enable all disabled privileges before calling Install on Server
    MSI (c) (40:B0) [10:42:28:233]: End dialog not enabled
    MSI (c) (40:B0) [10:42:28:233]: Original package ==> E:\LT Spice\Installer 2026-08-24  v26.0.2\LTspice64.msi
    MSI (c) (40:B0) [10:42:28:233]: Package we're running from ==> E:\LT Spice\Installer 2026-08-24  v26.0.2\LTspice64.msi
    MSI (c) (40:B0) [10:42:28:236]: APPCOMPAT: Compatibility mode property overrides found.
    MSI (c) (40:B0) [10:42:28:236]: APPCOMPAT: looking for appcompat database entry with ProductCode '{CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B}'.
    MSI (c) (40:B0) [10:42:28:237]: APPCOMPAT: no matching ProductCode found in database.
    MSI (c) (40:B0) [10:42:28:247]: MSCOREE not loaded loading copy from system32
    MSI (c) (40:B0) [10:42:28:249]: Machine policy value 'TransformsSecure' is 0
    MSI (c) (40:B0) [10:42:28:249]: User policy value 'TransformsAtSource' is 0
    MSI (c) (40:B0) [10:42:28:249]: Note: 1: 2205 2:  3: MsiFileHash
    MSI (c) (40:B0) [10:42:28:249]: Machine policy value 'DisablePatch' is 0
    MSI (c) (40:B0) [10:42:28:249]: Machine policy value 'AllowLockdownPatch' is 0
    MSI (c) (40:B0) [10:42:28:249]: Machine policy value 'DisableMsi' is 0
    MSI (c) (40:B0) [10:42:28:249]: Machine policy value 'AlwaysInstallElevated' is 0
    MSI (c) (40:B0) [10:42:28:249]: User policy value 'AlwaysInstallElevated' is 0
    MSI (c) (40:B0) [10:42:28:249]: Running product '{CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B}' with user privileges: It's not assigned.
    MSI (c) (40:B0) [10:42:28:249]: Machine policy value 'DisableLUAPatching' is 0
    MSI (c) (40:B0) [10:42:28:249]: Machine policy value 'DisableFlyWeightPatching' is 0
    MSI (c) (40:B0) [10:42:28:250]: APPCOMPAT: looking for appcompat database entry with ProductCode '{CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B}'.
    MSI (c) (40:B0) [10:42:28:250]: APPCOMPAT: no matching ProductCode found in database.
    MSI (c) (40:B0) [10:42:28:260]: Transforms are not secure.
    MSI (c) (40:B0) [10:42:28:260]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Logs\InstallerLog.log'.
    MSI (c) (40:B0) [10:42:28:260]: Command Line: CURRENTDIRECTORY=C:\Windows\SysWOW64 CLIENTUILEVEL=0 CLIENTPROCESSID=7488
    MSI (c) (40:B0) [10:42:28:260]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{39C828E8-EBEA-41FF-AC38-4A5921DF2236}'.
    MSI (c) (40:B0) [10:42:28:260]: Product Code passed to Engine.Initialize:           ''
    MSI (c) (40:B0) [10:42:28:260]: Product Code from property table before transforms: '{CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B}'
    MSI (c) (40:B0) [10:42:28:260]: Product Code from property table after transforms:  '{CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B}'
    MSI (c) (40:B0) [10:42:28:260]: Product not registered: beginning first-time install
    MSI (c) (40:B0) [10:42:28:260]: PROPERTY CHANGE: Deleting ALLUSERS property. Its current value is '2'.
    MSI (c) (40:B0) [10:42:28:260]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
    MSI (c) (40:B0) [10:42:28:260]: Entering CMsiConfigurationManager::SetLastUsedSource.
    MSI (c) (40:B0) [10:42:28:260]: User policy value 'SearchOrder' is 'nmu'
    MSI (c) (40:B0) [10:42:28:260]: Adding new sources is allowed.
    MSI (c) (40:B0) [10:42:28:260]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
    MSI (c) (40:B0) [10:42:28:260]: Package name extracted from package path: 'LTspice64.msi'
    MSI (c) (40:B0) [10:42:28:260]: Package to be registered: 'LTspice64.msi'
    MSI (c) (40:B0) [10:42:28:261]: Note: 1: 2262 2: AdminProperties 3: -2147287038
    MSI (c) (40:B0) [10:42:28:261]: Machine policy value 'AlwaysInstallElevated' is 0
    MSI (c) (40:B0) [10:42:28:261]: User policy value 'AlwaysInstallElevated' is 0
    MSI (c) (40:B0) [10:42:28:261]: Running product '{CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B}' with user privileges: It's not assigned.
    MSI (c) (40:B0) [10:42:28:261]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Windows\SysWOW64'.
    MSI (c) (40:B0) [10:42:28:261]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
    MSI (c) (40:B0) [10:42:28:261]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '7488'.
    MSI (c) (40:B0) [10:42:28:261]: TRANSFORMS property is now:
    MSI (c) (40:B0) [10:42:28:261]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '450'.
    MSI (c) (40:B0) [10:42:28:263]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\AppData\Roaming
    MSI (c) (40:B0) [10:42:28:263]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\Favorites
    MSI (c) (40:B0) [10:42:28:263]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Network Shortcuts
    MSI (c) (40:B0) [10:42:28:263]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\Documents
    MSI (c) (40:B0) [10:42:28:263]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
    MSI (c) (40:B0) [10:42:28:264]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Recent
    MSI (c) (40:B0) [10:42:28:264]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\SendTo
    MSI (c) (40:B0) [10:42:28:264]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Templates
    MSI (c) (40:B0) [10:42:28:264]: SHELL32::SHGetFolderPath returned: C:\ProgramData
    MSI (c) (40:B0) [10:42:28:264]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\AppData\Local
    MSI (c) (40:B0) [10:42:28:264]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\Pictures
    MSI (c) (40:B0) [10:42:28:264]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
    MSI (c) (40:B0) [10:42:28:264]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
    MSI (c) (40:B0) [10:42:28:265]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
    MSI (c) (40:B0) [10:42:28:265]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\Desktop
    MSI (c) (40:B0) [10:42:28:265]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
    MSI (c) (40:B0) [10:42:28:265]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
    MSI (c) (40:B0) [10:42:28:266]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
    MSI (c) (40:B0) [10:42:28:266]: SHELL32::SHGetFolderPath returned: C:\windows\Fonts
    MSI (c) (40:B0) [10:42:28:267]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 25
    MSI (c) (40:B0) [10:42:28:272]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
    MSI (c) (40:B0) [10:42:28:272]: PROPERTY CHANGE: Adding AdminUser property. Its value is '1'.
    MSI (c) (40:B0) [10:42:28:272]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
    MSI (c) (40:B0) [10:42:28:272]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
    MSI (c) (40:B0) [10:42:28:272]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'mtarr00@yahoo.com'.
    MSI (c) (40:B0) [10:42:28:273]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
    MSI (c) (40:B0) [10:42:28:273]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'mmc'.
    MSI (c) (40:B0) [10:42:28:273]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'E:\LT Spice\Installer 2026-08-24  v26.0.2\LTspice64.msi'.
    MSI (c) (40:B0) [10:42:28:273]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'E:\LT Spice\Installer 2026-08-24  v26.0.2\LTspice64.msi'.
    MSI (c) (40:B0) [10:42:28:273]: Machine policy value 'MsiDisableEmbeddedUI' is 0
    MSI (c) (40:B0) [10:42:28:273]: EEUI - Running MsiEmbeddedUI code
    MSI (c) (40:E0) [10:42:28:486]: Cloaking enabled.
    MSI (c) (40:E0) [10:42:28:486]: Attempting to enable all disabled privileges before calling Install on Server
    MSI (c) (40:E0) [10:42:28:486]: Connected to service for CA interface.
    MSI (c) (40!10) [10:42:28:767]: PROPERTY CHANGE: Adding AIEXTERNALUI property. Its value is '5'.
    MSI (c) (40!10) [10:42:28:767]: PROPERTY CHANGE: Adding CHAINERUIPROCESSID property. Its value is '17712Chainer'.
    MSI (c) (40!10) [10:42:28:767]: PROPERTY CHANGE: Adding AI_CLIENTPROCESSID property. Its value is '17712'.
    MSI (c) (40!10) [10:42:28:777]: PROPERTY CHANGE: Modifying AIEXTERNALUI property. Its current value is '5'. Its new value: '1'.
    MSI (c) (40!10) [10:42:28:796]: PROPERTY CHANGE: Adding PRIMARYFOLDER property. Its value is 'APPDIR'.
    MSI (c) (40!10) [10:42:28:796]: PROPERTY CHANGE: Adding AiEmbeddedDirectCall property. Its value is '1'.
    MSI (c) (40!10) [10:42:28:811]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is '603'. Its new value: '1100'.
    MSI (c) (40!10) [10:42:28:811]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is '603'. Its new value: '1100'.
    MSI (c) (40!10) [10:42:28:811]: PROPERTY CHANGE: Modifying WindowsBuild property. Its current value is '9600'. Its new value: '26200'.
    MSI (c) (40!10) [10:42:28:812]: PROPERTY CHANGE: Deleting AiEmbeddedDirectCall property. Its current value is '1'.
    MSI (c) (40!10) [10:42:28:812]: PROPERTY CHANGE: Adding AiEmbeddedDirectCall property. Its value is '1'.
    MSI (c) (40!10) [10:42:28:829]: PROPERTY CHANGE: Deleting AiEmbeddedDirectCall property. Its current value is '1'.
    MSI (c) (40!10) [10:42:28:829]: PROPERTY CHANGE: Adding AiEmbeddedDirectCall property. Its value is '1'.
    MSI (c) (40!10) [10:42:28:843]: PROPERTY CHANGE: Adding AI_SYSTEM_DPI property. Its value is '144'.
    MSI (c) (40!10) [10:42:28:843]: PROPERTY CHANGE: Adding AI_SYSTEM_DPI_SCALE property. Its value is '150'.
    MSI (c) (40!10) [10:42:28:873]: PROPERTY CHANGE: Deleting AiEmbeddedDirectCall property. Its current value is '1'.
    MSI (c) (40!10) [10:42:28:873]: PROPERTY CHANGE: Adding AiEmbeddedDirectCall property. Its value is '1'.
    MSI (c) (40!10) [10:42:28:874]: PROPERTY CHANGE: Deleting AiEmbeddedDirectCall property. Its current value is '1'.
    MSI (c) (40!10) [10:42:28:880]: Note: 1: 2205 2:  3: AI_ControlConditionEx
    MSI (c) (40!10) [10:42:28:880]: Note: 1: 2228 2:  3: AI_ControlConditionEx 4: SELECT `Dialog_`,`Control_`,`Action`,`Condition` FROM `AI_ControlConditionEx`
    MSI (c) (40!10) [10:42:28:885]: Note: 1: 2205 2:  3: AI_EventMappingEx
    MSI (c) (40!10) [10:42:28:885]: Note: 1: 2228 2:  3: AI_EventMappingEx 4: SELECT `Dialog_`,`Control_`,`Event`,`Attribute` FROM `AI_EventMappingEx`
    MSI (c) (40!10) [10:42:29:006]: Note: 1: 2205 2:  3: AI_ControlEx
    MSI (c) (40!10) [10:42:29:006]: Note: 1: 2228 2:  3: AI_ControlEx 4: SELECT `Dialog_`,`Control`,`Type`,`Parent`,`Attributes`,`Data` FROM `AI_ControlEx` WHERE `Dialog_` = 'PrepareDlg'
    MSI (c) (40!10) [10:42:29:023]: PROPERTY CHANGE: Adding AI_HWND_EUI property. Its value is '200128'.
    MSI (c) (40:B0) [10:42:29:036]: PROPERTY CHANGE: Adding MSICLIENTUSESEMBEDDEDUI property. Its value is '1'.
    MSI (c) (40:B0) [10:42:29:036]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'E:\LT Spice\Installer 2026-08-24  v26.0.2\'.
    MSI (c) (40:B0) [10:42:29:036]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'E:\LT Spice\Installer 2026-08-24  v26.0.2\'.
    MSI (c) (40:58) [10:42:29:047]: PROPERTY CHANGE: Adding VersionHandler property. Its value is '5.00'.
    MSI (c) (40:58) [10:42:29:047]: PROPERTY CHANGE: Adding TextHeightCorrection property. Its value is '1.2000'.
    === Logging started: 9/25/2026  10:42:29 ===
    MSI (c) (40:B0) [10:42:29:053]: Note: 1: 2262 2: PatchPackage 3: -2147287038
    MSI (c) (40:B0) [10:42:29:053]: Machine policy value 'DisableRollback' is 0
    MSI (c) (40:B0) [10:42:29:053]: User policy value 'DisableRollback' is 0
    MSI (c) (40:B0) [10:42:29:053]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
    MSI (c) (40:B0) [10:42:29:053]: Note: 1: 2203 2: C:\windows\Installer\inprogressinstallinfo.ipi 3: -2147287038
    MSI (c) (40:B0) [10:42:29:053]: APPCOMPAT: [DetectVersionLaunchCondition] Launch condition already passes.
    MSI (c) (40:B0) [10:42:29:065]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
    MSI (c) (40:B0) [10:42:29:065]: Doing action: INSTALL
    Action 10:42:29: INSTALL.
    Action start 10:42:29: INSTALL.
    MSI (c) (40:B0) [10:42:29:066]: UI Sequence table 'InstallUISequence' is present and populated.
    MSI (c) (40:B0) [10:42:29:066]: Running UISequence
    MSI (c) (40:B0) [10:42:29:066]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
    MSI (c) (40:B0) [10:42:29:066]: Doing action: AI_SET_INSTALL
    Action 10:42:29: AI_SET_INSTALL.
    Action start 10:42:29: AI_SET_INSTALL.
    MSI (c) (40:B0) [10:42:29:067]: PROPERTY CHANGE: Adding AI_INSTALL property. Its value is '1'.
    Action ended 10:42:29: AI_SET_INSTALL. Return value 1.
    MSI (c) (40:B0) [10:42:29:067]: Skipping action: AI_SET_MAINT (condition is false)
    MSI (c) (40:B0) [10:42:29:067]: Skipping action: AI_SET_RESUME (condition is false)
    MSI (c) (40:B0) [10:42:29:067]: Skipping action: AI_SET_PATCH (condition is false)
    MSI (c) (40:B0) [10:42:29:067]: Skipping action: AI_CORRECT_INSTALL (condition is false)
    MSI (c) (40:B0) [10:42:29:067]: Doing action: AI_DETECT_MODERNWIN
    Action 10:42:29: AI_DETECT_MODERNWIN.
    Action start 10:42:29: AI_DETECT_MODERNWIN.
    MSI (c) (40:D8) [10:42:29:075]: Invoking remote custom action. DLL: C:\Users\mtarr\AppData\Local\Temp\MSIC3CD.tmp, Entrypoint: DetectModernWindows
    MSI (c) (40:E0) [10:42:29:076]: Cloaking enabled.
    MSI (c) (40:E0) [10:42:29:076]: Attempting to enable all disabled privileges before calling Install on Server
    MSI (c) (40:E0) [10:42:29:077]: Connected to service for CA interface.
    Action ended 10:42:29: AI_DETECT_MODERNWIN. Return value 1.
    MSI (c) (40:B0) [10:42:29:117]: Doing action: AI_DETECT_WINTHEME
    Action 10:42:29: AI_DETECT_WINTHEME.
    Action start 10:42:29: AI_DETECT_WINTHEME.
    MSI (c) (40:D8) [10:42:29:124]: Invoking remote custom action. DLL: C:\Users\mtarr\AppData\Local\Temp\MSIC3FD.tmp, Entrypoint: DetectWindowsTheme
    Action ended 10:42:29: AI_DETECT_WINTHEME. Return value 1.
    MSI (c) (40:B0) [10:42:29:139]: Doing action: AI_EmbeddedUiAsync
    Action 10:42:29: AI_EmbeddedUiAsync.
    Action start 10:42:29: AI_EmbeddedUiAsync.
    Action ended 10:42:29: AI_EmbeddedUiAsync. Return value 1.
    MSI (c) (40:B0) [10:42:29:141]: Skipping action: AI_IaLogPkgStarted (condition is false)
    MSI (c) (40:B0) [10:42:29:141]: Doing action: AI_EnableDebugLog
    Action 10:42:29: AI_EnableDebugLog.
    Action start 10:42:29: AI_EnableDebugLog.
    MSI (c) (40:14) [10:42:29:146]: Invoking remote custom action. DLL: C:\Users\mtarr\AppData\Local\Temp\MSIC40E.tmp, Entrypoint: EmbeddedUIInstallHandleAccessServer
    MSI (c) (40:F8) [10:42:29:148]: Invoking remote custom action. DLL: C:\Users\mtarr\AppData\Local\Temp\MSIC40F.tmp, Entrypoint: EnableDebugLog
    AI_EnableDebugLog: Log disabled
    Action ended 10:42:29: AI_EnableDebugLog. Return value 1.
    MSI (c) (40:B0) [10:42:29:167]: Doing action: AI_DpiContentScale
    Action 10:42:29: AI_DpiContentScale.
    Action start 10:42:29: AI_DpiContentScale.
    MSI (c) (40:00) [10:42:29:179]: Invoking remote custom action. DLL: C:\Users\mtarr\AppData\Local\Temp\MSIC42F.tmp, Entrypoint: DpiContentScale
    Action ended 10:42:29: AI_DpiContentScale. Return value 1.
    MSI (c) (40:B0) [10:42:29:213]: Doing action: AI_ResolveKnownFolders
    Action 10:42:29: AI_ResolveKnownFolders.
    Action start 10:42:29: AI_ResolveKnownFolders.
    MSI (c) (40:10) [10:42:29:222]: Invoking remote custom action. DLL: C:\Users\mtarr\AppData\Local\Temp\MSIC45F.tmp, Entrypoint: AI_ResolveKnownFolders
    MSI (c) (40!F0) [10:42:29:233]: PROPERTY CHANGE: Adding SavedGamesFolder property. Its value is 'C:\Users\mtarr\Saved Games\'.
    MSI (c) (40!F0) [10:42:29:233]: PROPERTY CHANGE: Adding WindowsLibrariesFolder property. Its value is 'C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Libraries\'.
    MSI (c) (40!F0) [10:42:29:233]: PROPERTY CHANGE: Adding PublicDocumentsFolder property. Its value is 'C:\Users\Public\Documents\'.
    MSI (c) (40!F0) [10:42:29:233]: PROPERTY CHANGE: Adding PublicFolder property. Its value is 'C:\Users\Public\'.
    MSI (c) (40!F0) [10:42:29:234]: PROPERTY CHANGE: Adding UserProfileFolder property. Its value is 'C:\Users\mtarr\'.
    MSI (c) (40!F0) [10:42:29:234]: PROPERTY CHANGE: Adding IIsWWWRootFolder property. Its value is 'C:\inetpub\wwwroot\'.
    Action ended 10:42:29: AI_ResolveKnownFolders. Return value 1.
    MSI (c) (40:B0) [10:42:29:235]: Doing action: PrepareDlg
    Action 10:42:29: PrepareDlg.
    Action start 10:42:29: PrepareDlg.
    Action ended 10:42:29: PrepareDlg. Return value 1.
    MSI (c) (40:B0) [10:42:29:239]: Doing action: IsWine.dll
    Action 10:42:29: IsWine.dll.
    Action start 10:42:29: IsWine.dll.
    MSI (c) (40:2C) [10:42:29:245]: Invoking remote custom action. DLL: C:\Users\mtarr\AppData\Local\Temp\MSIC47F.tmp, Entrypoint: IsWineDetected
    MSI (c) (40:E0) [10:42:29:245]: Cloaking enabled.
    MSI (c) (40:E0) [10:42:29:245]: Attempting to enable all disabled privileges before calling Install on Server
    MSI (c) (40:E0) [10:42:29:245]: Connected to service for CA interface.
    Wine Detection: Native Windows environment (IS_WINE=0)
    MSI (c) (40!54) [10:42:29:272]: PROPERTY CHANGE: Adding IS_WINE property. Its value is '0'.
    Action ended 10:42:29: IsWine.dll. Return value 1.
    MSI (c) (40:B0) [10:42:29:274]: Skipping action: SetWineInstallationProperty (condition is false)
    MSI (c) (40:B0) [10:42:29:274]: Doing action: AI_BACKUP_AI_SETUPEXEPATH
    Action 10:42:29: AI_BACKUP_AI_SETUPEXEPATH.
    Action start 10:42:29: AI_BACKUP_AI_SETUPEXEPATH.
    Action ended 10:42:29: AI_BACKUP_AI_SETUPEXEPATH. Return value 1.
    MSI (c) (40:B0) [10:42:29:276]: Doing action: AI_IaToggle
    Action 10:42:29: AI_IaToggle.
    Action start 10:42:29: AI_IaToggle.
    MSI (c) (40:C4) [10:42:29:284]: Invoking remote custom action. DLL: C:\Users\mtarr\AppData\Local\Temp\MSIC49F.tmp, Entrypoint: OnAnalyticsToggle
    Action ended 10:42:29: AI_IaToggle. Return value 1.
    MSI (c) (40:B0) [10:42:29:299]: Doing action: AppSearch
    Action 10:42:29: AppSearch. Searching for installed applications
    Action start 10:42:29: AppSearch.
    AppSearch: Property: AI_INSTALLPERUSER, Signature: AI_INSTALLPERUSER
    MSI (c) (40:B0) [10:42:29:300]: Note: 1: 2262 2: Signature 3: -2147287038
    MSI (c) (40:B0) [10:42:29:300]: PROPERTY CHANGE: Modifying AI_INSTALLPERUSER property. Its current value is '1'. Its new value: '0'.
    AppSearch: Property: AI_INSTALLPERUSER, Signature: AI_INSTALLPERUSER_1
    MSI (c) (40:B0) [10:42:29:301]: Note: 1: 2262 2: Signature 3: -2147287038
    MSI (c) (40:B0) [10:42:29:301]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Analog Devices Inc.\{D7D4C089-7B20-418E-BA5E-E0557C67F5D9} 3: 2
    AppSearch: Property: AI_INSTALLPERUSER, Signature: AI_INSTALLPERUSER_2
    AppSearch: Property: AI_INSTALLPERUSER, Signature: AI_INSTALLPERUSER_3
    MSI (c) (40:B0) [10:42:29:302]: Note: 1: 2262 2: Signature 3: -2147287038
    MSI (c) (40:B0) [10:42:29:302]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Analog Devices Inc.\{D7D4C089-7B20-418E-BA5E-E0557C67F5D9} 3: 2
    AppSearch: Property: AI_IA_ENABLE, Signature: AI_IA_ENABLE
    MSI (c) (40:B0) [10:42:29:302]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Analog Devices Inc.\{CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 3: 2
    AppSearch: Property: AI_IA_ENABLE, Signature: AI_IA_ENABLE_1
    MSI (c) (40:B0) [10:42:29:302]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Analog Devices Inc.\{CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 3: 2
    AppSearch: Property: AI_IA_ENABLE, Signature: AI_IA_ENABLE_2
    MSI (c) (40:B0) [10:42:29:303]: Note: 1: 2262 2: Signature 3: -2147287038
    MSI (c) (40:B0) [10:42:29:303]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Analog Devices Inc.\{CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 3: 2
    AppSearch: Property: AI_IA_ENABLE, Signature: AI_IA_ENABLE_3
    MSI (c) (40:B0) [10:42:29:303]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Analog Devices Inc.\{CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 3: 2
    Action ended 10:42:29: AppSearch. Return value 1.
    MSI (c) (40:B0) [10:42:29:304]: Doing action: AI_DetectSoftware
    Action 10:42:29: AI_DetectSoftware.
    Action start 10:42:29: AI_DetectSoftware.
    MSI (c) (40:54) [10:42:29:313]: Invoking remote custom action. DLL: C:\Users\mtarr\AppData\Local\Temp\MSIC4C0.tmp, Entrypoint: OnDetectSoftware
    MSI (c) (40!DC) [10:42:29:442]: PROPERTY CHANGE: Adding AI_DETECTED_DOTNET_CORE_VERSION property. Its value is '8.0'.
    MSI (c) (40!DC) [10:42:29:443]: PROPERTY CHANGE: Adding AI_DETECTED_DOTNET_CORE32_VERSION property. Its value is '8.0'.
    MSI (c) (40!DC) [10:42:29:443]: PROPERTY CHANGE: Adding AI_DETECTED_DOTNET_CORE64_VERSION property. Its value is '8.0'.
    MSI (c) (40!DC) [10:42:29:443]: PROPERTY CHANGE: Adding AI_DETECTED_DOTNET_VERSION property. Its value is '4.8.1'.
    MSI (c) (40!DC) [10:42:29:443]: PROPERTY CHANGE: Adding AI_DETECTED_IE_VERSION property. Its value is '11.0'.
    MSI (c) (40!DC) [10:42:29:443]: PROPERTY CHANGE: Adding AI_DETECTED_DIRECTX_VERSION property. Its value is '12'.
    MSI (c) (40!DC) [10:42:29:443]: PROPERTY CHANGE: Adding AI_DETECTED_SQLSERVER_ODBCDRIVER_VERSION property. Its value is '09.0'.
    MSI (c) (40!DC) [10:42:29:443]: PROPERTY CHANGE: Adding AI_DETECTED_SQLSERVER_ODBCDRIVER9_VERSION property. Its value is '09.0'.
    MSI (c) (40!DC) [10:42:29:444]: PROPERTY CHANGE: Adding AI_DETECTED_VSTO_VERSION property. Its value is '4.0'.
    MSI (c) (40!DC) [10:42:29:444]: PROPERTY CHANGE: Adding AI_DETECTED_WINDOWS_POWERSHELL_VERSION property. Its value is '5.1'.
    MSI (c) (40!DC) [10:42:29:444]: PROPERTY CHANGE: Adding AI_DETECTED_POWERSHELL_VERSION property. Its value is '7.2'.
    MSI (c) (40!DC) [10:42:29:444]: PROPERTY CHANGE: Adding AI_DETECTED_POWERSHELL32_VERSION property. Its value is '7.2'.
    MSI (c) (40!DC) [10:42:29:444]: PROPERTY CHANGE: Adding AI_DETECTED_POWERSHELL64_VERSION property. Its value is '7.2'.
    MSI (c) (40!DC) [10:42:29:444]: PROPERTY CHANGE: Adding AI_DETECTED_VISUALCPP_VERSION_PROP property. Its value is '14.3'.
    MSI (c) (40!DC) [10:42:29:444]: PROPERTY CHANGE: Adding AI_DETECTED_VISUALCPP32_VERSION_PROP property. Its value is '14.3'.
    MSI (c) (40!DC) [10:42:29:444]: PROPERTY CHANGE: Adding AI_DETECTED_VISUALCPP64_VERSION_PROP property. Its value is '14.3'.
    MSI (c) (40!DC) [10:42:29:444]: PROPERTY CHANGE: Adding AI_DETECTED_OFFICE_ACCESS_VERSION property. Its value is '2016'.
    MSI (c) (40!DC) [10:42:29:444]: PROPERTY CHANGE: Adding AI_DETECTED_OFFICE_ACCESS64_VERSION property. Its value is '2016'.
    MSI (c) (40!DC) [10:42:29:444]: PROPERTY CHANGE: Adding AI_DETECTED_OFFICE_EXCEL_VERSION property. Its value is '2016'.
    MSI (c) (40!DC) [10:42:29:444]: PROPERTY CHANGE: Adding AI_DETECTED_OFFICE_EXCEL64_VERSION property. Its value is '2016'.
    MSI (c) (40!DC) [10:42:29:444]: PROPERTY CHANGE: Adding AI_DETECTED_OFFICE_ONENOTE_VERSION property. Its value is '2016'.
    MSI (c) (40!DC) [10:42:29:444]: PROPERTY CHANGE: Adding AI_DETECTED_OFFICE_ONENOTE64_VERSION property. Its value is '2016'.
    MSI (c) (40!DC) [10:42:29:444]: PROPERTY CHANGE: Adding AI_DETECTED_OFFICE_OUTLOOK_VERSION property. Its value is '2016'.
    MSI (c) (40!DC) [10:42:29:444]: PROPERTY CHANGE: Adding AI_DETECTED_OFFICE_OUTLOOK64_VERSION property. Its value is '2016'.
    MSI (c) (40!DC) [10:42:29:445]: PROPERTY CHANGE: Adding AI_DETECTED_OFFICE_POWERPOINT_VERSION property. Its value is '2016'.
    MSI (c) (40!DC) [10:42:29:445]: PROPERTY CHANGE: Adding AI_DETECTED_OFFICE_POWERPOINT64_VERSION property. Its value is '2016'.
    MSI (c) (40!DC) [10:42:29:445]: PROPERTY CHANGE: Adding AI_DETECTED_OFFICE_WORD_VERSION property. Its value is '2016'.
    MSI (c) (40!DC) [10:42:29:445]: PROPERTY CHANGE: Adding AI_DETECTED_OFFICE_WORD64_VERSION property. Its value is '2016'.
    MSI (c) (40!DC) [10:42:29:445]: PROPERTY CHANGE: Adding AI_DETECTED_OFFICE_MSFORMS_PIA_VERSION property. Its value is '2010'.
    MSI (c) (40!DC) [10:42:29:446]: PROPERTY CHANGE: Adding AI_DETECTED_OFFICE_MSFORMS2010_PIA_VERSION property. Its value is '2010'.
    MSI (c) (40!DC) [10:42:29:446]: PROPERTY CHANGE: Adding AI_DETECTED_PHYSICAL_MEMORY property. Its value is '32453'.
    MSI (c) (40!DC) [10:42:29:446]: PROPERTY CHANGE: Adding AI_DETECTED_GRAPHICS_ADAPTERS property. Its value is '[{"Name":"NVIDIA Quadro P400","MemorySize":2147483648}]'.
    MSI (c) (40!DC) [10:42:29:446]: PROPERTY CHANGE: Adding AI_DETECTED_COLOR_QUALITY property. Its value is '32'.
    MSI (c) (40!DC) [10:42:29:446]: PROPERTY CHANGE: Adding AI_DETECTED_ADMIN_USER property. Its value is '1'.
    MSI (c) (40!DC) [10:42:29:446]: PROPERTY CHANGE: Adding AI_DETECTED_PRODUCT_ANTIVIRUS property. Its value is 'Avast Antivirus;'.
    MSI (c) (40!DC) [10:42:29:447]: PROPERTY CHANGE: Adding AI_DETECTED_INTERNET_CONNECTION property. Its value is '1'.
    MSI (c) (40!DC) [10:42:29:447]: PROPERTY CHANGE: Adding AI_DETECTED_NOT_VIRTUAL_MACHINE property. Its value is '1'.
    MSI (c) (40!DC) [10:42:29:447]: PROPERTY CHANGE: Adding AI_DETECTED_SCREEN_RESOLUTION_X property. Its value is '3840'.
    MSI (c) (40!DC) [10:42:29:447]: PROPERTY CHANGE: Adding AI_DETECTED_SCREEN_RESOLUTION_Y property. Its value is '2160'.
    Action ended 10:42:29: AI_DetectSoftware. Return value 1.
    MSI (c) (40:B0) [10:42:29:449]: Skipping action: AI_RESTORE_AI_SETUPEXEPATH (condition is false)
    MSI (c) (40:B0) [10:42:29:449]: Doing action: AI_PRESERVE_INSTALL_TYPE
    Action 10:42:29: AI_PRESERVE_INSTALL_TYPE.
    Action start 10:42:29: AI_PRESERVE_INSTALL_TYPE.
    MSI (c) (40:4C) [10:42:29:457]: Invoking remote custom action. DLL: C:\Users\mtarr\AppData\Local\Temp\MSIC54D.tmp, Entrypoint: PreserveInstallType
    MSI (c) (40!E4) [10:42:29:466]: PROPERTY CHANGE: Adding ALLUSERS property. Its value is '1'.
    Action ended 10:42:29: AI_PRESERVE_INSTALL_TYPE. Return value 1.
    MSI (c) (40:B0) [10:42:29:467]: Doing action: FindRelatedProducts
    Action 10:42:29: FindRelatedProducts. Searching for related applications
    Action start 10:42:29: FindRelatedProducts.
    FindRelatedProducts: Found application: {B19C1C84-84DE-4FC1-8D78-9559FF7C3F81}
    MSI (c) (40:B0) [10:42:29:469]: PROPERTY CHANGE: Adding OLDPRODUCTS property. Its value is '{B19C1C84-84DE-4FC1-8D78-9559FF7C3F81}'.
    MSI (c) (40:B0) [10:42:29:469]: PROPERTY CHANGE: Adding MIGRATE property. Its value is '{B19C1C84-84DE-4FC1-8D78-9559FF7C3F81}'.
    Action ended 10:42:29: FindRelatedProducts. Return value 1.
    MSI (c) (40:B0) [10:42:29:470]: Skipping action: AI_DOWNGRADE (condition is false)
    MSI (c) (40:B0) [10:42:29:470]: Doing action: AI_IaLogMachineInfo
    Action 10:42:29: AI_IaLogMachineInfo.
    Action start 10:42:29: AI_IaLogMachineInfo.
    MSI (c) (40:48) [10:42:29:479]: Invoking remote custom action. DLL: C:\Users\mtarr\AppData\Local\Temp\MSIC55E.tmp, Entrypoint: OnAnalyticsLogMachineInfo
    Action ended 10:42:29: AI_IaLogMachineInfo. Return value 1.
    MSI (c) (40:B0) [10:42:29:523]: Doing action: LaunchConditions
    Action 10:42:29: LaunchConditions. Evaluating launch conditions
    Action start 10:42:29: LaunchConditions.
    Action ended 10:42:29: LaunchConditions. Return value 1.
    MSI (c) (40:B0) [10:42:29:525]: Doing action: AI_SETMIXINSTLOCATION
    Action 10:42:29: AI_SETMIXINSTLOCATION.
    Action start 10:42:29: AI_SETMIXINSTLOCATION.
    MSI (c) (40:DC) [10:42:29:534]: Invoking remote custom action. DLL: C:\Users\mtarr\AppData\Local\Temp\MSIC59D.tmp, Entrypoint: MixedAllUsersInstallLocation
    MSI (c) (40!A0) [10:42:29:542]: PROPERTY CHANGE: Adding AI_UserProgramFiles property. Its value is 'C:\Users\mtarr\AppData\Local\Programs\'.
    Action ended 10:42:29: AI_SETMIXINSTLOCATION. Return value 1.
    MSI (c) (40:B0) [10:42:29:544]: Doing action: AI_RESTORE_LOCATION
    Action 10:42:29: AI_RESTORE_LOCATION.
    Action start 10:42:29: AI_RESTORE_LOCATION.
    MSI (c) (40:7C) [10:42:29:552]: Invoking remote custom action. DLL: C:\Users\mtarr\AppData\Local\Temp\MSIC5AE.tmp, Entrypoint: RestoreLocation
    MSI (c) (40!7C) [10:42:29:561]: PROPERTY CHANGE: Adding APPDIR property. Its value is 'C:\Program Files\ADI\LTspice\'.
    Action ended 10:42:29: AI_RESTORE_LOCATION. Return value 1.
    MSI (c) (40:B0) [10:42:29:563]: Skipping action: SET_APPDIR (condition is false)
    MSI (c) (40:B0) [10:42:29:563]: Doing action: SET_SHORTCUTDIR
    Action 10:42:29: SET_SHORTCUTDIR.
    Action start 10:42:29: SET_SHORTCUTDIR.
    MSI (c) (40:B0) [10:42:29:564]: PROPERTY CHANGE: Adding SHORTCUTDIR property. Its value is 'C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\LTspice'.
    Action ended 10:42:29: SET_SHORTCUTDIR. Return value 1.
    MSI (c) (40:B0) [10:42:29:565]: Doing action: CostInitialize
    Action 10:42:29: CostInitialize. Computing space requirements
    Action start 10:42:29: CostInitialize.
    MSI (c) (40:B0) [10:42:29:566]: Machine policy value 'MaxPatchCacheSize' is 10
    MSI (c) (40:B0) [10:42:29:570]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'G:\'.
    MSI (c) (40:B0) [10:42:29:570]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
    Action ended 10:42:29: CostInitialize. Return value 1.
    MSI (c) (40:B0) [10:42:29:571]: Doing action: FileCost
    Action 10:42:29: FileCost. Computing space requirements
    Action start 10:42:29: FileCost.
    MSI (c) (40:B0) [10:42:29:572]: Note: 1: 2205 2:  3: MsiAssembly
    MSI (c) (40:B0) [10:42:29:572]: Note: 1: 2262 2: Class 3: -2147287038
    MSI (c) (40:B0) [10:42:29:572]: Note: 1: 2205 2:  3: TypeLib
    Action ended 10:42:29: FileCost. Return value 1.
    MSI (c) (40!D4) [10:42:29:575]: Note: 1: 2205 2:  3: AI_PreRequisite
    MSI (c) (40!D4) [10:42:29:575]: Note: 1: 2228 2:  3: AI_PreRequisite 4: SELECT `Options`,`Feature_`,`MissingCondition`,`DisplayName`,`PrereqKey`,`Sequence`,`InstallCondition` FROM `AI_PreRequisite`
    MSI (c) (40:B0) [10:42:29:595]: Doing action: CostFinalize
    Action 10:42:29: CostFinalize. Computing space requirements
    Action start 10:42:29: CostFinalize.
    MSI (c) (40:B0) [10:42:29:596]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
    MSI (c) (40:B0) [10:42:29:596]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
    MSI (c) (40:B0) [10:42:29:596]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
    MSI (c) (40:B0) [10:42:29:596]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
    MSI (c) (40:B0) [10:42:29:596]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
    MSI (c) (40:B0) [10:42:29:596]: Note: 1: 2262 2: Patch 3: -2147287038
    MSI (c) (40:B0) [10:42:29:597]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'G:\'.
    MSI (c) (40:B0) [10:42:29:597]: PROPERTY CHANGE: Adding LTspice_1_Dir property. Its value is 'C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\LTspice\'.
    MSI (c) (40:B0) [10:42:29:597]: PROPERTY CHANGE: Adding LTspice_2_Dir property. Its value is 'C:\Users\mtarr\AppData\Local\LTspice\'.
    MSI (c) (40:B0) [10:42:29:597]: PROPERTY CHANGE: Adding LTspiceHelp_Dir property. Its value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\'.
    MSI (c) (40:B0) [10:42:29:597]: PROPERTY CHANGE: Adding assets_Dir property. Its value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\assets\'.
    MSI (c) (40:B0) [10:42:29:597]: PROPERTY CHANGE: Adding js_Dir property. Its value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\assets\js\'.
    MSI (c) (40:B0) [10:42:29:597]: PROPERTY CHANGE: Adding css_Dir property. Its value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\assets\css\'.
    MSI (c) (40:B0) [10:42:29:597]: PROPERTY CHANGE: Adding images_Dir property. Its value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\assets\images\'.
    MSI (c) (40:B0) [10:42:29:597]: PROPERTY CHANGE: Adding math_Dir property. Its value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\assets\images\math\'.
    MSI (c) (40:B0) [10:42:29:597]: PROPERTY CHANGE: Adding lib_Dir property. Its value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\assets\images\lib\'.
    MSI (c) (40:B0) [10:42:29:597]: PROPERTY CHANGE: Adding whxdata_Dir property. Its value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\whxdata\'.
    MSI (c) (40:B0) [10:42:29:597]: PROPERTY CHANGE: Adding text_Dir property. Its value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\whxdata\text\'.
    MSI (c) (40:B0) [10:42:29:597]: PROPERTY CHANGE: Adding template_Dir property. Its value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\template\'.
    MSI (c) (40:B0) [10:42:29:597]: PROPERTY CHANGE: Adding styles_Dir property. Its value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\template\styles\'.
    MSI (c) (40:B0) [10:42:29:597]: PROPERTY CHANGE: Adding scripts_Dir property. Its value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\template\scripts\'.
    MSI (c) (40:B0) [10:42:29:597]: PROPERTY CHANGE: Adding images_1_Dir property. Its value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\template\images\'.
    MSI (c) (40:B0) [10:42:29:597]: PROPERTY CHANGE: Adding LTspice_Dir property. Its value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\template\LTspice\'.
    MSI (c) (40:B0) [10:42:29:597]: PROPERTY CHANGE: Adding __Dir property. Its value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\template\LTspice\2019\'.
    MSI (c) (40:B0) [10:42:29:597]: Target path resolution complete. Dumping Directory table...
    MSI (c) (40:B0) [10:42:29:597]: Note: target paths subject to change (via custom actions or browsing)
    MSI (c) (40:B0) [10:42:29:597]: Dir (target): Key: TARGETDIR	, Object: G:\
    MSI (c) (40:B0) [10:42:29:597]: Dir (target): Key: WindowsFolder	, Object: C:\windows\
    MSI (c) (40:B0) [10:42:29:597]: Dir (target): Key: SystemFolder	, Object: C:\windows\SysWOW64\
    MSI (c) (40:B0) [10:42:29:597]: Dir (target): Key: DesktopFolder	, Object: C:\Users\mtarr\Desktop\
    MSI (c) (40:B0) [10:42:29:597]: Dir (target): Key: ProgramMenuFolder	, Object: C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\
    MSI (c) (40:B0) [10:42:29:597]: Dir (target): Key: LTspice_1_Dir	, Object: C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\LTspice\
    MSI (c) (40:B0) [10:42:29:597]: Dir (target): Key: LocalAppDataFolder	, Object: C:\Users\mtarr\AppData\Local\
    MSI (c) (40:B0) [10:42:29:597]: Dir (target): Key: LTspice_2_Dir	, Object: C:\Users\mtarr\AppData\Local\LTspice\
    MSI (c) (40:B0) [10:42:29:597]: Dir (target): Key: APPDIR	, Object: C:\Program Files\ADI\LTspice\
    MSI (c) (40:B0) [10:42:29:597]: Dir (target): Key: LTspiceHelp_Dir	, Object: C:\Program Files\ADI\LTspice\LTspiceHelp\
    MSI (c) (40:B0) [10:42:29:597]: Dir (target): Key: assets_Dir	, Object: C:\Program Files\ADI\LTspice\LTspiceHelp\assets\
    MSI (c) (40:B0) [10:42:29:597]: Dir (target): Key: js_Dir	, Object: C:\Program Files\ADI\LTspice\LTspiceHelp\assets\js\
    MSI (c) (40:B0) [10:42:29:597]: Dir (target): Key: css_Dir	, Object: C:\Program Files\ADI\LTspice\LTspiceHelp\assets\css\
    MSI (c) (40:B0) [10:42:29:597]: Dir (target): Key: images_Dir	, Object: C:\Program Files\ADI\LTspice\LTspiceHelp\assets\images\
    MSI (c) (40:B0) [10:42:29:597]: Dir (target): Key: math_Dir	, Object: C:\Program Files\ADI\LTspice\LTspiceHelp\assets\images\math\
    MSI (c) (40:B0) [10:42:29:597]: Dir (target): Key: lib_Dir	, Object: C:\Program Files\ADI\LTspice\LTspiceHelp\assets\images\lib\
    MSI (c) (40:B0) [10:42:29:597]: Dir (target): Key: whxdata_Dir	, Object: C:\Program Files\ADI\LTspice\LTspiceHelp\whxdata\
    MSI (c) (40:B0) [10:42:29:597]: Dir (target): Key: text_Dir	, Object: C:\Program Files\ADI\LTspice\LTspiceHelp\whxdata\text\
    MSI (c) (40:B0) [10:42:29:597]: Dir (target): Key: template_Dir	, Object: C:\Program Files\ADI\LTspice\LTspiceHelp\template\
    MSI (c) (40:B0) [10:42:29:597]: Dir (target): Key: styles_Dir	, Object: C:\Program Files\ADI\LTspice\LTspiceHelp\template\styles\
    MSI (c) (40:B0) [10:42:29:597]: Dir (target): Key: scripts_Dir	, Object: C:\Program Files\ADI\LTspice\LTspiceHelp\template\scripts\
    MSI (c) (40:B0) [10:42:29:597]: Dir (target): Key: images_1_Dir	, Object: C:\Program Files\ADI\LTspice\LTspiceHelp\template\images\
    MSI (c) (40:B0) [10:42:29:597]: Dir (target): Key: LTspice_Dir	, Object: C:\Program Files\ADI\LTspice\LTspiceHelp\template\LTspice\
    MSI (c) (40:B0) [10:42:29:597]: Dir (target): Key: __Dir	, Object: C:\Program Files\ADI\LTspice\LTspiceHelp\template\LTspice\2019\
    MSI (c) (40:B0) [10:42:29:597]: Note: 1: 2205 2:  3: MsiAssembly
    MSI (c) (40:B0) [10:42:29:597]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
    MSI (c) (40:B0) [10:42:29:989]: Allowing installation of component: {2386C15C-A94F-428D-9DEB-5732F9051F6D} even though a modified unversioned keyfile exists and file versioning rules would disable the component
    MSI (c) (40:B0) [10:42:29:990]: Allowing installation of component: {053C271A-84E0-4B4C-8834-71D8FF477983} even though a modified unversioned keyfile exists and file versioning rules would disable the component
    MSI (c) (40:B0) [10:42:29:992]: Allowing installation of component: {FC96FA67-16FB-4D7F-9AF1-1F48D32BC4CC} even though a modified unversioned keyfile exists and file versioning rules would disable the component
    MSI (c) (40:B0) [10:42:29:992]: Allowing installation of component: {67AF4F7A-C3E8-46FB-99DA-2FEA24AFE5E4} even though a modified unversioned keyfile exists and file versioning rules would disable the component
    Action ended 10:42:29: CostFinalize. Return value 1.
    MSI (c) (40:B0) [10:42:29:999]: Doing action: MigrateFeatureStates
    Action 10:42:29: MigrateFeatureStates. Migrating feature states from related applications
    Action start 10:42:30: MigrateFeatureStates.
    MSI (c) (40:B0) [10:42:30:002]: Migrating feature settings from product(s) '{B19C1C84-84DE-4FC1-8D78-9559FF7C3F81}'
    MSI (c) (40:B0) [10:42:30:002]: MigrateFeatureStates: based on existing product, setting feature 'Libraries' to 'Local' state.
    MSI (c) (40:B0) [10:42:30:002]: Allowing installation of component: {67AF4F7A-C3E8-46FB-99DA-2FEA24AFE5E4} even though a modified unversioned keyfile exists and file versioning rules would disable the component
    MSI (c) (40:B0) [10:42:30:003]: Allowing installation of component: {FC96FA67-16FB-4D7F-9AF1-1F48D32BC4CC} even though a modified unversioned keyfile exists and file versioning rules would disable the component
    MSI (c) (40:B0) [10:42:30:003]: Allowing installation of component: {053C271A-84E0-4B4C-8834-71D8FF477983} even though a modified unversioned keyfile exists and file versioning rules would disable the component
    MSI (c) (40:B0) [10:42:30:003]: Allowing installation of component: {2386C15C-A94F-428D-9DEB-5732F9051F6D} even though a modified unversioned keyfile exists and file versioning rules would disable the component
    MSI (c) (40:B0) [10:42:30:018]: MigrateFeatureStates: based on existing product, setting feature 'Feature' to 'Local' state.
    MSI (c) (40:B0) [10:42:30:212]: MigrateFeatureStates: based on existing product, setting feature 'LTspice' to 'Local' state.
    Action ended 10:42:30: MigrateFeatureStates. Return value 1.
    MSI (c) (40:B0) [10:42:30:214]: Doing action: AI_ModalDialogs
    Action 10:42:30: AI_ModalDialogs.
    Action start 10:42:30: AI_ModalDialogs.
    MSI (c) (40:A4) [10:42:30:223]: Invoking remote custom action. DLL: C:\Users\mtarr\AppData\Local\Temp\MSIC84F.tmp, Entrypoint: ModalDialogs
    MSI (c) (40!08) [10:42:30:251]: PROPERTY CHANGE: Adding AiModalDialogInProgress property. Its value is '1'.
    MSI (c) (40!08) [10:42:30:251]: Doing action: WelcomeDlg
    Action 10:42:30: WelcomeDlg.
    Action start 10:42:30: WelcomeDlg.
    MSI (c) (40!D4) [10:42:30:261]: Note: 1: 2205 2:  3: AI_ControlEx
    MSI (c) (40!D4) [10:42:30:261]: Note: 1: 2228 2:  3: AI_ControlEx 4: SELECT `Dialog_`,`Control`,`Type`,`Parent`,`Attributes`,`Data` FROM `AI_ControlEx` WHERE `Dialog_` = 'WelcomeDlg'
    MSI (c) (40!D4) [10:42:33:249]: Note: 1: 2205 2:  3: AI_ControlEx
    MSI (c) (40!D4) [10:42:33:249]: Note: 1: 2228 2:  3: AI_ControlEx 4: SELECT `Dialog_`,`Control`,`Type`,`Parent`,`Attributes`,`Data` FROM `AI_ControlEx` WHERE `Dialog_` = 'LicenseAgreementDlg'
    MSI (c) (40!D4) [10:42:35:712]: PROPERTY CHANGE: Modifying IAgree property. Its current value is 'No'. Its new value: 'Yes'.
    MSI (c) (40!D4) [10:42:38:610]: PROPERTY CHANGE: Modifying AI_IA_ENABLE property. Its current value is '0'. Its new value: '1'.
    MSI (c) (40!D4) [10:42:38:621]: Note: 1: 2205 2:  3: AI_ControlEx
    MSI (c) (40!D4) [10:42:38:621]: Note: 1: 2228 2:  3: AI_ControlEx 4: SELECT `Dialog_`,`Control`,`Type`,`Parent`,`Attributes`,`Data` FROM `AI_ControlEx` WHERE `Dialog_` = 'ReadmeDlg'
    MSI (c) (40!D4) [10:42:40:626]: Note: 1: 2205 2:  3: AI_ControlEx
    MSI (c) (40!D4) [10:42:40:626]: Note: 1: 2228 2:  3: AI_ControlEx 4: SELECT `Dialog_`,`Control`,`Type`,`Parent`,`Attributes`,`Data` FROM `AI_ControlEx` WHERE `Dialog_` = 'InstallTypeDlg'
    MSI (c) (40!D4) [10:42:45:285]: PROPERTY CHANGE: Modifying AI_INSTALLPERUSER property. Its current value is '0'. Its new value: '1'.
    MSI (c) (40!D4) [10:42:45:286]: PROPERTY CHANGE: Adding AiDelayedActions property. Its value is ';DoMsiAction;AI_AuthorSinglePackage'.
    MSI (c) (40!D4) [10:42:45:288]: PROPERTY CHANGE: Modifying AiDelayedActions property. Its current value is ';DoMsiAction;AI_AuthorSinglePackage'. Its new value: ';DoMsiAction;AI_AuthorSinglePackage;DoMsiAction;InstallTypeDlg'.
    Action ended 10:42:45: WelcomeDlg. Return value 1.
    MSI (c) (40!08) [10:42:45:291]: PROPERTY CHANGE: Deleting AiDelayedActions property. Its current value is ';DoMsiAction;AI_AuthorSinglePackage;DoMsiAction;InstallTypeDlg'.
    MSI (c) (40!08) [10:42:45:291]: Doing action: AI_AuthorSinglePackage
    Action 10:42:45: AI_AuthorSinglePackage.
    Action start 10:42:45: AI_AuthorSinglePackage.
    MSI (c) (40:C4) [10:42:45:298]: Invoking remote custom action. DLL: C:\Users\mtarr\AppData\Local\Temp\MSI336.tmp, Entrypoint: AI_AuthorSinglePackage
    MSI (c) (40!FC) [10:42:45:312]: PROPERTY CHANGE: Deleting ALLUSERS property. Its current value is '1'.
    MSI (c) (40!FC) [10:42:45:312]: PROPERTY CHANGE: Deleting OLDPRODUCTS property. Its current value is '{B19C1C84-84DE-4FC1-8D78-9559FF7C3F81}'.
    MSI (c) (40!FC) [10:42:45:312]: PROPERTY CHANGE: Deleting MIGRATE property. Its current value is '{B19C1C84-84DE-4FC1-8D78-9559FF7C3F81}'.
    MSI (c) (40!FC) [10:42:45:312]: Doing action: FindRelatedProducts
    Action 10:42:45: FindRelatedProducts. Searching for related applications
    Action start 10:42:45: FindRelatedProducts.
    MSI (c) (40!FC) [10:42:45:314]: FindRelatedProducts: current install is per-user.  Related install for product '{B19C1C84-84DE-4FC1-8D78-9559FF7C3F81}' is per-machine.  Skipping...
    MSI (c) (40!FC) [10:42:45:315]: FindRelatedProducts: current install is per-user.  Related install for product '{B19C1C84-84DE-4FC1-8D78-9559FF7C3F81}' is per-machine.  Skipping...
    Action ended 10:42:45: FindRelatedProducts. Return value 1.
    MSI (c) (40!FC) [10:42:45:315]: Doing action: MigrateFeatureStates
    Action 10:42:45: MigrateFeatureStates. Migrating feature states from related applications
    Action start 10:42:45: MigrateFeatureStates.
    Action ended 10:42:45: MigrateFeatureStates. Return value 0.
    MSI (c) (40!FC) [10:42:45:317]: Doing action: AI_SETMIXINSTLOCATION
    Action 10:42:45: AI_SETMIXINSTLOCATION.
    Action start 10:42:45: AI_SETMIXINSTLOCATION.
    MSI (c) (40:E0) [10:42:45:326]: Invoking remote custom action. DLL: C:\Users\mtarr\AppData\Local\Temp\MSI356.tmp, Entrypoint: MixedAllUsersInstallLocation
    Action ended 10:42:45: AI_SETMIXINSTLOCATION. Return value 1.
    MSI (c) (40!FC) [10:42:45:338]: PROPERTY CHANGE: Deleting APPDIR property. Its current value is 'C:\Program Files\ADI\LTspice\'.
    MSI (c) (40!FC) [10:42:45:338]: Doing action: AI_RESTORE_LOCATION
    Action 10:42:45: AI_RESTORE_LOCATION.
    Action start 10:42:45: AI_RESTORE_LOCATION.
    MSI (c) (40:3C) [10:42:45:346]: Invoking remote custom action. DLL: C:\Users\mtarr\AppData\Local\Temp\MSI367.tmp, Entrypoint: RestoreLocation
    Action ended 10:42:45: AI_RESTORE_LOCATION. Return value 1.
    MSI (c) (40!FC) [10:42:45:363]: PROPERTY CHANGE: Adding APPDIR property. Its value is 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice'.
    MSI (c) (40!FC) [10:42:45:364]: PROPERTY CHANGE: Modifying APPDIR property. Its current value is 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice'. Its new value: 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\'.
    MSI (c) (40!FC) [10:42:45:365]: PROPERTY CHANGE: Modifying LTspiceHelp_Dir property. Its current value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\'. Its new value: 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\'.
    MSI (c) (40!FC) [10:42:45:365]: PROPERTY CHANGE: Modifying assets_Dir property. Its current value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\assets\'. Its new value: 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\'.
    MSI (c) (40!FC) [10:42:45:365]: PROPERTY CHANGE: Modifying js_Dir property. Its current value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\assets\js\'. Its new value: 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\js\'.
    MSI (c) (40!FC) [10:42:45:366]: PROPERTY CHANGE: Modifying css_Dir property. Its current value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\assets\css\'. Its new value: 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\css\'.
    MSI (c) (40!FC) [10:42:45:366]: PROPERTY CHANGE: Modifying images_Dir property. Its current value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\assets\images\'. Its new value: 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\'.
    MSI (c) (40!FC) [10:42:45:366]: PROPERTY CHANGE: Modifying math_Dir property. Its current value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\assets\images\math\'. Its new value: 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\math\'.
    MSI (c) (40!FC) [10:42:45:366]: PROPERTY CHANGE: Modifying lib_Dir property. Its current value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\assets\images\lib\'. Its new value: 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\'.
    MSI (c) (40!FC) [10:42:45:368]: PROPERTY CHANGE: Modifying whxdata_Dir property. Its current value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\whxdata\'. Its new value: 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\'.
    MSI (c) (40!FC) [10:42:45:371]: PROPERTY CHANGE: Modifying text_Dir property. Its current value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\whxdata\text\'. Its new value: 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\'.
    MSI (c) (40!FC) [10:42:45:371]: PROPERTY CHANGE: Modifying template_Dir property. Its current value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\template\'. Its new value: 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\'.
    MSI (c) (40!FC) [10:42:45:371]: PROPERTY CHANGE: Modifying styles_Dir property. Its current value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\template\styles\'. Its new value: 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\styles\'.
    MSI (c) (40!FC) [10:42:45:371]: PROPERTY CHANGE: Modifying scripts_Dir property. Its current value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\template\scripts\'. Its new value: 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\scripts\'.
    MSI (c) (40!FC) [10:42:45:371]: PROPERTY CHANGE: Modifying images_1_Dir property. Its current value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\template\images\'. Its new value: 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\images\'.
    MSI (c) (40!FC) [10:42:45:372]: PROPERTY CHANGE: Modifying LTspice_Dir property. Its current value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\template\LTspice\'. Its new value: 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\'.
    MSI (c) (40!FC) [10:42:45:372]: PROPERTY CHANGE: Modifying __Dir property. Its current value is 'C:\Program Files\ADI\LTspice\LTspiceHelp\template\LTspice\2019\'. Its new value: 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\2019\'.
    MSI (c) (40!FC) [10:42:45:373]: Note: 1: 2727 2: SHORTCUTDIR
    MSI (c) (40!FC) [10:42:45:373]: PROPERTY CHANGE: Modifying ProgramMenuFolder property. Its current value is 'C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\'. Its new value: 'C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs'.
    MSI (c) (40!FC) [10:42:45:373]: PROPERTY CHANGE: Adding ALLUSERS property. Its value is '2'.
    Action ended 10:42:45: AI_AuthorSinglePackage. Return value 1.
    MSI (c) (40!08) [10:42:45:377]: Doing action: InstallTypeDlg
    Action 10:42:45: InstallTypeDlg.
    Action start 10:42:45: InstallTypeDlg.
    MSI (c) (40!D4) [10:42:45:388]: PROPERTY CHANGE: Adding AI_ButtonText_Next_Orig property. Its value is '&Next >'.
    MSI (c) (40!D4) [10:42:45:388]: PROPERTY CHANGE: Modifying ButtonText_Next property. Its current value is '&Next >'. Its new value: '&Install'.
    MSI (c) (40!D4) [10:42:45:389]: PROPERTY CHANGE: Adding AI_Text_Next_Orig property. Its value is 'Next'.
    MSI (c) (40!D4) [10:42:45:390]: PROPERTY CHANGE: Modifying Text_Next property. Its current value is 'Next'. Its new value: 'Install'.
    MSI (c) (40!D4) [10:42:45:391]: PROPERTY CHANGE: Adding CustomActionData property. Its value is 'Libraries'.
    MSI (c) (40!D4) [10:42:45:392]: PROPERTY CHANGE: Adding AiDelayedActions property. Its value is ';DoMsiAction;UpdateFeaturesInstallStates'.
    MSI (c) (40!D4) [10:42:45:393]: PROPERTY CHANGE: Modifying AiDelayedActions property. Its current value is ';DoMsiAction;UpdateFeaturesInstallStates'. Its new value: ';DoMsiAction;UpdateFeaturesInstallStates;DoMsiAction;InstallTypeDlg'.
    Action ended 10:42:45: InstallTypeDlg. Return value 1.
    MSI (c) (40!08) [10:42:45:395]: PROPERTY CHANGE: Deleting AiDelayedActions property. Its current value is ';DoMsiAction;UpdateFeaturesInstallStates;DoMsiAction;InstallTypeDlg'.
    MSI (c) (40!08) [10:42:45:395]: Doing action: UpdateFeaturesInstallStates
    Action 10:42:45: UpdateFeaturesInstallStates.
    Action start 10:42:45: UpdateFeaturesInstallStates.
    MSI (c) (40:58) [10:42:45:404]: Invoking remote custom action. DLL: C:\Users\mtarr\AppData\Local\Temp\MSI3A6.tmp, Entrypoint: UpdateFeatureStates
    Action ended 10:42:45: UpdateFeaturesInstallStates. Return value 1.
    MSI (c) (40!08) [10:42:45:418]: Doing action: InstallTypeDlg
    MSI (c) (40!D4) [10:42:45:437]: Note: 1: 2205 2:  3: AI_ControlEx
    MSI (c) (40!D4) [10:42:45:437]: Note: 1: 2228 2:  3: AI_ControlEx 4: SELECT `Dialog_`,`Control`,`Type`,`Parent`,`Attributes`,`Data` FROM `AI_ControlEx` WHERE `Dialog_` = 'FolderDlg'
    MSI (c) (40!D4) [10:46:35:199]: PROPERTY CHANGE: Adding AiDelayedActions property. Its value is 'SetTargetPath;APPDIR;C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\'.
    MSI (c) (40!D4) [10:46:35:199]: PROPERTY CHANGE: Modifying AiDelayedActions property. Its current value is 'SetTargetPath;APPDIR;C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\'. Its new value: 'SetTargetPath;APPDIR;C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\;DoMsiAction;FolderDlg'.
    Action ended 10:46:35: InstallTypeDlg. Return value 1.
    MSI (c) (40!08) [10:46:35:204]: PROPERTY CHANGE: Deleting AiDelayedActions property. Its current value is 'SetTargetPath;APPDIR;C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\;DoMsiAction;FolderDlg'.
    MSI (c) (40!08) [10:46:35:204]: Doing action: FolderDlg
    Action 10:46:35: FolderDlg.
    Action start 10:46:35: FolderDlg.
    MSI (c) (40!D4) [10:46:35:213]: PROPERTY CHANGE: Adding AiDelayedActions property. Its value is ';DoMsiAction;InstallValidate'.
    MSI (c) (40!D4) [10:46:35:215]: PROPERTY CHANGE: Modifying AiDelayedActions property. Its current value is ';DoMsiAction;InstallValidate'. Its new value: ';DoMsiAction;InstallValidate;DoMsiAction;FolderDlg'.
    Action ended 10:46:35: FolderDlg. Return value 1.
    MSI (c) (40!08) [10:46:35:219]: PROPERTY CHANGE: Deleting AiDelayedActions property. Its current value is ';DoMsiAction;InstallValidate;DoMsiAction;FolderDlg'.
    MSI (c) (40!08) [10:46:35:219]: Doing action: InstallValidate
    Action 10:46:35: InstallValidate. Validating install
    Action start 10:46:35: InstallValidate.
    MSI (c) (40!08) [10:46:35:222]: Feature: LTspice; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Feature: Feature; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Feature: Libraries; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: LTspice; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: APPDIR; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc62.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: ProductInformation; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: AI_INSTALLPERUSER; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc56.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: LTspiceApplicationFiles; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: LTspice.exe; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc48.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: updater.exe; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc60.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: AI_IA_ENABLE; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: Remove.exe; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc68.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: Remove.txt; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: examples.zip; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: brsdata.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: lib.zip; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: ChangeLog.txt; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc59.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: aspecialfunctions.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: pcbnetlistextraction.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc66.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: hierarchy.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: datatraceselection.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc77.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: additionalresources.html; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: acperformansmallsignalacanalys.htm_1; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc71.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: commandlineswitches.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: assistedmode.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc7.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: inductormodels.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: addingattributes.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc75.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: parentdata.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: faq.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc92.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: plotpanes.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: attributevisibility.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc100.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: draftingoptions.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: howtogetabodeplotfromasmps.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc73.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: attachedcursors.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: addingthepins.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc49.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: automaticsymbolgeneration.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: netcomputenetworkparametersina.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: search_topics.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: customsymbols.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: axiscontrol.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: search_fv_0.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: operation.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: examplecircuits.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: search_auto_model_0.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: ddiode.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: runningunderlinux.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: search_ii_0.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: backannoannotatethesubcircuitp.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: barbitrarybehavioralvoltageorcur.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc10.new.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: basicschematicediting.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: ccapacitor.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: stopwords.xml; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: spice.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: circuitelements.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: search_ii_0.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: exportingwaveformdata.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: colorcontrol.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc1.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: savelimitthequantityofsaveddat.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: convergence.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc109.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: compression.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: creatingnewsymbols.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc103.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: dotkeep.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: loadbiasloadapreviouslysolvedd.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: whfts.xml; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: dcperformadcsourcesweepanalysi.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: navigatingthehierarchy.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc108.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: internetoptions.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: dotcommands.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc118.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: fra_probe.html; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: dotfra.html; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc4.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: drawingthebody.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: editingcomponents.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc105.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: efficiencycalculation.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: hacks.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc116.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: efficiencyreport.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: integrationmethods.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: endendofnetlist.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: fcurrentdependentcurrentsource.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: endsendofsubcircuitdefinition.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: uuniformrcline.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: evoltagedependentvoltagesource.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: expertmode.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: externallygeneratednetlists.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: fastaccessfileformat.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: fourcomputeafouriercomponent.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: fra_device.html; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: funcuserdefinedfunctions.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: generalpurposeschematicdrivenspi.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: generalstructureandconventions.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: globaldeclareglobalnodes.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: gvoltagedependentcurrentsource.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: hcurrentdependentvoltagesource.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: icsetinitialconditions.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: icurrentsource.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: step.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: includeincludeanotherfile.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: index.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: index.ppf; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: introduction.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: introduction1.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc23.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: jjfet.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: keyboardshortcuts.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc18.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: kmutualinductance.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: labelanodename.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: libincludealibrary.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: licenseagreementdisclaimer.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc21.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: xsubcircuit.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: startup.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc3.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: licenseanddistribution.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: linductor.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc25.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: loadstate.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: ltspice.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc2.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: machinearbitrarystatemachine.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: measureevaluateuserdefinedele.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc96.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: memoryproblems.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: mmosfet.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc36.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: modeldefineaspicemodel.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: modelcompatibility.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc30.new.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: modesofoperation.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: mosfetmodels.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc27.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: netlistoptions.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: nodesetsupplyhintsforinitialdc.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: toc34.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:222]: Component: nodiscard.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: noiseperformanoiseanalysis.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: toc44.new.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: olossytransmissionline.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: opfindthedcoperatingpoint.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: toc38.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: userdefinedfunctions.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: optionssetsimulatoroptions.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: toc32.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: paramuserdefinedparameters.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: placingcomponents.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: toc43.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: programupdates.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: projectdata.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: toc53.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: qbipolartransistor.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: rresistor.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: toc46.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: rulesofhierarchy.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: tlosslesstransmissionline.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: toc40.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: savebiassaveoperatingpointtodi.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: savedefaults.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: toc51.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: saveplotconfigurations.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: savestate.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: schematiccapture.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: edit2.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: schematiccolors.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: screendata.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: full_screen.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: search.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: settings.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: file.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: simulatingtransformers.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: softwareinstallation.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: Dark.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: thirdpartymodels.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: spicenetlist.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: filter_clearall.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: steady.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: stepparametersweeps.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: logo.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: subcktdefineasubcircuit.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: superexpertmode.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: Group56.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: svoltagecontrolledswitch.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: symbolandlibrarysearchpaths.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: filter2.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: temptemperaturesweeps.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: tffindthedcsmallsignaltransfe.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: homepagesaved.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: trandoanonlineartransientanaly.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: transientanalysisoptions.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: loading.gif; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: acperformansmallsignalacanalys.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: uic.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: index.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: universalopampmodels.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: vvoltagesource.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: Group9.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: waveformviewer.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: wavewriteselectednodestoawavfi.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: light.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: waveformarithmetic.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: waveforms.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: LTspiceArtBanner.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: wcurrentcontrolledswitch.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: zmesfetandigbt.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: logo.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: BarlowRegular.ttf; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: InterItalicVariableFont_opszwght.ttf; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: layout.css; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: BarlowRegular.ttf_1; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: BarlowSemiCondensedRegular.ttf; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: LTspiceArt1920_0609.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: default.css; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: chmRelative.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image11.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: ac_stepDB.png_1; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: menu.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: convergence_slide4_picture_8.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: convergence_slide3_picture_16.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: LTspice26LogoWhiteNoBackground.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: convergence_slide3_picture_17.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: dbMeasurementSchema.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image12.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image44.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image13.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image14.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image15.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image16.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image17.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image18.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image19.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image20.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image21.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image22.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image23.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image24.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: ac_stepDB.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image25.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image35.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image26.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image27.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image28.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image29.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image30.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image31.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image32.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: usersettings.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image33.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image36.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: homepage.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image37.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image38.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: layout.css_1; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image41.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image43.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: unsaved.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image46.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image47.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: cshredirect.js_1; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: image9.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: ResultsVsStepPlot.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: idata1.new.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: ResultsWSteps.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: compress.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: redirect.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: dB.png_1; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: AddTrace.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: topicpage.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: asymminor.gif; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: Capacitor.gif; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: csh.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: RMS.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: Att2Cur.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: toc120.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: BH.gif; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: vdmoscap.gif; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: toc11.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: ControlWaveform.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: CursRead.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: brsdata.js_1; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: CursStep.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: Ddnform.gif; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: idata1.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: diffprobe.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: Dupform.gif; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: toc112.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: EntrExpr.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: FFT.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: idx.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: Hierarch.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: Inductor.gif; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: toc128.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: modified_trap_problem_asc.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: modified_trap_principle.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: toc12.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: modified_trap_problem.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: dB.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: bmrk_unselect.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: modified_trap_problem_wave.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: MouseCursor.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: toc5.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: Navigate.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: porttype.gif; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: layoutconfig.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: ProbeWire.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: pwrProbe.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: brschleft.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: vbic.gif; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: savedflt.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: chup.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: spiceopt.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: vdmos.gif; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: collapse_toc.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: VisTrace.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: Voltage.gif; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: brschright.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: cbrt.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: cbrt.svg_1; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: chright.svg_2; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: hypot.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: dnlim.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: cross_selectpanel.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:223]: Component: sqrt.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: topic.min.css; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: collapseTOC.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: topic.min.css_1; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: chright.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: chleft.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: expand.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: chright.svg_1; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: cross.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: LoadingData.gif; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: Add_bookmarkmobile.svg_1; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: expand_toc.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: bmrk_select.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: chdown.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: darkglobe.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: expandTOC.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: download_pdf.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: edit.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: LTspiceArt3840SineTOC.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_136; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: homepagefilter2.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: LTspiceArt3840SineHeader.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js.gz_75; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: LTspiceArt1920_02.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: LTspiceArt1920_0207.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_140; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: homepage.ejs; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: LTspice300x200.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js.gz_79; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: collapse_all.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: LTspiceArt1920_0508.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: highlight.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: email.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js.gz_84; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: delete.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: dot.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_66; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: expand_all.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: facebook.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: filter.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: filter_clearall.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_73; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: frameless.skn; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: Group114.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_62; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc_default_tile.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: homepagefilter.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_81; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: homepageunsaved.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: homepage_background.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_69; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: LTspiceArt3840SineTools.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: layout.css.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_89; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: linkedin.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: loading_spinner.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_77; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: LTspice24LogoWhiteNoBackground.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: LTspiceArt1920_05.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_96; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: LTspiceArt1920_06.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: LTspiceArt.jpg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_85; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: page_up.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: print.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: read_aloud.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: read_aloud2.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: regular_screen.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: userstyles.css; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: saved.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: saved2.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: searchpagenext.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: searchpageprev.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: search.htm_1; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: search.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: share.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: tocimg1.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: tocimg2.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: tocimg3.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: Add_bookmarkmobile.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: tocimg4.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: tocimg5.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: tocimg6.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: tocimg7.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: tocimg8.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc_default_tile.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: topicpage.ejs; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: twitter.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: usersettings.ejs; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js.gz_62; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: usersettings.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: compatibility.css; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: compatibility.css_1; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: cshredirect.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: topicpage.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_121; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: cshredirect.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: homepage.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js.gz_60; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc41.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc111.new.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js.gz_70; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc57.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc90.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js.gz_64; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: glo.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: gdata1.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js.gz_73; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc107.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: layoutconfig.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_123; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc122.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_132; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: projectsettings.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: projectsettings.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_127; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: search_auto_index.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: search_auto_map_0.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_15; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: search_auto_map_0.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc121.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_7; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: search_auto_model_0.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: search_db.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_21; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: search_fv_0.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc102.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_12; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc114.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: search_topics.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js.gz_9; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: synonym.xml; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc.new.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_18; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc10.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc101.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_30; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc104.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc106.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_24; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc97.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc110.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc111.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc113.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc115.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_29; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc117.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc119.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc122.new.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc123.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc124.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc125.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc126.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc70.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc127.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc129.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc13.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc130.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc131.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc132.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc55.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc133.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc134.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc135.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc136.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc137.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc138.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc139.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc14.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc15.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc16.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc17.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_51; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc19.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc20.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_44; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc22.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc24.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js.gz_37; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc26.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc28.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js.gz_31; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc29.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc30.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js.gz_42; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc31.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc33.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js.gz_35; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc35.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc37.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_61; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc39.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc42.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_56; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc44.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc45.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc86.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc47.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc50.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_59; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc52.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc54.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc91.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc58.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc6.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc80.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc61.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc63.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_4; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc64.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc65.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc87.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc67.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc69.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_10; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc72.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc74.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc98.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc76.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc78.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc79.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc8.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc81.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc82.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc83.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc84.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc84.new.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc85.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc88.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc89.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc9.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc93.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc94.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc95.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: toc99.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:224]: Component: js_2; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_3; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_5; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_6; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_1; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_8; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_9; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_2; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_3; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_11; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_4; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_13; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_14; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_16; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_5; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_17; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_19; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_6; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_20; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_22; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_7; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_23; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_25; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_26; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_8; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_27; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_28; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_10; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_11; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_12; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_13; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_14; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_15; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_31; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_32; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_16; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_33; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_17; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_34; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_18; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_35; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_19; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_20; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_21; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_36; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_22; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_37; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_38; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_23; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_39; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_40; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_41; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_24; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_25; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_42; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_26; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_43; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_27; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_45; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_46; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_28; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_29; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_47; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_30; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_48; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_49; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_50; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_32; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_33; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_34; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_52; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_53; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_36; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_54; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_38; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_55; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_39; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_40; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_57; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_41; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_58; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_43; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_44; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_45; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_46; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_60; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_47; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_48; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_63; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_64; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_65; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_67; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_49; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_68; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_70; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_71; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_72; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_74; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_75; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_76; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_78; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_79; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_80; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_82; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_83; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_84; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_86; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_87; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_88; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_90; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_50; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_91; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_92; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_93; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_94; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_95; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_97; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_51; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_98; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_99; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_100; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_101; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_102; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_52; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_103; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_104; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_53; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_105; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_106; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_107; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_54; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_108; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_109; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_110; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_55; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_111; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_112; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_56; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_113; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_57; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_114; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_58; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_59; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_115; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_61; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_116; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_117; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_63; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_118; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_119; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_65; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_120; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_66; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_67; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_122; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_68; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_69; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_124; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_125; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_126; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_71; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_72; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_128; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_129; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_74; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_130; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_76; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_131; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_77; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_78; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_133; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_134; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_135; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_80; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_81; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_82; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_137; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_83; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_138; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js.gz_85; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: js_139; Installed: Absent;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: __LTspice.exe65; Installed: Null;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: __LTspice.exe66; Installed: Null;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: __updater.exe65; Installed: Null;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: __AI_INSTALLPERUSER65; Installed: Null;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: __AI_IA_ENABLE65; Installed: Null;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: __ProductInformation65; Installed: Null;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Component: __LTspice.exe67; Installed: Null;   Request: Local;   Action: Local
    MSI (c) (40!08) [10:46:35:225]: Note: 1: 2205 2:  3: BindImage
    MSI (c) (40!08) [10:46:35:225]: Note: 1: 2205 2:  3: PublishComponent
    MSI (c) (40!08) [10:46:35:225]: Note: 1: 2205 2:  3: SelfReg
    MSI (c) (40!08) [10:46:35:225]: Note: 1: 2205 2:  3: Font
    MSI (c) (40!08) [10:46:35:225]: Note: 1: 2262 2: Class 3: -2147287038
    MSI (c) (40!08) [10:46:35:225]: Note: 1: 2205 2:  3: TypeLib
    MSI (c) (40!08) [10:46:35:236]: Note: 1: 2205 2:  3: _RemoveFilePath
    MSI (c) (40!08) [10:46:35:236]: Note: 1: 2205 2:  3: MsiFileHash
    MSI (c) (40!08) [10:46:35:606]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\.1 3: 2
    MSI (c) (40!08) [10:46:35:607]: Note: 1: 2262 2: Class 3: -2147287038
    MSI (c) (40!08) [10:46:35:608]: Note: 1: 2262 2: Class 3: -2147287038
    MSI (c) (40!08) [10:46:35:609]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
    MSI (c) (40!08) [10:46:35:609]: Note: 1: 2205 2:  3: BindImage
    MSI (c) (40!08) [10:46:35:609]: Note: 1: 2205 2:  3: PublishComponent
    MSI (c) (40!08) [10:46:35:609]: Note: 1: 2205 2:  3: SelfReg
    MSI (c) (40!08) [10:46:35:609]: Note: 1: 2205 2:  3: Font
    MSI (c) (40!08) [10:46:35:609]: Note: 1: 2262 2: Class 3: -2147287038
    MSI (c) (40!08) [10:46:35:609]: Note: 1: 2205 2:  3: TypeLib
    MSI (c) (40!08) [10:46:35:609]: PROPERTY CHANGE: Modifying PrimaryVolumeSpaceAvailable property. Its current value is '0'. Its new value: '998284360'.
    MSI (c) (40!08) [10:46:35:609]: PROPERTY CHANGE: Modifying PrimaryVolumeSpaceRequired property. Its current value is '0'. Its new value: '993647'.
    MSI (c) (40!08) [10:46:35:609]: PROPERTY CHANGE: Modifying PrimaryVolumeSpaceRemaining property. Its current value is '0'. Its new value: '997290713'.
    MSI (c) (40!08) [10:46:35:609]: PROPERTY CHANGE: Adding PrimaryVolumePath property. Its value is 'C:'.
    Action ended 10:46:35: InstallValidate. Return value 1.
    MSI (c) (40!08) [10:46:35:612]: Doing action: FolderDlg
    Action 10:46:35: FolderDlg.
    Action start 10:46:35: FolderDlg.
    Action ended 10:46:35: FolderDlg. Return value 1.
    MSI (c) (40!08) [10:46:35:620]: PROPERTY CHANGE: Deleting AiModalDialogInProgress property. Its current value is '1'.
    MSI (c) (40!08) [10:46:35:620]: PROPERTY CHANGE: Adding ModalPerformed property. Its value is 'WelcomeDlg'.
    Action ended 10:46:35: AI_ModalDialogs. Return value 1.
    MSI (c) (40:B0) [10:46:35:622]: Doing action: WelcomeDlg
    Action 10:46:35: WelcomeDlg.
    Action start 10:46:35: WelcomeDlg.
    Action ended 10:46:35: WelcomeDlg. Return value 1.
    MSI (c) (40:B0) [10:46:35:625]: Skipping action: ResumeDlg (condition is false)
    MSI (c) (40:B0) [10:46:35:625]: Skipping action: MaintenanceWelcomeDlg (condition is false)
    MSI (c) (40:B0) [10:46:35:625]: Skipping action: PatchWelcomeDlg (condition is false)
    MSI (c) (40:B0) [10:46:35:625]: Doing action: ProgressDlg
    Action 10:46:35: ProgressDlg.
    Action start 10:46:35: ProgressDlg.
    MSI (c) (40!D4) [10:46:35:642]: Note: 1: 2205 2:  3: AI_ControlEx
    MSI (c) (40!D4) [10:46:35:642]: Note: 1: 2228 2:  3: AI_ControlEx 4: SELECT `Dialog_`,`Control`,`Type`,`Parent`,`Attributes`,`Data` FROM `AI_ControlEx` WHERE `Dialog_` = 'ProgressDlg'
    Action ended 10:46:35: ProgressDlg. Return value 1.
    MSI (c) (40:B0) [10:46:35:671]: Doing action: ExecuteAction
    Action 10:46:35: ExecuteAction.
    Action start 10:46:35: ExecuteAction.
    MSI (c) (40:B0) [10:46:35:673]: PROPERTY CHANGE: Adding SECONDSEQUENCE property. Its value is '1'.
    MSI (c) (40:B0) [10:46:35:673]: Grabbed execution mutex.
    MSI (c) (40:B0) [10:46:35:673]: Incrementing counter to disable shutdown. Counter after increment: 0
    MSI (c) (40:B0) [10:46:35:674]: Switching to server: APPDIR="C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\" AI_IA_ENABLE="1" TARGETDIR="G:\" AI_INSTALL="1" SHORTCUTDIR="C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\LTspice" MSICLIENTUSESEMBEDDEDUI="1" CURRENTDIRECTORY="C:\Windows\SysWOW64" CLIENTUILEVEL="0" CLIENTPROCESSID="7488" USERNAME="mtarr00@yahoo.com" COMPANYNAME="mmc" AIEXTERNALUI="1" CHAINERUIPROCESSID="17712Chainer" AI_CLIENTPROCESSID="17712" PRIMARYFOLDER="APPDIR" AI_HWND_EUI="200128" AI_SYSTEM_DPI="144" AI_SYSTEM_DPI_SCALE="150" SOURCEDIR="E:\LT Spice\Installer 2026-08-24  v26.0.2\" ACTION="INSTALL" EXECUTEACTION="INSTALL" IS_WINE="0" AI_DETECTED_DOTNET_CORE_VERSION="8.0" AI_DETECTED_DOTNET_CORE32_VERSION="8.0" AI_DETECTED_DOTNET_CORE64_VERSION="8.0" AI_DETECTED_DOTNET_VERSION="4.8.1" AI_DETECTED_IE_VERSION="11.0" AI_DETECTED_DIRECTX_VERSION="12" AI_DETECTED_SQLSERVER_ODBCDRIVER_VERSION="09.0" AI_DETECTED_SQLSERVER_ODBCDRIVER9_VERSION="09.0" AI_DETECTED_VSTO_VERSION="4.0" AI_DETECTED_WINDOWS_POWERSHELL_VERSION="5.1" AI_DETECTED_POWERSHELL_VERS
    MSI (c) (40:58) [10:46:35:691]: Cloaking enabled.
    MSI (c) (40:58) [10:46:35:691]: Attempting to enable all disabled privileges before calling Install on Server
    MSI (c) (40:58) [10:46:35:692]: EEUI Directory path does not have a delete permissions by client process: C:\Users\mtarr\AppData\Local\Temp\MSI21813
    MSI (c) (40:58) [10:46:35:692]: EEUI - Unable to send CA details to server
    MSI (s) (C8:78) [10:46:35:689]: Running installation inside multi-package transaction E:\LT Spice\Installer 2026-08-24  v26.0.2\LTspice64.msi
    MSI (s) (C8:78) [10:46:35:689]: Grabbed execution mutex.
    MSI (s) (C8:F8) [10:46:35:691]: Running as a service.
    MSI (s) (C8:20) [10:46:35:696]: Resetting cached policy values
    MSI (s) (C8:20) [10:46:35:696]: Machine policy value 'Debug' is 0
    MSI (s) (C8:20) [10:46:35:696]: ******* RunEngine:
               ******* Product: E:\LT Spice\Installer 2026-08-24  v26.0.2\LTspice64.msi
               ******* Action: INSTALL
               ******* CommandLine: **********
    MSI (s) (C8:20) [10:46:35:697]: Machine policy value 'DisableUserInstalls' is 0
    MSI (s) (C8:20) [10:46:35:723]: Note: 1: 2203 2: C:\windows\Installer\inprogressinstallinfo.ipi 3: -2147287038
    MSI (s) (C8:20) [10:46:35:725]: Machine policy value 'LimitSystemRestoreCheckpointing' is 0
    MSI (s) (C8:20) [10:46:35:725]: Note: 1: 1715 2: LTspice
    MSI (s) (C8:20) [10:46:35:725]: Calling SRSetRestorePoint API. dwRestorePtType: 0, dwEventType: 102, llSequenceNumber: 0, szDescription: "Installed LTspice".
    MSI (s) (C8:20) [10:46:46:873]: The call to SRSetRestorePoint API succeeded. Returned status: 0, llSequenceNumber: 230.
    MSI (s) (C8:20) [10:46:46:873]: Access database with Impersonation
    MSI (s) (C8:20) [10:46:46:875]: File will have security applied from OpCode.
    MSI (s) (C8:20) [10:46:47:141]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'E:\LT Spice\Installer 2026-08-24  v26.0.2\LTspice64.msi' against software restriction policy
    MSI (s) (C8:20) [10:46:47:142]: SOFTWARE RESTRICTION POLICY: E:\LT Spice\Installer 2026-08-24  v26.0.2\LTspice64.msi has a digital signature
    MSI (s) (C8:20) [10:46:47:410]: SOFTWARE RESTRICTION POLICY: E:\LT Spice\Installer 2026-08-24  v26.0.2\LTspice64.msi is permitted to run at the 'unrestricted' authorization level.
    MSI (s) (C8:20) [10:46:47:410]: MSCOREE not loaded loading copy from system32
    MSI (s) (C8:20) [10:46:47:418]: End dialog not enabled
    MSI (s) (C8:20) [10:46:47:418]: Original package ==> E:\LT Spice\Installer 2026-08-24  v26.0.2\LTspice64.msi
    MSI (s) (C8:20) [10:46:47:418]: Package we're running from ==> C:\windows\Installer\77b2d2.msi
    MSI (s) (C8:20) [10:46:47:422]: APPCOMPAT: Compatibility mode property overrides found.
    MSI (s) (C8:20) [10:46:47:423]: APPCOMPAT: looking for appcompat database entry with ProductCode '{CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B}'.
    MSI (s) (C8:20) [10:46:47:423]: APPCOMPAT: no matching ProductCode found in database.
    MSI (s) (C8:20) [10:46:47:435]: Machine policy value 'TransformsSecure' is 0
    MSI (s) (C8:20) [10:46:47:435]: User policy value 'TransformsAtSource' is 0
    MSI (s) (C8:20) [10:46:47:436]: Note: 1: 2205 2:  3: MsiFileHash
    MSI (s) (C8:20) [10:46:47:436]: Machine policy value 'DisablePatch' is 0
    MSI (s) (C8:20) [10:46:47:436]: Machine policy value 'AllowLockdownPatch' is 0
    MSI (s) (C8:20) [10:46:47:436]: Machine policy value 'DisableMsi' is 0
    MSI (s) (C8:20) [10:46:47:436]: Machine policy value 'AlwaysInstallElevated' is 0
    MSI (s) (C8:20) [10:46:47:436]: User policy value 'AlwaysInstallElevated' is 0
    MSI (s) (C8:20) [10:46:47:436]: Running product '{CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B}' with user privileges: It's not assigned.
    MSI (s) (C8:20) [10:46:47:436]: Machine policy value 'DisableLUAPatching' is 0
    MSI (s) (C8:20) [10:46:47:437]: Machine policy value 'DisableFlyWeightPatching' is 0
    MSI (s) (C8:20) [10:46:47:440]: APPCOMPAT: looking for appcompat database entry with ProductCode '{CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B}'.
    MSI (s) (C8:20) [10:46:47:440]: APPCOMPAT: no matching ProductCode found in database.
    MSI (s) (C8:20) [10:46:47:453]: Transforms are not secure.
    MSI (s) (C8:20) [10:46:47:454]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Logs\InstallerLog.log'.
    MSI (s) (C8:20) [10:46:47:454]: Command Line: APPDIR=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\ AI_IA_ENABLE=1 TARGETDIR=G:\ AI_INSTALL=1 SHORTCUTDIR=C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\LTspice MSICLIENTUSESEMBEDDEDUI=1 CURRENTDIRECTORY=C:\Windows\SysWOW64 CLIENTUILEVEL=0 CLIENTPROCESSID=7488 USERNAME=mtarr00@yahoo.com COMPANYNAME=mmc AIEXTERNALUI=1 CHAINERUIPROCESSID=17712Chainer AI_CLIENTPROCESSID=17712 PRIMARYFOLDER=APPDIR AI_HWND_EUI=200128 AI_SYSTEM_DPI=144 AI_SYSTEM_DPI_SCALE=150 SOURCEDIR=E:\LT Spice\Installer 2026-08-24  v26.0.2\ ACTION=INSTALL EXECUTEACTION=INSTALL IS_WINE=0 AI_DETECTED_DOTNET_CORE_VERSION=8.0 AI_DETECTED_DOTNET_CORE32_VERSION=8.0 AI_DETECTED_DOTNET_CORE64_VERSION=8.0 AI_DETECTED_DOTNET_VERSION=4.8.1 AI_DETECTED_IE_VERSION=11.0 AI_DETECTED_DIRECTX_VERSION=12 AI_DETECTED_SQLSERVER_ODBCDRIVER_VERSION=09.0 AI_DETECTED_SQLSERVER_ODBCDRIVER9_VERSION=09.0 AI_DETECTED_VSTO_VERSION=4.0 AI_DETECTED_WINDOWS_POWERSHELL_VERSION=5.1 AI_DETECTED_POWERSHELL_VERSION=7.2 AI_DETECTED_POWERSHELL32_VERSION=7.2 AI_DETECTED_POWERSHELL64_V
    MSI (s) (C8:20) [10:46:47:454]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{39C828E8-EBEA-41FF-AC38-4A5921DF2236}'.
    MSI (s) (C8:20) [10:46:47:454]: Product Code passed to Engine.Initialize:           ''
    MSI (s) (C8:20) [10:46:47:454]: Product Code from property table before transforms: '{CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B}'
    MSI (s) (C8:20) [10:46:47:454]: Product Code from property table after transforms:  '{CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B}'
    MSI (s) (C8:20) [10:46:47:454]: Product not registered: beginning first-time install
    MSI (s) (C8:20) [10:46:47:454]: PROPERTY CHANGE: Deleting ALLUSERS property. Its current value is '2'.
    MSI (s) (C8:20) [10:46:47:454]: Product {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} is not managed.
    MSI (s) (C8:20) [10:46:47:455]: Machine policy value 'AlwaysInstallElevated' is 0
    MSI (s) (C8:20) [10:46:47:455]: User policy value 'AlwaysInstallElevated' is 0
    MSI (s) (C8:20) [10:46:47:455]: MSI_LUA: Package is a dual mode package and is being installed in Per-User mode. No elevation is required.
    MSI (s) (C8:20) [10:46:47:455]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
    MSI (s) (C8:20) [10:46:47:455]: Entering CMsiConfigurationManager::SetLastUsedSource.
    MSI (s) (C8:20) [10:46:47:455]: User policy value 'SearchOrder' is 'nmu'
    MSI (s) (C8:20) [10:46:47:455]: Adding new sources is allowed.
    MSI (s) (C8:20) [10:46:47:455]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
    MSI (s) (C8:20) [10:46:47:455]: Package name extracted from package path: 'LTspice64.msi'
    MSI (s) (C8:20) [10:46:47:455]: Package to be registered: 'LTspice64.msi'
    MSI (s) (C8:20) [10:46:47:456]: Note: 1: 2262 2: AdminProperties 3: -2147287038
    MSI (s) (C8:20) [10:46:47:456]: Machine policy value 'AlwaysInstallElevated' is 0
    MSI (s) (C8:20) [10:46:47:456]: User policy value 'AlwaysInstallElevated' is 0
    MSI (s) (C8:20) [10:46:47:456]: Running product '{CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B}' with user privileges: It's not assigned.
    MSI (s) (C8:20) [10:46:47:456]: PROPERTY CHANGE: Adding APPDIR property. Its value is 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\'.
    MSI (s) (C8:20) [10:46:47:456]: PROPERTY CHANGE: Modifying AI_IA_ENABLE property. Its current value is '0'. Its new value: '1'.
    MSI (s) (C8:20) [10:46:47:456]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'G:\'.
    MSI (s) (C8:20) [10:46:47:456]: PROPERTY CHANGE: Adding AI_INSTALL property. Its value is '1'.
    MSI (s) (C8:20) [10:46:47:456]: PROPERTY CHANGE: Adding SHORTCUTDIR property. Its value is 'C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\LTspice'.
    MSI (s) (C8:20) [10:46:47:456]: PROPERTY CHANGE: Adding MSICLIENTUSESEMBEDDEDUI property. Its value is '1'.
    MSI (s) (C8:20) [10:46:47:456]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Windows\SysWOW64'.
    MSI (s) (C8:20) [10:46:47:456]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
    MSI (s) (C8:20) [10:46:47:456]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '7488'.
    MSI (s) (C8:20) [10:46:47:456]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'mtarr00@yahoo.com'.
    MSI (s) (C8:20) [10:46:47:456]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'mmc'.
    MSI (s) (C8:20) [10:46:47:456]: PROPERTY CHANGE: Adding AIEXTERNALUI property. Its value is '1'.
    MSI (s) (C8:20) [10:46:47:456]: PROPERTY CHANGE: Adding CHAINERUIPROCESSID property. Its value is '17712Chainer'.
    MSI (s) (C8:20) [10:46:47:456]: PROPERTY CHANGE: Adding AI_CLIENTPROCESSID property. Its value is '17712'.
    MSI (s) (C8:20) [10:46:47:456]: PROPERTY CHANGE: Adding PRIMARYFOLDER property. Its value is 'APPDIR'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_HWND_EUI property. Its value is '200128'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_SYSTEM_DPI property. Its value is '144'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_SYSTEM_DPI_SCALE property. Its value is '150'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'E:\LT Spice\Installer 2026-08-24  v26.0.2\'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding IS_WINE property. Its value is '0'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_DOTNET_CORE_VERSION property. Its value is '8.0'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_DOTNET_CORE32_VERSION property. Its value is '8.0'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_DOTNET_CORE64_VERSION property. Its value is '8.0'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_DOTNET_VERSION property. Its value is '4.8.1'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_IE_VERSION property. Its value is '11.0'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_DIRECTX_VERSION property. Its value is '12'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_SQLSERVER_ODBCDRIVER_VERSION property. Its value is '09.0'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_SQLSERVER_ODBCDRIVER9_VERSION property. Its value is '09.0'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_VSTO_VERSION property. Its value is '4.0'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_WINDOWS_POWERSHELL_VERSION property. Its value is '5.1'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_POWERSHELL_VERSION property. Its value is '7.2'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_POWERSHELL32_VERSION property. Its value is '7.2'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_POWERSHELL64_VERSION property. Its value is '7.2'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_VISUALCPP_VERSION_PROP property. Its value is '14.3'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_VISUALCPP32_VERSION_PROP property. Its value is '14.3'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_VISUALCPP64_VERSION_PROP property. Its value is '14.3'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_OFFICE_ACCESS_VERSION property. Its value is '2016'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_OFFICE_ACCESS64_VERSION property. Its value is '2016'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_OFFICE_EXCEL64_VERSION property. Its value is '2016'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_OFFICE_EXCEL_VERSION property. Its value is '2016'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_OFFICE_ONENOTE_VERSION property. Its value is '2016'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_OFFICE_ONENOTE64_VERSION property. Its value is '2016'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_OFFICE_OUTLOOK64_VERSION property. Its value is '2016'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_OFFICE_OUTLOOK_VERSION property. Its value is '2016'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_OFFICE_POWERPOINT_VERSION property. Its value is '2016'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_OFFICE_POWERPOINT64_VERSION property. Its value is '2016'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_OFFICE_WORD_VERSION property. Its value is '2016'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_OFFICE_WORD64_VERSION property. Its value is '2016'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_OFFICE_MSFORMS_PIA_VERSION property. Its value is '2010'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_PHYSICAL_MEMORY property. Its value is '32453'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_OFFICE_MSFORMS2010_PIA_VERSION property. Its value is '2010'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_GRAPHICS_ADAPTERS property. Its value is '[{"Name":"NVIDIA Quadro P400","MemorySize":2147483648}]'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_ADMIN_USER property. Its value is '1'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_COLOR_QUALITY property. Its value is '32'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_PRODUCT_ANTIVIRUS property. Its value is 'Avast Antivirus;'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_NOT_VIRTUAL_MACHINE property. Its value is '1'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_INTERNET_CONNECTION property. Its value is '1'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_SCREEN_RESOLUTION_X property. Its value is '3840'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding AI_DETECTED_SCREEN_RESOLUTION_Y property. Its value is '2160'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'G:\'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding SECONDSEQUENCE property. Its value is '1'.
    MSI (s) (C8:20) [10:46:47:457]: PROPERTY CHANGE: Adding ADDLOCAL property. Its value is 'LTspice,Feature,Libraries'.
    MSI (s) (C8:20) [10:46:47:457]: Machine policy value 'DisableAutomaticApplicationShutdown' is 0
    MSI (s) (C8:20) [10:46:47:459]: PROPERTY CHANGE: Adding MsiRestartManagerSessionKey property. Its value is '4d29e4b0842fb846832ef232d1f9b778'.
    MSI (s) (C8:20) [10:46:47:459]: RESTART MANAGER: Session opened.
    MSI (s) (C8:20) [10:46:47:460]: Engine has iefSecondSequence set to true.
    MSI (s) (C8:20) [10:46:47:460]: TRANSFORMS property is now:
    MSI (s) (C8:20) [10:46:47:460]: PROPERTY CHANGE: Deleting SOURCEDIR property. Its current value is 'E:\LT Spice\Installer 2026-08-24  v26.0.2\'.
    MSI (s) (C8:20) [10:46:47:460]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '450'.
    MSI (s) (C8:20) [10:46:47:497]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\AppData\Roaming
    MSI (s) (C8:20) [10:46:47:500]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\Favorites
    MSI (s) (C8:20) [10:46:47:501]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Network Shortcuts
    MSI (s) (C8:20) [10:46:47:504]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\Documents
    MSI (s) (C8:20) [10:46:47:506]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
    MSI (s) (C8:20) [10:46:47:507]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Recent
    MSI (s) (C8:20) [10:46:47:508]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\SendTo
    MSI (s) (C8:20) [10:46:47:510]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Templates
    MSI (s) (C8:20) [10:46:47:511]: SHELL32::SHGetFolderPath returned: C:\ProgramData
    MSI (s) (C8:20) [10:46:47:513]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\AppData\Local
    MSI (s) (C8:20) [10:46:47:515]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\Pictures
    MSI (s) (C8:20) [10:46:47:516]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
    MSI (s) (C8:20) [10:46:47:518]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
    MSI (s) (C8:20) [10:46:47:520]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
    MSI (s) (C8:20) [10:46:47:522]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu
    MSI (s) (C8:20) [10:46:47:525]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\Desktop
    MSI (s) (C8:20) [10:46:47:530]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
    MSI (s) (C8:20) [10:46:47:533]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
    MSI (s) (C8:20) [10:46:47:535]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs
    MSI (s) (C8:20) [10:46:47:537]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu
    MSI (s) (C8:20) [10:46:47:540]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
    MSI (s) (C8:20) [10:46:47:540]: SHELL32::SHGetFolderPath returned: C:\windows\Fonts
    MSI (s) (C8:20) [10:46:47:541]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
    MSI (s) (C8:20) [10:46:47:547]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\windows\Installer\77b2d2.msi'.
    MSI (s) (C8:20) [10:46:47:547]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'E:\LT Spice\Installer 2026-08-24  v26.0.2\LTspice64.msi'.
    MSI (s) (C8:20) [10:46:47:547]: Machine policy value 'MsiDisableEmbeddedUI' is 0
    MSI (s) (C8:20) [10:46:47:547]: EEUI - Disabling MsiEmbeddedUI due to existing external or embedded UI
    MSI (s) (C8:20) [10:46:47:547]: EEUI - Disabling MsiEmbeddedUI for service because it's not a quiet/basic install
    MSI (s) (C8:20) [10:46:47:547]: Note: 1: 2262 2: PatchPackage 3: -2147287038
    MSI (s) (C8:20) [10:46:47:547]: Machine policy value 'DisableRollback' is 0
    MSI (s) (C8:20) [10:46:47:547]: User policy value 'DisableRollback' is 0
    MSI (s) (C8:20) [10:46:47:547]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
    MSI (s) (C8:20) [10:46:47:552]: PROPERTY CHANGE: Adding Preselected property. Its value is '1'.
    MSI (s) (C8:20) [10:46:47:552]: APPCOMPAT: [DetectVersionLaunchCondition] Launch condition already passes.
    MSI (s) (C8:20) [10:46:47:554]: Doing action: INSTALL
    Action 10:46:47: INSTALL.
    Action start 10:46:47: INSTALL.
    MSI (s) (C8:20) [10:46:47:558]: Running ExecuteSequence
    MSI (s) (C8:20) [10:46:47:558]: Skipping action: AI_IaLogPkgStarted (condition is false)
    MSI (s) (C8:20) [10:46:47:558]: Skipping action: AI_DETECT_WINTHEME (condition is false)
    MSI (s) (C8:20) [10:46:47:558]: Doing action: AI_EnableDebugLog
    Action 10:46:47: AI_EnableDebugLog.
    Action start 10:46:47: AI_EnableDebugLog.
    MSI (s) (C8:20) [10:46:47:561]: Skipping action due to msidbCustomActionTypeFirstSequence option.
    Action ended 10:46:47: AI_EnableDebugLog. Return value 0.
    MSI (s) (C8:20) [10:46:47:562]: Doing action: AI_ResolveKnownFolders
    Action 10:46:47: AI_ResolveKnownFolders.
    Action start 10:46:47: AI_ResolveKnownFolders.
    MSI (s) (C8:F8) [10:46:47:704]: Invoking remote custom action. DLL: C:\windows\Installer\MSIB582.tmp, Entrypoint: AI_ResolveKnownFolders
    MSI (s) (C8:54) [10:46:47:705]: Generating random cookie.
    MSI (s) (C8:54) [10:46:47:710]: Created Custom Action Server with PID 9384 (0x24A8).
    MSI (s) (C8:CC) [10:46:47:728]: Running as a service.
    MSI (s) (C8:CC) [10:46:47:731]: Hello, I'm your 32bit Impersonated custom action server.
    MSI (s) (C8!B0) [10:46:47:744]: PROPERTY CHANGE: Adding SavedGamesFolder property. Its value is 'C:\Users\mtarr\Saved Games\'.
    MSI (s) (C8!B0) [10:46:47:745]: PROPERTY CHANGE: Adding WindowsLibrariesFolder property. Its value is 'C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Libraries\'.
    MSI (s) (C8!B0) [10:46:47:745]: PROPERTY CHANGE: Adding PublicDocumentsFolder property. Its value is 'C:\Users\Public\Documents\'.
    MSI (s) (C8!B0) [10:46:47:745]: PROPERTY CHANGE: Adding PublicFolder property. Its value is 'C:\Users\Public\'.
    MSI (s) (C8!B0) [10:46:47:745]: PROPERTY CHANGE: Adding UserProfileFolder property. Its value is 'C:\Users\mtarr\'.
    MSI (s) (C8!B0) [10:46:47:745]: PROPERTY CHANGE: Adding IIsWWWRootFolder property. Its value is 'C:\inetpub\wwwroot\'.
    Action ended 10:46:47: AI_ResolveKnownFolders. Return value 1.
    MSI (s) (C8:20) [10:46:47:749]: Doing action: AI_DETECT_MODERNWIN
    Action 10:46:47: AI_DETECT_MODERNWIN.
    Action start 10:46:47: AI_DETECT_MODERNWIN.
    MSI (s) (C8:D0) [10:46:47:759]: Invoking remote custom action. DLL: C:\windows\Installer\MSIB63E.tmp, Entrypoint: DetectModernWindows
    MSI (s) (C8!44) [10:46:47:770]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is '603'. Its new value: '1100'.
    MSI (s) (C8!44) [10:46:47:770]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is '603'. Its new value: '1100'.
    MSI (s) (C8!44) [10:46:47:770]: PROPERTY CHANGE: Modifying WindowsBuild property. Its current value is '9600'. Its new value: '26200'.
    Action ended 10:46:47: AI_DETECT_MODERNWIN. Return value 1.
    MSI (s) (C8:20) [10:46:47:774]: Doing action: AI_BACKUP_AI_SETUPEXEPATH
    Action 10:46:47: AI_BACKUP_AI_SETUPEXEPATH.
    Action start 10:46:47: AI_BACKUP_AI_SETUPEXEPATH.
    Action ended 10:46:47: AI_BACKUP_AI_SETUPEXEPATH. Return value 1.
    MSI (s) (C8:20) [10:46:47:779]: Doing action: AppSearch
    Action 10:46:47: AppSearch. Searching for installed applications
    Action start 10:46:47: AppSearch.
    MSI (s) (C8:20) [10:46:47:782]: Skipping AppSearch action: already done on client side
    Action ended 10:46:47: AppSearch. Return value 0.
    MSI (s) (C8:20) [10:46:47:783]: Skipping action: AI_RESTORE_AI_SETUPEXEPATH (condition is false)
    MSI (s) (C8:20) [10:46:47:783]: Doing action: AI_IaToggle
    Action 10:46:47: AI_IaToggle.
    Action start 10:46:47: AI_IaToggle.
    MSI (s) (C8:BC) [10:46:47:797]: Invoking remote custom action. DLL: C:\windows\Installer\MSIB66E.tmp, Entrypoint: OnAnalyticsToggle
    Action ended 10:46:47: AI_IaToggle. Return value 1.
    MSI (s) (C8:20) [10:46:47:814]: Doing action: AI_DetectSoftware
    Action 10:46:47: AI_DetectSoftware.
    Action start 10:46:47: AI_DetectSoftware.
    MSI (s) (C8:20) [10:46:47:816]: Skipping action due to msidbCustomActionTypeFirstSequence option.
    Action ended 10:46:47: AI_DetectSoftware. Return value 0.
    MSI (s) (C8:20) [10:46:47:817]: Skipping action: AI_FindExeLzma (condition is false)
    MSI (s) (C8:20) [10:46:47:817]: Skipping action: AI_ExtractCadLzma (condition is false)
    MSI (s) (C8:20) [10:46:47:817]: Skipping action: AI_DeleteRCadLzma (condition is false)
    MSI (s) (C8:20) [10:46:47:817]: Skipping action: AI_DeleteCadLzma (condition is false)
    MSI (s) (C8:20) [10:46:47:817]: Doing action: FindRelatedProducts
    Action 10:46:47: FindRelatedProducts. Searching for related applications
    Action start 10:46:47: FindRelatedProducts.
    MSI (s) (C8:20) [10:46:47:819]: Skipping FindRelatedProducts action: already done on client side
    Action ended 10:46:47: FindRelatedProducts. Return value 0.
    MSI (s) (C8:20) [10:46:47:821]: Skipping action: AI_DOWNGRADE (condition is false)
    MSI (s) (C8:20) [10:46:47:821]: Doing action: AI_IaLogMachineInfo
    Action 10:46:47: AI_IaLogMachineInfo.
    Action start 10:46:47: AI_IaLogMachineInfo.
    MSI (s) (C8:20) [10:46:47:823]: Skipping action due to msidbCustomActionTypeFirstSequence option.
    Action ended 10:46:47: AI_IaLogMachineInfo. Return value 0.
    MSI (s) (C8:20) [10:46:47:824]: Doing action: LaunchConditions
    Action 10:46:47: LaunchConditions. Evaluating launch conditions
    Action start 10:46:47: LaunchConditions.
    Action ended 10:46:47: LaunchConditions. Return value 1.
    MSI (s) (C8:20) [10:46:47:827]: Doing action: ValidateProductID
    Action 10:46:47: ValidateProductID.
    Action start 10:46:47: ValidateProductID.
    Action ended 10:46:47: ValidateProductID. Return value 1.
    MSI (s) (C8:20) [10:46:47:830]: Doing action: AI_SETMIXINSTLOCATION
    Action 10:46:47: AI_SETMIXINSTLOCATION.
    Action start 10:46:47: AI_SETMIXINSTLOCATION.
    MSI (s) (C8:F4) [10:46:47:841]: Invoking remote custom action. DLL: C:\windows\Installer\MSIB69E.tmp, Entrypoint: MixedAllUsersInstallLocation
    MSI (s) (C8!BC) [10:46:47:851]: PROPERTY CHANGE: Adding AI_UserProgramFiles property. Its value is 'C:\Users\mtarr\AppData\Local\Programs\'.
    Action ended 10:46:47: AI_SETMIXINSTLOCATION. Return value 1.
    MSI (s) (C8:20) [10:46:47:854]: Skipping action: AI_RESTORE_LOCATION (condition is false)
    MSI (s) (C8:20) [10:46:47:854]: Skipping action: SET_APPDIR (condition is false)
    MSI (s) (C8:20) [10:46:47:854]: Skipping action: SET_SHORTCUTDIR (condition is false)
    MSI (s) (C8:20) [10:46:47:854]: Doing action: SET_TARGETDIR_TO_APPDIR
    Action 10:46:47: SET_TARGETDIR_TO_APPDIR.
    Action start 10:46:47: SET_TARGETDIR_TO_APPDIR.
    MSI (s) (C8:20) [10:46:47:856]: PROPERTY CHANGE: Modifying TARGETDIR property. Its current value is 'G:\'. Its new value: 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\'.
    Action ended 10:46:47: SET_TARGETDIR_TO_APPDIR. Return value 1.
    MSI (s) (C8:20) [10:46:47:857]: Doing action: CostInitialize
    Action 10:46:47: CostInitialize. Computing space requirements
    Action start 10:46:47: CostInitialize.
    MSI (s) (C8:20) [10:46:47:859]: Machine policy value 'MaxPatchCacheSize' is 10
    MSI (s) (C8:20) [10:46:47:860]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
    MSI (s) (C8:20) [10:46:47:860]: Note: 1: 2262 2: Patch 3: -2147287038
    MSI (s) (C8:20) [10:46:47:861]: Note: 1: 2262 2: PatchPackage 3: -2147287038
    MSI (s) (C8:20) [10:46:47:861]: Note: 1: 2205 2:  3: MsiPatchHeaders
    MSI (s) (C8:20) [10:46:47:861]: Note: 1: 2205 2:  3: __MsiPatchFileList
    Action ended 10:46:47: CostInitialize. Return value 1.
    MSI (s) (C8:20) [10:46:47:862]: Doing action: FileCost
    Action 10:46:47: FileCost. Computing space requirements
    Action start 10:46:47: FileCost.
    MSI (s) (C8:20) [10:46:47:864]: Note: 1: 2205 2:  3: MsiAssembly
    MSI (s) (C8:20) [10:46:47:864]: Note: 1: 2262 2: Class 3: -2147287038
    MSI (s) (C8:20) [10:46:47:864]: Note: 1: 2205 2:  3: TypeLib
    Action ended 10:46:47: FileCost. Return value 1.
    MSI (c) (40!D4) [10:46:47:868]: Note: 1: 2205 2:  3: AI_PreRequisite
    MSI (c) (40!D4) [10:46:47:868]: Note: 1: 2228 2:  3: AI_PreRequisite 4: SELECT `Options`,`Feature_`,`MissingCondition`,`DisplayName`,`PrereqKey`,`Sequence`,`InstallCondition` FROM `AI_PreRequisite`
    MSI (s) (C8:20) [10:46:47:897]: Doing action: IsolateComponents
    Action 10:46:47: IsolateComponents.
    Action start 10:46:47: IsolateComponents.
    Action ended 10:46:47: IsolateComponents. Return value 0.
    MSI (s) (C8:20) [10:46:47:901]: Doing action: CostFinalize
    Action 10:46:47: CostFinalize. Computing space requirements
    Action start 10:46:47: CostFinalize.
    MSI (s) (C8:20) [10:46:47:903]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
    MSI (s) (C8:20) [10:46:47:903]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
    MSI (s) (C8:20) [10:46:47:903]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
    MSI (s) (C8:20) [10:46:47:903]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
    MSI (s) (C8:20) [10:46:47:903]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
    MSI (s) (C8:20) [10:46:47:905]: PROPERTY CHANGE: Adding LTspice_1_Dir property. Its value is 'C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\LTspice\'.
    MSI (s) (C8:20) [10:46:47:905]: PROPERTY CHANGE: Adding LTspice_2_Dir property. Its value is 'C:\Users\mtarr\AppData\Local\LTspice\'.
    MSI (s) (C8:20) [10:46:47:905]: PROPERTY CHANGE: Adding LTspiceHelp_Dir property. Its value is 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\'.
    MSI (s) (C8:20) [10:46:47:905]: PROPERTY CHANGE: Adding assets_Dir property. Its value is 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\'.
    MSI (s) (C8:20) [10:46:47:905]: PROPERTY CHANGE: Adding js_Dir property. Its value is 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\js\'.
    MSI (s) (C8:20) [10:46:47:905]: PROPERTY CHANGE: Adding css_Dir property. Its value is 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\css\'.
    MSI (s) (C8:20) [10:46:47:905]: PROPERTY CHANGE: Adding images_Dir property. Its value is 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\'.
    MSI (s) (C8:20) [10:46:47:905]: PROPERTY CHANGE: Adding math_Dir property. Its value is 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\math\'.
    MSI (s) (C8:20) [10:46:47:905]: PROPERTY CHANGE: Adding lib_Dir property. Its value is 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\'.
    MSI (s) (C8:20) [10:46:47:905]: PROPERTY CHANGE: Adding whxdata_Dir property. Its value is 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\'.
    MSI (s) (C8:20) [10:46:47:905]: PROPERTY CHANGE: Adding text_Dir property. Its value is 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\'.
    MSI (s) (C8:20) [10:46:47:905]: PROPERTY CHANGE: Adding template_Dir property. Its value is 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\'.
    MSI (s) (C8:20) [10:46:47:905]: PROPERTY CHANGE: Adding styles_Dir property. Its value is 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\styles\'.
    MSI (s) (C8:20) [10:46:47:905]: PROPERTY CHANGE: Adding scripts_Dir property. Its value is 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\scripts\'.
    MSI (s) (C8:20) [10:46:47:905]: PROPERTY CHANGE: Adding images_1_Dir property. Its value is 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\images\'.
    MSI (s) (C8:20) [10:46:47:905]: PROPERTY CHANGE: Adding LTspice_Dir property. Its value is 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\'.
    MSI (s) (C8:20) [10:46:47:905]: PROPERTY CHANGE: Adding __Dir property. Its value is 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\2019\'.
    MSI (s) (C8:20) [10:46:47:905]: Target path resolution complete. Dumping Directory table...
    MSI (s) (C8:20) [10:46:47:905]: Note: target paths subject to change (via custom actions or browsing)
    MSI (s) (C8:20) [10:46:47:905]: Dir (target): Key: TARGETDIR	, Object: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\
    MSI (s) (C8:20) [10:46:47:905]: Dir (target): Key: WindowsFolder	, Object: C:\windows\
    MSI (s) (C8:20) [10:46:47:905]: Dir (target): Key: SystemFolder	, Object: C:\windows\SysWOW64\
    MSI (s) (C8:20) [10:46:47:905]: Dir (target): Key: DesktopFolder	, Object: C:\Users\mtarr\Desktop\
    MSI (s) (C8:20) [10:46:47:905]: Dir (target): Key: ProgramMenuFolder	, Object: C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\
    MSI (s) (C8:20) [10:46:47:905]: Dir (target): Key: LTspice_1_Dir	, Object: C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\LTspice\
    MSI (s) (C8:20) [10:46:47:905]: Dir (target): Key: LocalAppDataFolder	, Object: C:\Users\mtarr\AppData\Local\
    MSI (s) (C8:20) [10:46:47:905]: Dir (target): Key: LTspice_2_Dir	, Object: C:\Users\mtarr\AppData\Local\LTspice\
    MSI (s) (C8:20) [10:46:47:905]: Dir (target): Key: APPDIR	, Object: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\
    MSI (s) (C8:20) [10:46:47:905]: Dir (target): Key: LTspiceHelp_Dir	, Object: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\
    MSI (s) (C8:20) [10:46:47:905]: Dir (target): Key: assets_Dir	, Object: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\
    MSI (s) (C8:20) [10:46:47:905]: Dir (target): Key: js_Dir	, Object: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\js\
    MSI (s) (C8:20) [10:46:47:905]: Dir (target): Key: css_Dir	, Object: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\css\
    MSI (s) (C8:20) [10:46:47:905]: Dir (target): Key: images_Dir	, Object: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\
    MSI (s) (C8:20) [10:46:47:905]: Dir (target): Key: math_Dir	, Object: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\math\
    MSI (s) (C8:20) [10:46:47:905]: Dir (target): Key: lib_Dir	, Object: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\
    MSI (s) (C8:20) [10:46:47:905]: Dir (target): Key: whxdata_Dir	, Object: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\
    MSI (s) (C8:20) [10:46:47:905]: Dir (target): Key: text_Dir	, Object: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\
    MSI (s) (C8:20) [10:46:47:905]: Dir (target): Key: template_Dir	, Object: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\
    MSI (s) (C8:20) [10:46:47:905]: Dir (target): Key: styles_Dir	, Object: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\styles\
    MSI (s) (C8:20) [10:46:47:905]: Dir (target): Key: scripts_Dir	, Object: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\scripts\
    MSI (s) (C8:20) [10:46:47:905]: Dir (target): Key: images_1_Dir	, Object: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\images\
    MSI (s) (C8:20) [10:46:47:905]: Dir (target): Key: LTspice_Dir	, Object: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\
    MSI (s) (C8:20) [10:46:47:905]: Dir (target): Key: __Dir	, Object: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\2019\
    MSI (s) (C8:20) [10:46:47:906]: Note: 1: 2205 2:  3: MsiAssembly
    MSI (s) (C8:20) [10:46:47:906]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
    MSI (s) (C8:20) [10:46:47:925]: Allowing installation of component: {2386C15C-A94F-428D-9DEB-5732F9051F6D} even though a modified unversioned keyfile exists and file versioning rules would disable the component
    MSI (s) (C8:20) [10:46:47:926]: Allowing installation of component: {053C271A-84E0-4B4C-8834-71D8FF477983} even though a modified unversioned keyfile exists and file versioning rules would disable the component
    MSI (s) (C8:20) [10:46:47:927]: Allowing installation of component: {FC96FA67-16FB-4D7F-9AF1-1F48D32BC4CC} even though a modified unversioned keyfile exists and file versioning rules would disable the component
    MSI (s) (C8:20) [10:46:47:928]: Allowing installation of component: {67AF4F7A-C3E8-46FB-99DA-2FEA24AFE5E4} even though a modified unversioned keyfile exists and file versioning rules would disable the component
    Action ended 10:46:47: CostFinalize. Return value 1.
    MSI (s) (C8:20) [10:46:47:932]: Doing action: MigrateFeatureStates
    Action 10:46:47: MigrateFeatureStates. Migrating feature states from related applications
    Action start 10:46:47: MigrateFeatureStates.
    MSI (s) (C8:20) [10:46:47:934]: Skipping MigrateFeatureStates action: already done on client side
    Action ended 10:46:47: MigrateFeatureStates. Return value 0.
    MSI (s) (C8:20) [10:46:47:935]: Skipping action: SetODBCFolders (condition is false)
    MSI (s) (C8:20) [10:46:47:935]: Skipping action: AI_PREPARE_UPGRADE (condition is false)
    MSI (s) (C8:20) [10:46:47:935]: Doing action: InstallValidate
    Action 10:46:47: InstallValidate. Validating install
    Action start 10:46:47: InstallValidate.
    MSI (s) (C8:20) [10:46:47:937]: PROPERTY CHANGE: Deleting MsiRestartManagerSessionKey property. Its current value is '4d29e4b0842fb846832ef232d1f9b778'.
    MSI (s) (C8:20) [10:46:47:937]: Feature: LTspice; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Feature: Feature; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Feature: Libraries; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: LTspice; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: APPDIR; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: toc62.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: ProductInformation; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: AI_INSTALLPERUSER; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: toc56.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: LTspiceApplicationFiles; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: LTspice.exe; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: toc48.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: updater.exe; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: toc60.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: AI_IA_ENABLE; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: Remove.exe; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: toc68.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: Remove.txt; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: examples.zip; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: brsdata.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: lib.zip; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: ChangeLog.txt; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: toc59.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: aspecialfunctions.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: pcbnetlistextraction.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: toc66.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: hierarchy.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: datatraceselection.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: toc77.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: additionalresources.html; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: acperformansmallsignalacanalys.htm_1; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: toc71.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: commandlineswitches.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: assistedmode.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: toc7.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: inductormodels.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: addingattributes.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: toc75.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: parentdata.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: faq.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: toc92.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: plotpanes.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: attributevisibility.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: toc100.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: draftingoptions.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: howtogetabodeplotfromasmps.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: toc73.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: attachedcursors.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: addingthepins.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: toc49.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: automaticsymbolgeneration.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: netcomputenetworkparametersina.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: search_topics.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: customsymbols.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: axiscontrol.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: search_fv_0.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: operation.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: examplecircuits.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: search_auto_model_0.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: ddiode.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: runningunderlinux.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: search_ii_0.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: backannoannotatethesubcircuitp.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: barbitrarybehavioralvoltageorcur.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: toc10.new.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: basicschematicediting.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: ccapacitor.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: stopwords.xml; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: spice.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: circuitelements.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: search_ii_0.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: exportingwaveformdata.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: colorcontrol.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:937]: Component: toc1.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: savelimitthequantityofsaveddat.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: convergence.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: toc109.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: compression.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: creatingnewsymbols.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: toc103.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: dotkeep.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: loadbiasloadapreviouslysolvedd.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: whfts.xml; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: dcperformadcsourcesweepanalysi.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: navigatingthehierarchy.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: toc108.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: internetoptions.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: dotcommands.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: toc118.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: fra_probe.html; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: dotfra.html; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: toc4.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: drawingthebody.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: editingcomponents.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: toc105.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: efficiencycalculation.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: hacks.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: toc116.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: efficiencyreport.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: integrationmethods.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: endendofnetlist.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: fcurrentdependentcurrentsource.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: endsendofsubcircuitdefinition.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: uuniformrcline.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: evoltagedependentvoltagesource.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: expertmode.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: externallygeneratednetlists.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: fastaccessfileformat.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: fourcomputeafouriercomponent.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: fra_device.html; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: funcuserdefinedfunctions.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: generalpurposeschematicdrivenspi.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: generalstructureandconventions.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: globaldeclareglobalnodes.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: gvoltagedependentcurrentsource.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: hcurrentdependentvoltagesource.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: icsetinitialconditions.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: icurrentsource.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: step.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: includeincludeanotherfile.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: index.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: index.ppf; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: introduction.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: introduction1.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: toc23.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: jjfet.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: keyboardshortcuts.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: toc18.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: kmutualinductance.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: labelanodename.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: libincludealibrary.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: licenseagreementdisclaimer.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: toc21.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: xsubcircuit.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: startup.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: toc3.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: licenseanddistribution.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: linductor.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: toc25.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: loadstate.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: ltspice.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: toc2.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: machinearbitrarystatemachine.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: measureevaluateuserdefinedele.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: toc96.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: memoryproblems.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: mmosfet.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: toc36.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: modeldefineaspicemodel.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: modelcompatibility.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: toc30.new.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: modesofoperation.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: mosfetmodels.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: toc27.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: netlistoptions.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: nodesetsupplyhintsforinitialdc.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: toc34.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: nodiscard.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: noiseperformanoiseanalysis.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: toc44.new.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: olossytransmissionline.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: opfindthedcoperatingpoint.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: toc38.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: userdefinedfunctions.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: optionssetsimulatoroptions.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: toc32.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: paramuserdefinedparameters.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: placingcomponents.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: toc43.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: programupdates.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: projectdata.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: toc53.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: qbipolartransistor.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: rresistor.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: toc46.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: rulesofhierarchy.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: tlosslesstransmissionline.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: toc40.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: savebiassaveoperatingpointtodi.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: savedefaults.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: toc51.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: saveplotconfigurations.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: savestate.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: schematiccapture.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: edit2.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: schematiccolors.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: screendata.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: full_screen.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: search.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: settings.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: file.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: simulatingtransformers.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: softwareinstallation.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: Dark.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: thirdpartymodels.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: spicenetlist.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: filter_clearall.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: steady.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: stepparametersweeps.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: logo.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: subcktdefineasubcircuit.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: superexpertmode.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: Group56.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: svoltagecontrolledswitch.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: symbolandlibrarysearchpaths.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: filter2.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: temptemperaturesweeps.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: tffindthedcsmallsignaltransfe.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: homepagesaved.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: trandoanonlineartransientanaly.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: transientanalysisoptions.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: loading.gif; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: acperformansmallsignalacanalys.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: uic.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: index.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: universalopampmodels.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: vvoltagesource.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: Group9.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: waveformviewer.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: wavewriteselectednodestoawavfi.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: light.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: waveformarithmetic.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: waveforms.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: LTspiceArtBanner.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: wcurrentcontrolledswitch.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: zmesfetandigbt.htm; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: logo.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: BarlowRegular.ttf; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: InterItalicVariableFont_opszwght.ttf; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: layout.css; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: BarlowRegular.ttf_1; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: BarlowSemiCondensedRegular.ttf; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: LTspiceArt1920_0609.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: default.css; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: chmRelative.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image11.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: ac_stepDB.png_1; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: menu.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: convergence_slide4_picture_8.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: convergence_slide3_picture_16.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: LTspice26LogoWhiteNoBackground.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: convergence_slide3_picture_17.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: dbMeasurementSchema.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image12.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image44.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image13.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image14.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image15.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image16.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image17.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image18.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image19.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image20.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image21.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image22.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image23.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image24.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: ac_stepDB.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image25.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image35.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image26.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image27.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image28.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image29.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image30.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image31.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image32.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: usersettings.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image33.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image36.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: homepage.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image37.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image38.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: layout.css_1; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image41.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image43.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: unsaved.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image46.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image47.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: cshredirect.js_1; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:938]: Component: image9.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: ResultsVsStepPlot.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: idata1.new.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: ResultsWSteps.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: compress.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: redirect.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: dB.png_1; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: AddTrace.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: topicpage.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: asymminor.gif; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: Capacitor.gif; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: csh.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: RMS.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: Att2Cur.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc120.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: BH.gif; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: vdmoscap.gif; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc11.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: ControlWaveform.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: CursRead.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: brsdata.js_1; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: CursStep.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: Ddnform.gif; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: idata1.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: diffprobe.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: Dupform.gif; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc112.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: EntrExpr.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: FFT.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: idx.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: Hierarch.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: Inductor.gif; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc128.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: modified_trap_problem_asc.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: modified_trap_principle.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc12.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: modified_trap_problem.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: dB.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: bmrk_unselect.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: modified_trap_problem_wave.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: MouseCursor.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc5.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: Navigate.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: porttype.gif; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: layoutconfig.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: ProbeWire.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: pwrProbe.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: brschleft.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: vbic.gif; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: savedflt.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: chup.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: spiceopt.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: vdmos.gif; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: collapse_toc.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: VisTrace.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: Voltage.gif; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: brschright.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: cbrt.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: cbrt.svg_1; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: chright.svg_2; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: hypot.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: dnlim.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: cross_selectpanel.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: sqrt.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: topic.min.css; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: collapseTOC.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: topic.min.css_1; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: chright.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: chleft.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: expand.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: chright.svg_1; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: cross.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: LoadingData.gif; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: Add_bookmarkmobile.svg_1; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: expand_toc.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: bmrk_select.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: chdown.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: darkglobe.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: expandTOC.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: download_pdf.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: edit.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: LTspiceArt3840SineTOC.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js_136; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: homepagefilter2.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: LTspiceArt3840SineHeader.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js.gz_75; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: LTspiceArt1920_02.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: LTspiceArt1920_0207.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js_140; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: homepage.ejs; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: LTspice300x200.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js.gz_79; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: collapse_all.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: LTspiceArt1920_0508.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: highlight.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: email.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js.gz_84; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: delete.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: dot.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js_66; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: expand_all.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: facebook.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: filter.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: filter_clearall.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js_73; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: frameless.skn; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: Group114.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js_62; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc_default_tile.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: homepagefilter.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js_81; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: homepageunsaved.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: homepage_background.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js_69; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: LTspiceArt3840SineTools.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: layout.css.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js_89; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: linkedin.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: loading_spinner.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js_77; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: LTspice24LogoWhiteNoBackground.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: LTspiceArt1920_05.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js_96; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: LTspiceArt1920_06.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: LTspiceArt.jpg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js_85; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: page_up.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: print.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: read_aloud.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: read_aloud2.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: regular_screen.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: userstyles.css; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: saved.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: saved2.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: searchpagenext.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: searchpageprev.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: search.htm_1; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: search.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: share.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: tocimg1.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: tocimg2.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: tocimg3.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: Add_bookmarkmobile.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: tocimg4.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: tocimg5.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: tocimg6.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: tocimg7.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: tocimg8.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc_default_tile.png; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: topicpage.ejs; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: twitter.svg; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: usersettings.ejs; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js.gz_62; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: usersettings.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: compatibility.css; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: compatibility.css_1; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: cshredirect.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: topicpage.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js_121; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: cshredirect.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: homepage.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js.gz_60; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc41.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc111.new.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js.gz_70; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc57.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc90.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js.gz_64; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: glo.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: gdata1.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js.gz_73; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc107.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: layoutconfig.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js_123; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc122.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js_132; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: projectsettings.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: projectsettings.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js_127; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: search_auto_index.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: search_auto_map_0.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js_15; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: search_auto_map_0.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc121.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js_7; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: search_auto_model_0.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: search_db.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js_21; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: search_fv_0.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc102.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js_12; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc114.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: search_topics.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js.gz_9; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: synonym.xml; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc.new.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js_18; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc10.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc101.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js_30; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc104.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc106.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js_24; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc97.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc110.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc111.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc113.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc115.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js_29; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc117.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc119.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc122.new.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc123.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc124.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc125.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc126.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc70.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc127.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc129.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc13.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc130.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc131.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc132.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc55.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc133.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc134.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc135.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc136.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc137.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc138.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc139.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc14.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc15.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc16.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc17.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js_51; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc19.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc20.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js_44; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc22.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc24.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js.gz_37; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc26.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc28.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js.gz_31; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc29.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc30.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js.gz_42; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc31.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc33.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: js.gz_35; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:939]: Component: toc35.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc37.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_61; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc39.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc42.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_56; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc44.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc45.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc86.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc47.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc50.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_59; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc52.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc54.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc91.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc58.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc6.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc80.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc61.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc63.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_4; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc64.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc65.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc87.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc67.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc69.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_10; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc72.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc74.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc98.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc76.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc78.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc79.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc8.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc81.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc82.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc83.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc84.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc84.new.js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc85.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc88.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc89.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc9.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc93.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc94.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc95.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: toc99.new.js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_2; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_3; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_5; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_6; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_1; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_8; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_9; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_2; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_3; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_11; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_4; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_13; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_14; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_16; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_5; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_17; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_19; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_6; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_20; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_22; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_7; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_23; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_25; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_26; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_8; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_27; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_28; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_10; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_11; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_12; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_13; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_14; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_15; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_31; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_32; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_16; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_33; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_17; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_34; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_18; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_35; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_19; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_20; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_21; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_36; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_22; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_37; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_38; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_23; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_39; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_40; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_41; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_24; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_25; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_42; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_26; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_43; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_27; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_45; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_46; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_28; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_29; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_47; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_30; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_48; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_49; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_50; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_32; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_33; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_34; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_52; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_53; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_36; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_54; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_38; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_55; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_39; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_40; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_57; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_41; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_58; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_43; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_44; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_45; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_46; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_60; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_47; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_48; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_63; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_64; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_65; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_67; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_49; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_68; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_70; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_71; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_72; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_74; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_75; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_76; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_78; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_79; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_80; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_82; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_83; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_84; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_86; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_87; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_88; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_90; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_50; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_91; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_92; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_93; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_94; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_95; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_97; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_51; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_98; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_99; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_100; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_101; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_102; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_52; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_103; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_104; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_53; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_105; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_106; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_107; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_54; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_108; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_109; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_110; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_55; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_111; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_112; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_56; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_113; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_57; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_114; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_58; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_59; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_115; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_61; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_116; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_117; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_63; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_118; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_119; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_65; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_120; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_66; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_67; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_122; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_68; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_69; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_124; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_125; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_126; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_71; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_72; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_128; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_129; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_74; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_130; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_76; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_131; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_77; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_78; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_133; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_134; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_135; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_80; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_81; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_82; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_137; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_83; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_138; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js.gz_85; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: js_139; Installed: Absent;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: __LTspice.exe65; Installed: Null;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: __LTspice.exe66; Installed: Null;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: __updater.exe65; Installed: Null;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: __AI_INSTALLPERUSER65; Installed: Null;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: __AI_IA_ENABLE65; Installed: Null;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: __ProductInformation65; Installed: Null;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Component: __LTspice.exe67; Installed: Null;   Request: Local;   Action: Local
    MSI (s) (C8:20) [10:46:47:940]: Note: 1: 2205 2:  3: BindImage
    MSI (s) (C8:20) [10:46:47:940]: Note: 1: 2205 2:  3: PublishComponent
    MSI (s) (C8:20) [10:46:47:940]: Note: 1: 2205 2:  3: SelfReg
    MSI (s) (C8:20) [10:46:47:940]: Note: 1: 2205 2:  3: Font
    MSI (s) (C8:20) [10:46:47:940]: Note: 1: 2262 2: Class 3: -2147287038
    MSI (s) (C8:20) [10:46:47:941]: Note: 1: 2205 2:  3: TypeLib
    MSI (s) (C8:20) [10:46:47:945]: Note: 1: 2205 2:  3: _RemoveFilePath
    MSI (s) (C8:20) [10:46:47:945]: Note: 1: 2205 2:  3: MsiFileHash
    MSI (s) (C8:20) [10:46:48:649]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\.1 3: 2
    MSI (s) (C8:20) [10:46:48:651]: Note: 1: 2262 2: Class 3: -2147287038
    MSI (s) (C8:20) [10:46:48:652]: Note: 1: 2262 2: Class 3: -2147287038
    MSI (s) (C8:20) [10:46:48:653]: Note: 1: 2262 2: Class 3: -2147287038
    MSI (s) (C8:20) [10:46:48:654]: Note: 1: 2262 2: Class 3: -2147287038
    MSI (s) (C8:20) [10:46:48:655]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
    MSI (s) (C8:20) [10:46:48:655]: Note: 1: 2205 2:  3: BindImage
    MSI (s) (C8:20) [10:46:48:655]: Note: 1: 2205 2:  3: PublishComponent
    MSI (s) (C8:20) [10:46:48:655]: Note: 1: 2205 2:  3: SelfReg
    MSI (s) (C8:20) [10:46:48:655]: Note: 1: 2205 2:  3: Font
    MSI (s) (C8:20) [10:46:48:655]: Note: 1: 2262 2: Class 3: -2147287038
    MSI (s) (C8:20) [10:46:48:655]: Note: 1: 2205 2:  3: TypeLib
    MSI (s) (C8:20) [10:46:48:784]: PROPERTY CHANGE: Modifying PrimaryVolumeSpaceAvailable property. Its current value is '0'. Its new value: '996775968'.
    MSI (s) (C8:20) [10:46:48:784]: PROPERTY CHANGE: Modifying PrimaryVolumeSpaceRequired property. Its current value is '0'. Its new value: '645511'.
    MSI (s) (C8:20) [10:46:48:784]: PROPERTY CHANGE: Modifying PrimaryVolumeSpaceRemaining property. Its current value is '0'. Its new value: '996130457'.
    MSI (s) (C8:20) [10:46:48:784]: PROPERTY CHANGE: Adding PrimaryVolumePath property. Its value is 'C:'.
    MSI (s) (C8:20) [10:46:48:786]: Note: 1: 2205 2:  3: FilesInUse
    Action ended 10:46:48: InstallValidate. Return value 1.
    MSI (s) (C8:20) [10:46:48:800]: Doing action: AI_IaLogCustomInfo
    Action 10:46:48: AI_IaLogCustomInfo.
    Action start 10:46:48: AI_IaLogCustomInfo.
    MSI (s) (C8:B8) [10:46:48:825]: Invoking remote custom action. DLL: C:\windows\Installer\MSIBA68.tmp, Entrypoint: OnAnalyticsLogCustomInfo
    Action ended 10:46:48: AI_IaLogCustomInfo. Return value 1.
    MSI (s) (C8:20) [10:46:48:850]: Doing action: AI_IaLogInstallData
    Action 10:46:48: AI_IaLogInstallData.
    Action start 10:46:48: AI_IaLogInstallData.
    MSI (s) (C8:08) [10:46:48:861]: Invoking remote custom action. DLL: C:\windows\Installer\MSIBA97.tmp, Entrypoint: OnAnalyticsLogInstallData
    Action ended 10:46:48: AI_IaLogInstallData. Return value 1.
    MSI (s) (C8:20) [10:46:48:879]: Doing action: RemoveExistingProducts
    Action 10:46:48: RemoveExistingProducts. Removing applications
    Action start 10:46:48: RemoveExistingProducts.
    Action ended 10:46:48: RemoveExistingProducts. Return value 1.
    MSI (s) (C8:20) [10:46:48:883]: Doing action: InstallInitialize
    Action 10:46:48: InstallInitialize.
    Action start 10:46:48: InstallInitialize.
    MSI (s) (C8:20) [10:46:48:885]: Machine policy value 'AlwaysInstallElevated' is 0
    MSI (s) (C8:20) [10:46:48:885]: User policy value 'AlwaysInstallElevated' is 0
    MSI (s) (C8:20) [10:46:48:885]: BeginTransaction: Locking Server
    MSI (s) (C8:20) [10:46:48:885]: Note: 1: 2203 2: C:\windows\Installer\inprogressinstallinfo.ipi 3: -2147287038
    MSI (s) (C8:20) [10:46:48:885]: Server not locked: locking for product {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B}
    Action ended 10:46:48: InstallInitialize. Return value 1.
    MSI (s) (C8:20) [10:46:48:891]: Doing action: AI_STORE_LOCATION
    Action 10:46:48: AI_STORE_LOCATION.
    Action start 10:46:48: AI_STORE_LOCATION.
    MSI (s) (C8:20) [10:46:48:892]: PROPERTY CHANGE: Adding ARPINSTALLLOCATION property. Its value is 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\'.
    Action ended 10:46:48: AI_STORE_LOCATION. Return value 1.
    MSI (s) (C8:20) [10:46:48:893]: Skipping action: AI_DeleteRLzma (condition is false)
    MSI (s) (C8:20) [10:46:48:893]: Skipping action: AI_ExtractLzma (condition is false)
    MSI (s) (C8:20) [10:46:48:893]: Doing action: AllocateRegistrySpace
    Action 10:46:48: AllocateRegistrySpace. Allocating registry space
    Action start 10:46:48: AllocateRegistrySpace.
    Action ended 10:46:48: AllocateRegistrySpace. Return value 1.
    MSI (s) (C8:20) [10:46:48:895]: Skipping action: AI_UPDATER_UNINSTALL (condition is false)
    MSI (s) (C8:20) [10:46:48:895]: Doing action: ProcessComponents
    Action 10:46:48: ProcessComponents. Updating component registration
    Action start 10:46:48: ProcessComponents.
    MSI (s) (C8:20) [10:46:48:897]: Note: 1: 2205 2:  3: MsiPatchCertificate
    MSI (s) (C8:20) [10:46:48:897]: LUA patching is disabled: missing MsiPatchCertificate table
    MSI (s) (C8:20) [10:46:48:897]: Resolving source.
    MSI (s) (C8:20) [10:46:48:897]: Resolving source to launched-from source.
    MSI (s) (C8:20) [10:46:48:897]: Setting launched-from source as last-used.
    MSI (s) (C8:20) [10:46:48:897]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'E:\LT Spice\Installer 2026-08-24  v26.0.2\'.
    MSI (s) (C8:20) [10:46:48:897]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'E:\LT Spice\Installer 2026-08-24  v26.0.2\'.
    MSI (s) (C8:20) [10:46:48:897]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B}'.
    MSI (s) (C8:20) [10:46:48:897]: SOURCEDIR ==> E:\LT Spice\Installer 2026-08-24  v26.0.2\
    MSI (s) (C8:20) [10:46:48:897]: SOURCEDIR product ==> {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B}
    MSI (s) (C8:20) [10:46:48:897]: Determining source type
    MSI (s) (C8:20) [10:46:48:898]: Source type from package 'LTspice64.msi': 2
    MSI (s) (C8:20) [10:46:48:898]: SECREPAIR: Hash Database: C:\windows\Installer\SourceHash{CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B}
    MSI (s) (C8:20) [10:46:48:898]: SECREPAIR: SourceHash database file already exists. Deleting it.
    MSI (s) (C8:20) [10:46:48:900]: Note: 1: 2262 2: SourceHash 3: -2147287038
    MSI (s) (C8:20) [10:46:48:903]: SECREPAIR: New Hash Database creation complete.
    MSI (s) (C8:20) [10:46:49:095]: Source path resolution complete. Dumping Directory table...
    MSI (s) (C8:20) [10:46:49:095]: Dir (source): Key: TARGETDIR	, Object: E:\LT Spice\Installer 2026-08-24  v26.0.2\	, LongSubPath: 	, ShortSubPath:
    MSI (s) (C8:20) [10:46:49:095]: Dir (source): Key: WindowsFolder	, Object: E:\LT Spice\Installer 2026-08-24  v26.0.2\	, LongSubPath: 	, ShortSubPath:
    MSI (s) (C8:20) [10:46:49:095]: Dir (source): Key: SystemFolder	, Object: E:\LT Spice\Installer 2026-08-24  v26.0.2\	, LongSubPath: SystemFolder\	, ShortSubPath: SYSTEM~1\
    MSI (s) (C8:20) [10:46:49:095]: Dir (source): Key: DesktopFolder	, Object: E:\LT Spice\Installer 2026-08-24  v26.0.2\	, LongSubPath: DesktopFolder\	, ShortSubPath: DESKTO~1\
    MSI (s) (C8:20) [10:46:49:095]: Dir (source): Key: ProgramMenuFolder	, Object: E:\LT Spice\Installer 2026-08-24  v26.0.2\	, LongSubPath: ProgramMenuFolder\	, ShortSubPath: PROGRA~1\
    MSI (s) (C8:20) [10:46:49:095]: Dir (source): Key: LTspice_1_Dir	, Object: E:\LT Spice\Installer 2026-08-24  v26.0.2\	, LongSubPath: ProgramMenuFolder\LTspice\	, ShortSubPath: PROGRA~1\LTspice\
    MSI (s) (C8:20) [10:46:49:095]: Dir (source): Key: LocalAppDataFolder	, Object: E:\LT Spice\Installer 2026-08-24  v26.0.2\	, LongSubPath: LocalAppDataFolder\	, ShortSubPath: LOCALA~1\
    MSI (s) (C8:20) [10:46:49:095]: Dir (source): Key: LTspice_2_Dir	, Object: E:\LT Spice\Installer 2026-08-24  v26.0.2\	, LongSubPath: LocalAppDataFolder\LTspice\	, ShortSubPath: LOCALA~1\LTspice\
    MSI (s) (C8:20) [10:46:49:095]: Dir (source): Key: APPDIR	, Object: E:\LT Spice\Installer 2026-08-24  v26.0.2\	, LongSubPath: 	, ShortSubPath:
    MSI (s) (C8:20) [10:46:49:095]: Dir (source): Key: LTspiceHelp_Dir	, Object: E:\LT Spice\Installer 2026-08-24  v26.0.2\	, LongSubPath: LTspiceHelp\	, ShortSubPath: LTSPIC~1\
    MSI (s) (C8:20) [10:46:49:095]: Dir (source): Key: assets_Dir	, Object: E:\LT Spice\Installer 2026-08-24  v26.0.2\	, LongSubPath: LTspiceHelp\assets\	, ShortSubPath: LTSPIC~1\assets\
    MSI (s) (C8:20) [10:46:49:095]: Dir (source): Key: js_Dir	, Object: E:\LT Spice\Installer 2026-08-24  v26.0.2\	, LongSubPath: LTspiceHelp\assets\js\	, ShortSubPath: LTSPIC~1\assets\js\
    MSI (s) (C8:20) [10:46:49:095]: Dir (source): Key: css_Dir	, Object: E:\LT Spice\Installer 2026-08-24  v26.0.2\	, LongSubPath: LTspiceHelp\assets\css\	, ShortSubPath: LTSPIC~1\assets\css\
    MSI (s) (C8:20) [10:46:49:095]: Dir (source): Key: images_Dir	, Object: E:\LT Spice\Installer 2026-08-24  v26.0.2\	, LongSubPath: LTspiceHelp\assets\images\	, ShortSubPath: LTSPIC~1\assets\images\
    MSI (s) (C8:20) [10:46:49:095]: Dir (source): Key: math_Dir	, Object: E:\LT Spice\Installer 2026-08-24  v26.0.2\	, LongSubPath: LTspiceHelp\assets\images\math\	, ShortSubPath: LTSPIC~1\assets\images\math\
    MSI (s) (C8:20) [10:46:49:095]: Dir (source): Key: lib_Dir	, Object: E:\LT Spice\Installer 2026-08-24  v26.0.2\	, LongSubPath: LTspiceHelp\assets\images\lib\	, ShortSubPath: LTSPIC~1\assets\images\lib\
    MSI (s) (C8:20) [10:46:49:095]: Dir (source): Key: whxdata_Dir	, Object: E:\LT Spice\Installer 2026-08-24  v26.0.2\	, LongSubPath: LTspiceHelp\whxdata\	, ShortSubPath: LTSPIC~1\whxdata\
    MSI (s) (C8:20) [10:46:49:095]: Dir (source): Key: text_Dir	, Object: E:\LT Spice\Installer 2026-08-24  v26.0.2\	, LongSubPath: LTspiceHelp\whxdata\text\	, ShortSubPath: LTSPIC~1\whxdata\text\
    MSI (s) (C8:20) [10:46:49:095]: Dir (source): Key: template_Dir	, Object: E:\LT Spice\Installer 2026-08-24  v26.0.2\	, LongSubPath: LTspiceHelp\template\	, ShortSubPath: LTSPIC~1\template\
    MSI (s) (C8:20) [10:46:49:095]: Dir (source): Key: styles_Dir	, Object: E:\LT Spice\Installer 2026-08-24  v26.0.2\	, LongSubPath: LTspiceHelp\template\styles\	, ShortSubPath: LTSPIC~1\template\styles\
    MSI (s) (C8:20) [10:46:49:095]: Dir (source): Key: scripts_Dir	, Object: E:\LT Spice\Installer 2026-08-24  v26.0.2\	, LongSubPath: LTspiceHelp\template\scripts\	, ShortSubPath: LTSPIC~1\template\scripts\
    MSI (s) (C8:20) [10:46:49:095]: Dir (source): Key: images_1_Dir	, Object: E:\LT Spice\Installer 2026-08-24  v26.0.2\	, LongSubPath: LTspiceHelp\template\images\	, ShortSubPath: LTSPIC~1\template\images\
    MSI (s) (C8:20) [10:46:49:095]: Dir (source): Key: LTspice_Dir	, Object: E:\LT Spice\Installer 2026-08-24  v26.0.2\	, LongSubPath: LTspiceHelp\template\LTspice\	, ShortSubPath: LTSPIC~1\template\LTspice\
    MSI (s) (C8:20) [10:46:49:096]: Dir (source): Key: __Dir	, Object: E:\LT Spice\Installer 2026-08-24  v26.0.2\	, LongSubPath: LTspiceHelp\template\LTspice\2019\	, ShortSubPath: LTSPIC~1\template\LTspice\2019\
    Action 10:46:49: GenerateScript. Generating script operations for action:
    GenerateScript: Updating component registration
    Action ended 10:46:49: ProcessComponents. Return value 1.
    MSI (s) (C8:20) [10:46:49:725]: Skipping action: MsiUnpublishAssemblies (condition is false)
    MSI (s) (C8:20) [10:46:49:725]: Skipping action: UnpublishComponents (condition is false)
    MSI (s) (C8:20) [10:46:49:725]: Skipping action: AI_ExpandArchUninstall (condition is false)
    MSI (s) (C8:20) [10:46:49:725]: Doing action: UnpublishFeatures
    Action 10:46:49: UnpublishFeatures. Unpublishing Product Features
    Action start 10:46:49: UnpublishFeatures.
    Action ended 10:46:49: UnpublishFeatures. Return value 1.
    MSI (s) (C8:20) [10:46:49:728]: Doing action: StopServices
    Action 10:46:49: StopServices. Stopping services
    Action start 10:46:49: StopServices.
    MSI (s) (C8:20) [10:46:49:729]: Note: 1: 2205 2:  3: ServiceControl
    MSI (s) (C8:20) [10:46:49:729]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
    Action ended 10:46:49: StopServices. Return value 1.
    MSI (s) (C8:20) [10:46:49:730]: Doing action: DeleteServices
    Action 10:46:49: DeleteServices. Deleting services
    Action start 10:46:49: DeleteServices.
    MSI (s) (C8:20) [10:46:49:742]: Note: 1: 2205 2:  3: ServiceControl
    MSI (s) (C8:20) [10:46:49:742]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
    Action ended 10:46:49: DeleteServices. Return value 1.
    MSI (s) (C8:20) [10:46:49:742]: Skipping action: UnregisterComPlus (condition is false)
    MSI (s) (C8:20) [10:46:49:742]: Skipping action: SelfUnregModules (condition is false)
    MSI (s) (C8:20) [10:46:49:742]: Skipping action: UnregisterTypeLibraries (condition is false)
    MSI (s) (C8:20) [10:46:49:742]: Skipping action: RemoveODBC (condition is false)
    MSI (s) (C8:20) [10:46:49:742]: Skipping action: UnregisterFonts (condition is false)
    MSI (s) (C8:20) [10:46:49:742]: Doing action: RemoveRegistryValues
    Action 10:46:49: RemoveRegistryValues. Removing system registry values
    Action start 10:46:49: RemoveRegistryValues.
    Action ended 10:46:49: RemoveRegistryValues. Return value 1.
    MSI (s) (C8:20) [10:46:49:745]: Skipping action: UnregisterClassInfo (condition is false)
    MSI (s) (C8:20) [10:46:49:745]: Skipping action: UnregisterExtensionInfo (condition is false)
    MSI (s) (C8:20) [10:46:49:745]: Skipping action: UnregisterProgIdInfo (condition is false)
    MSI (s) (C8:20) [10:46:49:745]: Skipping action: UnregisterMIMEInfo (condition is false)
    MSI (s) (C8:20) [10:46:49:745]: Doing action: RemoveIniValues
    Action 10:46:49: RemoveIniValues. Removing INI files entries
    Action start 10:46:49: RemoveIniValues.
    Action ended 10:46:49: RemoveIniValues. Return value 1.
    MSI (s) (C8:20) [10:46:49:748]: Skipping action: RemoveShortcuts (condition is false)
    MSI (s) (C8:20) [10:46:49:748]: Doing action: RemoveEnvironmentStrings
    Action 10:46:49: RemoveEnvironmentStrings. Updating environment strings
    Action start 10:46:49: RemoveEnvironmentStrings.
    MSI (s) (C8:20) [10:46:49:750]: Note: 1: 2205 2:  3: Environment
    MSI (s) (C8:20) [10:46:49:750]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 0)
    Action ended 10:46:49: RemoveEnvironmentStrings. Return value 1.
    MSI (s) (C8:20) [10:46:49:751]: Skipping action: RemoveDuplicateFiles (condition is false)
    MSI (s) (C8:20) [10:46:49:751]: Doing action: RemoveFiles
    Action 10:46:49: RemoveFiles. Removing files
    Action start 10:46:49: RemoveFiles.
    MSI (s) (C8:20) [10:46:49:753]: Note: 1: 2205 2:  3: RemoveFile
    Action ended 10:46:49: RemoveFiles. Return value 0.
    MSI (s) (C8:20) [10:46:49:754]: Skipping action: RemoveFolders (condition is false)
    MSI (s) (C8:20) [10:46:49:754]: Doing action: CreateFolders
    Action 10:46:49: CreateFolders. Creating folders
    Action start 10:46:49: CreateFolders.
    CreateFolders: Folder: Creating folders
    Action ended 10:46:49: CreateFolders. Return value 1.
    MSI (s) (C8:20) [10:46:49:760]: Doing action: MoveFiles
    Action 10:46:49: MoveFiles. Moving files
    Action start 10:46:49: MoveFiles.
    Action ended 10:46:49: MoveFiles. Return value 1.
    MSI (s) (C8:20) [10:46:49:763]: Doing action: InstallFiles
    Action 10:46:49: InstallFiles. Copying new files
    Action start 10:46:49: InstallFiles.
    InstallFiles: File: Copying new files,  Directory: ,  Size:
    MSI (s) (C8:20) [10:46:49:789]: Note: 1: 2205 2:  3: MsiPatchOldAssemblyFile
    MSI (s) (C8:20) [10:46:49:789]: Note: 1: 2228 2:  3: MsiPatchOldAssemblyFile 4: SELECT `MsiPatchOldAssemblyFile`.`Assembly_` FROM `MsiPatchOldAssemblyFile` WHERE  `MsiPatchOldAssemblyFile`.`File_` = ?
    MSI (s) (C8:20) [10:46:49:789]: Note: 1: 2205 2:  3: MsiSFCBypass
    MSI (s) (C8:20) [10:46:49:789]: Note: 1: 2228 2:  3: MsiSFCBypass 4: SELECT `File_` FROM `MsiSFCBypass` WHERE `File_` = ?
    MSI (s) (C8:20) [10:46:49:789]: Note: 1: 2205 2:  3: MsiPatchHeaders
    MSI (s) (C8:20) [10:46:49:789]: Note: 1: 2228 2:  3: MsiPatchHeaders 4: SELECT `Header` FROM `MsiPatchHeaders` WHERE `StreamRef` = ?
    MSI (s) (C8:20) [10:46:49:793]: Note: 1: 2205 2:  3: MsiPatchHeaders
    Action ended 10:46:50: InstallFiles. Return value 1.
    MSI (s) (C8:20) [10:46:50:491]: Skipping action: PatchFiles (condition is false)
    MSI (s) (C8:20) [10:46:50:491]: Doing action: DuplicateFiles
    Action 10:46:50: DuplicateFiles. Creating duplicate files
    Action start 10:46:50: DuplicateFiles.
    Action ended 10:46:50: DuplicateFiles. Return value 1.
    MSI (s) (C8:20) [10:46:50:494]: Doing action: BindImage
    Action 10:46:50: BindImage. Binding executables
    Action start 10:46:50: BindImage.
    Action ended 10:46:50: BindImage. Return value 1.
    MSI (s) (C8:20) [10:46:50:496]: Doing action: CreateShortcuts
    Action 10:46:50: CreateShortcuts. Creating shortcuts
    Action start 10:46:50: CreateShortcuts.
    CreateShortcuts: Shortcut: Creating shortcuts
    MSI (s) (C8:20) [10:46:50:512]: Note: 1: 2235 2:  3: DisplayResourceDLL 4: SELECT  `Shortcut`,`Name`, `FileName`, `Component`.`Directory_`, `Arguments`, `WkDir`, `Icon_`, `IconIndex`, `Hotkey`, `ShowCmd`, `Shortcut`.`Description`, `Shortcut`.`Directory_`, `Component`.`RuntimeFlags`, `Component`.`Action`, `Target`, `ComponentId`, `Feature`.`Action`, `Component`.`Installed`, `DisplayResourceDLL`, `DisplayResourceId`, `DescriptionResourceDLL`, `DescriptionResourceId` From `Shortcut`, `Feature`, `Component`, `File` WHERE `Target` = `Feature` AND `Shortcut`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
    MSI (s) (C8:20) [10:46:50:521]: Note: 1: 2205 2:  3: MsiShortcutProperty
    MSI (s) (C8:20) [10:46:50:521]: Note: 1: 2235 2:  3: DisplayResourceDLL 4: SELECT  `Shortcut`,`Name`, `Target`, null, `Arguments`, `WkDir`, `Icon_`, `IconIndex`, `Hotkey`, `ShowCmd`, `Shortcut`.`Description`, `Shortcut`.`Directory_`, `Component`.`RuntimeFlags`, null, null, null, null, null, `DisplayResourceDLL`, `DisplayResourceId`, `DescriptionResourceDLL`, `DescriptionResourceId` From `Shortcut`, `Component` WHERE `Shortcut`.`Component_` = `Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2)
    Action ended 10:46:50: CreateShortcuts. Return value 1.
    MSI (s) (C8:20) [10:46:50:529]: Doing action: RegisterClassInfo
    Action 10:46:50: RegisterClassInfo. Registering Class servers
    Action start 10:46:50: RegisterClassInfo.
    MSI (s) (C8:20) [10:46:50:531]: Note: 1: 2262 2: Class 3: -2147287038
    Action ended 10:46:50: RegisterClassInfo. Return value 1.
    MSI (s) (C8:20) [10:46:50:533]: Doing action: RegisterExtensionInfo
    Action 10:46:50: RegisterExtensionInfo. Registering extension servers
    Action start 10:46:50: RegisterExtensionInfo.
    RegisterExtensionInfo: Extension: Registering extension servers
    Action ended 10:46:50: RegisterExtensionInfo. Return value 1.
    MSI (s) (C8:20) [10:46:50:547]: Doing action: RegisterProgIdInfo
    Action 10:46:50: RegisterProgIdInfo. Registering program identifiers
    Action start 10:46:50: RegisterProgIdInfo.
    MSI (s) (C8:20) [10:46:50:549]: Note: 1: 2262 2: Class 3: -2147287038
    RegisterProgIdInfo: ProgId: Registering program identifiers
    Action ended 10:46:50: RegisterProgIdInfo. Return value 1.
    MSI (s) (C8:20) [10:46:50:561]: Doing action: RegisterMIMEInfo
    Action 10:46:50: RegisterMIMEInfo. Registering MIME info
    Action start 10:46:50: RegisterMIMEInfo.
    RegisterMIMEInfo: MIME Content Type: Registering MIME info, Extension:
    Action ended 10:46:50: RegisterMIMEInfo. Return value 1.
    MSI (s) (C8:20) [10:46:50:574]: Doing action: WriteRegistryValues
    Action 10:46:50: WriteRegistryValues. Writing system registry values
    Action start 10:46:50: WriteRegistryValues.
    WriteRegistryValues: Key: Writing system registry values, Name: , Value:
    Action ended 10:46:50: WriteRegistryValues. Return value 1.
    MSI (s) (C8:20) [10:46:50:584]: Doing action: WriteIniValues
    Action 10:46:50: WriteIniValues. Writing INI files values
    Action start 10:46:50: WriteIniValues.
    WriteIniValues: File: Writing INI files values,  Section: ,  Key: , Value:
    Action ended 10:46:50: WriteIniValues. Return value 1.
    MSI (s) (C8:20) [10:46:50:597]: Doing action: WriteEnvironmentStrings
    Action 10:46:50: WriteEnvironmentStrings. Updating environment strings
    Action start 10:46:50: WriteEnvironmentStrings.
    MSI (s) (C8:20) [10:46:50:599]: Note: 1: 2205 2:  3: Environment
    MSI (s) (C8:20) [10:46:50:599]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2)
    Action ended 10:46:50: WriteEnvironmentStrings. Return value 1.
    MSI (s) (C8:20) [10:46:50:600]: Doing action: RegisterFonts
    Action 10:46:50: RegisterFonts. Registering fonts
    Action start 10:46:50: RegisterFonts.
    MSI (s) (C8:20) [10:46:50:602]: Note: 1: 2205 2:  3: Font
    MSI (s) (C8:20) [10:46:50:602]: Note: 1: 2228 2:  3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Action` From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And (`FileAction`.`Action` = 1 Or `FileAction`.`Action` = 2) ORDER BY `FileAction`.`Directory_`
    Action ended 10:46:50: RegisterFonts. Return value 1.
    MSI (s) (C8:20) [10:46:50:603]: Skipping action: InstallODBC (condition is false)
    MSI (s) (C8:20) [10:46:50:603]: Doing action: RegisterTypeLibraries
    Action 10:46:50: RegisterTypeLibraries. Registering type libraries
    Action start 10:46:50: RegisterTypeLibraries.
    MSI (s) (C8:20) [10:46:50:604]: Note: 1: 2205 2:  3: TypeLib
    MSI (s) (C8:20) [10:46:50:604]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes`, `Component`.`RuntimeFlags` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Component`.`Action`=1 OR `Component`.`Action`=2) OR (`Component`.`Action` = null AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2)))
    Action ended 10:46:50: RegisterTypeLibraries. Return value 0.
    MSI (s) (C8:20) [10:46:50:605]: Doing action: SelfRegModules
    Action 10:46:50: SelfRegModules. Registering modules
    Action start 10:46:50: SelfRegModules.
    MSI (s) (C8:20) [10:46:50:607]: Note: 1: 2205 2:  3: SelfReg
    MSI (s) (C8:20) [10:46:50:607]: Note: 1: 2228 2:  3: SelfReg 4: Select `FileAction`.`FileName`,`FileAction`.`Directory_`,`FileAction`.`Action`, `FileAction`.`Component_`,`SelfReg`.`File_` From `SelfReg`, `FileAction` Where `SelfReg`.`File_` = `FileAction`.`File`  And (`FileAction`.`Action` = 1 OR `FileAction`.`Action` = 2)
    Action ended 10:46:50: SelfRegModules. Return value 1.
    MSI (s) (C8:20) [10:46:50:608]: Doing action: RegisterComPlus
    Action 10:46:50: RegisterComPlus. Registering COM+ Applications and Components
    Action start 10:46:50: RegisterComPlus.
    MSI (s) (C8:20) [10:46:50:610]: Note: 1: 2205 2:  3: Complus
    MSI (s) (C8:20) [10:46:50:610]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Action` = 1 OR `Action` = 2)
    Action ended 10:46:50: RegisterComPlus. Return value 0.
    MSI (s) (C8:20) [10:46:50:611]: Doing action: InstallServices
    Action 10:46:50: InstallServices. Installing new services
    Action start 10:46:50: InstallServices.
    MSI (s) (C8:20) [10:46:50:612]: Detected older ServiceInstall table schema
    MSI (s) (C8:20) [10:46:50:612]: Note: 1: 2205 2:  3: ServiceInstall
    MSI (s) (C8:20) [10:46:50:612]: Note: 1: 2228 2:  3: ServiceInstall 4: SELECT `ServiceInstall`,`Name`,`DisplayName`,`ServiceType`,`StartType`,`ErrorControl`,`LoadOrderGroup`,`Dependencies`,`StartName`,`Password`,`ComponentId`,`Directory_`,`FileName`,`Arguments` FROM `ServiceInstall`, `Component`, `File` WHERE `ServiceInstall`.`Component_` = `Component`.`Component` AND (`Component`.`KeyPath` = `File`.`File`) AND (`Action` = 1 OR `Action` = 2)
    Action ended 10:46:50: InstallServices. Return value 1.
    MSI (s) (C8:20) [10:46:50:613]: Doing action: StartServices
    Action 10:46:50: StartServices. Starting services
    Action start 10:46:50: StartServices.
    MSI (s) (C8:20) [10:46:50:615]: Note: 1: 2205 2:  3: ServiceControl
    MSI (s) (C8:20) [10:46:50:615]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
    Action ended 10:46:50: StartServices. Return value 1.
    MSI (s) (C8:20) [10:46:50:616]: Doing action: AI_ExpandArchInstall
    Action 10:46:50: AI_ExpandArchInstall. Generating actions for extracting archives
    Action start 10:46:50: AI_ExpandArchInstall.
    MSI (s) (C8:EC) [10:46:50:626]: Invoking remote custom action. DLL: C:\windows\Installer\MSIC17F.tmp, Entrypoint: OnExpandArchInstall
    MSI (s) (C8!50) [10:46:50:634]: PROPERTY CHANGE: Adding AI_ExpandArchRollback property. Its value is 'ExpandArchiveC:\Users\mtarr\AppData\Local\LTspice\C:\Users\mtarr\AppData\Local\LTspice\examples.zip$examples.zip = 341ExpandArchive_1C:\Users\mtarr\AppData\Local\LTspice\C:\Users\mtarr\AppData\Local\LTspice\lib.zip$lib.zip = 341ProductCode{CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B}ALLUSERS'.
    MSI (s) (C8!50) [10:46:50:634]: Doing action: AI_ExpandArchRollback
    Action 10:46:50: AI_ExpandArchRollback. Rolling back extracted files
    Action start 10:46:50: AI_ExpandArchRollback.
    AI_ExpandArchRollback: Rolling back contents of extracted archive: "Rolling back extracted files"
    Action ended 10:46:50: AI_ExpandArchRollback. Return value 1.
    MSI (s) (C8!50) [10:46:50:643]: PROPERTY CHANGE: Deleting AI_ExpandArchRollback property. Its current value is 'ExpandArchiveC:\Users\mtarr\AppData\Local\LTspice\C:\Users\mtarr\AppData\Local\LTspice\examples.zip$examples.zip = 341ExpandArchive_1C:\Users\mtarr\AppData\Local\LTspice\C:\Users\mtarr\AppData\Local\LTspice\lib.zip$lib.zip = 341ProductCode{CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B}ALLUSERS'.
    MSI (s) (C8!50) [10:46:50:643]: PROPERTY CHANGE: Adding AI_ExpandArchConfig property. Its value is 'ExpandArchiveC:\Users\mtarr\AppData\Local\LTspice\C:\Users\mtarr\AppData\Local\LTspice\examples.zip$examples.zip = 341ExpandArchive_1C:\Users\mtarr\AppData\Local\LTspice\C:\Users\mtarr\AppData\Local\LTspice\lib.zip$lib.zip = 341ProductCode{CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B}ALLUSERS'.
    MSI (s) (C8!50) [10:46:50:643]: Doing action: AI_ExpandArchConfig
    Action 10:46:50: AI_ExpandArchConfig. Extracting archives
    Action start 10:46:50: AI_ExpandArchConfig.
    AI_ExpandArchConfig: Extracting archive: "Extracting archives"
    Action ended 10:46:50: AI_ExpandArchConfig. Return value 1.
    MSI (s) (C8!50) [10:46:50:651]: PROPERTY CHANGE: Deleting AI_ExpandArchConfig property. Its current value is 'ExpandArchiveC:\Users\mtarr\AppData\Local\LTspice\C:\Users\mtarr\AppData\Local\LTspice\examples.zip$examples.zip = 341ExpandArchive_1C:\Users\mtarr\AppData\Local\LTspice\C:\Users\mtarr\AppData\Local\LTspice\lib.zip$lib.zip = 341ProductCode{CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B}ALLUSERS'.
    Action ended 10:46:50: AI_ExpandArchInstall. Return value 1.
    MSI (s) (C8:20) [10:46:50:656]: Doing action: RegisterUser
    Action 10:46:50: RegisterUser. Registering user
    Action start 10:46:50: RegisterUser.
    Action ended 10:46:50: RegisterUser. Return value 1.
    MSI (s) (C8:20) [10:46:50:658]: Doing action: RegisterProduct
    Action 10:46:50: RegisterProduct. Registering product
    Action start 10:46:50: RegisterProduct.
    1: Registering product
    MSI (s) (C8:20) [10:46:50:664]: PROPERTY CHANGE: Adding ProductToBeRegistered property. Its value is '1'.
    Action ended 10:46:50: RegisterProduct. Return value 1.
    MSI (s) (C8:20) [10:46:50:666]: Doing action: PublishComponents
    Action 10:46:50: PublishComponents. Publishing Qualified Components
    Action start 10:46:50: PublishComponents.
    MSI (s) (C8:20) [10:46:50:667]: Note: 1: 2205 2:  3: PublishComponent
    MSI (s) (C8:20) [10:46:50:667]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
    Action ended 10:46:50: PublishComponents. Return value 0.
    MSI (s) (C8:20) [10:46:50:668]: Doing action: MsiPublishAssemblies
    Action 10:46:50: MsiPublishAssemblies. Publishing assembly information
    Action start 10:46:50: MsiPublishAssemblies.
    MSI (s) (C8:20) [10:46:50:670]: Note: 1: 2205 2:  3: MsiAssembly
    MSI (s) (C8:20) [10:46:50:670]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
    Action ended 10:46:50: MsiPublishAssemblies. Return value 0.
    MSI (s) (C8:20) [10:46:50:671]: Doing action: PublishFeatures
    Action 10:46:50: PublishFeatures. Publishing Product Features
    Action start 10:46:50: PublishFeatures.
    PublishFeatures: Feature: Publishing Product Features
    Action ended 10:46:50: PublishFeatures. Return value 1.
    MSI (s) (C8:20) [10:46:50:680]: Doing action: PublishProduct
    Action 10:46:50: PublishProduct. Publishing product information
    Action start 10:46:50: PublishProduct.
    1: Publishing product information
    Action ended 10:46:50: PublishProduct. Return value 1.
    MSI (s) (C8:20) [10:46:50:690]: Doing action: InstallExecute
    Action 10:46:50: InstallExecute.
    Action start 10:46:50: InstallExecute.
    MSI (s) (C8:20) [10:46:50:691]: Running Script: C:\windows\Installer\MSIBB83.tmp
    MSI (s) (C8:20) [10:46:50:691]: PROPERTY CHANGE: Adding UpdateStarted property. Its value is '1'.
    MSI (s) (C8:20) [10:46:50:694]: Note: 1: 2265 2:  3: -2147287035
    MSI (s) (C8:20) [10:46:50:695]: Machine policy value 'DisableRollback' is 0
    MSI (s) (C8:20) [10:46:50:695]: Note: 1: 2318 2:
    MSI (s) (C8:20) [10:46:50:696]: Note: 1: 2318 2:
    MSI (s) (C8:20) [10:46:50:696]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
    MSI (s) (C8:20) [10:46:50:697]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1564038617,LangId=1033,Platform=589824,ScriptType=1,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=0)
    MSI (s) (C8:20) [10:46:50:698]: Executing op: ProductInfo(ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},ProductName=LTspice,PackageName=LTspice64.msi,Language=1033,Version=436207618,Assignment=0,ObsoleteArg=0,ProductIcon=ADI.exe,,PackageCode={39C828E8-EBEA-41FF-AC38-4A5921DF2236},,,InstanceType=0,LUASetting=0,RemoteURTInstalls=0,ProductDeploymentFlags=6)
    MSI (s) (C8:20) [10:46:50:700]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\AppData\Roaming
    MSI (s) (C8:20) [10:46:50:701]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\AppData\Roaming
    MSI (s) (C8:20) [10:46:50:702]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\AppData\Roaming
    MSI (s) (C8:20) [10:46:50:702]: Note: 1: 2318 2:
    MSI (s) (C8:20) [10:46:50:703]: Executing op: DialogInfo(Type=0,Argument=1033)
    MSI (s) (C8:20) [10:46:50:704]: Executing op: DialogInfo(Type=1,Argument=LTspice)
    MSI (s) (C8:20) [10:46:50:706]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,,CleanupAction=RollbackCleanup,CleanupDescription=Removing backup files,CleanupTemplate=File: [1])
    MSI (s) (C8:20) [10:46:50:706]: Executing op: SetBaseline(Baseline=0,)
    MSI (s) (C8:20) [10:46:50:706]: Executing op: SetBaseline(Baseline=1,)
    MSI (s) (C8:20) [10:46:50:706]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
    Action 10:46:50: ProcessComponents. Updating component registration
    MSI (s) (C8:20) [10:46:50:707]: Executing op: ProgressTotal(Total=759,Type=1,ByteEquivalent=24000)
    MSI (s) (C8:20) [10:46:50:708]: Executing op: ComponentRegister(ComponentId={6EBF38EC-5219-4109-AD57-B7A9B7F2EE62},KeyPath=C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\LTspice\,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {6EBF38EC-5219-4109-AD57-B7A9B7F2EE62} 3: C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\LTspice\
    MSI (s) (C8:20) [10:46:50:710]: Executing op: ComponentRegister(ComponentId={0E93667D-D42D-47CE-9D9A-885BB84E5B56},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0E93667D-D42D-47CE-9D9A-885BB84E5B56} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\
    MSI (s) (C8:20) [10:46:50:712]: Executing op: ComponentRegister(ComponentId={E1633D3E-7125-431A-9054-2DBB68B05B5E},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc62.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {E1633D3E-7125-431A-9054-2DBB68B05B5E} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc62.new.js
    MSI (s) (C8:20) [10:46:50:713]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc62.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:714]: Executing op: ComponentRegister(ComponentId={64F39AD3-CFA0-4FEC-8A54-3D41DF5AA622},KeyPath=21:\Software\Analog Devices Inc.\LTspice\Version,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=1)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {64F39AD3-CFA0-4FEC-8A54-3D41DF5AA622} 3: 21:\Software\Analog Devices Inc.\LTspice\Version
    MSI (s) (C8:20) [10:46:50:716]: Executing op: ComponentRegister(ComponentId={2C30A75F-6F0C-4C3A-8AEF-86AAA0506EF5},KeyPath=21:\Software\Analog Devices Inc.\{D7D4C089-7B20-418E-BA5E-E0557C67F5D9}\AI_INSTALLPERUSER,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=1)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2C30A75F-6F0C-4C3A-8AEF-86AAA0506EF5} 3: 21:\Software\Analog Devices Inc.\{D7D4C089-7B20-418E-BA5E-E0557C67F5D9}\AI_INSTALLPERUSER
    MSI (s) (C8:20) [10:46:50:718]: Executing op: ComponentRegister(ComponentId={9FADEEF6-DB8F-4EAD-9AB1-B18975103694},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc56.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {9FADEEF6-DB8F-4EAD-9AB1-B18975103694} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc56.new.js
    MSI (s) (C8:20) [10:46:50:720]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc56.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:720]: Executing op: ComponentRegister(ComponentId={0152C40D-0523-44EE-95A9-50610A247C16},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\License.txt,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0152C40D-0523-44EE-95A9-50610A247C16} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\License.txt
    MSI (s) (C8:20) [10:46:50:721]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\License.txt' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:722]: Executing op: ComponentRegister(ComponentId={EFD16A4C-1F33-49D7-A3BA-94E6C8A3168E},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspice.exe,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=1)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {EFD16A4C-1F33-49D7-A3BA-94E6C8A3168E} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspice.exe
    MSI (s) (C8:20) [10:46:50:723]: Executing op: ComponentRegister(ComponentId={2980BE88-9AF6-4849-8548-3FB07173BAD4},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc48.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2980BE88-9AF6-4849-8548-3FB07173BAD4} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc48.new.js
    MSI (s) (C8:20) [10:46:50:725]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc48.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:725]: Executing op: ComponentRegister(ComponentId={73683F70-5E6D-4238-AB8A-92B267CE282F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\updater.exe,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {73683F70-5E6D-4238-AB8A-92B267CE282F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\updater.exe
    MSI (s) (C8:20) [10:46:50:726]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\updater.exe' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:726]: Executing op: ComponentRegister(ComponentId={FD41BAD8-F89A-4516-BFA8-CEA7A24B3CFD},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc60.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {FD41BAD8-F89A-4516-BFA8-CEA7A24B3CFD} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc60.new.js
    MSI (s) (C8:20) [10:46:50:728]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc60.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:728]: Executing op: ComponentRegister(ComponentId={0101E9EB-F08C-48D4-9EF4-AFD3F7058CB7},KeyPath=21:\Software\Analog Devices Inc.\{CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B}\AI_IA_ENABLE,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=1)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0101E9EB-F08C-48D4-9EF4-AFD3F7058CB7} 3: 21:\Software\Analog Devices Inc.\{CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B}\AI_IA_ENABLE
    MSI (s) (C8:20) [10:46:50:729]: Executing op: ComponentRegister(ComponentId={29D3F3CE-4A6F-4FC6-AEE3-ABAC4203F6E3},KeyPath=C:\Users\mtarr\AppData\Local\LTspice\Remove.exe,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=1)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {29D3F3CE-4A6F-4FC6-AEE3-ABAC4203F6E3} 3: C:\Users\mtarr\AppData\Local\LTspice\Remove.exe
    MSI (s) (C8:20) [10:46:50:731]: Executing op: ComponentRegister(ComponentId={3C849469-3A80-4C23-B9F9-401F90C1A70E},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc68.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {3C849469-3A80-4C23-B9F9-401F90C1A70E} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc68.new.js
    MSI (s) (C8:20) [10:46:50:732]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc68.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:732]: Executing op: ComponentRegister(ComponentId={67AF4F7A-C3E8-46FB-99DA-2FEA24AFE5E4},KeyPath=C:\Users\mtarr\AppData\Local\LTspice\Remove.txt,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {67AF4F7A-C3E8-46FB-99DA-2FEA24AFE5E4} 3: C:\Users\mtarr\AppData\Local\LTspice\Remove.txt
    MSI (s) (C8:20) [10:46:50:734]: Executing op: ComponentRegister(ComponentId={FC96FA67-16FB-4D7F-9AF1-1F48D32BC4CC},KeyPath=C:\Users\mtarr\AppData\Local\LTspice\examples.zip,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {FC96FA67-16FB-4D7F-9AF1-1F48D32BC4CC} 3: C:\Users\mtarr\AppData\Local\LTspice\examples.zip
    MSI (s) (C8:20) [10:46:50:735]: Executing op: ComponentRegister(ComponentId={5F9D59BB-4E7D-4629-B1F3-733F8B93E187},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\whtagdata.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {5F9D59BB-4E7D-4629-B1F3-733F8B93E187} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\whtagdata.js
    MSI (s) (C8:20) [10:46:50:736]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\whtagdata.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:737]: Executing op: ComponentRegister(ComponentId={053C271A-84E0-4B4C-8834-71D8FF477983},KeyPath=C:\Users\mtarr\AppData\Local\LTspice\lib.zip,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {053C271A-84E0-4B4C-8834-71D8FF477983} 3: C:\Users\mtarr\AppData\Local\LTspice\lib.zip
    MSI (s) (C8:20) [10:46:50:738]: Executing op: ComponentRegister(ComponentId={2386C15C-A94F-428D-9DEB-5732F9051F6D},KeyPath=C:\Users\mtarr\AppData\Local\LTspice\ChangeLog.txt,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2386C15C-A94F-428D-9DEB-5732F9051F6D} 3: C:\Users\mtarr\AppData\Local\LTspice\ChangeLog.txt
    MSI (s) (C8:20) [10:46:50:739]: Executing op: ComponentRegister(ComponentId={ED098D35-A27D-4503-A2CC-0CD5F38FE39C},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc59.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {ED098D35-A27D-4503-A2CC-0CD5F38FE39C} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc59.new.js
    MSI (s) (C8:20) [10:46:50:741]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc59.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:741]: Executing op: ComponentRegister(ComponentId={4FAEAF8D-D93E-4DB5-8718-3691FFDC309D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\aspecialfunctions.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {4FAEAF8D-D93E-4DB5-8718-3691FFDC309D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\aspecialfunctions.htm
    MSI (s) (C8:20) [10:46:50:742]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\aspecialfunctions.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:743]: Executing op: ComponentRegister(ComponentId={46A56299-E243-48EC-8811-8F8379DB59F6},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\pcbnetlistextraction.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {46A56299-E243-48EC-8811-8F8379DB59F6} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\pcbnetlistextraction.htm
    MSI (s) (C8:20) [10:46:50:744]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\pcbnetlistextraction.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:744]: Executing op: ComponentRegister(ComponentId={6F0DEDE0-CA8B-4709-81A5-7888A6B10398},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc66.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {6F0DEDE0-CA8B-4709-81A5-7888A6B10398} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc66.new.js
    MSI (s) (C8:20) [10:46:50:745]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc66.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:746]: Executing op: ComponentRegister(ComponentId={8159CA9D-BDA6-4C72-8E80-449F6F4D2CC9},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\hierarchy.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8159CA9D-BDA6-4C72-8E80-449F6F4D2CC9} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\hierarchy.htm
    MSI (s) (C8:20) [10:46:50:747]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\hierarchy.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:747]: Executing op: ComponentRegister(ComponentId={7A9E6C80-63B0-4F36-8F73-D721604DAC65},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\datatraceselection.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {7A9E6C80-63B0-4F36-8F73-D721604DAC65} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\datatraceselection.htm
    MSI (s) (C8:20) [10:46:50:748]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\datatraceselection.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:749]: Executing op: ComponentRegister(ComponentId={F0AEDA55-8958-4827-A6F5-2053B29B4F0D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc77.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F0AEDA55-8958-4827-A6F5-2053B29B4F0D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc77.new.js
    MSI (s) (C8:20) [10:46:50:750]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc77.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:750]: Executing op: ComponentRegister(ComponentId={378E870E-F99A-4CC7-B13D-EA8F56503183},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\additionalresources.html,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {378E870E-F99A-4CC7-B13D-EA8F56503183} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\additionalresources.html
    MSI (s) (C8:20) [10:46:50:752]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\additionalresources.html' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:752]: Executing op: ComponentRegister(ComponentId={1B513739-C685-45C7-96B5-16B6C17CB00F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\ac--performansmallsignalacanalys.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {1B513739-C685-45C7-96B5-16B6C17CB00F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\ac--performansmallsignalacanalys.htm
    MSI (s) (C8:20) [10:46:50:753]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\ac--performansmallsignalacanalys.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:753]: Executing op: ComponentRegister(ComponentId={2DF29417-FF10-4358-889F-4FB6DE704A8B},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc71.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2DF29417-FF10-4358-889F-4FB6DE704A8B} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc71.new.js
    MSI (s) (C8:20) [10:46:50:755]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc71.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:755]: Executing op: ComponentRegister(ComponentId={BDA7F730-A83B-4B40-873A-B14B64E81803},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\commandlineswitches.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {BDA7F730-A83B-4B40-873A-B14B64E81803} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\commandlineswitches.htm
    MSI (s) (C8:20) [10:46:50:756]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\commandlineswitches.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:757]: Executing op: ComponentRegister(ComponentId={443AFABE-3733-4E18-B478-AA838CBAAB1D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assistedmode.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {443AFABE-3733-4E18-B478-AA838CBAAB1D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assistedmode.htm
    MSI (s) (C8:20) [10:46:50:758]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assistedmode.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:758]: Executing op: ComponentRegister(ComponentId={1FE32170-0256-4070-8754-EBA52C669C1F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc7.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {1FE32170-0256-4070-8754-EBA52C669C1F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc7.new.js
    MSI (s) (C8:20) [10:46:50:760]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc7.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:760]: Executing op: ComponentRegister(ComponentId={4378A082-8D02-4F71-913A-61913D3446CB},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\inductormodels.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {4378A082-8D02-4F71-913A-61913D3446CB} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\inductormodels.htm
    MSI (s) (C8:20) [10:46:50:761]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\inductormodels.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:761]: Executing op: ComponentRegister(ComponentId={6DF0F37A-B0C0-4C35-89DA-5DD1D2686706},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\addingattributes.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {6DF0F37A-B0C0-4C35-89DA-5DD1D2686706} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\addingattributes.htm
    MSI (s) (C8:20) [10:46:50:763]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\addingattributes.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:763]: Executing op: ComponentRegister(ComponentId={98DC6DEF-2E40-44FA-A63B-7C1757B215A4},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc75.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {98DC6DEF-2E40-44FA-A63B-7C1757B215A4} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc75.new.js
    MSI (s) (C8:20) [10:46:50:764]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc75.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:765]: Executing op: ComponentRegister(ComponentId={F0673798-3552-41E0-AB59-5E78522B0563},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\parentdata.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F0673798-3552-41E0-AB59-5E78522B0563} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\parentdata.js
    MSI (s) (C8:20) [10:46:50:766]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\parentdata.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:766]: Executing op: ComponentRegister(ComponentId={010F0391-B85E-4EA8-8043-6665457E0789},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\faq.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {010F0391-B85E-4EA8-8043-6665457E0789} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\faq.htm
    MSI (s) (C8:20) [10:46:50:768]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\faq.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:768]: Executing op: ComponentRegister(ComponentId={9725D56C-35AB-490B-89FC-733AB3E5A144},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc92.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {9725D56C-35AB-490B-89FC-733AB3E5A144} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc92.new.js
    MSI (s) (C8:20) [10:46:50:769]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc92.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:770]: Executing op: ComponentRegister(ComponentId={432019AC-F81A-4DE7-8FC3-053AD28E7B9B},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\plotpanes.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {432019AC-F81A-4DE7-8FC3-053AD28E7B9B} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\plotpanes.htm
    MSI (s) (C8:20) [10:46:50:771]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\plotpanes.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:771]: Executing op: ComponentRegister(ComponentId={EFF6D4DF-EA60-4F25-BB56-1BD5271BA078},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\attributevisibility.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {EFF6D4DF-EA60-4F25-BB56-1BD5271BA078} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\attributevisibility.htm
    MSI (s) (C8:20) [10:46:50:773]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\attributevisibility.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:773]: Executing op: ComponentRegister(ComponentId={18BB1927-C92F-4094-8BB0-BCB34D5AA129},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc100.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {18BB1927-C92F-4094-8BB0-BCB34D5AA129} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc100.new.js
    MSI (s) (C8:20) [10:46:50:775]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc100.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:775]: Executing op: ComponentRegister(ComponentId={F06DAA6A-7850-48AB-A04E-8B36EFBA12D4},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\draftingoptions.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F06DAA6A-7850-48AB-A04E-8B36EFBA12D4} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\draftingoptions.htm
    MSI (s) (C8:20) [10:46:50:776]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\draftingoptions.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:777]: Executing op: ComponentRegister(ComponentId={54209388-B65B-4E30-8C92-F75408305083},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\howtogetabodeplotfromasmps.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {54209388-B65B-4E30-8C92-F75408305083} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\howtogetabodeplotfromasmps.htm
    MSI (s) (C8:20) [10:46:50:778]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\howtogetabodeplotfromasmps.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:778]: Executing op: ComponentRegister(ComponentId={19F4A41E-C9E3-43A9-ABF7-7661FDCC05A7},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc73.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {19F4A41E-C9E3-43A9-ABF7-7661FDCC05A7} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc73.new.js
    MSI (s) (C8:20) [10:46:50:780]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc73.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:780]: Executing op: ComponentRegister(ComponentId={EE743147-1CD1-473C-9D07-11F5C36D700D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\attachedcursors.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {EE743147-1CD1-473C-9D07-11F5C36D700D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\attachedcursors.htm
    MSI (s) (C8:20) [10:46:50:782]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\attachedcursors.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:782]: Executing op: ComponentRegister(ComponentId={3AE471B2-0521-4EF3-9422-CCEEAC172395},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\addingthepins.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {3AE471B2-0521-4EF3-9422-CCEEAC172395} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\addingthepins.htm
    MSI (s) (C8:20) [10:46:50:783]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\addingthepins.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:784]: Executing op: ComponentRegister(ComponentId={6802661F-6B88-41BC-B4A3-5E596C264B8E},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc49.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {6802661F-6B88-41BC-B4A3-5E596C264B8E} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc49.new.js
    MSI (s) (C8:20) [10:46:50:785]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc49.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:785]: Executing op: ComponentRegister(ComponentId={8FBA317B-B72C-4795-9B13-E72FFB417244},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\automaticsymbolgeneration.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8FBA317B-B72C-4795-9B13-E72FFB417244} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\automaticsymbolgeneration.htm
    MSI (s) (C8:20) [10:46:50:787]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\automaticsymbolgeneration.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:787]: Executing op: ComponentRegister(ComponentId={A2C8F94B-05A0-4579-8779-B7EC4E0120FD},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\net--computenetworkparametersina.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A2C8F94B-05A0-4579-8779-B7EC4E0120FD} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\net--computenetworkparametersina.htm
    MSI (s) (C8:20) [10:46:50:789]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\net--computenetworkparametersina.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:789]: Executing op: ComponentRegister(ComponentId={072AF6AB-A873-4477-A854-8C2480290CB9},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_topics.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {072AF6AB-A873-4477-A854-8C2480290CB9} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_topics.js
    MSI (s) (C8:20) [10:46:50:791]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_topics.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:791]: Executing op: ComponentRegister(ComponentId={411D6869-4E2A-4164-A41E-F6F35B86F1BC},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\customsymbols.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {411D6869-4E2A-4164-A41E-F6F35B86F1BC} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\customsymbols.htm
    MSI (s) (C8:20) [10:46:50:792]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\customsymbols.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:793]: Executing op: ComponentRegister(ComponentId={B3473EFF-C8EB-41D2-92D5-1422AAC5641D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\axiscontrol.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {B3473EFF-C8EB-41D2-92D5-1422AAC5641D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\axiscontrol.htm
    MSI (s) (C8:20) [10:46:50:794]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\axiscontrol.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:794]: Executing op: ComponentRegister(ComponentId={5F02B101-9560-4BC4-84CC-EA9D1FE4C686},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_fv_0.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {5F02B101-9560-4BC4-84CC-EA9D1FE4C686} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_fv_0.js
    MSI (s) (C8:20) [10:46:50:796]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_fv_0.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:796]: Executing op: ComponentRegister(ComponentId={007FD985-D1C2-4BBB-B21D-757F0EE8FF36},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\operation.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {007FD985-D1C2-4BBB-B21D-757F0EE8FF36} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\operation.htm
    MSI (s) (C8:20) [10:46:50:798]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\operation.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:798]: Executing op: ComponentRegister(ComponentId={62516DBF-FF70-4A68-93C8-8AB84BBA6EA8},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\examplecircuits.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {62516DBF-FF70-4A68-93C8-8AB84BBA6EA8} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\examplecircuits.htm
    MSI (s) (C8:20) [10:46:50:800]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\examplecircuits.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:800]: Executing op: ComponentRegister(ComponentId={843C708A-AA5F-422F-8F55-4CD53549B717},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_auto_model_0.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {843C708A-AA5F-422F-8F55-4CD53549B717} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_auto_model_0.js
    MSI (s) (C8:20) [10:46:50:801]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_auto_model_0.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:801]: Executing op: ComponentRegister(ComponentId={1CBF7692-9FCF-4177-9534-A5B46B576B85},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\ddiode.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {1CBF7692-9FCF-4177-9534-A5B46B576B85} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\ddiode.htm
    MSI (s) (C8:20) [10:46:50:803]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\ddiode.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:803]: Executing op: ComponentRegister(ComponentId={807FA78F-7006-461C-92D3-61242C7D2914},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\runningunderlinux.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {807FA78F-7006-461C-92D3-61242C7D2914} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\runningunderlinux.htm
    MSI (s) (C8:20) [10:46:50:804]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\runningunderlinux.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:805]: Executing op: ComponentRegister(ComponentId={D2622822-7A6F-4E50-8D8F-6C8C0BD248A8},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_ii_0.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D2622822-7A6F-4E50-8D8F-6C8C0BD248A8} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_ii_0.js.gz
    MSI (s) (C8:20) [10:46:50:806]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_ii_0.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:806]: Executing op: ComponentRegister(ComponentId={D71F4F65-52B4-4261-8962-6AB202FD4A77},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\backanno--annotatethesubcircuitp.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D71F4F65-52B4-4261-8962-6AB202FD4A77} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\backanno--annotatethesubcircuitp.htm
    MSI (s) (C8:20) [10:46:50:808]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\backanno--annotatethesubcircuitp.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:808]: Executing op: ComponentRegister(ComponentId={8DB2C6B4-EF83-4B5C-AF28-C3AE42DEA374},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\barbitrarybehavioralvoltageorcur.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8DB2C6B4-EF83-4B5C-AF28-C3AE42DEA374} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\barbitrarybehavioralvoltageorcur.htm
    MSI (s) (C8:20) [10:46:50:809]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\barbitrarybehavioralvoltageorcur.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:810]: Executing op: ComponentRegister(ComponentId={BB961D9D-7729-4AD3-80C4-5639AB765AB1},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc10.new.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {BB961D9D-7729-4AD3-80C4-5639AB765AB1} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc10.new.js.gz
    MSI (s) (C8:20) [10:46:50:811]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc10.new.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:811]: Executing op: ComponentRegister(ComponentId={BD55636A-900B-47AD-8905-FAE7FAF5FD61},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\basicschematicediting.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {BD55636A-900B-47AD-8905-FAE7FAF5FD61} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\basicschematicediting.htm
    MSI (s) (C8:20) [10:46:50:813]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\basicschematicediting.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:813]: Executing op: ComponentRegister(ComponentId={2C58A04A-B13F-4143-B331-D3CF033FE764},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\ccapacitor.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2C58A04A-B13F-4143-B331-D3CF033FE764} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\ccapacitor.htm
    MSI (s) (C8:20) [10:46:50:815]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\ccapacitor.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:815]: Executing op: ComponentRegister(ComponentId={3EA39D02-5BBF-48E5-AC84-D2A6464DD6BC},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\stopwords.xml,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {3EA39D02-5BBF-48E5-AC84-D2A6464DD6BC} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\stopwords.xml
    MSI (s) (C8:20) [10:46:50:816]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\stopwords.xml' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:816]: Executing op: ComponentRegister(ComponentId={2FFFFB11-14A2-48C1-A925-560242246926},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\spice.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2FFFFB11-14A2-48C1-A925-560242246926} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\spice.htm
    MSI (s) (C8:20) [10:46:50:818]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\spice.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:818]: Executing op: ComponentRegister(ComponentId={84E2B1AB-6B8F-4811-8D9B-D7D3FA874E04},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\circuitelements.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {84E2B1AB-6B8F-4811-8D9B-D7D3FA874E04} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\circuitelements.htm
    MSI (s) (C8:20) [10:46:50:820]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\circuitelements.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:820]: Executing op: ComponentRegister(ComponentId={1CCC6D30-A49E-4EFE-81B5-4079A21CB366},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_ii_0.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {1CCC6D30-A49E-4EFE-81B5-4079A21CB366} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_ii_0.js
    MSI (s) (C8:20) [10:46:50:821]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_ii_0.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:821]: Executing op: ComponentRegister(ComponentId={F12FF1D4-7C6E-4B37-8067-425ADCF51D16},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\exportingwaveformdata.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F12FF1D4-7C6E-4B37-8067-425ADCF51D16} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\exportingwaveformdata.htm
    MSI (s) (C8:20) [10:46:50:823]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\exportingwaveformdata.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:823]: Executing op: ComponentRegister(ComponentId={83A0AADC-FFEF-46BD-B469-98BFD309F60D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\colorcontrol.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {83A0AADC-FFEF-46BD-B469-98BFD309F60D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\colorcontrol.htm
    MSI (s) (C8:20) [10:46:50:824]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\colorcontrol.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:825]: Executing op: ComponentRegister(ComponentId={51E1D355-183F-4D6F-931B-E5D22F3F481A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc1.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {51E1D355-183F-4D6F-931B-E5D22F3F481A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc1.new.js
    MSI (s) (C8:20) [10:46:50:826]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc1.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:826]: Executing op: ComponentRegister(ComponentId={F0CDA7F6-D9AE-4688-9A05-D91E571F1C88},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\save--limitthequantityofsaveddat.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F0CDA7F6-D9AE-4688-9A05-D91E571F1C88} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\save--limitthequantityofsaveddat.htm
    MSI (s) (C8:20) [10:46:50:828]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\save--limitthequantityofsaveddat.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:828]: Executing op: ComponentRegister(ComponentId={BD1BC827-E1F9-4792-9BB3-265C8F86CB35},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\convergence.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {BD1BC827-E1F9-4792-9BB3-265C8F86CB35} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\convergence.htm
    MSI (s) (C8:20) [10:46:50:829]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\convergence.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:829]: Executing op: ComponentRegister(ComponentId={1A460D27-6EE5-4A4B-9CCF-FAB5D650D0D5},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc109.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {1A460D27-6EE5-4A4B-9CCF-FAB5D650D0D5} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc109.new.js
    MSI (s) (C8:20) [10:46:50:830]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc109.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:831]: Executing op: ComponentRegister(ComponentId={68D807EB-6F1E-4C05-80D3-492372F0A003},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\compression.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {68D807EB-6F1E-4C05-80D3-492372F0A003} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\compression.htm
    MSI (s) (C8:20) [10:46:50:832]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\compression.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:832]: Executing op: ComponentRegister(ComponentId={53F589A8-57A9-40E7-BE34-D037D7B7972B},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\creatingnewsymbols.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {53F589A8-57A9-40E7-BE34-D037D7B7972B} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\creatingnewsymbols.htm
    MSI (s) (C8:20) [10:46:50:833]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\creatingnewsymbols.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:834]: Executing op: ComponentRegister(ComponentId={37516611-10EE-4F28-9DE7-876B1420E396},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc103.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {37516611-10EE-4F28-9DE7-876B1420E396} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc103.new.js
    MSI (s) (C8:20) [10:46:50:835]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc103.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:835]: Executing op: ComponentRegister(ComponentId={9F772B9A-26DD-48B0-8B7B-8E8E9520460C},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\dotkeep.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {9F772B9A-26DD-48B0-8B7B-8E8E9520460C} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\dotkeep.htm
    MSI (s) (C8:20) [10:46:50:837]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\dotkeep.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:837]: Executing op: ComponentRegister(ComponentId={52AF9F8E-453A-4999-8E82-F4C67DD54CF6},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\loadbias--loadapreviouslysolvedd.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {52AF9F8E-453A-4999-8E82-F4C67DD54CF6} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\loadbias--loadapreviouslysolvedd.htm
    MSI (s) (C8:20) [10:46:50:839]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\loadbias--loadapreviouslysolvedd.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:839]: Executing op: ComponentRegister(ComponentId={407ABAA1-425A-4EF4-811B-0DEBBAE3DAA2},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\whfts.xml,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {407ABAA1-425A-4EF4-811B-0DEBBAE3DAA2} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\whfts.xml
    MSI (s) (C8:20) [10:46:50:840]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\whfts.xml' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:840]: Executing op: ComponentRegister(ComponentId={55AC775A-FB68-40BB-AB91-C9FB46CFBF01},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\dc--performadcsourcesweepanalysi.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {55AC775A-FB68-40BB-AB91-C9FB46CFBF01} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\dc--performadcsourcesweepanalysi.htm
    MSI (s) (C8:20) [10:46:50:842]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\dc--performadcsourcesweepanalysi.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:842]: Executing op: ComponentRegister(ComponentId={72AB219D-FBFE-45BC-AB47-5B894E3AD645},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\navigatingthehierarchy.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {72AB219D-FBFE-45BC-AB47-5B894E3AD645} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\navigatingthehierarchy.htm
    MSI (s) (C8:20) [10:46:50:844]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\navigatingthehierarchy.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:844]: Executing op: ComponentRegister(ComponentId={0BCE9F47-6D79-4B62-96FE-1AF58AB6E2E9},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc108.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0BCE9F47-6D79-4B62-96FE-1AF58AB6E2E9} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc108.new.js
    MSI (s) (C8:20) [10:46:50:845]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc108.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:845]: Executing op: ComponentRegister(ComponentId={E28280AE-B169-4DE3-A148-9D9506E40CCC},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\internetoptions.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {E28280AE-B169-4DE3-A148-9D9506E40CCC} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\internetoptions.htm
    MSI (s) (C8:20) [10:46:50:847]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\internetoptions.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:847]: Executing op: ComponentRegister(ComponentId={3DBA3BF3-80AC-4D67-8630-3346C743DD18},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\dotcommands.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {3DBA3BF3-80AC-4D67-8630-3346C743DD18} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\dotcommands.htm
    MSI (s) (C8:20) [10:46:50:849]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\dotcommands.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:849]: Executing op: ComponentRegister(ComponentId={00836444-9677-4FDD-8B0B-1D9BD1D7A613},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc118.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {00836444-9677-4FDD-8B0B-1D9BD1D7A613} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc118.new.js
    MSI (s) (C8:20) [10:46:50:850]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc118.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:850]: Executing op: ComponentRegister(ComponentId={7527F98F-DA8A-4A92-9810-AF41DB4381BC},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\fra_probe.html,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {7527F98F-DA8A-4A92-9810-AF41DB4381BC} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\fra_probe.html
    MSI (s) (C8:20) [10:46:50:852]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\fra_probe.html' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:852]: Executing op: ComponentRegister(ComponentId={223B9163-D956-4088-BD28-319F60E3C794},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\dotfra.html,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {223B9163-D956-4088-BD28-319F60E3C794} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\dotfra.html
    MSI (s) (C8:20) [10:46:50:853]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\dotfra.html' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:853]: Executing op: ComponentRegister(ComponentId={43831726-95EE-472F-BCBA-CB898CC81553},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc4.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {43831726-95EE-472F-BCBA-CB898CC81553} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc4.new.js
    MSI (s) (C8:20) [10:46:50:855]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc4.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:855]: Executing op: ComponentRegister(ComponentId={0682601A-AF3A-4B34-9E36-3CF25B392CA1},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\drawingthebody.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0682601A-AF3A-4B34-9E36-3CF25B392CA1} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\drawingthebody.htm
    MSI (s) (C8:20) [10:46:50:856]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\drawingthebody.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:857]: Executing op: ComponentRegister(ComponentId={17B17C8D-2625-4936-8D01-A9B5D1A7200A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\editingcomponents.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {17B17C8D-2625-4936-8D01-A9B5D1A7200A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\editingcomponents.htm
    MSI (s) (C8:20) [10:46:50:858]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\editingcomponents.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:858]: Executing op: ComponentRegister(ComponentId={94FCA362-0725-4DEE-BCD2-15681D6D8523},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc105.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {94FCA362-0725-4DEE-BCD2-15681D6D8523} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc105.new.js
    MSI (s) (C8:20) [10:46:50:860]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc105.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:860]: Executing op: ComponentRegister(ComponentId={B0A3FE16-1704-4574-831E-30140A39DD52},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\efficiencycalculation.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {B0A3FE16-1704-4574-831E-30140A39DD52} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\efficiencycalculation.htm
    MSI (s) (C8:20) [10:46:50:861]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\efficiencycalculation.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:862]: Executing op: ComponentRegister(ComponentId={3499B806-F906-463B-B3AD-36318AEC1AC9},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\hacks.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {3499B806-F906-463B-B3AD-36318AEC1AC9} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\hacks.htm
    MSI (s) (C8:20) [10:46:50:863]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\hacks.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:863]: Executing op: ComponentRegister(ComponentId={2BC13C26-7261-49B8-8434-911347D79456},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc116.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2BC13C26-7261-49B8-8434-911347D79456} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc116.new.js
    MSI (s) (C8:20) [10:46:50:865]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc116.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:865]: Executing op: ComponentRegister(ComponentId={82649DD5-5EC6-48C8-9E03-3691E63B1D88},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\efficiencyreport.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {82649DD5-5EC6-48C8-9E03-3691E63B1D88} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\efficiencyreport.htm
    MSI (s) (C8:20) [10:46:50:866]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\efficiencyreport.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:867]: Executing op: ComponentRegister(ComponentId={8CDBD7F5-B752-48D3-B594-42917ED15C34},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\integrationmethods.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8CDBD7F5-B752-48D3-B594-42917ED15C34} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\integrationmethods.htm
    MSI (s) (C8:20) [10:46:50:868]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\integrationmethods.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:868]: Executing op: ComponentRegister(ComponentId={39A6A35B-E113-461B-ADB7-82B26E646816},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\end--endofnetlist.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {39A6A35B-E113-461B-ADB7-82B26E646816} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\end--endofnetlist.htm
    MSI (s) (C8:20) [10:46:50:870]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\end--endofnetlist.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:870]: Executing op: ComponentRegister(ComponentId={D58B4817-D645-47DC-B7A6-511CC2491690},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\fcurrentdependentcurrentsource.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D58B4817-D645-47DC-B7A6-511CC2491690} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\fcurrentdependentcurrentsource.htm
    MSI (s) (C8:20) [10:46:50:871]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\fcurrentdependentcurrentsource.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:872]: Executing op: ComponentRegister(ComponentId={D758586A-F121-4687-85D2-95FCCCB306C0},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\ends--endofsubcircuitdefinition.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D758586A-F121-4687-85D2-95FCCCB306C0} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\ends--endofsubcircuitdefinition.htm
    MSI (s) (C8:20) [10:46:50:873]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\ends--endofsubcircuitdefinition.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:873]: Executing op: ComponentRegister(ComponentId={10A7463C-586B-4072-BD99-4ECDF05115FB},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\uuniformrc-line.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {10A7463C-586B-4072-BD99-4ECDF05115FB} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\uuniformrc-line.htm
    MSI (s) (C8:20) [10:46:50:875]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\uuniformrc-line.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:875]: Executing op: ComponentRegister(ComponentId={97D864F2-3645-412C-9950-DCD38D56015F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\evoltagedependentvoltagesource.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {97D864F2-3645-412C-9950-DCD38D56015F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\evoltagedependentvoltagesource.htm
    MSI (s) (C8:20) [10:46:50:876]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\evoltagedependentvoltagesource.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:877]: Executing op: ComponentRegister(ComponentId={30EC362A-61E0-44C4-A2E4-6DC99DCA4982},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\expertmode.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {30EC362A-61E0-44C4-A2E4-6DC99DCA4982} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\expertmode.htm
    MSI (s) (C8:20) [10:46:50:878]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\expertmode.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:878]: Executing op: ComponentRegister(ComponentId={82301F46-D400-4CD3-9073-AB9D83FDAD25},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\externallygeneratednetlists.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {82301F46-D400-4CD3-9073-AB9D83FDAD25} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\externallygeneratednetlists.htm
    MSI (s) (C8:20) [10:46:50:880]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\externallygeneratednetlists.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:880]: Executing op: ComponentRegister(ComponentId={F0C9EA37-0EFC-49B5-B0C2-AD133EA3FFC2},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\fastaccessfileformat.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F0C9EA37-0EFC-49B5-B0C2-AD133EA3FFC2} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\fastaccessfileformat.htm
    MSI (s) (C8:20) [10:46:50:882]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\fastaccessfileformat.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:882]: Executing op: ComponentRegister(ComponentId={43F5E2B5-9AE3-4C7C-8FAC-4D26C05474C4},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\four--computeafouriercomponent.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {43F5E2B5-9AE3-4C7C-8FAC-4D26C05474C4} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\four--computeafouriercomponent.htm
    MSI (s) (C8:20) [10:46:50:883]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\four--computeafouriercomponent.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:883]: Executing op: ComponentRegister(ComponentId={488FD3ED-ABB8-403D-966E-8C1310E40B48},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\fra_device.html,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {488FD3ED-ABB8-403D-966E-8C1310E40B48} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\fra_device.html
    MSI (s) (C8:20) [10:46:50:885]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\fra_device.html' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:885]: Executing op: ComponentRegister(ComponentId={AB2867B8-155D-4EF3-89AF-860B77F5957A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\func--userdefinedfunctions.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {AB2867B8-155D-4EF3-89AF-860B77F5957A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\func--userdefinedfunctions.htm
    MSI (s) (C8:20) [10:46:50:887]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\func--userdefinedfunctions.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:887]: Executing op: ComponentRegister(ComponentId={62DD9A51-AD3C-4471-BAFC-877C9420F9A8},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\generalpurposeschematicdrivenspi.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {62DD9A51-AD3C-4471-BAFC-877C9420F9A8} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\generalpurposeschematicdrivenspi.htm
    MSI (s) (C8:20) [10:46:50:888]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\generalpurposeschematicdrivenspi.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:889]: Executing op: ComponentRegister(ComponentId={643B6154-3EC3-4A50-8356-6F280138C949},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\generalstructureandconventions.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {643B6154-3EC3-4A50-8356-6F280138C949} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\generalstructureandconventions.htm
    MSI (s) (C8:20) [10:46:50:890]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\generalstructureandconventions.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:890]: Executing op: ComponentRegister(ComponentId={7B2942BB-6DCF-433D-A05F-72C594ACB635},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\global--declareglobalnodes.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {7B2942BB-6DCF-433D-A05F-72C594ACB635} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\global--declareglobalnodes.htm
    MSI (s) (C8:20) [10:46:50:892]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\global--declareglobalnodes.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:892]: Executing op: ComponentRegister(ComponentId={0980041E-3101-4ECB-AB77-DE21BD851BF7},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\gvoltagedependentcurrentsource.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0980041E-3101-4ECB-AB77-DE21BD851BF7} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\gvoltagedependentcurrentsource.htm
    MSI (s) (C8:20) [10:46:50:894]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\gvoltagedependentcurrentsource.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:894]: Executing op: ComponentRegister(ComponentId={D73AAA08-2B39-47C6-806E-2A6B3B6C623A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\hcurrentdependentvoltagesource.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D73AAA08-2B39-47C6-806E-2A6B3B6C623A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\hcurrentdependentvoltagesource.htm
    MSI (s) (C8:20) [10:46:50:895]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\hcurrentdependentvoltagesource.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:896]: Executing op: ComponentRegister(ComponentId={0EEA3B5C-CF40-45F6-B516-F3B871FDC5BC},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\ic--setinitialconditions.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0EEA3B5C-CF40-45F6-B516-F3B871FDC5BC} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\ic--setinitialconditions.htm
    MSI (s) (C8:20) [10:46:50:897]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\ic--setinitialconditions.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:897]: Executing op: ComponentRegister(ComponentId={ED1CD660-6A69-48D3-B5E0-EA57187C4F60},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\icurrentsource.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {ED1CD660-6A69-48D3-B5E0-EA57187C4F60} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\icurrentsource.htm
    MSI (s) (C8:20) [10:46:50:899]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\icurrentsource.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:899]: Executing op: ComponentRegister(ComponentId={4F37288D-92E4-4B58-BB18-74D493A069F7},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\step.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {4F37288D-92E4-4B58-BB18-74D493A069F7} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\step.htm
    MSI (s) (C8:20) [10:46:50:901]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\step.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:901]: Executing op: ComponentRegister(ComponentId={AC982D11-D86E-4DEE-81F3-7D863F3FCE2E},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\include--includeanotherfile.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {AC982D11-D86E-4DEE-81F3-7D863F3FCE2E} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\include--includeanotherfile.htm
    MSI (s) (C8:20) [10:46:50:903]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\include--includeanotherfile.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:903]: Executing op: ComponentRegister(ComponentId={114D0B89-135F-4422-A1FF-BD3DD33B3A45},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\index.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {114D0B89-135F-4422-A1FF-BD3DD33B3A45} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\index.htm
    MSI (s) (C8:20) [10:46:50:904]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\index.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:905]: Executing op: ComponentRegister(ComponentId={70A16220-64A4-46A2-A787-001F45FE1483},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\index.ppf,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {70A16220-64A4-46A2-A787-001F45FE1483} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\index.ppf
    MSI (s) (C8:20) [10:46:50:906]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\index.ppf' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:906]: Executing op: ComponentRegister(ComponentId={0DE81556-F29B-43F0-9ECE-707CD0B1510C},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\introduction.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0DE81556-F29B-43F0-9ECE-707CD0B1510C} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\introduction.htm
    MSI (s) (C8:20) [10:46:50:908]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\introduction.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:908]: Executing op: ComponentRegister(ComponentId={81335983-F5E0-41F3-9843-11482AC06C95},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\introduction1.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {81335983-F5E0-41F3-9843-11482AC06C95} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\introduction1.htm
    MSI (s) (C8:20) [10:46:50:910]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\introduction1.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:910]: Executing op: ComponentRegister(ComponentId={8DA12DF7-D0F8-4AD4-8C87-F1EDC636F44E},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc23.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8DA12DF7-D0F8-4AD4-8C87-F1EDC636F44E} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc23.new.js
    MSI (s) (C8:20) [10:46:50:911]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc23.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:911]: Executing op: ComponentRegister(ComponentId={891F2BCE-324F-4535-8BC4-3EF7646FC68F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\jjfet.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {891F2BCE-324F-4535-8BC4-3EF7646FC68F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\jjfet.htm
    MSI (s) (C8:20) [10:46:50:913]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\jjfet.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:913]: Executing op: ComponentRegister(ComponentId={97975334-52C8-4A8C-8A6E-BD203D67AB23},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\keyboardshortcuts.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {97975334-52C8-4A8C-8A6E-BD203D67AB23} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\keyboardshortcuts.htm
    MSI (s) (C8:20) [10:46:50:914]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\keyboardshortcuts.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:914]: Executing op: ComponentRegister(ComponentId={FC223C36-77CF-4FA3-AF53-0359D2CA187D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc18.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {FC223C36-77CF-4FA3-AF53-0359D2CA187D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc18.new.js
    MSI (s) (C8:20) [10:46:50:916]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc18.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:916]: Executing op: ComponentRegister(ComponentId={EA5028A1-6B68-413E-A637-8EDA9C9DBC61},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\kmutualinductance.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {EA5028A1-6B68-413E-A637-8EDA9C9DBC61} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\kmutualinductance.htm
    MSI (s) (C8:20) [10:46:50:917]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\kmutualinductance.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:917]: Executing op: ComponentRegister(ComponentId={3D0F693A-4480-47D5-AAF1-65002E91153D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\labelanodename.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {3D0F693A-4480-47D5-AAF1-65002E91153D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\labelanodename.htm
    MSI (s) (C8:20) [10:46:50:919]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\labelanodename.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:919]: Executing op: ComponentRegister(ComponentId={CF9C7BAB-F934-4249-9F99-6A55E9C2C888},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\lib--includealibrary.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {CF9C7BAB-F934-4249-9F99-6A55E9C2C888} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\lib--includealibrary.htm
    MSI (s) (C8:20) [10:46:50:920]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\lib--includealibrary.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:921]: Executing op: ComponentRegister(ComponentId={9890E715-53D5-4B34-949C-E3C68ABA407C},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\licenseagreementdisclaimer.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {9890E715-53D5-4B34-949C-E3C68ABA407C} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\licenseagreementdisclaimer.htm
    MSI (s) (C8:20) [10:46:50:922]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\licenseagreementdisclaimer.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:922]: Executing op: ComponentRegister(ComponentId={81B1D1C1-9028-41A0-A2CA-C6252C6DCDB5},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc21.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {81B1D1C1-9028-41A0-A2CA-C6252C6DCDB5} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc21.new.js
    MSI (s) (C8:20) [10:46:50:924]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc21.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:924]: Executing op: ComponentRegister(ComponentId={0D4D5B81-9A21-4C6D-883C-A7A4F8F3620B},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\xsubcircuit.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0D4D5B81-9A21-4C6D-883C-A7A4F8F3620B} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\xsubcircuit.htm
    MSI (s) (C8:20) [10:46:50:926]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\xsubcircuit.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:926]: Executing op: ComponentRegister(ComponentId={A64550AF-C08B-4E25-94E2-E6CB0FF22C93},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\startup.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A64550AF-C08B-4E25-94E2-E6CB0FF22C93} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\startup.htm
    MSI (s) (C8:20) [10:46:50:927]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\startup.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:928]: Executing op: ComponentRegister(ComponentId={8F0AB6D9-52B3-4106-B518-BD4E55BE88B9},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc3.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8F0AB6D9-52B3-4106-B518-BD4E55BE88B9} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc3.new.js
    MSI (s) (C8:20) [10:46:50:929]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc3.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:929]: Executing op: ComponentRegister(ComponentId={C67D2F7F-349D-49F7-8278-7FBE3EE8B65F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\licenseanddistribution.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {C67D2F7F-349D-49F7-8278-7FBE3EE8B65F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\licenseanddistribution.htm
    MSI (s) (C8:20) [10:46:50:931]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\licenseanddistribution.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:931]: Executing op: ComponentRegister(ComponentId={01C107C7-36ED-4EAC-BDA2-5D3F975C7C52},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\linductor.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {01C107C7-36ED-4EAC-BDA2-5D3F975C7C52} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\linductor.htm
    MSI (s) (C8:20) [10:46:50:932]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\linductor.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:933]: Executing op: ComponentRegister(ComponentId={DB68D579-B306-47B4-8D44-D3C1F60E989C},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc25.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {DB68D579-B306-47B4-8D44-D3C1F60E989C} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc25.new.js
    MSI (s) (C8:20) [10:46:50:934]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc25.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:934]: Executing op: ComponentRegister(ComponentId={5786FF3E-95AD-4D7F-8072-AB919C73F1EC},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\loadstate.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {5786FF3E-95AD-4D7F-8072-AB919C73F1EC} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\loadstate.htm
    MSI (s) (C8:20) [10:46:50:935]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\loadstate.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:936]: Executing op: ComponentRegister(ComponentId={B1EF9154-18A6-45D9-B8E3-D70942E02D9A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\ltspice.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {B1EF9154-18A6-45D9-B8E3-D70942E02D9A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\ltspice.htm
    MSI (s) (C8:20) [10:46:50:937]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\ltspice.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:937]: Executing op: ComponentRegister(ComponentId={9D194141-4E4A-4E2D-B24A-7F5A06DA7044},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc2.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {9D194141-4E4A-4E2D-B24A-7F5A06DA7044} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc2.new.js
    MSI (s) (C8:20) [10:46:50:938]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc2.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:939]: Executing op: ComponentRegister(ComponentId={CED1A160-443A-4C6D-B06C-DAE2C89160D3},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\machine--arbitrarystatemachine.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {CED1A160-443A-4C6D-B06C-DAE2C89160D3} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\machine--arbitrarystatemachine.htm
    MSI (s) (C8:20) [10:46:50:940]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\machine--arbitrarystatemachine.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:940]: Executing op: ComponentRegister(ComponentId={BA42F6FD-928D-4430-AD57-43FEA136D08D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\measure--evaluateuser-definedele.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {BA42F6FD-928D-4430-AD57-43FEA136D08D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\measure--evaluateuser-definedele.htm
    MSI (s) (C8:20) [10:46:50:941]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\measure--evaluateuser-definedele.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:942]: Executing op: ComponentRegister(ComponentId={B5D649B0-E7F6-4BC2-8775-FBA960DE1E35},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc96.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {B5D649B0-E7F6-4BC2-8775-FBA960DE1E35} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc96.new.js
    MSI (s) (C8:20) [10:46:50:943]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc96.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:943]: Executing op: ComponentRegister(ComponentId={43CA2CAA-AC37-421A-9091-70A075B232E1},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\memoryproblems.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {43CA2CAA-AC37-421A-9091-70A075B232E1} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\memoryproblems.htm
    MSI (s) (C8:20) [10:46:50:945]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\memoryproblems.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:945]: Executing op: ComponentRegister(ComponentId={D3F5B478-29DB-4B6A-93CA-A1659CFD4464},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\mmosfet.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D3F5B478-29DB-4B6A-93CA-A1659CFD4464} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\mmosfet.htm
    MSI (s) (C8:20) [10:46:50:947]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\mmosfet.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:947]: Executing op: ComponentRegister(ComponentId={18B6C686-9C83-454B-8FD9-305D7FA49250},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc36.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {18B6C686-9C83-454B-8FD9-305D7FA49250} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc36.new.js
    MSI (s) (C8:20) [10:46:50:948]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc36.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:948]: Executing op: ComponentRegister(ComponentId={3EE17714-EFCA-420A-858A-8C5B4454F3CF},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\model--defineaspicemodel.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {3EE17714-EFCA-420A-858A-8C5B4454F3CF} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\model--defineaspicemodel.htm
    MSI (s) (C8:20) [10:46:50:950]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\model--defineaspicemodel.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:950]: Executing op: ComponentRegister(ComponentId={CCAC269F-1F52-45DF-9336-563548B96237},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\modelcompatibility.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {CCAC269F-1F52-45DF-9336-563548B96237} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\modelcompatibility.htm
    MSI (s) (C8:20) [10:46:50:952]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\modelcompatibility.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:952]: Executing op: ComponentRegister(ComponentId={CBD6B2B9-F158-44A0-948A-8349F228B668},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc30.new.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {CBD6B2B9-F158-44A0-948A-8349F228B668} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc30.new.js.gz
    MSI (s) (C8:20) [10:46:50:953]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc30.new.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:954]: Executing op: ComponentRegister(ComponentId={A092C594-93B4-49CB-A8C3-8BEF312BD2B7},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\modesofoperation.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A092C594-93B4-49CB-A8C3-8BEF312BD2B7} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\modesofoperation.htm
    MSI (s) (C8:20) [10:46:50:955]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\modesofoperation.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:955]: Executing op: ComponentRegister(ComponentId={F07D8EDE-2C3A-4B1D-AF8D-E70AED80ACBD},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\mosfetmodels.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F07D8EDE-2C3A-4B1D-AF8D-E70AED80ACBD} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\mosfetmodels.htm
    MSI (s) (C8:20) [10:46:50:957]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\mosfetmodels.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:957]: Executing op: ComponentRegister(ComponentId={35BC06DB-B66D-498C-A6AD-B2C70ED402CB},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc27.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {35BC06DB-B66D-498C-A6AD-B2C70ED402CB} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc27.new.js
    MSI (s) (C8:20) [10:46:50:959]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc27.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:959]: Executing op: ComponentRegister(ComponentId={A502884D-C9C7-444E-B532-CB8353058B0D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\netlistoptions.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A502884D-C9C7-444E-B532-CB8353058B0D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\netlistoptions.htm
    MSI (s) (C8:20) [10:46:50:960]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\netlistoptions.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:961]: Executing op: ComponentRegister(ComponentId={0CA2A201-0303-4EEF-9C61-035266AA27B5},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\nodeset--supplyhintsforinitialdc.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0CA2A201-0303-4EEF-9C61-035266AA27B5} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\nodeset--supplyhintsforinitialdc.htm
    MSI (s) (C8:20) [10:46:50:962]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\nodeset--supplyhintsforinitialdc.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:962]: Executing op: ComponentRegister(ComponentId={06FCDD04-43FE-4ECC-A207-59CFA7EEF6FA},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc34.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {06FCDD04-43FE-4ECC-A207-59CFA7EEF6FA} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc34.new.js
    MSI (s) (C8:20) [10:46:50:964]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc34.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:964]: Executing op: ComponentRegister(ComponentId={7C31E154-5CA4-4A30-A749-DF4713BE4E76},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\nodiscard.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {7C31E154-5CA4-4A30-A749-DF4713BE4E76} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\nodiscard.htm
    MSI (s) (C8:20) [10:46:50:966]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\nodiscard.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:966]: Executing op: ComponentRegister(ComponentId={BFE993AF-D86C-4C46-965B-7472E4C31779},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\noise--performanoiseanalysis.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {BFE993AF-D86C-4C46-965B-7472E4C31779} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\noise--performanoiseanalysis.htm
    MSI (s) (C8:20) [10:46:50:967]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\noise--performanoiseanalysis.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:968]: Executing op: ComponentRegister(ComponentId={0D0F1106-9F89-4FAD-808F-985CC76D22D1},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc44.new.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0D0F1106-9F89-4FAD-808F-985CC76D22D1} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc44.new.js.gz
    MSI (s) (C8:20) [10:46:50:969]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc44.new.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:969]: Executing op: ComponentRegister(ComponentId={026B9C14-DFEA-43FA-975A-8921AF939C28},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\olossytransmissionline.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {026B9C14-DFEA-43FA-975A-8921AF939C28} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\olossytransmissionline.htm
    MSI (s) (C8:20) [10:46:50:971]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\olossytransmissionline.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:971]: Executing op: ComponentRegister(ComponentId={39FA32D3-21FE-467F-97C3-2A51F37BEFEC},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\op--findthedcoperatingpoint.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {39FA32D3-21FE-467F-97C3-2A51F37BEFEC} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\op--findthedcoperatingpoint.htm
    MSI (s) (C8:20) [10:46:50:973]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\op--findthedcoperatingpoint.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:973]: Executing op: ComponentRegister(ComponentId={DF8ECD03-5B73-4A89-BDAC-2326177ABEE5},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc38.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {DF8ECD03-5B73-4A89-BDAC-2326177ABEE5} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc38.new.js
    MSI (s) (C8:20) [10:46:50:975]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc38.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:975]: Executing op: ComponentRegister(ComponentId={3DF82B52-D250-4710-8262-BCD7EF964C06},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\user-definedfunctions.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {3DF82B52-D250-4710-8262-BCD7EF964C06} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\user-definedfunctions.htm
    MSI (s) (C8:20) [10:46:50:976]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\user-definedfunctions.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:977]: Executing op: ComponentRegister(ComponentId={274CFC39-40E5-4084-9A19-9A8E962DF9C4},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\options--setsimulatoroptions.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {274CFC39-40E5-4084-9A19-9A8E962DF9C4} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\options--setsimulatoroptions.htm
    MSI (s) (C8:20) [10:46:50:978]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\options--setsimulatoroptions.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:978]: Executing op: ComponentRegister(ComponentId={A739465C-67AF-470F-BCAC-C58A5D52CE8F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc32.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A739465C-67AF-470F-BCAC-C58A5D52CE8F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc32.new.js
    MSI (s) (C8:20) [10:46:50:980]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc32.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:980]: Executing op: ComponentRegister(ComponentId={436A0530-DA15-4A34-AF17-A36FD7D6A14A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\param--user-definedparameters.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {436A0530-DA15-4A34-AF17-A36FD7D6A14A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\param--user-definedparameters.htm
    MSI (s) (C8:20) [10:46:50:982]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\param--user-definedparameters.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:982]: Executing op: ComponentRegister(ComponentId={F8FB3DEA-014B-4D4A-A40D-541C62872C1A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\placingcomponents.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F8FB3DEA-014B-4D4A-A40D-541C62872C1A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\placingcomponents.htm
    MSI (s) (C8:20) [10:46:50:983]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\placingcomponents.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:984]: Executing op: ComponentRegister(ComponentId={2C8EA69C-E33B-4152-9928-869C88F1AEE4},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc43.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2C8EA69C-E33B-4152-9928-869C88F1AEE4} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc43.new.js
    MSI (s) (C8:20) [10:46:50:985]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc43.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:986]: Executing op: ComponentRegister(ComponentId={A5613B82-635E-41AE-AA81-799308F3BA76},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\programupdates.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A5613B82-635E-41AE-AA81-799308F3BA76} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\programupdates.htm
    MSI (s) (C8:20) [10:46:50:987]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\programupdates.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:987]: Executing op: ComponentRegister(ComponentId={A67F2C94-3889-4E9F-B880-B0C32BC93C1E},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\projectdata.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A67F2C94-3889-4E9F-B880-B0C32BC93C1E} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\projectdata.js
    MSI (s) (C8:20) [10:46:50:989]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\projectdata.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:989]: Executing op: ComponentRegister(ComponentId={804384D3-AB9B-4A77-8BB5-880A87D44DE8},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc53.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {804384D3-AB9B-4A77-8BB5-880A87D44DE8} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc53.new.js
    MSI (s) (C8:20) [10:46:50:991]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc53.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:991]: Executing op: ComponentRegister(ComponentId={953D3D06-573F-40F9-8B9A-D3D5E7EFC5C3},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\qbipolartransistor.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {953D3D06-573F-40F9-8B9A-D3D5E7EFC5C3} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\qbipolartransistor.htm
    MSI (s) (C8:20) [10:46:50:993]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\qbipolartransistor.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:993]: Executing op: ComponentRegister(ComponentId={54131D0C-BA20-4E5D-89C6-BE0272BDDE8F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\rresistor.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {54131D0C-BA20-4E5D-89C6-BE0272BDDE8F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\rresistor.htm
    MSI (s) (C8:20) [10:46:50:995]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\rresistor.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:995]: Executing op: ComponentRegister(ComponentId={BB22ADB7-E934-43B2-9D57-B525C7518C72},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc46.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {BB22ADB7-E934-43B2-9D57-B525C7518C72} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc46.new.js
    MSI (s) (C8:20) [10:46:50:997]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc46.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:997]: Executing op: ComponentRegister(ComponentId={2455E685-1357-420E-871E-7B689B6A5784},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\rulesofhierarchy.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2455E685-1357-420E-871E-7B689B6A5784} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\rulesofhierarchy.htm
    MSI (s) (C8:20) [10:46:50:998]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\rulesofhierarchy.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:50:999]: Executing op: ComponentRegister(ComponentId={D6705DC9-5691-4609-8250-4EC2B47724EE},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\tlosslesstransmissionline.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D6705DC9-5691-4609-8250-4EC2B47724EE} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\tlosslesstransmissionline.htm
    MSI (s) (C8:20) [10:46:51:000]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\tlosslesstransmissionline.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:000]: Executing op: ComponentRegister(ComponentId={2C6D8866-0565-4787-B4B8-7F67F87883A9},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc40.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2C6D8866-0565-4787-B4B8-7F67F87883A9} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc40.new.js
    MSI (s) (C8:20) [10:46:51:002]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc40.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:002]: Executing op: ComponentRegister(ComponentId={DD6AEB6D-BC6B-410A-A733-08D6B79D2C4B},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\savebias--saveoperatingpointtodi.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {DD6AEB6D-BC6B-410A-A733-08D6B79D2C4B} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\savebias--saveoperatingpointtodi.htm
    MSI (s) (C8:20) [10:46:51:004]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\savebias--saveoperatingpointtodi.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:004]: Executing op: ComponentRegister(ComponentId={2F96279E-2718-4AF2-8F5D-781B4AEC96FE},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\savedefaults.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2F96279E-2718-4AF2-8F5D-781B4AEC96FE} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\savedefaults.htm
    MSI (s) (C8:20) [10:46:51:006]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\savedefaults.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:006]: Executing op: ComponentRegister(ComponentId={2685F7BB-5122-43AF-89E6-96B271D221F6},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc51.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2685F7BB-5122-43AF-89E6-96B271D221F6} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc51.new.js
    MSI (s) (C8:20) [10:46:51:007]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc51.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:007]: Executing op: ComponentRegister(ComponentId={8D678D55-C155-4BA5-9152-075F08C437BB},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\saveplotconfigurations.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8D678D55-C155-4BA5-9152-075F08C437BB} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\saveplotconfigurations.htm
    MSI (s) (C8:20) [10:46:51:009]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\saveplotconfigurations.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:009]: Executing op: ComponentRegister(ComponentId={65D6D893-23B9-4C8D-A9B7-F90B0094C10A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\savestate.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {65D6D893-23B9-4C8D-A9B7-F90B0094C10A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\savestate.htm
    MSI (s) (C8:20) [10:46:51:010]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\savestate.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:011]: Executing op: ComponentRegister(ComponentId={EE4A5502-FE6A-4E6E-8A24-C5E2E0507206},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\schematiccapture.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {EE4A5502-FE6A-4E6E-8A24-C5E2E0507206} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\schematiccapture.htm
    MSI (s) (C8:20) [10:46:51:012]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\schematiccapture.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:012]: Executing op: ComponentRegister(ComponentId={5F058F9E-75E7-4782-84AC-99A65B12BC07},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\edit2.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {5F058F9E-75E7-4782-84AC-99A65B12BC07} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\edit2.svg
    MSI (s) (C8:20) [10:46:51:014]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\edit2.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:014]: Executing op: ComponentRegister(ComponentId={A6C16AA2-3014-4A96-BC69-4023776ADC74},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\schematiccolors.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A6C16AA2-3014-4A96-BC69-4023776ADC74} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\schematiccolors.htm
    MSI (s) (C8:20) [10:46:51:016]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\schematiccolors.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:016]: Executing op: ComponentRegister(ComponentId={1364079D-0D6C-43AD-8173-F38C2E4D5639},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\screendata.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {1364079D-0D6C-43AD-8173-F38C2E4D5639} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\screendata.js
    MSI (s) (C8:20) [10:46:51:018]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\screendata.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:018]: Executing op: ComponentRegister(ComponentId={66B977A9-4C49-498D-BD41-CCB05244DCF7},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\full_screen.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {66B977A9-4C49-498D-BD41-CCB05244DCF7} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\full_screen.svg
    MSI (s) (C8:20) [10:46:51:020]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\full_screen.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:020]: Executing op: ComponentRegister(ComponentId={F5E4F01E-F246-4645-B503-04B3E2350035},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\search.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F5E4F01E-F246-4645-B503-04B3E2350035} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\search.htm
    MSI (s) (C8:20) [10:46:51:021]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\search.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:022]: Executing op: ComponentRegister(ComponentId={7E559C72-0345-41C7-94FD-3D54A9D30174},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\settings.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {7E559C72-0345-41C7-94FD-3D54A9D30174} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\settings.htm
    MSI (s) (C8:20) [10:46:51:023]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\settings.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:023]: Executing op: ComponentRegister(ComponentId={DBDDFA57-EBA9-4E98-836D-7823CB40451C},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\file.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {DBDDFA57-EBA9-4E98-836D-7823CB40451C} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\file.png
    MSI (s) (C8:20) [10:46:51:025]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\file.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:025]: Executing op: ComponentRegister(ComponentId={74222ECB-082C-4A57-8B21-4C92EFA24BF5},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\simulatingtransformers.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {74222ECB-082C-4A57-8B21-4C92EFA24BF5} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\simulatingtransformers.htm
    MSI (s) (C8:20) [10:46:51:027]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\simulatingtransformers.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:027]: Executing op: ComponentRegister(ComponentId={8B34CD89-2B94-46CB-889C-5FF739644D2B},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\softwareinstallation.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8B34CD89-2B94-46CB-889C-5FF739644D2B} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\softwareinstallation.htm
    MSI (s) (C8:20) [10:46:51:029]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\softwareinstallation.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:029]: Executing op: ComponentRegister(ComponentId={1BA8C0A7-BF7A-48F5-8669-0909B9EA8D3B},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\Dark.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {1BA8C0A7-BF7A-48F5-8669-0909B9EA8D3B} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\Dark.svg
    MSI (s) (C8:20) [10:46:51:030]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\Dark.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:030]: Executing op: ComponentRegister(ComponentId={D664F334-D501-402C-9C16-B10493EC087E},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\third-partymodels.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D664F334-D501-402C-9C16-B10493EC087E} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\third-partymodels.htm
    MSI (s) (C8:20) [10:46:51:032]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\third-partymodels.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:032]: Executing op: ComponentRegister(ComponentId={2C9C4B79-6583-42E0-8759-826119FB816A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\spicenetlist.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2C9C4B79-6583-42E0-8759-826119FB816A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\spicenetlist.htm
    MSI (s) (C8:20) [10:46:51:034]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\spicenetlist.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:034]: Executing op: ComponentRegister(ComponentId={9710AEE2-C789-4C85-BFD8-A4F2DB015726},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\filter_clearall.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {9710AEE2-C789-4C85-BFD8-A4F2DB015726} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\filter_clearall.svg
    MSI (s) (C8:20) [10:46:51:036]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\filter_clearall.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:036]: Executing op: ComponentRegister(ComponentId={C8EC7BF4-588A-4818-93B8-916CF74B7D1D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\steady.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {C8EC7BF4-588A-4818-93B8-916CF74B7D1D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\steady.htm
    MSI (s) (C8:20) [10:46:51:038]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\steady.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:038]: Executing op: ComponentRegister(ComponentId={4CE6C98E-B376-4734-81A1-D57C9D7BEF4D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\step--parametersweeps.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {4CE6C98E-B376-4734-81A1-D57C9D7BEF4D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\step--parametersweeps.htm
    MSI (s) (C8:20) [10:46:51:039]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\step--parametersweeps.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:040]: Executing op: ComponentRegister(ComponentId={6FE54118-A8AA-4519-87EC-B1B0C41173E2},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\logo.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {6FE54118-A8AA-4519-87EC-B1B0C41173E2} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\logo.png
    MSI (s) (C8:20) [10:46:51:041]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\logo.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:041]: Executing op: ComponentRegister(ComponentId={CA728C13-4036-4190-8CE4-4791F2ABC394},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\subckt--defineasubcircuit.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {CA728C13-4036-4190-8CE4-4791F2ABC394} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\subckt--defineasubcircuit.htm
    MSI (s) (C8:20) [10:46:51:043]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\subckt--defineasubcircuit.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:043]: Executing op: ComponentRegister(ComponentId={1EB720E0-57A1-4EAA-8C68-AE50A55C7CC1},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\superexpertmode.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {1EB720E0-57A1-4EAA-8C68-AE50A55C7CC1} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\superexpertmode.htm
    MSI (s) (C8:20) [10:46:51:045]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\superexpertmode.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:045]: Executing op: ComponentRegister(ComponentId={B8DCA9BD-9163-4A51-B438-1866EF021F6B},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\Group 56.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {B8DCA9BD-9163-4A51-B438-1866EF021F6B} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\Group 56.svg
    MSI (s) (C8:20) [10:46:51:047]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\Group 56.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:047]: Executing op: ComponentRegister(ComponentId={DC15304B-4B36-4113-A53E-CA1D8A8B4532},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\svoltagecontrolledswitch.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {DC15304B-4B36-4113-A53E-CA1D8A8B4532} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\svoltagecontrolledswitch.htm
    MSI (s) (C8:20) [10:46:51:048]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\svoltagecontrolledswitch.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:049]: Executing op: ComponentRegister(ComponentId={3EF43A42-7BE6-4C25-9C88-5128B084763E},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\symbolandlibrarysearchpaths.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {3EF43A42-7BE6-4C25-9C88-5128B084763E} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\symbolandlibrarysearchpaths.htm
    MSI (s) (C8:20) [10:46:51:050]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\symbolandlibrarysearchpaths.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:050]: Executing op: ComponentRegister(ComponentId={27017601-B92D-4FDA-82CD-F21EC5B20A9E},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\filter2.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {27017601-B92D-4FDA-82CD-F21EC5B20A9E} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\filter2.svg
    MSI (s) (C8:20) [10:46:51:052]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\filter2.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:052]: Executing op: ComponentRegister(ComponentId={23082EFA-ED31-4CB1-A596-015EE1BBB57E},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\temp--temperaturesweeps.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {23082EFA-ED31-4CB1-A596-015EE1BBB57E} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\temp--temperaturesweeps.htm
    MSI (s) (C8:20) [10:46:51:054]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\temp--temperaturesweeps.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:054]: Executing op: ComponentRegister(ComponentId={D0795ABD-7A32-47B0-8ADF-98CF5C136CC5},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\tf--findthedcsmall-signaltransfe.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D0795ABD-7A32-47B0-8ADF-98CF5C136CC5} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\tf--findthedcsmall-signaltransfe.htm
    MSI (s) (C8:20) [10:46:51:055]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\tf--findthedcsmall-signaltransfe.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:055]: Executing op: ComponentRegister(ComponentId={D74BBD64-67E5-4A65-B904-9B47235915A1},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\homepage-saved.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D74BBD64-67E5-4A65-B904-9B47235915A1} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\homepage-saved.svg
    MSI (s) (C8:20) [10:46:51:057]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\homepage-saved.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:057]: Executing op: ComponentRegister(ComponentId={2610F5D7-9925-451E-BC13-1934AC02C9A1},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\tran--doanonlineartransientanaly.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2610F5D7-9925-451E-BC13-1934AC02C9A1} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\tran--doanonlineartransientanaly.htm
    MSI (s) (C8:20) [10:46:51:059]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\tran--doanonlineartransientanaly.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:059]: Executing op: ComponentRegister(ComponentId={D62CE6C1-DF16-4091-A1C0-3F1AAC94FCA1},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\transientanalysisoptions.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D62CE6C1-DF16-4091-A1C0-3F1AAC94FCA1} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\transientanalysisoptions.htm
    MSI (s) (C8:20) [10:46:51:060]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\transientanalysisoptions.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:061]: Executing op: ComponentRegister(ComponentId={62EEF28E-DE57-475E-A8F8-1E2B8ECC3BA3},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\loading.gif,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {62EEF28E-DE57-475E-A8F8-1E2B8ECC3BA3} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\loading.gif
    MSI (s) (C8:20) [10:46:51:062]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\loading.gif' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:062]: Executing op: ComponentRegister(ComponentId={8516D1D5-18CC-4BA4-817D-12A4420A96E2},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\zooming.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8516D1D5-18CC-4BA4-817D-12A4420A96E2} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\zooming.htm
    MSI (s) (C8:20) [10:46:51:064]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\zooming.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:064]: Executing op: ComponentRegister(ComponentId={1769CC49-2934-4DA7-8C92-6ECE83704949},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\uic.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {1769CC49-2934-4DA7-8C92-6ECE83704949} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\uic.htm
    MSI (s) (C8:20) [10:46:51:066]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\uic.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:066]: Executing op: ComponentRegister(ComponentId={DB1B3AD0-DD9F-41DE-8CBF-0CB9F50D6661},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\index.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {DB1B3AD0-DD9F-41DE-8CBF-0CB9F50D6661} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\index.png
    MSI (s) (C8:20) [10:46:51:067]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\index.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:068]: Executing op: ComponentRegister(ComponentId={B2825417-A0B7-44F2-ABAB-DAE056BC3136},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\universalopampmodels.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {B2825417-A0B7-44F2-ABAB-DAE056BC3136} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\universalopampmodels.htm
    MSI (s) (C8:20) [10:46:51:069]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\universalopampmodels.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:070]: Executing op: ComponentRegister(ComponentId={3644A333-0414-469E-BFD2-22586ADCC85A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\vvoltagesource.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {3644A333-0414-469E-BFD2-22586ADCC85A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\vvoltagesource.htm
    MSI (s) (C8:20) [10:46:51:071]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\vvoltagesource.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:071]: Executing op: ComponentRegister(ComponentId={0C759B7F-8DB8-4AE2-BC0C-B90FEB1273CD},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\Group 9.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0C759B7F-8DB8-4AE2-BC0C-B90FEB1273CD} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\Group 9.svg
    MSI (s) (C8:20) [10:46:51:073]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\Group 9.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:073]: Executing op: ComponentRegister(ComponentId={659284BF-2641-461E-A8B5-C4EBD17A33A7},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\waveformviewer.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {659284BF-2641-461E-A8B5-C4EBD17A33A7} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\waveformviewer.htm
    MSI (s) (C8:20) [10:46:51:075]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\waveformviewer.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:075]: Executing op: ComponentRegister(ComponentId={91E5725F-6A80-4C02-98B3-B99360934103},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\wave--writeselectednodestoawavfi.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {91E5725F-6A80-4C02-98B3-B99360934103} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\wave--writeselectednodestoawavfi.htm
    MSI (s) (C8:20) [10:46:51:076]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\wave--writeselectednodestoawavfi.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:076]: Executing op: ComponentRegister(ComponentId={E3AF26C5-C40D-450B-8370-DFD8DEFC7F7D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\light.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {E3AF26C5-C40D-450B-8370-DFD8DEFC7F7D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\light.svg
    MSI (s) (C8:20) [10:46:51:078]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\light.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:078]: Executing op: ComponentRegister(ComponentId={C1867933-BFBD-4B7C-AFA3-7814870B5F11},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\waveformarithmetic.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {C1867933-BFBD-4B7C-AFA3-7814870B5F11} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\waveformarithmetic.htm
    MSI (s) (C8:20) [10:46:51:080]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\waveformarithmetic.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:080]: Executing op: ComponentRegister(ComponentId={D713E9E6-397F-4C3D-A187-5BE08911759B},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\waveforms.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D713E9E6-397F-4C3D-A187-5BE08911759B} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\waveforms.htm
    MSI (s) (C8:20) [10:46:51:081]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\waveforms.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:082]: Executing op: ComponentRegister(ComponentId={1B684469-773B-4DD2-8BE0-1BE7B1E5ACE0},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-Banner.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {1B684469-773B-4DD2-8BE0-1BE7B1E5ACE0} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-Banner.png
    MSI (s) (C8:20) [10:46:51:083]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-Banner.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:083]: Executing op: ComponentRegister(ComponentId={1CFD0788-2620-4E9C-89D8-C41CDA28897F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\wcurrentcontrolledswitch.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {1CFD0788-2620-4E9C-89D8-C41CDA28897F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\wcurrentcontrolledswitch.htm
    MSI (s) (C8:20) [10:46:51:085]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\wcurrentcontrolledswitch.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:085]: Executing op: ComponentRegister(ComponentId={34C60D8F-0922-4A05-A385-B97CF255E11E},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\zmesfetandigbt.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {34C60D8F-0922-4A05-A385-B97CF255E11E} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\zmesfetandigbt.htm
    MSI (s) (C8:20) [10:46:51:087]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\zmesfetandigbt.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:087]: Executing op: ComponentRegister(ComponentId={672C40CB-AB8C-44B0-853B-4F00E7199AB7},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\logo.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {672C40CB-AB8C-44B0-853B-4F00E7199AB7} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\logo.svg
    MSI (s) (C8:20) [10:46:51:088]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\logo.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:088]: Executing op: ComponentRegister(ComponentId={C36764CA-D80D-44B5-8E1B-1858DE5C9BA7},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\css\default.css.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {C36764CA-D80D-44B5-8E1B-1858DE5C9BA7} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\css\default.css.gz
    MSI (s) (C8:20) [10:46:51:090]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\css\default.css.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:090]: Executing op: ComponentRegister(ComponentId={613BB469-D2CB-45A3-9FD8-552E14DE490E},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\css\,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {613BB469-D2CB-45A3-9FD8-552E14DE490E} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\css\
    MSI (s) (C8:20) [10:46:51:092]: Executing op: ComponentRegister(ComponentId={EAD1891B-CBFA-47CC-9614-BF33291AE9C0},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\layout.css,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {EAD1891B-CBFA-47CC-9614-BF33291AE9C0} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\layout.css
    MSI (s) (C8:20) [10:46:51:093]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\layout.css' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:094]: Executing op: ComponentRegister(ComponentId={8214FBC2-5C5B-43D0-8494-966384F1D142},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\css\,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8214FBC2-5C5B-43D0-8494-966384F1D142} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\css\
    MSI (s) (C8:20) [10:46:51:095]: Executing op: ComponentRegister(ComponentId={AD1FC3D0-A21D-4823-BC44-34FDDC2428EB},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\css\,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {AD1FC3D0-A21D-4823-BC44-34FDDC2428EB} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\css\
    MSI (s) (C8:20) [10:46:51:097]: Executing op: ComponentRegister(ComponentId={C01243F9-6C06-41E3-8F19-C5D945F1D0C3},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-1920_06-09.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {C01243F9-6C06-41E3-8F19-C5D945F1D0C3} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-1920_06-09.png
    MSI (s) (C8:20) [10:46:51:098]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-1920_06-09.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:099]: Executing op: ComponentRegister(ComponentId={774CC51A-6B41-47B3-9543-81A081FDEA03},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\css\default.css,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {774CC51A-6B41-47B3-9543-81A081FDEA03} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\css\default.css
    MSI (s) (C8:20) [10:46:51:100]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\css\default.css' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:100]: Executing op: ComponentRegister(ComponentId={64B941CE-9422-4A19-B2D2-16AC40BF238F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\js\chmRelative.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {64B941CE-9422-4A19-B2D2-16AC40BF238F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\js\chmRelative.js
    MSI (s) (C8:20) [10:46:51:102]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\js\chmRelative.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:102]: Executing op: ComponentRegister(ComponentId={7314F8B9-248C-4C20-9D08-0FCBBCD056F2},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image11.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {7314F8B9-248C-4C20-9D08-0FCBBCD056F2} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image11.png
    MSI (s) (C8:20) [10:46:51:104]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image11.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:104]: Executing op: ComponentRegister(ComponentId={EEDF6DE2-B637-4162-94B5-632712144405},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\ac_stepDB.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {EEDF6DE2-B637-4162-94B5-632712144405} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\ac_stepDB.png
    MSI (s) (C8:20) [10:46:51:105]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\ac_stepDB.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:105]: Executing op: ComponentRegister(ComponentId={ABF456D2-26E5-43D0-B5EC-6FEB04962D54},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\menu.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {ABF456D2-26E5-43D0-B5EC-6FEB04962D54} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\menu.svg
    MSI (s) (C8:20) [10:46:51:107]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\menu.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:107]: Executing op: ComponentRegister(ComponentId={9DC9992B-C6CE-448E-8024-7BF7CB146FF5},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\convergence_slide4_picture_8.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {9DC9992B-C6CE-448E-8024-7BF7CB146FF5} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\convergence_slide4_picture_8.png
    MSI (s) (C8:20) [10:46:51:109]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\convergence_slide4_picture_8.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:109]: Executing op: ComponentRegister(ComponentId={8147004D-BC75-4419-B433-BD9E40BBA1FA},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\convergence_slide3_picture_16.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8147004D-BC75-4419-B433-BD9E40BBA1FA} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\convergence_slide3_picture_16.png
    MSI (s) (C8:20) [10:46:51:110]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\convergence_slide3_picture_16.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:111]: Executing op: ComponentRegister(ComponentId={8513061B-D733-4474-93C0-03AE5975EC25},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice 26 Logo White No Background.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8513061B-D733-4474-93C0-03AE5975EC25} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice 26 Logo White No Background.svg
    MSI (s) (C8:20) [10:46:51:112]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice 26 Logo White No Background.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:112]: Executing op: ComponentRegister(ComponentId={7735B5D8-FBD2-4103-86CC-3B8084A4E313},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\convergence_slide3_picture_17.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {7735B5D8-FBD2-4103-86CC-3B8084A4E313} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\convergence_slide3_picture_17.png
    MSI (s) (C8:20) [10:46:51:114]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\convergence_slide3_picture_17.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:114]: Executing op: ComponentRegister(ComponentId={B6E22E80-7AFC-44BC-B524-64455FA8F909},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\dbMeasurementSchema.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {B6E22E80-7AFC-44BC-B524-64455FA8F909} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\dbMeasurementSchema.png
    MSI (s) (C8:20) [10:46:51:116]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\dbMeasurementSchema.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:116]: Executing op: ComponentRegister(ComponentId={CF0B25FE-DFCD-4577-B7A3-0E4C50ACA488},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image12.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {CF0B25FE-DFCD-4577-B7A3-0E4C50ACA488} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image12.png
    MSI (s) (C8:20) [10:46:51:118]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image12.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:118]: Executing op: ComponentRegister(ComponentId={4B62BCE1-182E-4639-A1DB-376D31FB7285},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image44.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {4B62BCE1-182E-4639-A1DB-376D31FB7285} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image44.png
    MSI (s) (C8:20) [10:46:51:119]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image44.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:120]: Executing op: ComponentRegister(ComponentId={09C440BC-FF40-41E7-84ED-F6532FB5A258},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image13.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {09C440BC-FF40-41E7-84ED-F6532FB5A258} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image13.png
    MSI (s) (C8:20) [10:46:51:121]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image13.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:121]: Executing op: ComponentRegister(ComponentId={5A55AC3C-AE94-42C0-93A9-6F0BE4179222},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image14.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {5A55AC3C-AE94-42C0-93A9-6F0BE4179222} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image14.png
    MSI (s) (C8:20) [10:46:51:123]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image14.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:123]: Executing op: ComponentRegister(ComponentId={A9244442-1615-498F-AACA-41DF048BA807},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image15.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A9244442-1615-498F-AACA-41DF048BA807} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image15.png
    MSI (s) (C8:20) [10:46:51:125]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image15.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:125]: Executing op: ComponentRegister(ComponentId={AEAE7586-50F5-4AD7-90E0-2B7AFEA8710D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image16.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {AEAE7586-50F5-4AD7-90E0-2B7AFEA8710D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image16.png
    MSI (s) (C8:20) [10:46:51:128]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image16.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:128]: Executing op: ComponentRegister(ComponentId={FAFE64ED-B927-433B-89BE-608CAA9556F3},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image17.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {FAFE64ED-B927-433B-89BE-608CAA9556F3} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image17.png
    MSI (s) (C8:20) [10:46:51:129]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image17.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:130]: Executing op: ComponentRegister(ComponentId={37C9AEE0-C4AE-477F-9F3C-9D473D2F6DCC},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image18.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {37C9AEE0-C4AE-477F-9F3C-9D473D2F6DCC} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image18.png
    MSI (s) (C8:20) [10:46:51:131]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image18.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:131]: Executing op: ComponentRegister(ComponentId={801D4513-563D-4E54-88EE-74F106601B52},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image19.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {801D4513-563D-4E54-88EE-74F106601B52} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image19.png
    MSI (s) (C8:20) [10:46:51:132]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image19.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:133]: Executing op: ComponentRegister(ComponentId={43B251EA-72B5-4DC1-AE46-1A999131E224},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image20.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {43B251EA-72B5-4DC1-AE46-1A999131E224} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image20.png
    MSI (s) (C8:20) [10:46:51:134]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image20.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:134]: Executing op: ComponentRegister(ComponentId={71E1A8DF-434C-4FB8-B424-1695474290F6},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image21.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {71E1A8DF-434C-4FB8-B424-1695474290F6} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image21.png
    MSI (s) (C8:20) [10:46:51:135]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image21.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:135]: Executing op: ComponentRegister(ComponentId={B0941684-4E06-4999-B9F4-BEFB0FDEF4C5},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image22.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {B0941684-4E06-4999-B9F4-BEFB0FDEF4C5} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image22.png
    MSI (s) (C8:20) [10:46:51:137]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image22.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:137]: Executing op: ComponentRegister(ComponentId={E90A9406-A840-4000-8B0A-6476BD778B23},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image23.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {E90A9406-A840-4000-8B0A-6476BD778B23} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image23.png
    MSI (s) (C8:20) [10:46:51:138]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image23.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:139]: Executing op: ComponentRegister(ComponentId={D37BED57-7A21-457B-93CD-06473B23F8D9},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image24.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D37BED57-7A21-457B-93CD-06473B23F8D9} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image24.png
    MSI (s) (C8:20) [10:46:51:140]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image24.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:140]: Executing op: ComponentRegister(ComponentId={D4D3B064-DC1A-4F88-8E82-8C8D147C023A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\Search_Paths.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D4D3B064-DC1A-4F88-8E82-8C8D147C023A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\Search_Paths.png
    MSI (s) (C8:20) [10:46:51:142]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\Search_Paths.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:142]: Executing op: ComponentRegister(ComponentId={8B9C1562-EDCF-44BB-A714-DADF40EEA50B},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image25.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8B9C1562-EDCF-44BB-A714-DADF40EEA50B} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image25.png
    MSI (s) (C8:20) [10:46:51:143]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image25.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:143]: Executing op: ComponentRegister(ComponentId={27426C22-050F-4284-A45F-0300AEBC9B42},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image35.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {27426C22-050F-4284-A45F-0300AEBC9B42} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image35.png
    MSI (s) (C8:20) [10:46:51:145]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image35.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:145]: Executing op: ComponentRegister(ComponentId={02207C0D-BBF1-4A77-88BA-1A0F6316D464},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image26.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {02207C0D-BBF1-4A77-88BA-1A0F6316D464} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image26.png
    MSI (s) (C8:20) [10:46:51:147]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image26.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:147]: Executing op: ComponentRegister(ComponentId={76E73360-D3B8-48CA-B7D8-223B66370D0E},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image27.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {76E73360-D3B8-48CA-B7D8-223B66370D0E} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image27.png
    MSI (s) (C8:20) [10:46:51:148]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image27.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:149]: Executing op: ComponentRegister(ComponentId={68847917-9251-4E1B-BC77-011D73FF1AAA},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image28.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {68847917-9251-4E1B-BC77-011D73FF1AAA} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image28.png
    MSI (s) (C8:20) [10:46:51:150]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image28.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:150]: Executing op: ComponentRegister(ComponentId={A77C76C7-185B-477F-90D5-29941B3747D8},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image29.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A77C76C7-185B-477F-90D5-29941B3747D8} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image29.png
    MSI (s) (C8:20) [10:46:51:152]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image29.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:152]: Executing op: ComponentRegister(ComponentId={75F385AC-6BEF-4434-AFBC-418A9164E8A1},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image30.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {75F385AC-6BEF-4434-AFBC-418A9164E8A1} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image30.png
    MSI (s) (C8:20) [10:46:51:154]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image30.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:154]: Executing op: ComponentRegister(ComponentId={7F60ABAF-C4D5-4457-8ACA-8BC66933CB0C},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image31.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {7F60ABAF-C4D5-4457-8ACA-8BC66933CB0C} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image31.png
    MSI (s) (C8:20) [10:46:51:155]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image31.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:156]: Executing op: ComponentRegister(ComponentId={16C81420-2193-4857-855D-2CD87AFD5AAD},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image32.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {16C81420-2193-4857-855D-2CD87AFD5AAD} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image32.png
    MSI (s) (C8:20) [10:46:51:157]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image32.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:157]: Executing op: ComponentRegister(ComponentId={7922F958-4AA2-413C-9077-CF5F5CF47A3A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\usersettings.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {7922F958-4AA2-413C-9077-CF5F5CF47A3A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\usersettings.js
    MSI (s) (C8:20) [10:46:51:159]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\usersettings.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:159]: Executing op: ComponentRegister(ComponentId={C60E27FB-E35D-4612-AD7B-E7B77F334FAB},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image33.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {C60E27FB-E35D-4612-AD7B-E7B77F334FAB} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image33.png
    MSI (s) (C8:20) [10:46:51:161]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image33.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:161]: Executing op: ComponentRegister(ComponentId={02DBFD62-0675-4CFF-8275-E889F0E14252},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image36.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {02DBFD62-0675-4CFF-8275-E889F0E14252} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image36.png
    MSI (s) (C8:20) [10:46:51:163]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image36.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:163]: Executing op: ComponentRegister(ComponentId={4E139051-8C1D-43E5-89D7-92F81BF79F45},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\scripts\homepage.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {4E139051-8C1D-43E5-89D7-92F81BF79F45} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\scripts\homepage.js
    MSI (s) (C8:20) [10:46:51:164]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\scripts\homepage.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:165]: Executing op: ComponentRegister(ComponentId={0CA33500-C515-4068-BE9B-D2198DC433C1},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image37.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0CA33500-C515-4068-BE9B-D2198DC433C1} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image37.png
    MSI (s) (C8:20) [10:46:51:166]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image37.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:166]: Executing op: ComponentRegister(ComponentId={4768A9EE-C2C1-4CAE-9DFC-EE5F1E121163},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image38.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {4768A9EE-C2C1-4CAE-9DFC-EE5F1E121163} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image38.png
    MSI (s) (C8:20) [10:46:51:168]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image38.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:168]: Executing op: ComponentRegister(ComponentId={6E0061F7-80B1-4B4F-8899-CAAA4452C4D9},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\2019\layout.css,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {6E0061F7-80B1-4B4F-8899-CAAA4452C4D9} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\2019\layout.css
    MSI (s) (C8:20) [10:46:51:170]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\2019\layout.css' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:170]: Executing op: ComponentRegister(ComponentId={DADFB0B1-30E5-47B1-8FDB-3B27BAF5C243},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image41.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {DADFB0B1-30E5-47B1-8FDB-3B27BAF5C243} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image41.png
    MSI (s) (C8:20) [10:46:51:172]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image41.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:172]: Executing op: ComponentRegister(ComponentId={A00E1075-AC97-4D2A-81F1-CF1347FE64E3},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image43.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A00E1075-AC97-4D2A-81F1-CF1347FE64E3} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image43.png
    MSI (s) (C8:20) [10:46:51:174]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image43.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:174]: Executing op: ComponentRegister(ComponentId={0828D639-6ACE-4A91-824D-BC966210CB70},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\unsaved.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0828D639-6ACE-4A91-824D-BC966210CB70} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\unsaved.svg
    MSI (s) (C8:20) [10:46:51:175]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\unsaved.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:176]: Executing op: ComponentRegister(ComponentId={CFD02EE9-C83B-4314-98B8-5615EE086BF5},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image46.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {CFD02EE9-C83B-4314-98B8-5615EE086BF5} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image46.png
    MSI (s) (C8:20) [10:46:51:177]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image46.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:177]: Executing op: ComponentRegister(ComponentId={73877CEC-1E21-40AF-B48C-D692D55EE194},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image47.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {73877CEC-1E21-40AF-B48C-D692D55EE194} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image47.png
    MSI (s) (C8:20) [10:46:51:179]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image47.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:179]: Executing op: ComponentRegister(ComponentId={A572318F-58C0-4415-885A-7CB9AECE0496},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\scripts\csh-redirect.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A572318F-58C0-4415-885A-7CB9AECE0496} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\scripts\csh-redirect.js
    MSI (s) (C8:20) [10:46:51:181]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\scripts\csh-redirect.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:181]: Executing op: ComponentRegister(ComponentId={A24E82DE-9BBF-46F0-8156-7D9C4FDA5293},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image9.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A24E82DE-9BBF-46F0-8156-7D9C4FDA5293} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image9.png
    MSI (s) (C8:20) [10:46:51:183]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\image9.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:183]: Executing op: ComponentRegister(ComponentId={A2C45796-510A-4913-8F5F-384D560F0503},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\ResultsVsStepPlot.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A2C45796-510A-4913-8F5F-384D560F0503} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\ResultsVsStepPlot.png
    MSI (s) (C8:20) [10:46:51:185]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\ResultsVsStepPlot.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:185]: Executing op: ComponentRegister(ComponentId={F5AE5EFB-5071-413E-910E-3DF6A9E20AA8},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\idata1.new.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F5AE5EFB-5071-413E-910E-3DF6A9E20AA8} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\idata1.new.js.gz
    MSI (s) (C8:20) [10:46:51:187]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\idata1.new.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:187]: Executing op: ComponentRegister(ComponentId={EAE83FEE-5462-4581-85EA-5F7FCD18B575},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\ResultsWSteps.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {EAE83FEE-5462-4581-85EA-5F7FCD18B575} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\ResultsWSteps.png
    MSI (s) (C8:20) [10:46:51:188]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\ResultsWSteps.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:189]: Executing op: ComponentRegister(ComponentId={5FFEE53B-4C8A-45C8-8F3F-FA5ED702520A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\compress.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {5FFEE53B-4C8A-45C8-8F3F-FA5ED702520A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\compress.png
    MSI (s) (C8:20) [10:46:51:190]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\compress.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:190]: Executing op: ComponentRegister(ComponentId={2A78446B-E474-4AE5-A912-303573C6F128},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\scripts\redirect.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2A78446B-E474-4AE5-A912-303573C6F128} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\scripts\redirect.js
    MSI (s) (C8:20) [10:46:51:192]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\scripts\redirect.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:192]: Executing op: ComponentRegister(ComponentId={339B6D52-EDCD-4B4C-912F-349B7A829F16},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\300dB.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {339B6D52-EDCD-4B4C-912F-349B7A829F16} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\300dB.png
    MSI (s) (C8:20) [10:46:51:194]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\300dB.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:194]: Executing op: ComponentRegister(ComponentId={48B9D78B-D9CA-4721-814F-AFABD8A1B6C9},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\AddTrace.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {48B9D78B-D9CA-4721-814F-AFABD8A1B6C9} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\AddTrace.png
    MSI (s) (C8:20) [10:46:51:195]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\AddTrace.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:196]: Executing op: ComponentRegister(ComponentId={D5444998-9150-4EE6-81EB-AC27C24EE7F3},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\scripts\topicpage.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D5444998-9150-4EE6-81EB-AC27C24EE7F3} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\scripts\topicpage.js.gz
    MSI (s) (C8:20) [10:46:51:197]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\scripts\topicpage.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:197]: Executing op: ComponentRegister(ComponentId={9C163C2B-5E25-4AA8-AD7F-3C2FC6822629},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\asymminor.gif,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {9C163C2B-5E25-4AA8-AD7F-3C2FC6822629} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\asymminor.gif
    MSI (s) (C8:20) [10:46:51:199]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\asymminor.gif' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:199]: Executing op: ComponentRegister(ComponentId={B76492D4-1E1F-4CA1-97AD-D2C3B4A49BA0},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\Capacitor.gif,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {B76492D4-1E1F-4CA1-97AD-D2C3B4A49BA0} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\Capacitor.gif
    MSI (s) (C8:20) [10:46:51:201]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\Capacitor.gif' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:201]: Executing op: ComponentRegister(ComponentId={EE6B0559-FF1B-492F-AC39-8105FCDAA567},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\csh.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {EE6B0559-FF1B-492F-AC39-8105FCDAA567} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\csh.new.js
    MSI (s) (C8:20) [10:46:51:203]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\csh.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:203]: Executing op: ComponentRegister(ComponentId={2BD2EA6B-C78C-4D90-9F40-26421A1A986B},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\RMS.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2BD2EA6B-C78C-4D90-9F40-26421A1A986B} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\RMS.png
    MSI (s) (C8:20) [10:46:51:205]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\RMS.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:205]: Executing op: ComponentRegister(ComponentId={8EB062AA-81CD-411E-A0C3-C4C79C599F69},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\Att2Cur.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8EB062AA-81CD-411E-A0C3-C4C79C599F69} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\Att2Cur.png
    MSI (s) (C8:20) [10:46:51:206]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\Att2Cur.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:207]: Executing op: ComponentRegister(ComponentId={824CEE24-E71F-4952-90B1-95C8576530BE},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc120.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {824CEE24-E71F-4952-90B1-95C8576530BE} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc120.new.js
    MSI (s) (C8:20) [10:46:51:208]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc120.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:208]: Executing op: ComponentRegister(ComponentId={40BB3F78-FAD9-4A9C-ACEC-F4105EA5FBF8},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\BH.gif,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {40BB3F78-FAD9-4A9C-ACEC-F4105EA5FBF8} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\BH.gif
    MSI (s) (C8:20) [10:46:51:210]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\BH.gif' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:210]: Executing op: ComponentRegister(ComponentId={2B59E025-4D5D-4BF6-BC3B-E45B223CC600},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\vdmoscap.gif,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2B59E025-4D5D-4BF6-BC3B-E45B223CC600} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\vdmoscap.gif
    MSI (s) (C8:20) [10:46:51:212]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\vdmoscap.gif' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:212]: Executing op: ComponentRegister(ComponentId={7A4B9DEB-22F3-46C0-AB46-61F774342018},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc11.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {7A4B9DEB-22F3-46C0-AB46-61F774342018} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc11.new.js
    MSI (s) (C8:20) [10:46:51:214]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc11.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:214]: Executing op: ComponentRegister(ComponentId={8107C097-66FA-4F51-89DC-9E169F0E8D98},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\ControlWaveform.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8107C097-66FA-4F51-89DC-9E169F0E8D98} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\ControlWaveform.png
    MSI (s) (C8:20) [10:46:51:216]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\ControlWaveform.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:216]: Executing op: ComponentRegister(ComponentId={465A4419-873C-4954-B8B7-641740C5788F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\CursRead.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {465A4419-873C-4954-B8B7-641740C5788F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\CursRead.png
    MSI (s) (C8:20) [10:46:51:218]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\CursRead.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:218]: Executing op: ComponentRegister(ComponentId={49A6DD57-70CA-4CE1-B2E7-C10108C20FCF},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\brsdata.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {49A6DD57-70CA-4CE1-B2E7-C10108C20FCF} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\brsdata.js
    MSI (s) (C8:20) [10:46:51:220]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\brsdata.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:220]: Executing op: ComponentRegister(ComponentId={80775919-072F-4E3A-9A70-990B288E7B9C},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\CursStep.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {80775919-072F-4E3A-9A70-990B288E7B9C} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\CursStep.png
    MSI (s) (C8:20) [10:46:51:221]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\CursStep.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:222]: Executing op: ComponentRegister(ComponentId={F4DAA88C-C02A-412E-8DB8-74F4F9AAC639},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\Ddnform.gif,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F4DAA88C-C02A-412E-8DB8-74F4F9AAC639} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\Ddnform.gif
    MSI (s) (C8:20) [10:46:51:223]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\Ddnform.gif' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:224]: Executing op: ComponentRegister(ComponentId={22CC55AA-B047-4C88-8BF6-A6C3DD747FBE},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\idata1.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {22CC55AA-B047-4C88-8BF6-A6C3DD747FBE} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\idata1.new.js
    MSI (s) (C8:20) [10:46:51:225]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\idata1.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:225]: Executing op: ComponentRegister(ComponentId={A3BBF6AD-D985-4111-BEC2-844049E7B0CB},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\diffprobe.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A3BBF6AD-D985-4111-BEC2-844049E7B0CB} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\diffprobe.png
    MSI (s) (C8:20) [10:46:51:227]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\diffprobe.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:227]: Executing op: ComponentRegister(ComponentId={ADCBB25F-FDED-4909-ACEE-D179A9ACBC0B},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\Dupform.gif,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {ADCBB25F-FDED-4909-ACEE-D179A9ACBC0B} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\Dupform.gif
    MSI (s) (C8:20) [10:46:51:229]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\Dupform.gif' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:229]: Executing op: ComponentRegister(ComponentId={E7B7CB6E-FA16-418C-BD94-62D59781573F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc112.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {E7B7CB6E-FA16-418C-BD94-62D59781573F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc112.new.js
    MSI (s) (C8:20) [10:46:51:231]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc112.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:231]: Executing op: ComponentRegister(ComponentId={C7A59EF4-16F6-444A-996E-E371FC7F3680},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\EntrExpr.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {C7A59EF4-16F6-444A-996E-E371FC7F3680} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\EntrExpr.png
    MSI (s) (C8:20) [10:46:51:233]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\EntrExpr.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:233]: Executing op: ComponentRegister(ComponentId={DF400699-DF0C-470E-B4EC-D4DBB0E7B4D0},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\FFT.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {DF400699-DF0C-470E-B4EC-D4DBB0E7B4D0} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\FFT.png
    MSI (s) (C8:20) [10:46:51:234]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\FFT.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:235]: Executing op: ComponentRegister(ComponentId={E7645E06-A844-4BF8-ADE7-56AC298970C7},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\idx.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {E7645E06-A844-4BF8-ADE7-56AC298970C7} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\idx.new.js
    MSI (s) (C8:20) [10:46:51:236]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\idx.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:236]: Executing op: ComponentRegister(ComponentId={9F830D4C-C518-4D08-B247-A608F7DCD06D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\Hierarch.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {9F830D4C-C518-4D08-B247-A608F7DCD06D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\Hierarch.png
    MSI (s) (C8:20) [10:46:51:238]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\Hierarch.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:238]: Executing op: ComponentRegister(ComponentId={62A2F9D7-168A-407F-A886-4E3897D24B26},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\Inductor.gif,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {62A2F9D7-168A-407F-A886-4E3897D24B26} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\Inductor.gif
    MSI (s) (C8:20) [10:46:51:240]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\Inductor.gif' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:240]: Executing op: ComponentRegister(ComponentId={944A21BE-CF2C-447E-A6D6-3482AFB29341},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc128.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {944A21BE-CF2C-447E-A6D6-3482AFB29341} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc128.new.js
    MSI (s) (C8:20) [10:46:51:242]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc128.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:242]: Executing op: ComponentRegister(ComponentId={4DD3D0D3-E85E-4652-ACA3-9DCAF226131B},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\modified_trap_problem_asc.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {4DD3D0D3-E85E-4652-ACA3-9DCAF226131B} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\modified_trap_problem_asc.png
    MSI (s) (C8:20) [10:46:51:244]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\modified_trap_problem_asc.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:244]: Executing op: ComponentRegister(ComponentId={51A00342-FE0C-4E3A-ABBC-87A1F8BB4E89},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\modified_trap_principle.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {51A00342-FE0C-4E3A-ABBC-87A1F8BB4E89} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\modified_trap_principle.png
    MSI (s) (C8:20) [10:46:51:246]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\modified_trap_principle.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:246]: Executing op: ComponentRegister(ComponentId={E93778C6-98A3-4AC1-BAE1-2F6345F23C34},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc12.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {E93778C6-98A3-4AC1-BAE1-2F6345F23C34} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc12.new.js
    MSI (s) (C8:20) [10:46:51:248]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc12.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:248]: Executing op: ComponentRegister(ComponentId={0968D84A-C7DB-4E36-B9EA-019E2AAC0E0C},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\modified_trap_problem.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0968D84A-C7DB-4E36-B9EA-019E2AAC0E0C} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\modified_trap_problem.png
    MSI (s) (C8:20) [10:46:51:249]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\modified_trap_problem.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:250]: Executing op: ComponentRegister(ComponentId={2C740AD6-7DE9-43F4-9209-F9660749C885},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\WavColor.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2C740AD6-7DE9-43F4-9209-F9660749C885} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\WavColor.png
    MSI (s) (C8:20) [10:46:51:251]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\WavColor.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:251]: Executing op: ComponentRegister(ComponentId={A166C9D0-6170-4AB6-9014-D668FD58540D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\bmrk_unselect.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A166C9D0-6170-4AB6-9014-D668FD58540D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\bmrk_unselect.svg
    MSI (s) (C8:20) [10:46:51:253]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\bmrk_unselect.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:253]: Executing op: ComponentRegister(ComponentId={4ECD32AE-D67A-41A6-9AE3-4337E641907D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\modified_trap_problem_wave.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {4ECD32AE-D67A-41A6-9AE3-4337E641907D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\modified_trap_problem_wave.png
    MSI (s) (C8:20) [10:46:51:254]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\modified_trap_problem_wave.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:255]: Executing op: ComponentRegister(ComponentId={CC41AC38-6DAE-420D-BBDC-9AA383153E7B},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\MouseCursor.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {CC41AC38-6DAE-420D-BBDC-9AA383153E7B} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\MouseCursor.png
    MSI (s) (C8:20) [10:46:51:256]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\MouseCursor.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:256]: Executing op: ComponentRegister(ComponentId={4A30BEF3-7817-47E8-A9A1-9B78D6A668A0},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc5.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {4A30BEF3-7817-47E8-A9A1-9B78D6A668A0} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc5.new.js
    MSI (s) (C8:20) [10:46:51:258]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc5.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:258]: Executing op: ComponentRegister(ComponentId={FD18B2F9-2353-448F-8B56-0718AE908171},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\Navigate.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {FD18B2F9-2353-448F-8B56-0718AE908171} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\Navigate.png
    MSI (s) (C8:20) [10:46:51:259]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\Navigate.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:259]: Executing op: ComponentRegister(ComponentId={151DBB4B-B5D3-42AD-9681-02C612CF4E3C},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\porttype.gif,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {151DBB4B-B5D3-42AD-9681-02C612CF4E3C} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\porttype.gif
    MSI (s) (C8:20) [10:46:51:261]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\porttype.gif' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:261]: Executing op: ComponentRegister(ComponentId={C42D423C-BCAD-43CA-BE57-65FECACBB7CF},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\layoutconfig.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {C42D423C-BCAD-43CA-BE57-65FECACBB7CF} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\layoutconfig.js.gz
    MSI (s) (C8:20) [10:46:51:263]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\layoutconfig.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:263]: Executing op: ComponentRegister(ComponentId={2EC70844-200C-48C3-BAAF-F371BEC70E44},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\ProbeWire.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2EC70844-200C-48C3-BAAF-F371BEC70E44} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\ProbeWire.png
    MSI (s) (C8:20) [10:46:51:265]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\ProbeWire.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:265]: Executing op: ComponentRegister(ComponentId={AA47C99C-9FF0-4183-B0B0-BAEC20679815},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\pwrProbe.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {AA47C99C-9FF0-4183-B0B0-BAEC20679815} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\pwrProbe.png
    MSI (s) (C8:20) [10:46:51:266]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\pwrProbe.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:266]: Executing op: ComponentRegister(ComponentId={C5190242-F226-48FE-8EA2-C12415F2D49F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\brs-ch-left.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {C5190242-F226-48FE-8EA2-C12415F2D49F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\brs-ch-left.svg
    MSI (s) (C8:20) [10:46:51:268]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\brs-ch-left.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:268]: Executing op: ComponentRegister(ComponentId={FD05E74F-371E-44B8-A11D-9FC8B2296BEE},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\vbic.gif,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {FD05E74F-371E-44B8-A11D-9FC8B2296BEE} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\vbic.gif
    MSI (s) (C8:20) [10:46:51:270]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\vbic.gif' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:270]: Executing op: ComponentRegister(ComponentId={0A8E07FC-6072-4704-BD93-7D58A23076D0},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\savedflt.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0A8E07FC-6072-4704-BD93-7D58A23076D0} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\savedflt.png
    MSI (s) (C8:20) [10:46:51:271]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\savedflt.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:271]: Executing op: ComponentRegister(ComponentId={E8C31B56-1F18-4B5E-A2EE-81108491C09A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\ch-up.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {E8C31B56-1F18-4B5E-A2EE-81108491C09A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\ch-up.svg
    MSI (s) (C8:20) [10:46:51:273]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\ch-up.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:273]: Executing op: ComponentRegister(ComponentId={D1EC52D4-25A6-439D-B087-70969DCA9F59},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\spiceopt.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D1EC52D4-25A6-439D-B087-70969DCA9F59} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\spiceopt.png
    MSI (s) (C8:20) [10:46:51:275]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\spiceopt.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:275]: Executing op: ComponentRegister(ComponentId={6CC73FC9-8179-4C3B-9DA4-4D99E38984E0},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\vdmos.gif,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {6CC73FC9-8179-4C3B-9DA4-4D99E38984E0} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\vdmos.gif
    MSI (s) (C8:20) [10:46:51:276]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\vdmos.gif' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:276]: Executing op: ComponentRegister(ComponentId={80ACE0B7-259C-41E3-88CD-F92FF19FB893},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\collapse_toc.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {80ACE0B7-259C-41E3-88CD-F92FF19FB893} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\collapse_toc.svg
    MSI (s) (C8:20) [10:46:51:278]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\collapse_toc.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:278]: Executing op: ComponentRegister(ComponentId={566648CC-9C71-4443-BB80-76FA6950E5A6},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\VisTrace.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {566648CC-9C71-4443-BB80-76FA6950E5A6} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\VisTrace.png
    MSI (s) (C8:20) [10:46:51:280]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\VisTrace.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:280]: Executing op: ComponentRegister(ComponentId={E23DC0EF-B13E-46EB-9C31-B2C3C2188C2F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\Voltage.gif,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {E23DC0EF-B13E-46EB-9C31-B2C3C2188C2F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\Voltage.gif
    MSI (s) (C8:20) [10:46:51:281]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\Voltage.gif' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:281]: Executing op: ComponentRegister(ComponentId={33D3CB27-287A-48E6-B659-6FDD69FDD481},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\brs-ch-right.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {33D3CB27-287A-48E6-B659-6FDD69FDD481} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\brs-ch-right.svg
    MSI (s) (C8:20) [10:46:51:283]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\brs-ch-right.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:283]: Executing op: ComponentRegister(ComponentId={38C6A5D5-B1FA-4B2A-857D-47BD4343CDEF},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\math\uplim.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {38C6A5D5-B1FA-4B2A-857D-47BD4343CDEF} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\math\uplim.svg
    MSI (s) (C8:20) [10:46:51:285]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\math\uplim.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:285]: Executing op: ComponentRegister(ComponentId={9C043D23-0359-4702-AC8B-75204E2E68D5},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\math\cbrt.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {9C043D23-0359-4702-AC8B-75204E2E68D5} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\math\cbrt.svg
    MSI (s) (C8:20) [10:46:51:286]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\math\cbrt.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:286]: Executing op: ComponentRegister(ComponentId={2808B550-1E18-4F4A-8F41-0BEC07AD0D20},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\ch-right.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2808B550-1E18-4F4A-8F41-0BEC07AD0D20} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\ch-right.svg
    MSI (s) (C8:20) [10:46:51:287]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\ch-right.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:288]: Executing op: ComponentRegister(ComponentId={BF18A617-CAA3-428B-B046-85E178EC9D23},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\math\hypot.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {BF18A617-CAA3-428B-B046-85E178EC9D23} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\math\hypot.svg
    MSI (s) (C8:20) [10:46:51:289]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\math\hypot.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:289]: Executing op: ComponentRegister(ComponentId={56855FFA-1C24-4696-8A6A-D2EE235F95D5},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\math\dnlim.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {56855FFA-1C24-4696-8A6A-D2EE235F95D5} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\math\dnlim.svg
    MSI (s) (C8:20) [10:46:51:291]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\math\dnlim.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:291]: Executing op: ComponentRegister(ComponentId={D1F62371-ECA0-4601-8CB6-6429D944024B},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\cross_selectpanel.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D1F62371-ECA0-4601-8CB6-6429D944024B} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\cross_selectpanel.svg
    MSI (s) (C8:20) [10:46:51:292]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\cross_selectpanel.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:292]: Executing op: ComponentRegister(ComponentId={A9D63524-35F7-474C-A035-FFC55B12923F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\math\sqrt.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A9D63524-35F7-474C-A035-FFC55B12923F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\math\sqrt.svg
    MSI (s) (C8:20) [10:46:51:294]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\math\sqrt.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:294]: Executing op: ComponentRegister(ComponentId={C6595839-4C1E-4F68-BE0C-D9A9A5B51FFF},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\styles\topic.min.css.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {C6595839-4C1E-4F68-BE0C-D9A9A5B51FFF} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\styles\topic.min.css.gz
    MSI (s) (C8:20) [10:46:51:295]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\styles\topic.min.css.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:295]: Executing op: ComponentRegister(ComponentId={0D958F65-A548-4A6E-B3E1-E79B3655B9FF},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\collapse(TOC).svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0D958F65-A548-4A6E-B3E1-E79B3655B9FF} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\collapse(TOC).svg
    MSI (s) (C8:20) [10:46:51:297]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\collapse(TOC).svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:297]: Executing op: ComponentRegister(ComponentId={6CC5CEC3-7ADC-4297-8A26-9E1FF4FAE4D1},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\styles\topic.min.css,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {6CC5CEC3-7ADC-4297-8A26-9E1FF4FAE4D1} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\styles\topic.min.css
    MSI (s) (C8:20) [10:46:51:298]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\styles\topic.min.css' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:299]: Executing op: ComponentRegister(ComponentId={5E9E9637-7B9D-4E02-BFAC-A8D5DAE0F8A2},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\images\modal-close.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {5E9E9637-7B9D-4E02-BFAC-A8D5DAE0F8A2} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\images\modal-close.png
    MSI (s) (C8:20) [10:46:51:300]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\images\modal-close.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:300]: Executing op: ComponentRegister(ComponentId={F1441B42-8FEF-4959-BA95-873DE42E794A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\ch-left.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F1441B42-8FEF-4959-BA95-873DE42E794A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\ch-left.svg
    MSI (s) (C8:20) [10:46:51:302]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\ch-left.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:302]: Executing op: ComponentRegister(ComponentId={B20E5C63-85A9-4117-9864-8940CA0CFF48},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\images\expand.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {B20E5C63-85A9-4117-9864-8940CA0CFF48} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\images\expand.png
    MSI (s) (C8:20) [10:46:51:303]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\images\expand.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:303]: Executing op: ComponentRegister(ComponentId={65351965-7066-43E6-B951-C5E7CBCC75F7},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\images\ch-right.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {65351965-7066-43E6-B951-C5E7CBCC75F7} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\images\ch-right.svg
    MSI (s) (C8:20) [10:46:51:305]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\images\ch-right.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:305]: Executing op: ComponentRegister(ComponentId={DEF931DC-8C9C-4784-94DC-A678FCC47E36},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\cross.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {DEF931DC-8C9C-4784-94DC-A678FCC47E36} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\cross.svg
    MSI (s) (C8:20) [10:46:51:306]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\cross.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:307]: Executing op: ComponentRegister(ComponentId={C14EA385-D6C7-4573-B717-89F9B397EDE7},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\images\LoadingData.gif,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {C14EA385-D6C7-4573-B717-89F9B397EDE7} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\images\LoadingData.gif
    MSI (s) (C8:20) [10:46:51:308]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\images\LoadingData.gif' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:308]: Executing op: ComponentRegister(ComponentId={0208E7FD-64E1-4655-852C-E5D5C6D6CF7E},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\Add_bookmark(mobile).svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0208E7FD-64E1-4655-852C-E5D5C6D6CF7E} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\Add_bookmark(mobile).svg
    MSI (s) (C8:20) [10:46:51:310]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\Add_bookmark(mobile).svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:310]: Executing op: ComponentRegister(ComponentId={2F915D73-B473-49EC-9D6E-54CC4DDAB85F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\expand_toc.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2F915D73-B473-49EC-9D6E-54CC4DDAB85F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\expand_toc.svg
    MSI (s) (C8:20) [10:46:51:311]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\expand_toc.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:312]: Executing op: ComponentRegister(ComponentId={38E9E59E-9C20-4A5F-88C2-54DCF8F62566},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\bmrk_select.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {38E9E59E-9C20-4A5F-88C2-54DCF8F62566} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\bmrk_select.svg
    MSI (s) (C8:20) [10:46:51:313]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\bmrk_select.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:313]: Executing op: ComponentRegister(ComponentId={E5F2B17A-D01C-4407-8428-33ADC0265F6F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\ch-down.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {E5F2B17A-D01C-4407-8428-33ADC0265F6F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\ch-down.svg
    MSI (s) (C8:20) [10:46:51:315]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\ch-down.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:315]: Executing op: ComponentRegister(ComponentId={9FFDCA30-26A1-46BD-BE6D-C22BCEF549DB},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\dark-globe.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {9FFDCA30-26A1-46BD-BE6D-C22BCEF549DB} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\dark-globe.svg
    MSI (s) (C8:20) [10:46:51:316]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\dark-globe.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:316]: Executing op: ComponentRegister(ComponentId={BC7971AA-7DED-4183-937E-3343B0041FCA},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\expand(TOC).svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {BC7971AA-7DED-4183-937E-3343B0041FCA} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\expand(TOC).svg
    MSI (s) (C8:20) [10:46:51:318]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\expand(TOC).svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:318]: Executing op: ComponentRegister(ComponentId={5E733333-C696-49BA-880D-E44156688920},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\download_pdf.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {5E733333-C696-49BA-880D-E44156688920} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\download_pdf.svg
    MSI (s) (C8:20) [10:46:51:320]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\download_pdf.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:320]: Executing op: ComponentRegister(ComponentId={1770468C-8AC2-471D-8D5D-7FA40B0F05D6},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\edit.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {1770468C-8AC2-471D-8D5D-7FA40B0F05D6} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\edit.svg
    MSI (s) (C8:20) [10:46:51:321]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\edit.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:321]: Executing op: ComponentRegister(ComponentId={75081D43-75CE-487A-9120-AA09EA23BFEA},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-3840-Sine-TOC.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {75081D43-75CE-487A-9120-AA09EA23BFEA} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-3840-Sine-TOC.png
    MSI (s) (C8:20) [10:46:51:323]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-3840-Sine-TOC.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:323]: Executing op: ComponentRegister(ComponentId={2237134C-5612-41D9-9BCE-D1D834E8B9BD},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\93.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2237134C-5612-41D9-9BCE-D1D834E8B9BD} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\93.js
    MSI (s) (C8:20) [10:46:51:324]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\93.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:325]: Executing op: ComponentRegister(ComponentId={12B4726D-3310-4F9F-9DCA-42EE875B6C24},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\homepage-filter2.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {12B4726D-3310-4F9F-9DCA-42EE875B6C24} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\homepage-filter2.svg
    MSI (s) (C8:20) [10:46:51:326]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\homepage-filter2.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:326]: Executing op: ComponentRegister(ComponentId={4F33F4BA-7E87-46D7-80F6-3E2A06F8CA25},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-3840-Sine-Header.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {4F33F4BA-7E87-46D7-80F6-3E2A06F8CA25} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-3840-Sine-Header.png
    MSI (s) (C8:20) [10:46:51:328]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-3840-Sine-Header.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:328]: Executing op: ComponentRegister(ComponentId={42C10D5A-BFDC-478E-B580-C7918717BDAB},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\86.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {42C10D5A-BFDC-478E-B580-C7918717BDAB} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\86.js.gz
    MSI (s) (C8:20) [10:46:51:330]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\86.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:330]: Executing op: ComponentRegister(ComponentId={AC1C4DC6-424D-4748-A9D8-E33CF5D7E9AB},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-1920_02.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {AC1C4DC6-424D-4748-A9D8-E33CF5D7E9AB} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-1920_02.png
    MSI (s) (C8:20) [10:46:51:331]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-1920_02.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:332]: Executing op: ComponentRegister(ComponentId={382EECAC-E633-4EE2-BB86-042BAF9B789E},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-1920_02-07.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {382EECAC-E633-4EE2-BB86-042BAF9B789E} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-1920_02-07.png
    MSI (s) (C8:20) [10:46:51:333]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-1920_02-07.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:333]: Executing op: ComponentRegister(ComponentId={98D4BDAB-025D-476B-B365-5BE5531E6459},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\99.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {98D4BDAB-025D-476B-B365-5BE5531E6459} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\99.js
    MSI (s) (C8:20) [10:46:51:335]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\99.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:335]: Executing op: ComponentRegister(ComponentId={E5C9503B-09BE-42AF-AB83-D233343A9B1E},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\homepage.ejs,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {E5C9503B-09BE-42AF-AB83-D233343A9B1E} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\homepage.ejs
    MSI (s) (C8:20) [10:46:51:337]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\homepage.ejs' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:337]: Executing op: ComponentRegister(ComponentId={B1ED02E5-D286-4235-B250-5DE078D98563},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice 300x200.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {B1ED02E5-D286-4235-B250-5DE078D98563} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice 300x200.png
    MSI (s) (C8:20) [10:46:51:338]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice 300x200.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:338]: Executing op: ComponentRegister(ComponentId={926FA588-2222-4115-82DB-EBD5CDA46456},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\90.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {926FA588-2222-4115-82DB-EBD5CDA46456} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\90.js.gz
    MSI (s) (C8:20) [10:46:51:340]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\90.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:340]: Executing op: ComponentRegister(ComponentId={8674B507-54FB-44FB-8E6B-D29A6DDD396D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\collapse_all.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8674B507-54FB-44FB-8E6B-D29A6DDD396D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\collapse_all.svg
    MSI (s) (C8:20) [10:46:51:342]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\collapse_all.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:342]: Executing op: ComponentRegister(ComponentId={76A513D9-83A0-4024-AF83-BAFA3FCE00F7},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-1920_05-08.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {76A513D9-83A0-4024-AF83-BAFA3FCE00F7} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-1920_05-08.png
    MSI (s) (C8:20) [10:46:51:343]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-1920_05-08.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:344]: Executing op: ComponentRegister(ComponentId={62B71CA7-31C7-4466-89D1-97A9F071162C},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\highlight.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {62B71CA7-31C7-4466-89D1-97A9F071162C} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\highlight.svg
    MSI (s) (C8:20) [10:46:51:345]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\highlight.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:345]: Executing op: ComponentRegister(ComponentId={41A4D699-EFED-4DF4-8158-E09FBCF1023F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\email.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {41A4D699-EFED-4DF4-8158-E09FBCF1023F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\email.svg
    MSI (s) (C8:20) [10:46:51:347]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\email.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:347]: Executing op: ComponentRegister(ComponentId={8547428B-D1D9-44B8-B3AE-EE1A5064E54B},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\95.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8547428B-D1D9-44B8-B3AE-EE1A5064E54B} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\95.js.gz
    MSI (s) (C8:20) [10:46:51:348]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\95.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:349]: Executing op: ComponentRegister(ComponentId={464070B7-AA1B-4B7D-AC93-3CB0B38A9D5A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\delete.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {464070B7-AA1B-4B7D-AC93-3CB0B38A9D5A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\delete.svg
    MSI (s) (C8:20) [10:46:51:350]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\delete.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:350]: Executing op: ComponentRegister(ComponentId={829089E7-B027-4DA8-BE0C-C5B003462BA8},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\dot.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {829089E7-B027-4DA8-BE0C-C5B003462BA8} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\dot.svg
    MSI (s) (C8:20) [10:46:51:352]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\dot.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:352]: Executing op: ComponentRegister(ComponentId={454406F9-8F53-4593-BB1A-FEB7090B2749},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\19.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {454406F9-8F53-4593-BB1A-FEB7090B2749} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\19.js
    MSI (s) (C8:20) [10:46:51:353]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\19.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:353]: Executing op: ComponentRegister(ComponentId={54403F9B-6631-44D4-A90B-EE10A26D6486},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\expand_all.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {54403F9B-6631-44D4-A90B-EE10A26D6486} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\expand_all.svg
    MSI (s) (C8:20) [10:46:51:355]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\expand_all.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:355]: Executing op: ComponentRegister(ComponentId={6B20C6D4-2261-4E91-A975-99915A32FDE0},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\facebook.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {6B20C6D4-2261-4E91-A975-99915A32FDE0} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\facebook.svg
    MSI (s) (C8:20) [10:46:51:356]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\facebook.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:357]: Executing op: ComponentRegister(ComponentId={499F0A05-4418-448F-969F-ECB6564429C5},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\filter.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {499F0A05-4418-448F-969F-ECB6564429C5} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\filter.svg
    MSI (s) (C8:20) [10:46:51:358]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\filter.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:358]: Executing op: ComponentRegister(ComponentId={CC49BAAD-BB40-45C2-BA41-9C43425A1984},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\filter_clearall.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {CC49BAAD-BB40-45C2-BA41-9C43425A1984} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\filter_clearall.png
    MSI (s) (C8:20) [10:46:51:360]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\filter_clearall.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:360]: Executing op: ComponentRegister(ComponentId={F67FA0FB-48D5-44EA-8600-F80B0A269642},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\75.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F67FA0FB-48D5-44EA-8600-F80B0A269642} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\75.js
    MSI (s) (C8:20) [10:46:51:361]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\75.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:362]: Executing op: ComponentRegister(ComponentId={BA31B288-1274-44CC-A8F2-2012AEE91B9D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\frameless.skn,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {BA31B288-1274-44CC-A8F2-2012AEE91B9D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\frameless.skn
    MSI (s) (C8:20) [10:46:51:363]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\frameless.skn' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:363]: Executing op: ComponentRegister(ComponentId={8635C764-B0A0-4D63-8261-47E3B3482784},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\Group 114.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8635C764-B0A0-4D63-8261-47E3B3482784} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\Group 114.svg
    MSI (s) (C8:20) [10:46:51:365]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\Group 114.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:366]: Executing op: ComponentRegister(ComponentId={8545E0A4-BB05-44FE-A9BD-4AAFA477BDE0},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\14.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8545E0A4-BB05-44FE-A9BD-4AAFA477BDE0} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\14.js
    MSI (s) (C8:20) [10:46:51:368]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\14.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:368]: Executing op: ComponentRegister(ComponentId={F6F141AA-A669-4066-9C83-21D7689EBE6A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\toc_default_tile.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F6F141AA-A669-4066-9C83-21D7689EBE6A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\toc_default_tile.svg
    MSI (s) (C8:20) [10:46:51:371]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\toc_default_tile.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:371]: Executing op: ComponentRegister(ComponentId={6E0FEF02-950A-41B7-94AE-451572166AD7},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\homepage-filter.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {6E0FEF02-950A-41B7-94AE-451572166AD7} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\homepage-filter.svg
    MSI (s) (C8:20) [10:46:51:372]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\homepage-filter.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:372]: Executing op: ComponentRegister(ComponentId={B16586E8-D92A-40F9-A0AE-5C4B10ABE075},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\31.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {B16586E8-D92A-40F9-A0AE-5C4B10ABE075} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\31.js
    MSI (s) (C8:20) [10:46:51:374]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\31.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:374]: Executing op: ComponentRegister(ComponentId={D7261197-8082-4923-8474-82C417E960C2},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\homepage-unsaved.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D7261197-8082-4923-8474-82C417E960C2} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\homepage-unsaved.svg
    MSI (s) (C8:20) [10:46:51:376]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\homepage-unsaved.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:376]: Executing op: ComponentRegister(ComponentId={8DA57C93-CE08-416E-BC18-C8C7D7749393},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\homepage_background.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8DA57C93-CE08-416E-BC18-C8C7D7749393} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\homepage_background.png
    MSI (s) (C8:20) [10:46:51:377]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\homepage_background.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:377]: Executing op: ComponentRegister(ComponentId={62958C29-895D-4BB2-A793-58371E47B6D6},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\22.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {62958C29-895D-4BB2-A793-58371E47B6D6} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\22.js
    MSI (s) (C8:20) [10:46:51:379]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\22.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:379]: Executing op: ComponentRegister(ComponentId={6BBFE547-F9C9-4318-BE3B-08CA62E73520},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-3840-Sine-Tools.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {6BBFE547-F9C9-4318-BE3B-08CA62E73520} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-3840-Sine-Tools.png
    MSI (s) (C8:20) [10:46:51:380]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-3840-Sine-Tools.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:380]: Executing op: ComponentRegister(ComponentId={63D67883-8985-49CE-B5BE-5CB8DAB8846F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\layout.css.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {63D67883-8985-49CE-B5BE-5CB8DAB8846F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\layout.css.gz
    MSI (s) (C8:20) [10:46:51:382]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\layout.css.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:382]: Executing op: ComponentRegister(ComponentId={3E081AE4-07BA-4264-AD3E-02D19996D0FA},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\39.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {3E081AE4-07BA-4264-AD3E-02D19996D0FA} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\39.js
    MSI (s) (C8:20) [10:46:51:384]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\39.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:384]: Executing op: ComponentRegister(ComponentId={76DBDF22-77D4-441E-A236-0389EAC4ED33},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\linkedin.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {76DBDF22-77D4-441E-A236-0389EAC4ED33} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\linkedin.svg
    MSI (s) (C8:20) [10:46:51:387]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\linkedin.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:387]: Executing op: ComponentRegister(ComponentId={2750899B-3AA5-4983-B243-7CEA95728938},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\loading_spinner.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2750899B-3AA5-4983-B243-7CEA95728938} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\loading_spinner.svg
    MSI (s) (C8:20) [10:46:51:389]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\loading_spinner.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:390]: Executing op: ComponentRegister(ComponentId={7628415C-8399-477F-AECD-7DC2B4F31383},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\29.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {7628415C-8399-477F-AECD-7DC2B4F31383} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\29.js
    MSI (s) (C8:20) [10:46:51:392]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\29.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:392]: Executing op: ComponentRegister(ComponentId={B8B41A1F-315D-4D52-8968-249C21145811},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice 24 Logo White No Background.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {B8B41A1F-315D-4D52-8968-249C21145811} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice 24 Logo White No Background.svg
    MSI (s) (C8:20) [10:46:51:394]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice 24 Logo White No Background.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:394]: Executing op: ComponentRegister(ComponentId={1FAFD273-9CA3-4C1E-8AE5-35D286E85F13},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-1920_05.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {1FAFD273-9CA3-4C1E-8AE5-35D286E85F13} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-1920_05.png
    MSI (s) (C8:20) [10:46:51:396]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-1920_05.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:396]: Executing op: ComponentRegister(ComponentId={E7774280-3E32-4986-89AA-BAC866FA903F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\49.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {E7774280-3E32-4986-89AA-BAC866FA903F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\49.js
    MSI (s) (C8:20) [10:46:51:400]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\49.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:400]: Executing op: ComponentRegister(ComponentId={939D4E79-779C-4E37-9592-03D5B8F07C5B},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-1920_06.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {939D4E79-779C-4E37-9592-03D5B8F07C5B} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-1920_06.png
    MSI (s) (C8:20) [10:46:51:402]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art-1920_06.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:402]: Executing op: ComponentRegister(ComponentId={76E23619-EC21-4CAF-B69B-180C0BA70881},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art.jpg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {76E23619-EC21-4CAF-B69B-180C0BA70881} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art.jpg
    MSI (s) (C8:20) [10:46:51:404]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\LTspice-Art.jpg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:404]: Executing op: ComponentRegister(ComponentId={382D383C-984F-43CE-AC59-1A63F2371EF4},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\35.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {382D383C-984F-43CE-AC59-1A63F2371EF4} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\35.js
    MSI (s) (C8:20) [10:46:51:406]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\35.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:406]: Executing op: ComponentRegister(ComponentId={5D5611C8-3B7E-4DBD-A1A6-4E60723464F8},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\page_up.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {5D5611C8-3B7E-4DBD-A1A6-4E60723464F8} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\page_up.svg
    MSI (s) (C8:20) [10:46:51:407]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\page_up.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:407]: Executing op: ComponentRegister(ComponentId={C5907CAC-DFA5-448C-B65F-3B354CFAAB85},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\print.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {C5907CAC-DFA5-448C-B65F-3B354CFAAB85} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\print.svg
    MSI (s) (C8:20) [10:46:51:409]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\print.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:409]: Executing op: ComponentRegister(ComponentId={F429F4D5-AAC9-450D-A915-650896528FB2},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\read_aloud.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F429F4D5-AAC9-450D-A915-650896528FB2} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\read_aloud.svg
    MSI (s) (C8:20) [10:46:51:410]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\read_aloud.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:410]: Executing op: ComponentRegister(ComponentId={746439C0-2591-4838-A734-04AA0C5C0676},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\read_aloud2.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {746439C0-2591-4838-A734-04AA0C5C0676} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\read_aloud2.svg
    MSI (s) (C8:20) [10:46:51:412]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\read_aloud2.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:412]: Executing op: ComponentRegister(ComponentId={C688229F-45A0-4026-95BF-B46274BFA120},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\regular_screen.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {C688229F-45A0-4026-95BF-B46274BFA120} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\regular_screen.svg
    MSI (s) (C8:20) [10:46:51:414]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\regular_screen.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:414]: Executing op: ComponentRegister(ComponentId={B452E093-40B3-4A50-B291-65073A301817},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\userstyles.css,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {B452E093-40B3-4A50-B291-65073A301817} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\userstyles.css
    MSI (s) (C8:20) [10:46:51:416]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\userstyles.css' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:416]: Executing op: ComponentRegister(ComponentId={9691EE64-6D49-400A-85DE-019F69712B7F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\saved.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {9691EE64-6D49-400A-85DE-019F69712B7F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\saved.svg
    MSI (s) (C8:20) [10:46:51:417]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\saved.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:417]: Executing op: ComponentRegister(ComponentId={EC3720E9-5725-4FBA-B185-73FB410074FC},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\saved2.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {EC3720E9-5725-4FBA-B185-73FB410074FC} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\saved2.svg
    MSI (s) (C8:20) [10:46:51:419]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\saved2.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:419]: Executing op: ComponentRegister(ComponentId={3F429910-740D-400F-BD5A-9010F874AE6A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\search-page-next.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {3F429910-740D-400F-BD5A-9010F874AE6A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\search-page-next.svg
    MSI (s) (C8:20) [10:46:51:420]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\search-page-next.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:420]: Executing op: ComponentRegister(ComponentId={3F610D8A-7003-4520-B977-0FDD88A48397},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\search-page-prev.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {3F610D8A-7003-4520-B977-0FDD88A48397} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\search-page-prev.svg
    MSI (s) (C8:20) [10:46:51:422]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\search-page-prev.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:422]: Executing op: ComponentRegister(ComponentId={1BDCF79A-99FC-49D2-B99D-1648EA7EE93E},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\search.htm,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {1BDCF79A-99FC-49D2-B99D-1648EA7EE93E} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\search.htm
    MSI (s) (C8:20) [10:46:51:423]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\search.htm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:423]: Executing op: ComponentRegister(ComponentId={A42DFD3F-4570-4285-A348-FA96DF49C6D7},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\search.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A42DFD3F-4570-4285-A348-FA96DF49C6D7} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\search.svg
    MSI (s) (C8:20) [10:46:51:424]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\search.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:425]: Executing op: ComponentRegister(ComponentId={CA299C09-A599-46FF-820F-60DD572789D9},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\share.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {CA299C09-A599-46FF-820F-60DD572789D9} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\share.svg
    MSI (s) (C8:20) [10:46:51:426]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\share.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:426]: Executing op: ComponentRegister(ComponentId={0EF759F5-E23B-4E7C-B87C-A15A783435EE},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\tocimg1.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0EF759F5-E23B-4E7C-B87C-A15A783435EE} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\tocimg1.png
    MSI (s) (C8:20) [10:46:51:428]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\tocimg1.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:428]: Executing op: ComponentRegister(ComponentId={5CCF0870-0764-47A5-A822-A054A8F7A9B6},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\tocimg2.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {5CCF0870-0764-47A5-A822-A054A8F7A9B6} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\tocimg2.png
    MSI (s) (C8:20) [10:46:51:429]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\tocimg2.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:429]: Executing op: ComponentRegister(ComponentId={6B350A14-74E8-46DD-9973-35827EBCE35B},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\tocimg3.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {6B350A14-74E8-46DD-9973-35827EBCE35B} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\tocimg3.png
    MSI (s) (C8:20) [10:46:51:431]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\tocimg3.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:431]: Executing op: ComponentRegister(ComponentId={8C1C8908-0AF7-41E4-9345-B421585CA3CB},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\userstyles.css.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8C1C8908-0AF7-41E4-9345-B421585CA3CB} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\userstyles.css.gz
    MSI (s) (C8:20) [10:46:51:432]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\userstyles.css.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:432]: Executing op: ComponentRegister(ComponentId={71CF204F-7327-4925-BA9F-B76BCF9EF46C},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\tocimg4.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {71CF204F-7327-4925-BA9F-B76BCF9EF46C} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\tocimg4.png
    MSI (s) (C8:20) [10:46:51:434]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\tocimg4.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:434]: Executing op: ComponentRegister(ComponentId={EF18D9D4-FD7D-4D6F-B028-90DB1629DDFD},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\tocimg5.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {EF18D9D4-FD7D-4D6F-B028-90DB1629DDFD} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\tocimg5.png
    MSI (s) (C8:20) [10:46:51:436]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\tocimg5.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:436]: Executing op: ComponentRegister(ComponentId={6F08107C-F098-49B8-B8CE-25162ECAD384},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\tocimg6.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {6F08107C-F098-49B8-B8CE-25162ECAD384} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\tocimg6.png
    MSI (s) (C8:20) [10:46:51:437]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\tocimg6.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:438]: Executing op: ComponentRegister(ComponentId={C229036C-E745-44DB-8996-E732AEE1E5E2},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\tocimg7.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {C229036C-E745-44DB-8996-E732AEE1E5E2} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\tocimg7.png
    MSI (s) (C8:20) [10:46:51:439]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\tocimg7.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:439]: Executing op: ComponentRegister(ComponentId={3A6AF275-CD6F-41DC-81C0-CE310112AF4D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\tocimg8.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {3A6AF275-CD6F-41DC-81C0-CE310112AF4D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\tocimg8.png
    MSI (s) (C8:20) [10:46:51:441]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\tocimg8.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:441]: Executing op: ComponentRegister(ComponentId={4F94D1CC-8C7D-4199-B98C-1A05F23C3535},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\toc_default_tile.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {4F94D1CC-8C7D-4199-B98C-1A05F23C3535} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\toc_default_tile.png
    MSI (s) (C8:20) [10:46:51:442]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\toc_default_tile.png' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:443]: Executing op: ComponentRegister(ComponentId={4C420888-0C1B-4344-AD74-FA70B3C9565A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\topicpage.ejs,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {4C420888-0C1B-4344-AD74-FA70B3C9565A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\topicpage.ejs
    MSI (s) (C8:20) [10:46:51:444]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\topicpage.ejs' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:444]: Executing op: ComponentRegister(ComponentId={34A9D4B8-E402-43FA-B57C-BDDD098C9740},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\twitter.svg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {34A9D4B8-E402-43FA-B57C-BDDD098C9740} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\twitter.svg
    MSI (s) (C8:20) [10:46:51:446]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\twitter.svg' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:446]: Executing op: ComponentRegister(ComponentId={7F87AD0B-FC09-45F6-87A3-5E47DD12E525},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\usersettings.ejs,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {7F87AD0B-FC09-45F6-87A3-5E47DD12E525} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\usersettings.ejs
    MSI (s) (C8:20) [10:46:51:448]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\usersettings.ejs' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:448]: Executing op: ComponentRegister(ComponentId={4EEF32D6-B415-4DBE-B8C8-CEA7526883B1},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\69.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {4EEF32D6-B415-4DBE-B8C8-CEA7526883B1} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\69.js.gz
    MSI (s) (C8:20) [10:46:51:449]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\69.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:450]: Executing op: ComponentRegister(ComponentId={3161F121-1A2F-48AC-B5B8-1C1909F56816},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\usersettings.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {3161F121-1A2F-48AC-B5B8-1C1909F56816} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\usersettings.js.gz
    MSI (s) (C8:20) [10:46:51:451]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\usersettings.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:451]: Executing op: ComponentRegister(ComponentId={C0FE1AC1-AFB6-4BEA-8AD3-170F4264C1B4},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\2019\layout.css.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {C0FE1AC1-AFB6-4BEA-8AD3-170F4264C1B4} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\2019\layout.css.gz
    MSI (s) (C8:20) [10:46:51:453]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\2019\layout.css.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:453]: Executing op: ComponentRegister(ComponentId={4710EB46-E9B1-44C4-94DE-04A4A6D0D8FC},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\2019\compatibility.css,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {4710EB46-E9B1-44C4-94DE-04A4A6D0D8FC} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\2019\compatibility.css
    MSI (s) (C8:20) [10:46:51:455]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\2019\compatibility.css' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:455]: Executing op: ComponentRegister(ComponentId={D6A96C75-5E51-4148-9F83-018DB16B81A2},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\scripts\redirect.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D6A96C75-5E51-4148-9F83-018DB16B81A2} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\scripts\redirect.js.gz
    MSI (s) (C8:20) [10:46:51:457]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\scripts\redirect.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:457]: Executing op: ComponentRegister(ComponentId={1AD27F9F-F0BE-4E4F-BD47-B84E063A6983},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\scripts\topicpage.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {1AD27F9F-F0BE-4E4F-BD47-B84E063A6983} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\scripts\topicpage.js
    MSI (s) (C8:20) [10:46:51:458]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\scripts\topicpage.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:459]: Executing op: ComponentRegister(ComponentId={22A476AD-8C38-4BD5-8DFD-9A590131E946},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\74.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {22A476AD-8C38-4BD5-8DFD-9A590131E946} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\74.js
    MSI (s) (C8:20) [10:46:51:460]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\74.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:460]: Executing op: ComponentRegister(ComponentId={F2B3176C-91A0-4007-AA88-D63C9849524D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\scripts\csh-redirect.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F2B3176C-91A0-4007-AA88-D63C9849524D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\scripts\csh-redirect.js.gz
    MSI (s) (C8:20) [10:46:51:462]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\scripts\csh-redirect.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:462]: Executing op: ComponentRegister(ComponentId={F412E116-0CF4-4624-BADF-A44CBDD85C8F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\scripts\homepage.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F412E116-0CF4-4624-BADF-A44CBDD85C8F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\scripts\homepage.js.gz
    MSI (s) (C8:20) [10:46:51:464]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\scripts\homepage.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:464]: Executing op: ComponentRegister(ComponentId={63316C75-3CFA-4899-B514-FB4625968AB6},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\67.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {63316C75-3CFA-4899-B514-FB4625968AB6} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\67.js.gz
    MSI (s) (C8:20) [10:46:51:465]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\67.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:466]: Executing op: ComponentRegister(ComponentId={7C42BC79-DE6D-40B1-BB9C-43BE0784A295},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc41.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {7C42BC79-DE6D-40B1-BB9C-43BE0784A295} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc41.new.js
    MSI (s) (C8:20) [10:46:51:467]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc41.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:467]: Executing op: ComponentRegister(ComponentId={09A1CC7F-7EBC-41E5-9EA1-82CF267D4C9A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc111.new.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {09A1CC7F-7EBC-41E5-9EA1-82CF267D4C9A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc111.new.js.gz
    MSI (s) (C8:20) [10:46:51:469]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc111.new.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:469]: Executing op: ComponentRegister(ComponentId={DEB9AE37-52E2-43F3-97A7-3EE5B8152E2F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\79.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {DEB9AE37-52E2-43F3-97A7-3EE5B8152E2F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\79.js.gz
    MSI (s) (C8:20) [10:46:51:471]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\79.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:471]: Executing op: ComponentRegister(ComponentId={D602267A-AC13-4015-B0AA-AF2E2DD4D8BE},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc57.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D602267A-AC13-4015-B0AA-AF2E2DD4D8BE} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc57.new.js
    MSI (s) (C8:20) [10:46:51:473]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc57.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:473]: Executing op: ComponentRegister(ComponentId={18FF2BF2-D2C5-4DDD-927A-19869442895F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc90.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {18FF2BF2-D2C5-4DDD-927A-19869442895F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc90.new.js
    MSI (s) (C8:20) [10:46:51:474]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc90.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:474]: Executing op: ComponentRegister(ComponentId={EEEB1FED-E73F-40FC-890B-2590CD15A192},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\70.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {EEEB1FED-E73F-40FC-890B-2590CD15A192} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\70.js.gz
    MSI (s) (C8:20) [10:46:51:476]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\70.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:476]: Executing op: ComponentRegister(ComponentId={0747D5FB-AAE3-4210-A278-07D543AF334B},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\glo.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0747D5FB-AAE3-4210-A278-07D543AF334B} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\glo.new.js
    MSI (s) (C8:20) [10:46:51:478]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\glo.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:478]: Executing op: ComponentRegister(ComponentId={1BAAFD18-B7E1-4A84-92C4-0E807FD8CEF8},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\gdata1.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {1BAAFD18-B7E1-4A84-92C4-0E807FD8CEF8} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\gdata1.new.js
    MSI (s) (C8:20) [10:46:51:479]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\gdata1.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:480]: Executing op: ComponentRegister(ComponentId={21D98A36-C6BB-4FEA-BA0B-B94A7DCBDDCB},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\83.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {21D98A36-C6BB-4FEA-BA0B-B94A7DCBDDCB} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\83.js.gz
    MSI (s) (C8:20) [10:46:51:481]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\83.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:481]: Executing op: ComponentRegister(ComponentId={C8DAC918-5C93-4846-9B04-877E3489C0BD},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc107.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {C8DAC918-5C93-4846-9B04-877E3489C0BD} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc107.new.js
    MSI (s) (C8:20) [10:46:51:483]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc107.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:483]: Executing op: ComponentRegister(ComponentId={1AFE7E69-5CCF-4CF6-95A5-B469D7647AB8},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\layoutconfig.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {1AFE7E69-5CCF-4CF6-95A5-B469D7647AB8} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\layoutconfig.js
    MSI (s) (C8:20) [10:46:51:485]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\layoutconfig.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:485]: Executing op: ComponentRegister(ComponentId={F1EE9586-DAA7-4D17-831D-A7369F1C1F4F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\77.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F1EE9586-DAA7-4D17-831D-A7369F1C1F4F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\77.js
    MSI (s) (C8:20) [10:46:51:487]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\77.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:487]: Executing op: ComponentRegister(ComponentId={888E8F53-5906-4267-A5D8-E2CEE35EF619},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {888E8F53-5906-4267-A5D8-E2CEE35EF619} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc.new.js
    MSI (s) (C8:20) [10:46:51:488]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:489]: Executing op: ComponentRegister(ComponentId={5CC70390-3EC5-4223-A778-F1FE8C12E133},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc122.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {5CC70390-3EC5-4223-A778-F1FE8C12E133} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc122.new.js
    MSI (s) (C8:20) [10:46:51:490]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc122.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:491]: Executing op: ComponentRegister(ComponentId={FFE133EE-6A27-413C-AD0E-A40DE5656751},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\89.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {FFE133EE-6A27-413C-AD0E-A40DE5656751} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\89.js
    MSI (s) (C8:20) [10:46:51:492]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\89.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:492]: Executing op: ComponentRegister(ComponentId={F605A728-5847-43F4-B6E8-43E81058EDE2},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\projectsettings.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F605A728-5847-43F4-B6E8-43E81058EDE2} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\projectsettings.js
    MSI (s) (C8:20) [10:46:51:493]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\projectsettings.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:494]: Executing op: ComponentRegister(ComponentId={0D90A7BA-8917-437C-8420-B85472F5175C},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\projectsettings.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0D90A7BA-8917-437C-8420-B85472F5175C} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\projectsettings.js.gz
    MSI (s) (C8:20) [10:46:51:495]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\projectsettings.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:495]: Executing op: ComponentRegister(ComponentId={57CBE549-B068-4FC8-B910-B3E4FF53F6C6},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\81.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {57CBE549-B068-4FC8-B910-B3E4FF53F6C6} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\81.js
    MSI (s) (C8:20) [10:46:51:497]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\81.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:497]: Executing op: ComponentRegister(ComponentId={F0E7F1A9-2F62-4A4A-9865-C8457C0799B1},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_auto_index.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F0E7F1A9-2F62-4A4A-9865-C8457C0799B1} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_auto_index.js
    MSI (s) (C8:20) [10:46:51:498]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_auto_index.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:499]: Executing op: ComponentRegister(ComponentId={A371EFDE-B219-4F46-AE6C-1463B864088E},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_auto_map_0.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A371EFDE-B219-4F46-AE6C-1463B864088E} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_auto_map_0.js
    MSI (s) (C8:20) [10:46:51:500]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_auto_map_0.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:500]: Executing op: ComponentRegister(ComponentId={60CAA7CE-99A8-4BFE-9DA1-D16F301E92B0},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\103.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {60CAA7CE-99A8-4BFE-9DA1-D16F301E92B0} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\103.js
    MSI (s) (C8:20) [10:46:51:501]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\103.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:501]: Executing op: ComponentRegister(ComponentId={03A91929-0307-4F2C-88CB-A0F437F58966},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_auto_map_0.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {03A91929-0307-4F2C-88CB-A0F437F58966} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_auto_map_0.js.gz
    MSI (s) (C8:20) [10:46:51:503]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_auto_map_0.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:503]: Executing op: ComponentRegister(ComponentId={9948B1CE-7B23-471D-9301-182854A0C465},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc121.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {9948B1CE-7B23-471D-9301-182854A0C465} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc121.new.js
    MSI (s) (C8:20) [10:46:51:504]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc121.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:504]: Executing op: ComponentRegister(ComponentId={9FE0C802-6841-4471-B6A1-10DC0058887C},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\40.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {9FE0C802-6841-4471-B6A1-10DC0058887C} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\40.js
    MSI (s) (C8:20) [10:46:51:506]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\40.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:506]: Executing op: ComponentRegister(ComponentId={71288BE8-8B69-45DA-8566-43A78CCC2741},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_auto_model_0.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {71288BE8-8B69-45DA-8566-43A78CCC2741} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_auto_model_0.js.gz
    MSI (s) (C8:20) [10:46:51:507]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_auto_model_0.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:507]: Executing op: ComponentRegister(ComponentId={19402A61-E986-4822-AECD-1CC1FCDB208F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_db.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {19402A61-E986-4822-AECD-1CC1FCDB208F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_db.js
    MSI (s) (C8:20) [10:46:51:509]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_db.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:509]: Executing op: ComponentRegister(ComponentId={93577769-91BC-4377-A86A-E61543A20B40},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\105.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {93577769-91BC-4377-A86A-E61543A20B40} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\105.js
    MSI (s) (C8:20) [10:46:51:510]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\105.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:510]: Executing op: ComponentRegister(ComponentId={F4A7C590-4AFF-4973-8517-28F51E82A526},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_fv_0.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F4A7C590-4AFF-4973-8517-28F51E82A526} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_fv_0.js.gz
    MSI (s) (C8:20) [10:46:51:511]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_fv_0.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:512]: Executing op: ComponentRegister(ComponentId={53A574C7-2A75-4692-9A45-21855627FBCC},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc102.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {53A574C7-2A75-4692-9A45-21855627FBCC} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc102.new.js
    MSI (s) (C8:20) [10:46:51:513]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc102.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:513]: Executing op: ComponentRegister(ComponentId={E020F4EB-2142-401B-9AAB-EF9336639730},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\102.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {E020F4EB-2142-401B-9AAB-EF9336639730} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\102.js
    MSI (s) (C8:20) [10:46:51:514]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\102.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:515]: Executing op: ComponentRegister(ComponentId={9D9092A9-7D83-4217-BB8A-615346EFC92A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc114.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {9D9092A9-7D83-4217-BB8A-615346EFC92A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc114.new.js
    MSI (s) (C8:20) [10:46:51:516]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc114.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:516]: Executing op: ComponentRegister(ComponentId={FE7CAF48-0BFB-4813-B2B5-278CDE4CD864},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_topics.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {FE7CAF48-0BFB-4813-B2B5-278CDE4CD864} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_topics.js.gz
    MSI (s) (C8:20) [10:46:51:517]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\search_topics.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:517]: Executing op: ComponentRegister(ComponentId={A4549B48-925C-4AEF-9BE9-E1E0CCD561EE},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\122.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A4549B48-925C-4AEF-9BE9-E1E0CCD561EE} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\122.js.gz
    MSI (s) (C8:20) [10:46:51:519]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\122.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:519]: Executing op: ComponentRegister(ComponentId={29F85F94-B3FE-4BD3-B69C-5CACB4BDD0EA},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\synonym.xml,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {29F85F94-B3FE-4BD3-B69C-5CACB4BDD0EA} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\synonym.xml
    MSI (s) (C8:20) [10:46:51:520]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\synonym.xml' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:520]: Executing op: ComponentRegister(ComponentId={1E0E7686-5246-481F-98A5-082C33571F25},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc.new.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {1E0E7686-5246-481F-98A5-082C33571F25} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc.new.js.gz
    MSI (s) (C8:20) [10:46:51:522]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc.new.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:522]: Executing op: ComponentRegister(ComponentId={44D2B41D-BA8A-4859-8F2B-EEC829B46288},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\104.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {44D2B41D-BA8A-4859-8F2B-EEC829B46288} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\104.js
    MSI (s) (C8:20) [10:46:51:523]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\104.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:523]: Executing op: ComponentRegister(ComponentId={AC84102C-3F58-4CD0-A984-1C7FC13B362C},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc10.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {AC84102C-3F58-4CD0-A984-1C7FC13B362C} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc10.new.js
    MSI (s) (C8:20) [10:46:51:525]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc10.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:525]: Executing op: ComponentRegister(ComponentId={DB8F8D92-BB7E-495B-A1B2-9FFAB40BFF19},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc101.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {DB8F8D92-BB7E-495B-A1B2-9FFAB40BFF19} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc101.new.js
    MSI (s) (C8:20) [10:46:51:526]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc101.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:526]: Executing op: ComponentRegister(ComponentId={351F2956-671B-43F1-82D5-7F02D97AE9CD},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\11.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {351F2956-671B-43F1-82D5-7F02D97AE9CD} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\11.js
    MSI (s) (C8:20) [10:46:51:527]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\11.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:528]: Executing op: ComponentRegister(ComponentId={1DD514EF-C790-48D1-A717-416F19CD529B},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc104.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {1DD514EF-C790-48D1-A717-416F19CD529B} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc104.new.js
    MSI (s) (C8:20) [10:46:51:529]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc104.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:529]: Executing op: ComponentRegister(ComponentId={99DFC54F-1A1F-4E7A-B6BF-36B36C784F4F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc106.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {99DFC54F-1A1F-4E7A-B6BF-36B36C784F4F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc106.new.js
    MSI (s) (C8:20) [10:46:51:530]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc106.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:531]: Executing op: ComponentRegister(ComponentId={5A800F75-4DD6-4B2E-8338-296FBC46A430},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\106.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {5A800F75-4DD6-4B2E-8338-296FBC46A430} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\106.js
    MSI (s) (C8:20) [10:46:51:532]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\106.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:532]: Executing op: ComponentRegister(ComponentId={A841E7B3-49B2-4320-881C-783AAB853D2F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc97.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A841E7B3-49B2-4320-881C-783AAB853D2F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc97.new.js
    MSI (s) (C8:20) [10:46:51:534]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc97.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:534]: Executing op: ComponentRegister(ComponentId={3CAAFC13-5401-4BBE-87D0-54FB444DA321},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc110.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {3CAAFC13-5401-4BBE-87D0-54FB444DA321} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc110.new.js
    MSI (s) (C8:20) [10:46:51:535]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc110.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:535]: Executing op: ComponentRegister(ComponentId={F16CF952-1E97-4FCC-82E8-F7BA91DE5031},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc111.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F16CF952-1E97-4FCC-82E8-F7BA91DE5031} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc111.new.js
    MSI (s) (C8:20) [10:46:51:537]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc111.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:537]: Executing op: ComponentRegister(ComponentId={E451D8B6-5B77-45EB-9BE7-D3D00FDB27E8},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc113.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {E451D8B6-5B77-45EB-9BE7-D3D00FDB27E8} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc113.new.js
    MSI (s) (C8:20) [10:46:51:538]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc113.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:538]: Executing op: ComponentRegister(ComponentId={43180CF0-C842-4DE3-B56B-9E18EE48754C},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc115.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {43180CF0-C842-4DE3-B56B-9E18EE48754C} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc115.new.js
    MSI (s) (C8:20) [10:46:51:540]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc115.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:540]: Executing op: ComponentRegister(ComponentId={55B74F1E-522B-4299-B3A2-17625CFEB4AC},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\108.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {55B74F1E-522B-4299-B3A2-17625CFEB4AC} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\108.js
    MSI (s) (C8:20) [10:46:51:541]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\108.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:542]: Executing op: ComponentRegister(ComponentId={201A50D6-CE1A-4781-9DB0-11E1E54A6879},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc117.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {201A50D6-CE1A-4781-9DB0-11E1E54A6879} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc117.new.js
    MSI (s) (C8:20) [10:46:51:543]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc117.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:543]: Executing op: ComponentRegister(ComponentId={1E73FB82-8B1A-4289-B1CA-B1A98C27E696},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc119.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {1E73FB82-8B1A-4289-B1CA-B1A98C27E696} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc119.new.js
    MSI (s) (C8:20) [10:46:51:545]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc119.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:545]: Executing op: ComponentRegister(ComponentId={5201F320-5FED-49EB-98A6-3311ECD297D2},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc122.new.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {5201F320-5FED-49EB-98A6-3311ECD297D2} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc122.new.js.gz
    MSI (s) (C8:20) [10:46:51:546]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc122.new.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:547]: Executing op: ComponentRegister(ComponentId={C78ECBA3-7710-498A-A4B9-AAAE2850AFBC},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc123.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {C78ECBA3-7710-498A-A4B9-AAAE2850AFBC} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc123.new.js
    MSI (s) (C8:20) [10:46:51:548]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc123.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:548]: Executing op: ComponentRegister(ComponentId={4804CE3A-71AC-4BED-907F-00CEFFB9265F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc124.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {4804CE3A-71AC-4BED-907F-00CEFFB9265F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc124.new.js
    MSI (s) (C8:20) [10:46:51:550]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc124.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:550]: Executing op: ComponentRegister(ComponentId={D90D95F3-6C8A-40B8-AA24-44C0E9CE0FAF},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc125.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D90D95F3-6C8A-40B8-AA24-44C0E9CE0FAF} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc125.new.js
    MSI (s) (C8:20) [10:46:51:551]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc125.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:552]: Executing op: ComponentRegister(ComponentId={1C1E511D-D279-4B30-9052-F61B21EFDC21},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc126.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {1C1E511D-D279-4B30-9052-F61B21EFDC21} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc126.new.js
    MSI (s) (C8:20) [10:46:51:554]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc126.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:554]: Executing op: ComponentRegister(ComponentId={8DCDD5BC-CCAD-469C-A3EB-2749AC48CD97},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc70.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8DCDD5BC-CCAD-469C-A3EB-2749AC48CD97} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc70.new.js
    MSI (s) (C8:20) [10:46:51:555]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc70.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:556]: Executing op: ComponentRegister(ComponentId={45EFAA3F-3439-45A9-B188-FEBE15BF2EC5},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc127.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {45EFAA3F-3439-45A9-B188-FEBE15BF2EC5} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc127.new.js
    MSI (s) (C8:20) [10:46:51:557]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc127.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:557]: Executing op: ComponentRegister(ComponentId={D5A131F7-7AD2-411A-80C2-A350B70BC1E2},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc129.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D5A131F7-7AD2-411A-80C2-A350B70BC1E2} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc129.new.js
    MSI (s) (C8:20) [10:46:51:558]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc129.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:559]: Executing op: ComponentRegister(ComponentId={81347EDA-509F-45E6-AACC-10912CA28D17},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc13.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {81347EDA-509F-45E6-AACC-10912CA28D17} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc13.new.js
    MSI (s) (C8:20) [10:46:51:560]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc13.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:560]: Executing op: ComponentRegister(ComponentId={F10D1C36-A79C-4CB0-B940-4DF8A51AE0D0},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc130.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F10D1C36-A79C-4CB0-B940-4DF8A51AE0D0} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc130.new.js
    MSI (s) (C8:20) [10:46:51:562]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc130.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:562]: Executing op: ComponentRegister(ComponentId={FD545689-B968-4CC0-81B7-7ED89688F8A8},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc131.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {FD545689-B968-4CC0-81B7-7ED89688F8A8} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc131.new.js
    MSI (s) (C8:20) [10:46:51:563]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc131.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:564]: Executing op: ComponentRegister(ComponentId={A73548F5-4B43-4B18-8E56-E04CB04DC563},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc132.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A73548F5-4B43-4B18-8E56-E04CB04DC563} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc132.new.js
    MSI (s) (C8:20) [10:46:51:565]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc132.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:565]: Executing op: ComponentRegister(ComponentId={62309EE1-38B2-4320-A0E1-AC40337E775F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc55.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {62309EE1-38B2-4320-A0E1-AC40337E775F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc55.new.js
    MSI (s) (C8:20) [10:46:51:567]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc55.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:567]: Executing op: ComponentRegister(ComponentId={E699CC77-E472-4F21-8EFD-388BF8E34025},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc133.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {E699CC77-E472-4F21-8EFD-388BF8E34025} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc133.new.js
    MSI (s) (C8:20) [10:46:51:569]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc133.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:569]: Executing op: ComponentRegister(ComponentId={828F944D-5FAA-4E6E-A0E8-878C4F587AED},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc134.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {828F944D-5FAA-4E6E-A0E8-878C4F587AED} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc134.new.js
    MSI (s) (C8:20) [10:46:51:571]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc134.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:571]: Executing op: ComponentRegister(ComponentId={4B778392-A74F-4C7A-B901-66B98765A726},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc135.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {4B778392-A74F-4C7A-B901-66B98765A726} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc135.new.js
    MSI (s) (C8:20) [10:46:51:572]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc135.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:573]: Executing op: ComponentRegister(ComponentId={2CF61007-3C65-4286-9CF4-220E3E9F6F11},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc136.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2CF61007-3C65-4286-9CF4-220E3E9F6F11} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc136.new.js
    MSI (s) (C8:20) [10:46:51:574]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc136.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:574]: Executing op: ComponentRegister(ComponentId={193B229E-702C-40F1-8114-4A4CF199EEF7},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc137.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {193B229E-702C-40F1-8114-4A4CF199EEF7} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc137.new.js
    MSI (s) (C8:20) [10:46:51:576]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc137.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:576]: Executing op: ComponentRegister(ComponentId={93F73C4C-F15D-4904-BC45-34D31FC0616F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc138.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {93F73C4C-F15D-4904-BC45-34D31FC0616F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc138.new.js
    MSI (s) (C8:20) [10:46:51:578]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc138.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:578]: Executing op: ComponentRegister(ComponentId={1145E11B-ED15-44AE-B326-E500F931523D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc139.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {1145E11B-ED15-44AE-B326-E500F931523D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc139.new.js
    MSI (s) (C8:20) [10:46:51:579]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc139.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:579]: Executing op: ComponentRegister(ComponentId={B3F7AA35-FDBB-4D51-ADFC-BB743D37D5C8},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc14.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {B3F7AA35-FDBB-4D51-ADFC-BB743D37D5C8} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc14.new.js
    MSI (s) (C8:20) [10:46:51:581]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc14.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:581]: Executing op: ComponentRegister(ComponentId={AC9A31EB-86D6-4DEC-B16A-90DEE2A122EC},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc15.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {AC9A31EB-86D6-4DEC-B16A-90DEE2A122EC} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc15.new.js
    MSI (s) (C8:20) [10:46:51:582]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc15.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:583]: Executing op: ComponentRegister(ComponentId={42B159F2-27E8-48AB-BFB8-4EE9D8B01B3A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc16.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {42B159F2-27E8-48AB-BFB8-4EE9D8B01B3A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc16.new.js
    MSI (s) (C8:20) [10:46:51:584]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc16.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:584]: Executing op: ComponentRegister(ComponentId={EC2C07AB-7383-456F-85CA-E66D8A9C9085},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc17.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {EC2C07AB-7383-456F-85CA-E66D8A9C9085} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc17.new.js
    MSI (s) (C8:20) [10:46:51:586]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc17.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:586]: Executing op: ComponentRegister(ComponentId={4909D075-50C9-4EF2-9410-A4D51295611D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\128.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {4909D075-50C9-4EF2-9410-A4D51295611D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\128.js
    MSI (s) (C8:20) [10:46:51:588]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\128.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:588]: Executing op: ComponentRegister(ComponentId={3612E63E-1528-4477-A179-CEADCCC7FD8E},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc19.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {3612E63E-1528-4477-A179-CEADCCC7FD8E} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc19.new.js
    MSI (s) (C8:20) [10:46:51:589]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc19.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:590]: Executing op: ComponentRegister(ComponentId={F1DD57DB-2B77-4A80-B19E-89444BB4AB00},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc20.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F1DD57DB-2B77-4A80-B19E-89444BB4AB00} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc20.new.js
    MSI (s) (C8:20) [10:46:51:591]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc20.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:591]: Executing op: ComponentRegister(ComponentId={979AA220-2175-4101-8B06-0B53A8E64E9D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\121.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {979AA220-2175-4101-8B06-0B53A8E64E9D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\121.js
    MSI (s) (C8:20) [10:46:51:593]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\121.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:593]: Executing op: ComponentRegister(ComponentId={84367478-7484-4B6E-B19F-7B954C346658},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc22.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {84367478-7484-4B6E-B19F-7B954C346658} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc22.new.js
    MSI (s) (C8:20) [10:46:51:595]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc22.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:595]: Executing op: ComponentRegister(ComponentId={AAEC6199-B9BE-456E-AD1F-3A0B2D2AE5AE},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc24.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {AAEC6199-B9BE-456E-AD1F-3A0B2D2AE5AE} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc24.new.js
    MSI (s) (C8:20) [10:46:51:597]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc24.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:597]: Executing op: ComponentRegister(ComponentId={EBB25E48-0403-4E3F-BD75-46D43BD62388},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\131.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {EBB25E48-0403-4E3F-BD75-46D43BD62388} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\131.js.gz
    MSI (s) (C8:20) [10:46:51:598]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\131.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:598]: Executing op: ComponentRegister(ComponentId={B8A2A299-378D-4EB2-A12C-E731ADF4F1F1},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc26.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {B8A2A299-378D-4EB2-A12C-E731ADF4F1F1} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc26.new.js
    MSI (s) (C8:20) [10:46:51:600]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc26.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:600]: Executing op: ComponentRegister(ComponentId={ECA52FE6-718F-43A9-8DB7-E158243DAB4B},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc28.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {ECA52FE6-718F-43A9-8DB7-E158243DAB4B} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc28.new.js
    MSI (s) (C8:20) [10:46:51:602]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc28.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:602]: Executing op: ComponentRegister(ComponentId={13A367BC-1F22-4C19-94D8-4D936D7B1DCF},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\126.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {13A367BC-1F22-4C19-94D8-4D936D7B1DCF} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\126.js.gz
    MSI (s) (C8:20) [10:46:51:604]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\126.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:604]: Executing op: ComponentRegister(ComponentId={6220AA73-B8B9-494B-BCAD-3396349E43AA},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc29.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {6220AA73-B8B9-494B-BCAD-3396349E43AA} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc29.new.js
    MSI (s) (C8:20) [10:46:51:605]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc29.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:606]: Executing op: ComponentRegister(ComponentId={13A685DC-E514-4132-9E4B-C86E837B28A8},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc30.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {13A685DC-E514-4132-9E4B-C86E837B28A8} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc30.new.js
    MSI (s) (C8:20) [10:46:51:607]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc30.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:607]: Executing op: ComponentRegister(ComponentId={DA9EA323-368D-470F-9906-3E5D3D93D983},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\134.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {DA9EA323-368D-470F-9906-3E5D3D93D983} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\134.js.gz
    MSI (s) (C8:20) [10:46:51:609]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\134.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:609]: Executing op: ComponentRegister(ComponentId={6BABF391-5B9F-445E-8BBE-C0FF45A46043},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc31.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {6BABF391-5B9F-445E-8BBE-C0FF45A46043} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc31.new.js
    MSI (s) (C8:20) [10:46:51:611]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc31.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:611]: Executing op: ComponentRegister(ComponentId={253FAA55-CFE5-4995-87FC-099144CDB47F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc33.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {253FAA55-CFE5-4995-87FC-099144CDB47F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc33.new.js
    MSI (s) (C8:20) [10:46:51:612]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc33.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:613]: Executing op: ComponentRegister(ComponentId={88D13351-CA5F-4EE7-9851-F5E830A47B90},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\129.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {88D13351-CA5F-4EE7-9851-F5E830A47B90} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\129.js.gz
    MSI (s) (C8:20) [10:46:51:614]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\129.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:614]: Executing op: ComponentRegister(ComponentId={27259558-E06D-4110-870D-A6D99BFA677D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc35.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {27259558-E06D-4110-870D-A6D99BFA677D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc35.new.js
    MSI (s) (C8:20) [10:46:51:616]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc35.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:616]: Executing op: ComponentRegister(ComponentId={A450BEE7-0EC2-464D-A2CD-CCB896C089DA},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc37.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A450BEE7-0EC2-464D-A2CD-CCB896C089DA} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc37.new.js
    MSI (s) (C8:20) [10:46:51:618]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc37.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:618]: Executing op: ComponentRegister(ComponentId={9C35E682-9332-4CD9-8F4A-AC5E56A04DFF},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\137.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {9C35E682-9332-4CD9-8F4A-AC5E56A04DFF} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\137.js
    MSI (s) (C8:20) [10:46:51:619]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\137.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:620]: Executing op: ComponentRegister(ComponentId={6E7EC5DB-E878-45A3-A9B3-E1579DD945E8},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc39.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {6E7EC5DB-E878-45A3-A9B3-E1579DD945E8} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc39.new.js
    MSI (s) (C8:20) [10:46:51:621]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc39.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:621]: Executing op: ComponentRegister(ComponentId={59A3013E-3E17-4313-8631-9082220B503F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc42.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {59A3013E-3E17-4313-8631-9082220B503F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc42.new.js
    MSI (s) (C8:20) [10:46:51:623]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc42.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:623]: Executing op: ComponentRegister(ComponentId={CAD1C9A8-76B9-426F-BCC3-DCE6AFD8825F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\82.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {CAD1C9A8-76B9-426F-BCC3-DCE6AFD8825F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\82.js
    MSI (s) (C8:20) [10:46:51:624]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\82.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:624]: Executing op: ComponentRegister(ComponentId={71F33501-5C61-47AF-AAB8-E300F2910A78},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc44.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {71F33501-5C61-47AF-AAB8-E300F2910A78} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc44.new.js
    MSI (s) (C8:20) [10:46:51:626]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc44.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:626]: Executing op: ComponentRegister(ComponentId={05CBB9EE-B7F0-41E4-BB42-7165FBC3AF13},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc45.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {05CBB9EE-B7F0-41E4-BB42-7165FBC3AF13} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc45.new.js
    MSI (s) (C8:20) [10:46:51:627]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc45.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:628]: Executing op: ComponentRegister(ComponentId={91AAC297-773F-4456-ACF0-6830C39FF4D6},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc86.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {91AAC297-773F-4456-ACF0-6830C39FF4D6} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc86.new.js
    MSI (s) (C8:20) [10:46:51:629]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc86.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:629]: Executing op: ComponentRegister(ComponentId={F9131CE1-D5B8-4BE1-BC8B-16A601953D39},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc47.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F9131CE1-D5B8-4BE1-BC8B-16A601953D39} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc47.new.js
    MSI (s) (C8:20) [10:46:51:631]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc47.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:631]: Executing op: ComponentRegister(ComponentId={24393E47-5657-48F6-8D1E-FB212BB85E47},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc50.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {24393E47-5657-48F6-8D1E-FB212BB85E47} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc50.new.js
    MSI (s) (C8:20) [10:46:51:633]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc50.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:633]: Executing op: ComponentRegister(ComponentId={F3C3A841-2B43-48F0-BAAD-D994E2D7FA2F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\136.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F3C3A841-2B43-48F0-BAAD-D994E2D7FA2F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\136.js
    MSI (s) (C8:20) [10:46:51:635]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\136.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:635]: Executing op: ComponentRegister(ComponentId={ED755C27-E28A-4837-AA91-49D4BA2D29C4},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc52.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {ED755C27-E28A-4837-AA91-49D4BA2D29C4} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc52.new.js
    MSI (s) (C8:20) [10:46:51:636]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc52.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:636]: Executing op: ComponentRegister(ComponentId={ACF42134-168B-4658-835C-CC5A5ECA5216},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc54.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {ACF42134-168B-4658-835C-CC5A5ECA5216} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc54.new.js
    MSI (s) (C8:20) [10:46:51:638]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc54.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:638]: Executing op: ComponentRegister(ComponentId={43231C93-A6A4-4BC9-9A64-34F79ECE80F7},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc91.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {43231C93-A6A4-4BC9-9A64-34F79ECE80F7} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc91.new.js
    MSI (s) (C8:20) [10:46:51:639]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc91.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:640]: Executing op: ComponentRegister(ComponentId={A921CB92-4942-4E16-BB83-6C6E478933DF},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc58.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A921CB92-4942-4E16-BB83-6C6E478933DF} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc58.new.js
    MSI (s) (C8:20) [10:46:51:641]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc58.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:641]: Executing op: ComponentRegister(ComponentId={5CDDD432-69FE-4E45-B981-049560945262},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc6.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {5CDDD432-69FE-4E45-B981-049560945262} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc6.new.js
    MSI (s) (C8:20) [10:46:51:643]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc6.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:643]: Executing op: ComponentRegister(ComponentId={998B5251-C2A5-4F6D-82D6-763E99D1C136},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc80.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {998B5251-C2A5-4F6D-82D6-763E99D1C136} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc80.new.js
    MSI (s) (C8:20) [10:46:51:644]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc80.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:645]: Executing op: ComponentRegister(ComponentId={E71DFACC-690D-4CB9-A0D4-144ECD80C716},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc61.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {E71DFACC-690D-4CB9-A0D4-144ECD80C716} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc61.new.js
    MSI (s) (C8:20) [10:46:51:646]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc61.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:646]: Executing op: ComponentRegister(ComponentId={449EA348-AC60-400E-BFF9-B4C6D91FA09E},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc63.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {449EA348-AC60-400E-BFF9-B4C6D91FA09E} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc63.new.js
    MSI (s) (C8:20) [10:46:51:648]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc63.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:648]: Executing op: ComponentRegister(ComponentId={D3E44CA6-60D9-4BC7-A911-3DEE5752F42F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\1.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D3E44CA6-60D9-4BC7-A911-3DEE5752F42F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\1.js
    MSI (s) (C8:20) [10:46:51:649]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\1.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:650]: Executing op: ComponentRegister(ComponentId={7A33097F-868B-4803-95BE-D23026E9B2B4},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc64.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {7A33097F-868B-4803-95BE-D23026E9B2B4} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc64.new.js
    MSI (s) (C8:20) [10:46:51:651]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc64.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:651]: Executing op: ComponentRegister(ComponentId={613BED9F-1B2D-450B-BB0E-9AB01AD37273},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc65.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {613BED9F-1B2D-450B-BB0E-9AB01AD37273} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc65.new.js
    MSI (s) (C8:20) [10:46:51:653]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc65.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:653]: Executing op: ComponentRegister(ComponentId={D2CC1819-7E91-4EF9-A83C-AD27080E8E0A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc87.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D2CC1819-7E91-4EF9-A83C-AD27080E8E0A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc87.new.js
    MSI (s) (C8:20) [10:46:51:655]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc87.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:655]: Executing op: ComponentRegister(ComponentId={B5AF8FD5-F7C5-41DD-A0C2-A170C55BB2CD},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc67.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {B5AF8FD5-F7C5-41DD-A0C2-A170C55BB2CD} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc67.new.js
    MSI (s) (C8:20) [10:46:51:657]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc67.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:657]: Executing op: ComponentRegister(ComponentId={E7C3E96E-EFEF-4B48-8C09-EE3AC54F01AC},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc69.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {E7C3E96E-EFEF-4B48-8C09-EE3AC54F01AC} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc69.new.js
    MSI (s) (C8:20) [10:46:51:659]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc69.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:659]: Executing op: ComponentRegister(ComponentId={49285978-EFB9-4E4F-8540-7445D334D0DA},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\10.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {49285978-EFB9-4E4F-8540-7445D334D0DA} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\10.js
    MSI (s) (C8:20) [10:46:51:660]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\10.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:661]: Executing op: ComponentRegister(ComponentId={E85E70C1-9F6F-4B31-84BF-6F1B49BBD6CC},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc72.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {E85E70C1-9F6F-4B31-84BF-6F1B49BBD6CC} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc72.new.js
    MSI (s) (C8:20) [10:46:51:662]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc72.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:662]: Executing op: ComponentRegister(ComponentId={20FFF79E-1D8E-4A80-BD34-0FAB47332287},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc74.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {20FFF79E-1D8E-4A80-BD34-0FAB47332287} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc74.new.js
    MSI (s) (C8:20) [10:46:51:664]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc74.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:664]: Executing op: ComponentRegister(ComponentId={87B44728-D66C-4313-B520-CDD6D139230D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc98.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {87B44728-D66C-4313-B520-CDD6D139230D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc98.new.js
    MSI (s) (C8:20) [10:46:51:666]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc98.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:666]: Executing op: ComponentRegister(ComponentId={D1105F65-5FEB-433A-BB50-55190C62B568},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc76.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D1105F65-5FEB-433A-BB50-55190C62B568} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc76.new.js
    MSI (s) (C8:20) [10:46:51:667]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc76.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:667]: Executing op: ComponentRegister(ComponentId={90F21B93-445A-41E9-897A-E2BCF0CC174B},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc78.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {90F21B93-445A-41E9-897A-E2BCF0CC174B} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc78.new.js
    MSI (s) (C8:20) [10:46:51:669]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc78.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:669]: Executing op: ComponentRegister(ComponentId={E0A1E50C-30E2-46A1-979E-9D1C8D09BADF},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc79.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {E0A1E50C-30E2-46A1-979E-9D1C8D09BADF} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc79.new.js
    MSI (s) (C8:20) [10:46:51:671]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc79.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:671]: Executing op: ComponentRegister(ComponentId={903797B0-92D4-434B-86B6-91767EE31801},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc8.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {903797B0-92D4-434B-86B6-91767EE31801} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc8.new.js
    MSI (s) (C8:20) [10:46:51:672]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc8.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:673]: Executing op: ComponentRegister(ComponentId={294F3798-26CC-40CA-99A3-43317D1316B7},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc81.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {294F3798-26CC-40CA-99A3-43317D1316B7} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc81.new.js
    MSI (s) (C8:20) [10:46:51:674]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc81.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:674]: Executing op: ComponentRegister(ComponentId={00E6C02F-785B-42DB-A0D1-3DE8729261B6},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc82.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {00E6C02F-785B-42DB-A0D1-3DE8729261B6} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc82.new.js
    MSI (s) (C8:20) [10:46:51:676]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc82.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:676]: Executing op: ComponentRegister(ComponentId={5B0FB95C-8065-48B1-B5EB-40DFFF1733EE},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc83.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {5B0FB95C-8065-48B1-B5EB-40DFFF1733EE} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc83.new.js
    MSI (s) (C8:20) [10:46:51:678]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc83.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:678]: Executing op: ComponentRegister(ComponentId={81CEB57E-1F0B-415C-91BF-DD92AA11D9DC},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc84.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {81CEB57E-1F0B-415C-91BF-DD92AA11D9DC} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc84.new.js
    MSI (s) (C8:20) [10:46:51:680]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc84.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:680]: Executing op: ComponentRegister(ComponentId={0FA1977E-493D-4632-A4F3-81E3D7490DAD},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc84.new.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0FA1977E-493D-4632-A4F3-81E3D7490DAD} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc84.new.js.gz
    MSI (s) (C8:20) [10:46:51:681]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc84.new.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:682]: Executing op: ComponentRegister(ComponentId={8E1AF220-3684-4350-879E-1962D17381CA},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc85.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8E1AF220-3684-4350-879E-1962D17381CA} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc85.new.js
    MSI (s) (C8:20) [10:46:51:683]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc85.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:683]: Executing op: ComponentRegister(ComponentId={96716349-45EF-45D2-B070-0B199D51CA89},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc88.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {96716349-45EF-45D2-B070-0B199D51CA89} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc88.new.js
    MSI (s) (C8:20) [10:46:51:685]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc88.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:685]: Executing op: ComponentRegister(ComponentId={6C9C44ED-D4B7-4A81-8F23-7D5FCAF31859},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc89.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {6C9C44ED-D4B7-4A81-8F23-7D5FCAF31859} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc89.new.js
    MSI (s) (C8:20) [10:46:51:687]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc89.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:687]: Executing op: ComponentRegister(ComponentId={F6FAD98B-6AC6-401B-A0F6-90C2A8A696CC},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc9.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F6FAD98B-6AC6-401B-A0F6-90C2A8A696CC} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc9.new.js
    MSI (s) (C8:20) [10:46:51:688]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc9.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:688]: Executing op: ComponentRegister(ComponentId={4705C2A7-3C9A-460C-B827-D2C95BCBFE6F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc93.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {4705C2A7-3C9A-460C-B827-D2C95BCBFE6F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc93.new.js
    MSI (s) (C8:20) [10:46:51:690]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc93.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:690]: Executing op: ComponentRegister(ComponentId={EE8C40AE-78C3-4176-BBC0-9911D33618F0},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc94.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {EE8C40AE-78C3-4176-BBC0-9911D33618F0} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc94.new.js
    MSI (s) (C8:20) [10:46:51:691]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc94.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:692]: Executing op: ComponentRegister(ComponentId={5228D401-E598-4AA8-BE41-7A8E659170E3},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc95.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {5228D401-E598-4AA8-BE41-7A8E659170E3} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc95.new.js
    MSI (s) (C8:20) [10:46:51:693]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc95.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:693]: Executing op: ComponentRegister(ComponentId={FBD7F6F6-629C-40C2-AFBF-AAE628EC7728},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc99.new.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {FBD7F6F6-629C-40C2-AFBF-AAE628EC7728} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc99.new.js
    MSI (s) (C8:20) [10:46:51:695]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\toc99.new.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:695]: Executing op: ComponentRegister(ComponentId={BB0796C2-479D-44A1-8664-CE4EE7620B03},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\0.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {BB0796C2-479D-44A1-8664-CE4EE7620B03} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\0.js
    MSI (s) (C8:20) [10:46:51:697]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\0.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:697]: Executing op: ComponentRegister(ComponentId={FDAA1A58-C718-46CD-916E-40E0EAA999FC},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\117.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {FDAA1A58-C718-46CD-916E-40E0EAA999FC} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\117.js
    MSI (s) (C8:20) [10:46:51:699]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\117.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:699]: Executing op: ComponentRegister(ComponentId={86EE50AE-C1F8-4FC8-A3B4-64DEA77157C4},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\123.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {86EE50AE-C1F8-4FC8-A3B4-64DEA77157C4} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\123.js
    MSI (s) (C8:20) [10:46:51:700]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\123.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:700]: Executing op: ComponentRegister(ComponentId={7D14D2D1-BB02-4894-BFD7-554537F2EBA5},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\100.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {7D14D2D1-BB02-4894-BFD7-554537F2EBA5} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\100.js
    MSI (s) (C8:20) [10:46:51:702]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\100.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:702]: Executing op: ComponentRegister(ComponentId={463C00AE-C335-45B4-8FF4-BC3E939CD391},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\121.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {463C00AE-C335-45B4-8FF4-BC3E939CD391} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\121.js.gz
    MSI (s) (C8:20) [10:46:51:704]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\121.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:704]: Executing op: ComponentRegister(ComponentId={2573FC69-D4CA-43DC-8A4D-6553F79D5505},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\1.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2573FC69-D4CA-43DC-8A4D-6553F79D5505} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\1.js.gz
    MSI (s) (C8:20) [10:46:51:706]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\1.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:706]: Executing op: ComponentRegister(ComponentId={7F270750-DDFB-4CE2-8C64-2E78D2ECE682},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\101.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {7F270750-DDFB-4CE2-8C64-2E78D2ECE682} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\101.js
    MSI (s) (C8:20) [10:46:51:708]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\101.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:708]: Executing op: ComponentRegister(ComponentId={5039AF29-862D-423E-BD78-C6F504021C89},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\54.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {5039AF29-862D-423E-BD78-C6F504021C89} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\54.js
    MSI (s) (C8:20) [10:46:51:709]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\54.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:709]: Executing op: ComponentRegister(ComponentId={0B55C988-71DD-4AE7-8D04-D3AD277BE69C},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\100.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0B55C988-71DD-4AE7-8D04-D3AD277BE69C} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\100.js.gz
    MSI (s) (C8:20) [10:46:51:711]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\100.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:711]: Executing op: ComponentRegister(ComponentId={E0E59823-43F7-44AE-A845-844D3F769BDC},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\101.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {E0E59823-43F7-44AE-A845-844D3F769BDC} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\101.js.gz
    MSI (s) (C8:20) [10:46:51:712]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\101.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:712]: Executing op: ComponentRegister(ComponentId={2845F6A6-E61F-4B7F-973C-0EE72AA7939C},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\120.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2845F6A6-E61F-4B7F-973C-0EE72AA7939C} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\120.js
    MSI (s) (C8:20) [10:46:51:714]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\120.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:714]: Executing op: ComponentRegister(ComponentId={00B02534-CB61-49A7-B7AE-4C9745858105},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\102.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {00B02534-CB61-49A7-B7AE-4C9745858105} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\102.js.gz
    MSI (s) (C8:20) [10:46:51:716]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\102.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:716]: Executing op: ComponentRegister(ComponentId={5D170A04-4548-467C-8E2F-EDED5C2C1134},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\126.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {5D170A04-4548-467C-8E2F-EDED5C2C1134} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\126.js
    MSI (s) (C8:20) [10:46:51:718]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\126.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:718]: Executing op: ComponentRegister(ComponentId={8603E2B0-0E36-47A2-AF89-6E24009B7DE9},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\20.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8603E2B0-0E36-47A2-AF89-6E24009B7DE9} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\20.js
    MSI (s) (C8:20) [10:46:51:719]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\20.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:720]: Executing op: ComponentRegister(ComponentId={16897C8E-C28E-40BA-BF27-991CA19ED047},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\109.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {16897C8E-C28E-40BA-BF27-991CA19ED047} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\109.js
    MSI (s) (C8:20) [10:46:51:721]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\109.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:721]: Executing op: ComponentRegister(ComponentId={91D2574B-7E26-4B5A-B227-91D65CADB21D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\103.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {91D2574B-7E26-4B5A-B227-91D65CADB21D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\103.js.gz
    MSI (s) (C8:20) [10:46:51:723]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\103.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:723]: Executing op: ComponentRegister(ComponentId={6B0AF397-08EA-43C8-9CAC-61A7BA1C0991},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\130.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {6B0AF397-08EA-43C8-9CAC-61A7BA1C0991} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\130.js
    MSI (s) (C8:20) [10:46:51:724]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\130.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:725]: Executing op: ComponentRegister(ComponentId={15053AF8-0D26-489A-9C7C-EB451A142A74},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\15.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {15053AF8-0D26-489A-9C7C-EB451A142A74} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\15.js
    MSI (s) (C8:20) [10:46:51:726]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\15.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:726]: Executing op: ComponentRegister(ComponentId={8DC666D2-882B-428C-B27E-C03E673A0BF1},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\104.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8DC666D2-882B-428C-B27E-C03E673A0BF1} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\104.js.gz
    MSI (s) (C8:20) [10:46:51:728]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\104.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:728]: Executing op: ComponentRegister(ComponentId={00EA5630-BED4-479C-B5EF-DCD489832662},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\113.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {00EA5630-BED4-479C-B5EF-DCD489832662} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\113.js
    MSI (s) (C8:20) [10:46:51:730]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\113.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:730]: Executing op: ComponentRegister(ComponentId={B1C016DA-BC5B-4118-9B2C-2CAD7EBEC8D4},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\133.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {B1C016DA-BC5B-4118-9B2C-2CAD7EBEC8D4} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\133.js
    MSI (s) (C8:20) [10:46:51:732]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\133.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:732]: Executing op: ComponentRegister(ComponentId={3BF182F5-CD2A-4AEA-9C55-C06413B42D3A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\105.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {3BF182F5-CD2A-4AEA-9C55-C06413B42D3A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\105.js.gz
    MSI (s) (C8:20) [10:46:51:733]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\105.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:734]: Executing op: ComponentRegister(ComponentId={8A604871-C1FE-4B43-9E9B-AB1FB46E652A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\45.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8A604871-C1FE-4B43-9E9B-AB1FB46E652A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\45.js
    MSI (s) (C8:20) [10:46:51:735]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\45.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:736]: Executing op: ComponentRegister(ComponentId={FFB70666-3C38-462C-BAC3-F0021E491E6A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\118.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {FFB70666-3C38-462C-BAC3-F0021E491E6A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\118.js
    MSI (s) (C8:20) [10:46:51:737]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\118.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:737]: Executing op: ComponentRegister(ComponentId={C0A19093-C9E6-4752-9C7A-EE6840B3B439},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\66.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {C0A19093-C9E6-4752-9C7A-EE6840B3B439} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\66.js
    MSI (s) (C8:20) [10:46:51:739]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\66.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:739]: Executing op: ComponentRegister(ComponentId={79B49B00-6CD7-45AC-A364-FABD63E26D46},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\106.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {79B49B00-6CD7-45AC-A364-FABD63E26D46} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\106.js.gz
    MSI (s) (C8:20) [10:46:51:741]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\106.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:741]: Executing op: ComponentRegister(ComponentId={81AC7418-062C-4047-BB6D-DCE42FF36305},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\107.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {81AC7418-062C-4047-BB6D-DCE42FF36305} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\107.js
    MSI (s) (C8:20) [10:46:51:743]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\107.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:743]: Executing op: ComponentRegister(ComponentId={11495F8A-D41E-444E-BB74-F51A79A98097},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\110.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {11495F8A-D41E-444E-BB74-F51A79A98097} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\110.js
    MSI (s) (C8:20) [10:46:51:745]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\110.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:745]: Executing op: ComponentRegister(ComponentId={9E1E6AE3-1E00-4C2C-8A4F-11517305F060},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\107.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {9E1E6AE3-1E00-4C2C-8A4F-11517305F060} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\107.js.gz
    MSI (s) (C8:20) [10:46:51:746]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\107.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:747]: Executing op: ComponentRegister(ComponentId={FA7A399E-06E3-48AB-B7BE-E4D387999B22},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\117.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {FA7A399E-06E3-48AB-B7BE-E4D387999B22} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\117.js.gz
    MSI (s) (C8:20) [10:46:51:748]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\117.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:748]: Executing op: ComponentRegister(ComponentId={6458B593-8DEA-4789-8D77-679ABB179C7B},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\108.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {6458B593-8DEA-4789-8D77-679ABB179C7B} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\108.js.gz
    MSI (s) (C8:20) [10:46:51:750]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\108.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:750]: Executing op: ComponentRegister(ComponentId={AF4D97F8-BD47-4381-9EE0-DD08F348023D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\109.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {AF4D97F8-BD47-4381-9EE0-DD08F348023D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\109.js.gz
    MSI (s) (C8:20) [10:46:51:752]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\109.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:752]: Executing op: ComponentRegister(ComponentId={C175D3EC-26DB-4E20-9C59-898B9FF483AF},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\110.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {C175D3EC-26DB-4E20-9C59-898B9FF483AF} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\110.js.gz
    MSI (s) (C8:20) [10:46:51:753]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\110.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:753]: Executing op: ComponentRegister(ComponentId={E98E3994-2F44-4B98-A4C0-AC595536A2E7},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\55.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {E98E3994-2F44-4B98-A4C0-AC595536A2E7} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\55.js.gz
    MSI (s) (C8:20) [10:46:51:755]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\55.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:755]: Executing op: ComponentRegister(ComponentId={7931F1E7-F753-4D18-87E6-2C23CD7AF5C9},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\124.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {7931F1E7-F753-4D18-87E6-2C23CD7AF5C9} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\124.js
    MSI (s) (C8:20) [10:46:51:756]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\124.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:757]: Executing op: ComponentRegister(ComponentId={A426813A-1B6F-4697-8FFE-0F3C60C98BE5},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\111.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A426813A-1B6F-4697-8FFE-0F3C60C98BE5} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\111.js
    MSI (s) (C8:20) [10:46:51:758]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\111.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:758]: Executing op: ComponentRegister(ComponentId={2B23016B-B6D2-4EE9-84D3-BEEE4457DF13},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\96.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2B23016B-B6D2-4EE9-84D3-BEEE4457DF13} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\96.js.gz
    MSI (s) (C8:20) [10:46:51:760]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\96.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:760]: Executing op: ComponentRegister(ComponentId={195C9A32-37FD-4E60-BB0F-85DDE345F274},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\80.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {195C9A32-37FD-4E60-BB0F-85DDE345F274} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\80.js
    MSI (s) (C8:20) [10:46:51:762]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\80.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:762]: Executing op: ComponentRegister(ComponentId={8FCB8732-5602-4847-97EF-3DAC95D92E4A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\111.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8FCB8732-5602-4847-97EF-3DAC95D92E4A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\111.js.gz
    MSI (s) (C8:20) [10:46:51:763]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\111.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:764]: Executing op: ComponentRegister(ComponentId={394A4516-69E8-48D5-BE9D-81563E9489BC},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\112.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {394A4516-69E8-48D5-BE9D-81563E9489BC} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\112.js
    MSI (s) (C8:20) [10:46:51:765]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\112.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:766]: Executing op: ComponentRegister(ComponentId={5F5AE69E-D0D8-4DE7-AA04-CEAF3E47F0B1},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\112.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {5F5AE69E-D0D8-4DE7-AA04-CEAF3E47F0B1} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\112.js.gz
    MSI (s) (C8:20) [10:46:51:767]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\112.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:767]: Executing op: ComponentRegister(ComponentId={84A9DF80-012A-4096-9EDB-40D68061C6F1},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\95.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {84A9DF80-012A-4096-9EDB-40D68061C6F1} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\95.js
    MSI (s) (C8:20) [10:46:51:769]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\95.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:769]: Executing op: ComponentRegister(ComponentId={FBB627B7-2159-4294-ABA2-3D678804848D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\73.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {FBB627B7-2159-4294-ABA2-3D678804848D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\73.js.gz
    MSI (s) (C8:20) [10:46:51:771]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\73.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:771]: Executing op: ComponentRegister(ComponentId={B7F2B34F-2AF4-456A-A875-58902CAE2787},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\113.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {B7F2B34F-2AF4-456A-A875-58902CAE2787} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\113.js.gz
    MSI (s) (C8:20) [10:46:51:773]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\113.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:773]: Executing op: ComponentRegister(ComponentId={7086FDB6-45AA-40CD-8CAE-02D2A4086523},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\76.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {7086FDB6-45AA-40CD-8CAE-02D2A4086523} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\76.js.gz
    MSI (s) (C8:20) [10:46:51:774]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\76.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:775]: Executing op: ComponentRegister(ComponentId={0BCC1A74-B96F-4181-B190-B1CBC99996D0},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\114.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0BCC1A74-B96F-4181-B190-B1CBC99996D0} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\114.js
    MSI (s) (C8:20) [10:46:51:776]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\114.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:776]: Executing op: ComponentRegister(ComponentId={D6516555-0B3E-48D5-87EA-5050F9B05FCF},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\114.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D6516555-0B3E-48D5-87EA-5050F9B05FCF} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\114.js.gz
    MSI (s) (C8:20) [10:46:51:777]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\114.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:778]: Executing op: ComponentRegister(ComponentId={4D78EE8D-4B69-4276-AF0C-E9E4A097AA18},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\41.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {4D78EE8D-4B69-4276-AF0C-E9E4A097AA18} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\41.js
    MSI (s) (C8:20) [10:46:51:779]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\41.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:779]: Executing op: ComponentRegister(ComponentId={E0B572C7-F51E-4A20-BF6D-DA41E53DDC5D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\115.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {E0B572C7-F51E-4A20-BF6D-DA41E53DDC5D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\115.js
    MSI (s) (C8:20) [10:46:51:781]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\115.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:781]: Executing op: ComponentRegister(ComponentId={57B42DA1-C5AA-444C-8E59-0895FDA1818A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\115.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {57B42DA1-C5AA-444C-8E59-0895FDA1818A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\115.js.gz
    MSI (s) (C8:20) [10:46:51:783]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\115.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:783]: Executing op: ComponentRegister(ComponentId={D71E7F05-4F51-4A2F-9EF2-CE8671B45DBE},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\52.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D71E7F05-4F51-4A2F-9EF2-CE8671B45DBE} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\52.js
    MSI (s) (C8:20) [10:46:51:784]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\52.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:785]: Executing op: ComponentRegister(ComponentId={320ACB34-CE48-4AC1-B396-756C63F83C3F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\116.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {320ACB34-CE48-4AC1-B396-756C63F83C3F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\116.js
    MSI (s) (C8:20) [10:46:51:786]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\116.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:787]: Executing op: ComponentRegister(ComponentId={A7DDCBA6-37EF-4B3C-B8A9-28C4D896CB98},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\44.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A7DDCBA6-37EF-4B3C-B8A9-28C4D896CB98} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\44.js
    MSI (s) (C8:20) [10:46:51:788]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\44.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:788]: Executing op: ComponentRegister(ComponentId={0B5DB171-6933-4B7C-A5A4-624FD7787896},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\116.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0B5DB171-6933-4B7C-A5A4-624FD7787896} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\116.js.gz
    MSI (s) (C8:20) [10:46:51:790]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\116.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:790]: Executing op: ComponentRegister(ComponentId={32D85E5C-2B1D-4F61-A150-205F216091E8},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\118.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {32D85E5C-2B1D-4F61-A150-205F216091E8} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\118.js.gz
    MSI (s) (C8:20) [10:46:51:792]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\118.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:792]: Executing op: ComponentRegister(ComponentId={B1F30BC1-182F-4200-813D-E2A35550C7C3},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\119.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {B1F30BC1-182F-4200-813D-E2A35550C7C3} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\119.js
    MSI (s) (C8:20) [10:46:51:793]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\119.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:794]: Executing op: ComponentRegister(ComponentId={571D1E48-12FE-4695-AA7B-B1562827134E},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\119.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {571D1E48-12FE-4695-AA7B-B1562827134E} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\119.js.gz
    MSI (s) (C8:20) [10:46:51:795]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\119.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:795]: Executing op: ComponentRegister(ComponentId={0A6F43F4-6FEE-497E-B383-D1B864CD47AD},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\12.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0A6F43F4-6FEE-497E-B383-D1B864CD47AD} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\12.js
    MSI (s) (C8:20) [10:46:51:797]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\12.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:797]: Executing op: ComponentRegister(ComponentId={EE487B0A-8675-4B68-BD20-C90955ECC9A2},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\120.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {EE487B0A-8675-4B68-BD20-C90955ECC9A2} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\120.js.gz
    MSI (s) (C8:20) [10:46:51:798]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\120.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:798]: Executing op: ComponentRegister(ComponentId={0C891288-C8C3-4E0D-81B1-6CB6237DA51F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\43.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0C891288-C8C3-4E0D-81B1-6CB6237DA51F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\43.js
    MSI (s) (C8:20) [10:46:51:800]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\43.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:800]: Executing op: ComponentRegister(ComponentId={F95CCD08-3780-43CD-A20C-740038C36E14},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\122.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F95CCD08-3780-43CD-A20C-740038C36E14} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\122.js
    MSI (s) (C8:20) [10:46:51:802]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\122.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:802]: Executing op: ComponentRegister(ComponentId={6CAD4554-B930-42CB-882E-F1302C0C14EB},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\123.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {6CAD4554-B930-42CB-882E-F1302C0C14EB} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\123.js.gz
    MSI (s) (C8:20) [10:46:51:804]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\123.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:804]: Executing op: ComponentRegister(ComponentId={B33889D9-8ECD-458D-ABCF-4875478AA6C5},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\124.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {B33889D9-8ECD-458D-ABCF-4875478AA6C5} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\124.js.gz
    MSI (s) (C8:20) [10:46:51:805]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\124.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:805]: Executing op: ComponentRegister(ComponentId={5282353B-2E2F-4E4E-9DD1-EB749FF84E88},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\125.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {5282353B-2E2F-4E4E-9DD1-EB749FF84E88} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\125.js
    MSI (s) (C8:20) [10:46:51:807]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\125.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:807]: Executing op: ComponentRegister(ComponentId={82A02097-F8C9-4DE8-B7AA-94C050287A86},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\125.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {82A02097-F8C9-4DE8-B7AA-94C050287A86} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\125.js.gz
    MSI (s) (C8:20) [10:46:51:809]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\125.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:809]: Executing op: ComponentRegister(ComponentId={8136B6D8-6C61-4D59-A36E-6DEBA2294AA8},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\138.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8136B6D8-6C61-4D59-A36E-6DEBA2294AA8} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\138.js
    MSI (s) (C8:20) [10:46:51:810]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\138.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:811]: Executing op: ComponentRegister(ComponentId={FBEDF49A-0C83-40F7-85C8-C46FF37C0E23},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\127.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {FBEDF49A-0C83-40F7-85C8-C46FF37C0E23} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\127.js
    MSI (s) (C8:20) [10:46:51:812]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\127.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:812]: Executing op: ComponentRegister(ComponentId={14391CED-C057-4F02-957C-9AC676DAD6CD},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\96.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {14391CED-C057-4F02-957C-9AC676DAD6CD} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\96.js
    MSI (s) (C8:20) [10:46:51:814]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\96.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:814]: Executing op: ComponentRegister(ComponentId={C12B47C4-E8A2-4DD6-9B8F-503DEBD9901D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\127.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {C12B47C4-E8A2-4DD6-9B8F-503DEBD9901D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\127.js.gz
    MSI (s) (C8:20) [10:46:51:815]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\127.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:816]: Executing op: ComponentRegister(ComponentId={2319B716-27AB-4D85-B993-58713ECA8BAE},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\82.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2319B716-27AB-4D85-B993-58713ECA8BAE} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\82.js.gz
    MSI (s) (C8:20) [10:46:51:817]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\82.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:817]: Executing op: ComponentRegister(ComponentId={653C807E-E260-4B68-8031-C8F7C86673C3},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\128.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {653C807E-E260-4B68-8031-C8F7C86673C3} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\128.js.gz
    MSI (s) (C8:20) [10:46:51:819]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\128.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:819]: Executing op: ComponentRegister(ComponentId={936E52A9-4CEA-49F9-9647-EC65B1CED0BB},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\129.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {936E52A9-4CEA-49F9-9647-EC65B1CED0BB} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\129.js
    MSI (s) (C8:20) [10:46:51:820]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\129.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:820]: Executing op: ComponentRegister(ComponentId={05D98443-6352-45D3-A49E-0E623A553314},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\13.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {05D98443-6352-45D3-A49E-0E623A553314} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\13.js
    MSI (s) (C8:20) [10:46:51:822]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\13.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:822]: Executing op: ComponentRegister(ComponentId={D83B5E46-34F6-4439-8F5D-DE2C8726705E},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\130.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D83B5E46-34F6-4439-8F5D-DE2C8726705E} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\130.js.gz
    MSI (s) (C8:20) [10:46:51:824]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\130.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:824]: Executing op: ComponentRegister(ComponentId={45AEF58B-7BA1-4078-BC7C-8B5CBCB6DDB7},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\131.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {45AEF58B-7BA1-4078-BC7C-8B5CBCB6DDB7} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\131.js
    MSI (s) (C8:20) [10:46:51:825]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\131.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:825]: Executing op: ComponentRegister(ComponentId={EFB1A1CD-A412-4A1C-BBA4-E83FDC23E4EB},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\85.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {EFB1A1CD-A412-4A1C-BBA4-E83FDC23E4EB} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\85.js.gz
    MSI (s) (C8:20) [10:46:51:827]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\85.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:827]: Executing op: ComponentRegister(ComponentId={38940200-D919-4857-938C-B91AF63590AC},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\132.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {38940200-D919-4857-938C-B91AF63590AC} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\132.js
    MSI (s) (C8:20) [10:46:51:829]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\132.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:829]: Executing op: ComponentRegister(ComponentId={8B38660E-8FC4-4A27-BF3F-744DA18AB444},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\132.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8B38660E-8FC4-4A27-BF3F-744DA18AB444} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\132.js.gz
    MSI (s) (C8:20) [10:46:51:830]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\132.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:830]: Executing op: ComponentRegister(ComponentId={A7E53037-1DEB-4E87-B0C9-59772E8258C8},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\133.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A7E53037-1DEB-4E87-B0C9-59772E8258C8} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\133.js.gz
    MSI (s) (C8:20) [10:46:51:832]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\133.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:832]: Executing op: ComponentRegister(ComponentId={1E9FF258-A750-4026-9537-CAD9654D0F18},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\134.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {1E9FF258-A750-4026-9537-CAD9654D0F18} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\134.js
    MSI (s) (C8:20) [10:46:51:834]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\134.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:834]: Executing op: ComponentRegister(ComponentId={5BA7126C-F782-455B-BD33-B47610574386},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\78.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {5BA7126C-F782-455B-BD33-B47610574386} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\78.js.gz
    MSI (s) (C8:20) [10:46:51:835]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\78.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:836]: Executing op: ComponentRegister(ComponentId={B7C60A2C-9EF3-4C25-94F8-E1818EDAC2EA},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\135.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {B7C60A2C-9EF3-4C25-94F8-E1818EDAC2EA} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\135.js
    MSI (s) (C8:20) [10:46:51:837]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\135.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:837]: Executing op: ComponentRegister(ComponentId={69172882-FD62-4A8A-8B73-640DD5AD17E0},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\135.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {69172882-FD62-4A8A-8B73-640DD5AD17E0} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\135.js.gz
    MSI (s) (C8:20) [10:46:51:839]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\135.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:839]: Executing op: ComponentRegister(ComponentId={7450D889-954E-4B65-B73C-EBC4DFC874B2},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\72.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {7450D889-954E-4B65-B73C-EBC4DFC874B2} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\72.js.gz
    MSI (s) (C8:20) [10:46:51:840]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\72.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:841]: Executing op: ComponentRegister(ComponentId={5BC0D018-8F22-4C5E-BD1F-D9E55A9DA97A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\3.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {5BC0D018-8F22-4C5E-BD1F-D9E55A9DA97A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\3.js.gz
    MSI (s) (C8:20) [10:46:51:842]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\3.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:842]: Executing op: ComponentRegister(ComponentId={DFD06974-1DA9-44AE-9407-C0E990B052A7},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\136.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {DFD06974-1DA9-44AE-9407-C0E990B052A7} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\136.js.gz
    MSI (s) (C8:20) [10:46:51:844]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\136.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:844]: Executing op: ComponentRegister(ComponentId={2212CBE3-89B7-45C0-9AB8-A08F59F3B9E9},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\73.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2212CBE3-89B7-45C0-9AB8-A08F59F3B9E9} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\73.js
    MSI (s) (C8:20) [10:46:51:845]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\73.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:845]: Executing op: ComponentRegister(ComponentId={B65C9DC5-15ED-4BB0-A633-286378A726DA},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\137.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {B65C9DC5-15ED-4BB0-A633-286378A726DA} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\137.js.gz
    MSI (s) (C8:20) [10:46:51:847]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\137.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:847]: Executing op: ComponentRegister(ComponentId={95433358-567E-4E44-983A-D040CE5F3729},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\138.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {95433358-567E-4E44-983A-D040CE5F3729} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\138.js.gz
    MSI (s) (C8:20) [10:46:51:849]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\138.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:849]: Executing op: ComponentRegister(ComponentId={9001A068-2557-4A91-B7C4-972419B4E122},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\16.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {9001A068-2557-4A91-B7C4-972419B4E122} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\16.js
    MSI (s) (C8:20) [10:46:51:850]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\16.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:850]: Executing op: ComponentRegister(ComponentId={23CF4939-4F9B-4EE7-8D8C-319D0343546A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\17.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {23CF4939-4F9B-4EE7-8D8C-319D0343546A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\17.js
    MSI (s) (C8:20) [10:46:51:852]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\17.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:852]: Executing op: ComponentRegister(ComponentId={018B88D5-6D09-45B4-B330-0F8C47389789},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\18.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {018B88D5-6D09-45B4-B330-0F8C47389789} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\18.js
    MSI (s) (C8:20) [10:46:51:853]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\18.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:853]: Executing op: ComponentRegister(ComponentId={BE42E4E2-D217-42A7-8FCE-C85D3B9363C1},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\2.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {BE42E4E2-D217-42A7-8FCE-C85D3B9363C1} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\2.js
    MSI (s) (C8:20) [10:46:51:855]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\2.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:855]: Executing op: ComponentRegister(ComponentId={AF66D3E3-5673-43A1-9BFB-A8A27776EA52},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\2.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {AF66D3E3-5673-43A1-9BFB-A8A27776EA52} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\2.js.gz
    MSI (s) (C8:20) [10:46:51:856]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\2.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:856]: Executing op: ComponentRegister(ComponentId={A555A2B8-6A3B-4C08-A330-9C631D85AF13},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\21.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A555A2B8-6A3B-4C08-A330-9C631D85AF13} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\21.js
    MSI (s) (C8:20) [10:46:51:858]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\21.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:858]: Executing op: ComponentRegister(ComponentId={A31C87B4-00F4-4712-A2B7-4CB3575CBDF4},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\23.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A31C87B4-00F4-4712-A2B7-4CB3575CBDF4} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\23.js
    MSI (s) (C8:20) [10:46:51:859]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\23.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:860]: Executing op: ComponentRegister(ComponentId={4EDCF980-B18A-48DA-AFDB-B1DBFDE760F3},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\24.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {4EDCF980-B18A-48DA-AFDB-B1DBFDE760F3} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\24.js
    MSI (s) (C8:20) [10:46:51:861]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\24.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:861]: Executing op: ComponentRegister(ComponentId={CD71EBCD-8A0C-48FA-A356-C06FC66AED08},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\25.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {CD71EBCD-8A0C-48FA-A356-C06FC66AED08} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\25.js
    MSI (s) (C8:20) [10:46:51:863]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\25.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:863]: Executing op: ComponentRegister(ComponentId={081FB790-EFEE-4591-9D73-E88F41E718C6},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\26.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {081FB790-EFEE-4591-9D73-E88F41E718C6} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\26.js
    MSI (s) (C8:20) [10:46:51:864]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\26.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:864]: Executing op: ComponentRegister(ComponentId={5FB34078-1539-4C87-AF61-A45AB5F3B70C},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\27.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {5FB34078-1539-4C87-AF61-A45AB5F3B70C} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\27.js
    MSI (s) (C8:20) [10:46:51:866]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\27.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:866]: Executing op: ComponentRegister(ComponentId={5E9CB3A9-B42D-43C7-B93A-DDCA3F421E54},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\28.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {5E9CB3A9-B42D-43C7-B93A-DDCA3F421E54} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\28.js
    MSI (s) (C8:20) [10:46:51:867]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\28.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:868]: Executing op: ComponentRegister(ComponentId={9116EFAC-A60A-4FC0-BAC0-11A3426CE748},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\83.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {9116EFAC-A60A-4FC0-BAC0-11A3426CE748} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\83.js
    MSI (s) (C8:20) [10:46:51:869]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\83.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:869]: Executing op: ComponentRegister(ComponentId={16EC5310-F5F7-45A9-8411-8C8D6841D69C},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\3.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {16EC5310-F5F7-45A9-8411-8C8D6841D69C} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\3.js
    MSI (s) (C8:20) [10:46:51:871]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\3.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:871]: Executing op: ComponentRegister(ComponentId={77B61787-B6C0-4DE0-BFEE-7000BC3E8FB4},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\30.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {77B61787-B6C0-4DE0-BFEE-7000BC3E8FB4} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\30.js
    MSI (s) (C8:20) [10:46:51:872]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\30.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:872]: Executing op: ComponentRegister(ComponentId={8F245CC3-359A-4AEE-A7D2-2F19DF0AF726},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\32.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8F245CC3-359A-4AEE-A7D2-2F19DF0AF726} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\32.js
    MSI (s) (C8:20) [10:46:51:874]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\32.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:874]: Executing op: ComponentRegister(ComponentId={12B54696-C689-463F-8677-ACD641553E5E},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\33.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {12B54696-C689-463F-8677-ACD641553E5E} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\33.js
    MSI (s) (C8:20) [10:46:51:875]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\33.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:875]: Executing op: ComponentRegister(ComponentId={EA74892D-77A1-427F-83A3-F5FE31B08849},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\34.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {EA74892D-77A1-427F-83A3-F5FE31B08849} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\34.js
    MSI (s) (C8:20) [10:46:51:877]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\34.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:877]: Executing op: ComponentRegister(ComponentId={52FBEFF6-3F58-4460-AFBC-9EF97B0BA414},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\36.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {52FBEFF6-3F58-4460-AFBC-9EF97B0BA414} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\36.js
    MSI (s) (C8:20) [10:46:51:878]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\36.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:879]: Executing op: ComponentRegister(ComponentId={2F056D90-CD5F-4717-81BD-BBAD8EBE35D2},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\37.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2F056D90-CD5F-4717-81BD-BBAD8EBE35D2} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\37.js
    MSI (s) (C8:20) [10:46:51:880]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\37.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:880]: Executing op: ComponentRegister(ComponentId={266CB0B5-08AE-43F7-9DE0-F0BA6B75F63D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\38.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {266CB0B5-08AE-43F7-9DE0-F0BA6B75F63D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\38.js
    MSI (s) (C8:20) [10:46:51:882]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\38.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:882]: Executing op: ComponentRegister(ComponentId={13752981-087E-4A27-AB90-D8808ADCEE4F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\4.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {13752981-087E-4A27-AB90-D8808ADCEE4F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\4.js
    MSI (s) (C8:20) [10:46:51:883]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\4.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:884]: Executing op: ComponentRegister(ComponentId={799D2D9C-4EED-45BF-948E-422056251EFB},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\4.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {799D2D9C-4EED-45BF-948E-422056251EFB} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\4.js.gz
    MSI (s) (C8:20) [10:46:51:885]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\4.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:885]: Executing op: ComponentRegister(ComponentId={0631A41D-3106-4BEC-8D41-40C7FF6F67C3},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\42.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0631A41D-3106-4BEC-8D41-40C7FF6F67C3} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\42.js
    MSI (s) (C8:20) [10:46:51:887]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\42.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:887]: Executing op: ComponentRegister(ComponentId={633BB8E5-B626-44C7-9B2F-1C0BB94C91F7},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\46.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {633BB8E5-B626-44C7-9B2F-1C0BB94C91F7} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\46.js
    MSI (s) (C8:20) [10:46:51:888]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\46.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:889]: Executing op: ComponentRegister(ComponentId={DDDE011A-4BDB-4B3D-81DA-EFDAF8C14A2A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\47.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {DDDE011A-4BDB-4B3D-81DA-EFDAF8C14A2A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\47.js
    MSI (s) (C8:20) [10:46:51:890]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\47.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:890]: Executing op: ComponentRegister(ComponentId={91DB12CA-2A53-4E61-AD82-BFBAA8EF8AEF},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\78.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {91DB12CA-2A53-4E61-AD82-BFBAA8EF8AEF} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\78.js
    MSI (s) (C8:20) [10:46:51:892]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\78.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:892]: Executing op: ComponentRegister(ComponentId={C412FDC0-7984-4BA4-8A0E-6FD0F9D1EEE9},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\48.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {C412FDC0-7984-4BA4-8A0E-6FD0F9D1EEE9} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\48.js
    MSI (s) (C8:20) [10:46:51:893]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\48.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:894]: Executing op: ComponentRegister(ComponentId={0E5E28B6-E528-40BA-9209-25D621685601},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\5.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0E5E28B6-E528-40BA-9209-25D621685601} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\5.js
    MSI (s) (C8:20) [10:46:51:895]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\5.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:895]: Executing op: ComponentRegister(ComponentId={8BEE4090-6273-4B09-8DE2-7EE345EFAD70},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\5.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8BEE4090-6273-4B09-8DE2-7EE345EFAD70} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\5.js.gz
    MSI (s) (C8:20) [10:46:51:897]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\5.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:897]: Executing op: ComponentRegister(ComponentId={254BB10C-45F3-4E4C-9052-70025F21B252},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\85.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {254BB10C-45F3-4E4C-9052-70025F21B252} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\85.js
    MSI (s) (C8:20) [10:46:51:898]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\85.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:899]: Executing op: ComponentRegister(ComponentId={406242BB-1716-492C-8722-67ACBD1A90F1},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\50.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {406242BB-1716-492C-8722-67ACBD1A90F1} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\50.js
    MSI (s) (C8:20) [10:46:51:900]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\50.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:900]: Executing op: ComponentRegister(ComponentId={9B45D48A-EA19-4145-8C05-8A8CE010639D},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\51.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {9B45D48A-EA19-4145-8C05-8A8CE010639D} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\51.js
    MSI (s) (C8:20) [10:46:51:902]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\51.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:902]: Executing op: ComponentRegister(ComponentId={764F64CF-0E51-4654-82B5-500E01DAA2B4},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\53.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {764F64CF-0E51-4654-82B5-500E01DAA2B4} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\53.js
    MSI (s) (C8:20) [10:46:51:904]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\53.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:904]: Executing op: ComponentRegister(ComponentId={375AB294-6565-4741-8F58-7D06A6A0D179},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\67.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {375AB294-6565-4741-8F58-7D06A6A0D179} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\67.js
    MSI (s) (C8:20) [10:46:51:905]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\67.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:905]: Executing op: ComponentRegister(ComponentId={F1823343-CE58-450F-A0AC-C525BB529F2F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\54.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F1823343-CE58-450F-A0AC-C525BB529F2F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\54.js.gz
    MSI (s) (C8:20) [10:46:51:907]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\54.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:907]: Executing op: ComponentRegister(ComponentId={A8C9C0BF-F93D-468D-B779-E169C8ABD8A9},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\55.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A8C9C0BF-F93D-468D-B779-E169C8ABD8A9} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\55.js
    MSI (s) (C8:20) [10:46:51:909]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\55.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:909]: Executing op: ComponentRegister(ComponentId={BAB4B8FB-5D3B-4072-A285-272D36DFA84B},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\56.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {BAB4B8FB-5D3B-4072-A285-272D36DFA84B} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\56.js
    MSI (s) (C8:20) [10:46:51:910]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\56.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:911]: Executing op: ComponentRegister(ComponentId={E4C2D004-307F-4A53-A5E9-5195D7F2C342},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\56.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {E4C2D004-307F-4A53-A5E9-5195D7F2C342} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\56.js.gz
    MSI (s) (C8:20) [10:46:51:912]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\56.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:912]: Executing op: ComponentRegister(ComponentId={24E63589-8585-4262-9385-ABC9F6D43E6F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\57.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {24E63589-8585-4262-9385-ABC9F6D43E6F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\57.js
    MSI (s) (C8:20) [10:46:51:914]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\57.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:914]: Executing op: ComponentRegister(ComponentId={BC7C3CE1-B7AB-4121-AE6D-57742D227961},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\58.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {BC7C3CE1-B7AB-4121-AE6D-57742D227961} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\58.js
    MSI (s) (C8:20) [10:46:51:916]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\58.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:916]: Executing op: ComponentRegister(ComponentId={6C0670FC-161E-4C5A-842D-7B64460FAF06},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\59.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {6C0670FC-161E-4C5A-842D-7B64460FAF06} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\59.js
    MSI (s) (C8:20) [10:46:51:917]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\59.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:918]: Executing op: ComponentRegister(ComponentId={93711E0B-3CB5-4019-8A6F-F59D16B77046},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\59.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {93711E0B-3CB5-4019-8A6F-F59D16B77046} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\59.js.gz
    MSI (s) (C8:20) [10:46:51:919]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\59.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:919]: Executing op: ComponentRegister(ComponentId={81051871-B414-49D4-A74D-1D8457FF6620},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\6.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {81051871-B414-49D4-A74D-1D8457FF6620} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\6.js
    MSI (s) (C8:20) [10:46:51:921]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\6.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:921]: Executing op: ComponentRegister(ComponentId={8233A0A9-66C6-438A-BA4D-0CF39FB1B8DB},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\60.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8233A0A9-66C6-438A-BA4D-0CF39FB1B8DB} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\60.js
    MSI (s) (C8:20) [10:46:51:922]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\60.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:922]: Executing op: ComponentRegister(ComponentId={C30162D7-D8CE-4764-9F59-4867AAABDFD8},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\61.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {C30162D7-D8CE-4764-9F59-4867AAABDFD8} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\61.js
    MSI (s) (C8:20) [10:46:51:924]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\61.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:924]: Executing op: ComponentRegister(ComponentId={79068E6B-2CF0-4CFB-94FC-E8F240C686DC},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\61.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {79068E6B-2CF0-4CFB-94FC-E8F240C686DC} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\61.js.gz
    MSI (s) (C8:20) [10:46:51:925]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\61.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:925]: Executing op: ComponentRegister(ComponentId={63AA39E2-2C06-458E-97F6-4C45FE816B57},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\62.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {63AA39E2-2C06-458E-97F6-4C45FE816B57} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\62.js
    MSI (s) (C8:20) [10:46:51:927]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\62.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:927]: Executing op: ComponentRegister(ComponentId={7C8FB99F-AEF9-4627-BCBA-6384CA5E7644},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\63.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {7C8FB99F-AEF9-4627-BCBA-6384CA5E7644} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\63.js
    MSI (s) (C8:20) [10:46:51:929]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\63.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:929]: Executing op: ComponentRegister(ComponentId={BEE9572D-68BB-45CF-B0ED-4F9D213BC362},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\63.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {BEE9572D-68BB-45CF-B0ED-4F9D213BC362} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\63.js.gz
    MSI (s) (C8:20) [10:46:51:930]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\63.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:930]: Executing op: ComponentRegister(ComponentId={499FD15F-9C17-4043-B9E1-586FC1BDAB61},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\64.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {499FD15F-9C17-4043-B9E1-586FC1BDAB61} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\64.js
    MSI (s) (C8:20) [10:46:51:932]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\64.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:932]: Executing op: ComponentRegister(ComponentId={11CC4333-A6A9-4873-842E-EDA049FF1137},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\64.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {11CC4333-A6A9-4873-842E-EDA049FF1137} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\64.js.gz
    MSI (s) (C8:20) [10:46:51:934]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\64.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:934]: Executing op: ComponentRegister(ComponentId={C3B429CB-BEB1-485D-AB10-04AFD2D99422},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\65.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {C3B429CB-BEB1-485D-AB10-04AFD2D99422} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\65.js
    MSI (s) (C8:20) [10:46:51:935]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\65.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:935]: Executing op: ComponentRegister(ComponentId={1EC74E47-8CD8-4522-8A55-1AA146F85CD7},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\65.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {1EC74E47-8CD8-4522-8A55-1AA146F85CD7} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\65.js.gz
    MSI (s) (C8:20) [10:46:51:937]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\65.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:937]: Executing op: ComponentRegister(ComponentId={20B5CF9E-8BF2-49D9-9E68-4E23211BDDE3},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\66.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {20B5CF9E-8BF2-49D9-9E68-4E23211BDDE3} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\66.js.gz
    MSI (s) (C8:20) [10:46:51:938]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\66.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:939]: Executing op: ComponentRegister(ComponentId={0AC9FB5A-B7D3-44C7-8756-1FD9AA12E206},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\68.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {0AC9FB5A-B7D3-44C7-8756-1FD9AA12E206} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\68.js
    MSI (s) (C8:20) [10:46:51:940]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\68.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:940]: Executing op: ComponentRegister(ComponentId={64D7C52E-7E37-40D1-A2D4-2BEE38104D7C},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\68.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {64D7C52E-7E37-40D1-A2D4-2BEE38104D7C} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\68.js.gz
    MSI (s) (C8:20) [10:46:51:941]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\68.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:942]: Executing op: ComponentRegister(ComponentId={79F7E5B2-7C55-42CD-85F9-2B378E784506},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\69.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {79F7E5B2-7C55-42CD-85F9-2B378E784506} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\69.js
    MSI (s) (C8:20) [10:46:51:943]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\69.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:943]: Executing op: ComponentRegister(ComponentId={F84076F7-CC47-47E4-A01D-7F04BF182C8A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\7.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F84076F7-CC47-47E4-A01D-7F04BF182C8A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\7.js
    MSI (s) (C8:20) [10:46:51:945]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\7.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:945]: Executing op: ComponentRegister(ComponentId={F964C53D-4174-44A8-A1EC-B1BA3C3043E6},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\7.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {F964C53D-4174-44A8-A1EC-B1BA3C3043E6} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\7.js.gz
    MSI (s) (C8:20) [10:46:51:946]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\7.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:946]: Executing op: ComponentRegister(ComponentId={4E026965-D599-4D72-9DA0-C489CDD919C0},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\70.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {4E026965-D599-4D72-9DA0-C489CDD919C0} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\70.js
    MSI (s) (C8:20) [10:46:51:948]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\70.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:948]: Executing op: ComponentRegister(ComponentId={A5BA6983-5EF0-4CA6-A584-EDED2B98808A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\71.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A5BA6983-5EF0-4CA6-A584-EDED2B98808A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\71.js
    MSI (s) (C8:20) [10:46:51:949]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\71.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:949]: Executing op: ComponentRegister(ComponentId={051688A0-931A-431D-8123-924DF19B68B2},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\71.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {051688A0-931A-431D-8123-924DF19B68B2} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\71.js.gz
    MSI (s) (C8:20) [10:46:51:951]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\71.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:951]: Executing op: ComponentRegister(ComponentId={144DAC7C-DA14-48EA-9CDE-B273B9DD6F63},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\72.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {144DAC7C-DA14-48EA-9CDE-B273B9DD6F63} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\72.js
    MSI (s) (C8:20) [10:46:51:952]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\72.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:953]: Executing op: ComponentRegister(ComponentId={21F8A718-5102-4096-8D80-1681AEA6AAD6},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\74.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {21F8A718-5102-4096-8D80-1681AEA6AAD6} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\74.js.gz
    MSI (s) (C8:20) [10:46:51:954]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\74.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:954]: Executing op: ComponentRegister(ComponentId={7F10F73F-4335-482A-AECA-D40E86E82DE7},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\75.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {7F10F73F-4335-482A-AECA-D40E86E82DE7} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\75.js.gz
    MSI (s) (C8:20) [10:46:51:956]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\75.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:956]: Executing op: ComponentRegister(ComponentId={D984F04C-7EB6-4EB8-95AF-510B61E7C629},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\76.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D984F04C-7EB6-4EB8-95AF-510B61E7C629} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\76.js
    MSI (s) (C8:20) [10:46:51:957]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\76.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:957]: Executing op: ComponentRegister(ComponentId={91630773-F890-4291-A91F-38A04388A5F7},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\77.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {91630773-F890-4291-A91F-38A04388A5F7} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\77.js.gz
    MSI (s) (C8:20) [10:46:51:959]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\77.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:959]: Executing op: ComponentRegister(ComponentId={45A2AC47-6F63-4248-97BD-2AB93D3ABBAE},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\98.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {45A2AC47-6F63-4248-97BD-2AB93D3ABBAE} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\98.js.gz
    MSI (s) (C8:20) [10:46:51:960]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\98.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:960]: Executing op: ComponentRegister(ComponentId={220EF083-A50C-41FC-93A2-179567DFF5FC},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\79.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {220EF083-A50C-41FC-93A2-179567DFF5FC} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\79.js
    MSI (s) (C8:20) [10:46:51:962]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\79.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:962]: Executing op: ComponentRegister(ComponentId={6A5FEBC4-35F7-43F6-85A9-E9A54A1163D8},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\8.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {6A5FEBC4-35F7-43F6-85A9-E9A54A1163D8} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\8.js
    MSI (s) (C8:20) [10:46:51:963]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\8.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:963]: Executing op: ComponentRegister(ComponentId={8EB35842-5D14-4CA5-A849-7155CDC6635F},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\87.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8EB35842-5D14-4CA5-A849-7155CDC6635F} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\87.js
    MSI (s) (C8:20) [10:46:51:965]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\87.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:965]: Executing op: ComponentRegister(ComponentId={5750A86F-07A9-4883-BBD4-6C83133D36E5},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\80.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {5750A86F-07A9-4883-BBD4-6C83133D36E5} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\80.js.gz
    MSI (s) (C8:20) [10:46:51:966]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\80.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:966]: Executing op: ComponentRegister(ComponentId={8F75BFB3-35C2-4F9F-A94D-44A03E5CFA34},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\81.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {8F75BFB3-35C2-4F9F-A94D-44A03E5CFA34} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\81.js.gz
    MSI (s) (C8:20) [10:46:51:968]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\81.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:968]: Executing op: ComponentRegister(ComponentId={D228B9CB-F7BD-437B-AE72-8332C8033D48},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\92.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {D228B9CB-F7BD-437B-AE72-8332C8033D48} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\92.js
    MSI (s) (C8:20) [10:46:51:969]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\92.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:970]: Executing op: ComponentRegister(ComponentId={CDEEAB11-DF5C-4D7C-ACC4-3E9326121001},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\99.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {CDEEAB11-DF5C-4D7C-ACC4-3E9326121001} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\99.js.gz
    MSI (s) (C8:20) [10:46:51:971]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\99.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:971]: Executing op: ComponentRegister(ComponentId={71FB5297-CC16-4CFC-A20A-D755E778BE71},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\84.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {71FB5297-CC16-4CFC-A20A-D755E778BE71} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\84.js
    MSI (s) (C8:20) [10:46:51:973]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\84.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:973]: Executing op: ComponentRegister(ComponentId={5025C89E-376F-4E9A-924B-6D5F5A721426},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\84.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {5025C89E-376F-4E9A-924B-6D5F5A721426} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\84.js.gz
    MSI (s) (C8:20) [10:46:51:975]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\84.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:975]: Executing op: ComponentRegister(ComponentId={3F3FFD3D-D5CF-41A9-A250-1FF5BE395277},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\86.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {3F3FFD3D-D5CF-41A9-A250-1FF5BE395277} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\86.js
    MSI (s) (C8:20) [10:46:51:976]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\86.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:977]: Executing op: ComponentRegister(ComponentId={52EF4959-8CA6-49D3-8F90-E4193A427CF9},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\87.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {52EF4959-8CA6-49D3-8F90-E4193A427CF9} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\87.js.gz
    MSI (s) (C8:20) [10:46:51:978]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\87.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:978]: Executing op: ComponentRegister(ComponentId={A619D5DF-86B6-4658-B17D-D4F347D244EF},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\88.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {A619D5DF-86B6-4658-B17D-D4F347D244EF} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\88.js
    MSI (s) (C8:20) [10:46:51:980]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\88.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:980]: Executing op: ComponentRegister(ComponentId={30FDBB42-A521-411C-9BB3-9C54482A047C},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\88.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {30FDBB42-A521-411C-9BB3-9C54482A047C} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\88.js.gz
    MSI (s) (C8:20) [10:46:51:982]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\88.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:982]: Executing op: ComponentRegister(ComponentId={75117040-26F6-4ABF-ADD4-ECC227B5B862},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\89.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {75117040-26F6-4ABF-ADD4-ECC227B5B862} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\89.js.gz
    MSI (s) (C8:20) [10:46:51:983]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\89.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:984]: Executing op: ComponentRegister(ComponentId={2A9D7EFC-86C4-49CB-AE6B-D11F42EB42E7},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\9.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2A9D7EFC-86C4-49CB-AE6B-D11F42EB42E7} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\9.js
    MSI (s) (C8:20) [10:46:51:985]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\9.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:985]: Executing op: ComponentRegister(ComponentId={B89E3541-151E-4E35-AD42-CBCBEFECF779},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\90.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {B89E3541-151E-4E35-AD42-CBCBEFECF779} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\90.js
    MSI (s) (C8:20) [10:46:51:987]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\90.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:987]: Executing op: ComponentRegister(ComponentId={60A15659-6CA0-4A6A-A281-63DBBB1B812B},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\91.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {60A15659-6CA0-4A6A-A281-63DBBB1B812B} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\91.js
    MSI (s) (C8:20) [10:46:51:988]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\91.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:989]: Executing op: ComponentRegister(ComponentId={2E5E7B2B-BD6C-45A7-98B4-4C2DED7D2329},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\91.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {2E5E7B2B-BD6C-45A7-98B4-4C2DED7D2329} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\91.js.gz
    MSI (s) (C8:20) [10:46:51:990]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\91.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:990]: Executing op: ComponentRegister(ComponentId={913809D5-EE7B-47EE-BDA9-36F835577424},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\92.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {913809D5-EE7B-47EE-BDA9-36F835577424} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\92.js.gz
    MSI (s) (C8:20) [10:46:51:992]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\92.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:992]: Executing op: ComponentRegister(ComponentId={91F12172-6A56-4F87-8903-9A09BED80B76},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\93.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {91F12172-6A56-4F87-8903-9A09BED80B76} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\93.js.gz
    MSI (s) (C8:20) [10:46:51:994]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\93.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:994]: Executing op: ComponentRegister(ComponentId={058477A1-DD21-48BD-9673-59A1A9979BB9},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\94.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {058477A1-DD21-48BD-9673-59A1A9979BB9} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\94.js
    MSI (s) (C8:20) [10:46:51:995]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\94.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:995]: Executing op: ComponentRegister(ComponentId={66D5BB11-2A1D-4001-8A71-41172C861E9A},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\94.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {66D5BB11-2A1D-4001-8A71-41172C861E9A} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\94.js.gz
    MSI (s) (C8:20) [10:46:51:997]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\94.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:997]: Executing op: ComponentRegister(ComponentId={BF07C412-8C95-4F11-B8AA-FEC95A38A970},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\97.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {BF07C412-8C95-4F11-B8AA-FEC95A38A970} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\97.js
    MSI (s) (C8:20) [10:46:51:998]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\97.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:51:999]: Executing op: ComponentRegister(ComponentId={BDA382B3-0513-46B0-9850-96E535057739},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\97.js.gz,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {BDA382B3-0513-46B0-9850-96E535057739} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\97.js.gz
    MSI (s) (C8:20) [10:46:52:000]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\97.js.gz' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:52:000]: Executing op: ComponentRegister(ComponentId={48869CD5-7A42-4C0A-888C-DE11DEC99F6E},KeyPath=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\98.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B} 2: {48869CD5-7A42-4C0A-888C-DE11DEC99F6E} 3: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\98.js
    MSI (s) (C8:20) [10:46:52:002]: WIN64DUALFOLDERS: Substitution in 'C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\98.js' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
    MSI (s) (C8:20) [10:46:52:002]: Executing op: ActionStart(Name=CreateFolders,Description=Creating folders,Template=Folder: [1])
    Action 10:46:52: CreateFolders. Creating folders
    MSI (s) (C8:20) [10:46:52:013]: Executing op: FolderCreate(Folder=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\,Foreign=0,,)
    CreateFolders: Folder: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\
    MSI (s) (C8:20) [10:46:52:015]: Executing op: FolderCreate(Folder=C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\LTspice\,Foreign=0,,)
    CreateFolders: Folder: C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\LTspice\
    MSI (s) (C8:20) [10:46:52:017]: Executing op: ActionStart(Name=InstallFiles,Description=Copying new files,Template=File: [1],  Directory: [9],  Size: [6])
    Action 10:46:52: InstallFiles. Copying new files
    MSI (s) (C8:20) [10:46:52:018]: Executing op: ProgressTotal(Total=193319552,Type=0,ByteEquivalent=1)
    MSI (s) (C8:20) [10:46:52:019]: Executing op: SetTargetFolder(Folder=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\)
    MSI (s) (C8:20) [10:46:52:019]: Executing op: SetSourceFolder(Folder=1\)
    MSI (s) (C8:20) [10:46:52:019]: Executing op: ChangeMedia(,MediaPrompt=Please insert the disk: ,MediaCabinet=disk1.cab,BytesPerTick=65536,CopierType=2,ModuleFileName=C:\windows\Installer\77b2d2.msi,,,,,IsFirstPhysicalMedia=1)
    MSI (s) (C8:20) [10:46:52:019]: Executing op: FileCopy(SourceName=License.txt,SourceCabKey=License.txt,DestName=License.txt,Attributes=0,FileSize=35447,PerTick=65536,,VerifyMedia=1,,,,,CheckCRC=0,Version=65535.65535.65535.65535,Language=0,InstallMode=58982400,,,,,,,)
    MSI (s) (C8:20) [10:46:52:020]: File: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\License.txt;	To be installed;	Won't patch;	No existing file
    MSI (s) (C8:20) [10:46:52:020]: Source for file 'License.txt' is compressed
    InstallFiles: File: License.txt,  Directory: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\,  Size: 35447
    MSI (s) (C8:20) [10:46:52:028]: Executing op: FileCopy(SourceName=LTspice.exe,SourceCabKey=LTspice.exe,DestName=LTspice.exe,Attributes=0,FileSize=68247664,PerTick=65536,,VerifyMedia=1,,,,,CheckCRC=0,Version=65535.65535.65535.65535,Language=1033,InstallMode=58982400,,,,,,,)
    MSI (s) (C8:20) [10:46:52:029]: File: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspice.exe;	To be installed;	Won't patch;	No existing file
    MSI (s) (C8:20) [10:46:52:029]: Source for file 'LTspice.exe' is compressed
    InstallFiles: File: LTspice.exe,  Directory: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\,  Size: 68247664
    MSI (s) (C8:20) [10:46:52:410]: Executing op: FileCopy(SourceName=updater.exe,SourceCabKey=updater.exe,DestName=updater.exe,Attributes=0,FileSize=1963008,PerTick=65536,,VerifyMedia=1,,,,,CheckCRC=0,Version=65535.65535.65535.65535,Language=1033,InstallMode=58982400,,,,,,,)
    MSI (s) (C8:20) [10:46:52:410]: File: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\updater.exe;	To be installed;	Won't patch;	No existing file
    MSI (s) (C8:20) [10:46:52:410]: Source for file 'updater.exe' is compressed
    InstallFiles: File: updater.exe,  Directory: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\,  Size: 1963008
    MSI (s) (C8:20) [10:46:52:424]: Executing op: FileCopy(SourceName=examples.zip,SourceCabKey=examples.zip_1,DestName=examples.zip,Attributes=0,FileSize=3744217,PerTick=65536,,VerifyMedia=1,,,,,CheckCRC=0,Version=65535.65535.65535.65535,Language=0,InstallMode=58982400,,,,,,,)
    MSI (s) (C8:20) [10:46:52:425]: File: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\examples.zip;	To be installed;	Won't patch;	No existing file
    MSI (s) (C8:20) [10:46:52:425]: Source for file 'examples.zip_1' is compressed
    InstallFiles: File: examples.zip,  Directory: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\,  Size: 3744217
    MSI (s) (C8:20) [10:46:52:446]: Executing op: FileCopy(SourceName=lib.zip,SourceCabKey=lib.zip_1,DestName=lib.zip,Attributes=0,FileSize=38947602,PerTick=65536,,VerifyMedia=1,,,,,CheckCRC=0,Version=65535.65535.65535.65535,Language=0,InstallMode=58982400,,,,,,,)
    MSI (s) (C8:20) [10:46:52:446]: File: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\lib.zip;	To be installed;	Won't patch;	No existing file
    MSI (s) (C8:20) [10:46:52:446]: Source for file 'lib.zip_1' is compressed
    InstallFiles: File: lib.zip,  Directory: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\,  Size: 38947602
    MSI (s) (C8:20) [10:46:52:590]: Executing op: FileCopy(SourceName=License.pdf,SourceCabKey=License.pdf,DestName=License.pdf,Attributes=0,FileSize=100985,PerTick=65536,,VerifyMedia=1,,,,,CheckCRC=0,Version=65535.65535.65535.65535,Language=0,InstallMode=58982400,,,,,,,)
    MSI (s) (C8:20) [10:46:52:590]: File: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\License.pdf;	To be installed;	Won't patch;	No existing file
    MSI (s) (C8:20) [10:46:52:590]: Source for file 'License.pdf' is compressed
    InstallFiles: File: License.pdf,  Directory: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\,  Size: 100985
    MSI (s) (C8:20) [10:46:52:593]: Executing op: FileCopy(SourceName=LTSPIC~1.JSO|LTspice.json,SourceCabKey=LTspice.json,DestName=LTspice.json,Attributes=0,FileSize=664,PerTick=65536,,VerifyMedia=1,,,,,CheckCRC=0,Version=65535.65535.65535.65535,Language=0,InstallMode=58982400,,,,,,,)
    MSI (s) (C8:20) [10:46:52:593]: File: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspice.json;	To be installed;	Won't patch;	No existing file
    MSI (s) (C8:20) [10:46:52:593]: Source for file 'LTspice.json' is compressed
    InstallFiles: File: LTspice.json,  Directory: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\,  Size: 664
    MSI (s) (C8:20) [10:46:52:596]: Executing op: FileCopy(SourceName=LTSPIC~1.TXT|LTspiceChangeLog.txt,SourceCabKey=LTspiceChangeLog.txt,DestName=LTspiceChangeLog.txt,Attributes=0,FileSize=11304,PerTick=65536,,VerifyMedia=1,,,,,CheckCRC=0,Version=65535.65535.65535.65535,Language=0,InstallMode=58982400,,,,,,,)
    MSI (s) (C8:20) [10:46:52:597]: File: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceChangeLog.txt;	To be installed;	Won't patch;	No existing file
    MSI (s) (C8:20) [10:46:52:597]: Source for file 'LTspiceChangeLog.txt' is compressed
    InstallFiles: File: LTspiceChangeLog.txt,  Directory: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\,  Size: 11304
    MSI (s) (C8:20) [10:46:52:599]: Executing op: SetTargetFolder(Folder=C:\Users\mtarr\AppData\Local\LTspice\)
    MSI (s) (C8:20) [10:46:52:599]: Executing op: SetSourceFolder(Folder=1\LOCALA~1\LTspice\|LocalAppDataFolder\LTspice\)
    MSI (s) (C8:20) [10:46:52:599]: Executing op: FileCopy(SourceName=Remove.txt,SourceCabKey=Remove.txt,DestName=Remove.txt,Attributes=0,FileSize=115787,PerTick=65536,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,)
    MSI (s) (C8:20) [10:46:52:600]: File: C:\Users\mtarr\AppData\Local\LTspice\Remove.txt;	Won't Overwrite;	Won't patch;	Existing file is unversioned but modified
    MSI (s) (C8:20) [10:46:52:600]: Executing op: FileCopy(SourceName=CHANGE~1.TXT|ChangeLog.txt,SourceCabKey=ChangeLog.txt,DestName=ChangeLog.txt,Attributes=0,FileSize=221436,PerTick=65536,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,)
    MSI (s) (C8:20) [10:46:52:600]: File: C:\Users\mtarr\AppData\Local\LTspice\ChangeLog.txt;	Won't Overwrite;	Won't patch;	Existing file is unversioned but modified
    MSI (s) (C8:20) [10:46:52:600]: Executing op: FileCopy(SourceName=Remove.exe,SourceCabKey=Remove.exe,DestName=Remove.exe,Attributes=0,FileSize=246784,PerTick=65536,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,)
    MSI (s) (C8:20) [10:46:52:601]: File: C:\Users\mtarr\AppData\Local\LTspice\Remove.exe;	Overwrite;	Won't patch;	Existing file is unversioned and unmodified - no source file hash provided to compare
    MSI (s) (C8:20) [10:46:52:601]: Source for file 'Remove.exe' is compressed
    InstallFiles: File: Remove.exe,  Directory: C:\Users\mtarr\AppData\Local\LTspice\,  Size: 246784
    MSI (s) (C8:20) [10:46:52:603]: Re-applying security from existing file.
    MSI (s) (C8:20) [10:46:52:605]: Verifying accessibility of file: Remove.exe
    MSI (s) (C8:20) [10:46:52:605]: Using source file security for destination.
    MSI (s) (C8:20) [10:46:52:605]: Note: 1: 2318 2: C:\Config.Msi\77b2d4.rbf
    MSI (s) (C8:20) [10:46:52:607]: Note: 1: 1310 2: 0 3: C:\Users\mtarr\AppData\Local\LTspice\Remove.exe
    Info 1310. Error writing to file: C:\Users\mtarr\AppData\Local\LTspice\Remove.exe.  System error 0.  Verify that you have access to that directory.
    MSI (s) (C8:20) [10:46:52:608]: Executing op: FileCopy(SourceName=examples.zip,SourceCabKey=examples.zip,DestName=examples.zip,Attributes=0,FileSize=3744217,PerTick=65536,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,)
    MSI (s) (C8:20) [10:46:52:609]: File: C:\Users\mtarr\AppData\Local\LTspice\examples.zip;	Won't Overwrite;	Won't patch;	Existing file is unversioned but modified
    MSI (s) (C8:20) [10:46:52:609]: Executing op: FileCopy(SourceName=lib.zip,SourceCabKey=lib.zip,DestName=lib.zip,Attributes=0,FileSize=38947602,PerTick=65536,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,,,,,,,)
    MSI (s) (C8:20) [10:46:52:609]: File: C:\Users\mtarr\AppData\Local\LTspice\lib.zip;	Won't Overwrite;	Won't patch;	Existing file is unversioned but modified
    MSI (s) (C8:20) [10:46:52:609]: Executing op: SetTargetFolder(Folder=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\)
    MSI (s) (C8:20) [10:46:52:609]: Executing op: SetSourceFolder(Folder=1\)
    MSI (s) (C8:20) [10:46:52:609]: Executing op: FileCopy(SourceName=Remove.exe,SourceCabKey=Remove.exe_1,DestName=Remove.exe,Attributes=0,FileSize=242688,PerTick=65536,,VerifyMedia=1,,,,,CheckCRC=0,Version=65535.65535.65535.65535,Language=0,InstallMode=58982400,,,,,,,)
    MSI (s) (C8:20) [10:46:52:610]: File: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\Remove.exe;	To be installed;	Won't patch;	No existing file
    MSI (s) (C8:20) [10:46:52:610]: Source for file 'Remove.exe_1' is compressed
    InstallFiles: File: Remove.exe,  Directory: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\,  Size: 242688
    MSI (s) (C8:20) [10:46:52:613]: Note: 1: 1304 2: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\Remove.exe
    Error 1304. Error writing to file: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\Remove.exe.  Verify that you have access to that directory.
    MSI (s) (C8:20) [10:46:59:613]: Product: LTspice -- Error 1304. Error writing to file: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\Remove.exe.  Verify that you have access to that directory.
    MSI (s) (C8:20) [10:46:59:614]: Note: 1: 1304 2: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\Remove.exe
    MSI (s) (C8:20) [10:47:00:472]: Product: LTspice -- Error 1304. Error writing to file: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\Remove.exe.  Verify that you have access to that directory.
    MSI (s) (C8:20) [10:47:00:473]: Note: 1: 1304 2: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\Remove.exe
    MSI (s) (C8:78) [10:47:01:384]: I/O on thread 20640 could not be cancelled. Error: 1168
    MSI (s) (C8:78) [10:47:01:384]: I/O on thread 6392 could not be cancelled. Error: 1168
    MSI (s) (C8:78) [10:47:01:384]: I/O on thread 1716 could not be cancelled. Error: 1168
    MSI (s) (C8:78) [10:47:01:384]: I/O on thread 22324 could not be cancelled. Error: 1168
    MSI (s) (C8:78) [10:47:01:384]: I/O on thread 4328 could not be cancelled. Error: 1168
    MSI (s) (C8:78) [10:47:01:384]: I/O on thread 11212 could not be cancelled. Error: 1168
    MSI (s) (C8:78) [10:47:01:384]: I/O on thread 21792 could not be cancelled. Error: 1168
    MSI (s) (C8:78) [10:47:01:384]: I/O on thread 22604 could not be cancelled. Error: 1168
    MSI (s) (C8:78) [10:47:01:384]: I/O on thread 14292 could not be cancelled. Error: 1168
    MSI (s) (C8:78) [10:47:01:384]: I/O on thread 10160 could not be cancelled. Error: 1168
    MSI (s) (C8:78) [10:47:01:384]: I/O on thread 4464 could not be cancelled. Error: 1168
    MSI (s) (C8:78) [10:47:01:384]: I/O on thread 6840 could not be cancelled. Error: 1168
    MSI (s) (C8:78) [10:47:01:384]: I/O on thread 12040 could not be cancelled. Error: 1168
    MSI (s) (C8:78) [10:47:01:384]: I/O on thread 8240 could not be cancelled. Error: 1168
    MSI (s) (C8:78) [10:47:01:384]: I/O on thread 16400 could not be cancelled. Error: 1168
    MSI (s) (C8:78) [10:47:01:384]: I/O on thread 10516 could not be cancelled. Error: 1168
    MSI (s) (C8:78) [10:47:01:384]: I/O on thread 16592 could not be cancelled. Error: 1168
    MSI (s) (C8:78) [10:47:01:384]: I/O on thread 7212 could not be cancelled. Error: 1168
    MSI (s) (C8:78) [10:47:01:384]: I/O on thread 22092 could not be cancelled. Error: 1168
    MSI (s) (C8:78) [10:47:01:384]: I/O on thread 13952 could not be cancelled. Error: 1168
    MSI (s) (C8:78) [10:47:01:384]: I/O on thread 2724 could not be cancelled. Error: 1168
    MSI (s) (C8:78) [10:47:01:384]: I/O on thread 9956 could not be cancelled. Error: 1168
    MSI (s) (C8:78) [10:47:01:384]: I/O on thread 6184 could not be cancelled. Error: 1168
    MSI (s) (C8:78) [10:47:01:384]: I/O on thread 11112 could not be cancelled. Error: 1168
    MSI (s) (C8:78) [10:47:01:384]: I/O on thread 14164 could not be cancelled. Error: 1168
    MSI (s) (C8:78) [10:47:01:384]: I/O on thread 16828 could not be cancelled. Error: 1168
    MSI (s) (C8:20) [10:47:01:385]: Product: LTspice -- Error 1304. Error writing to file: C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\Remove.exe.  Verify that you have access to that directory.
    MSI (c) (40:58) [10:47:01:387]: EEUI - Invalid return value 1 for message type 50331908.
    MSI (c) (40:58) [10:47:01:387]: EEUI - Embedded UI Handler returned ERROR_INSTALL_FAILURE
    Are you sure you want to cancel?
    Action ended 10:47:01: InstallExecute. Return value 3.
    MSI (s) (C8:20) [10:47:01:406]: Note: 1: 2265 2:  3: -2147287035
    MSI (s) (C8:20) [10:47:01:406]: User policy value 'DisableRollback' is 0
    MSI (s) (C8:20) [10:47:01:406]: Machine policy value 'DisableRollback' is 0
    MSI (s) (C8:20) [10:47:01:408]: Note: 1: 2318 2:
    MSI (s) (C8:20) [10:47:01:409]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1564038618,LangId=1033,Platform=589824,ScriptType=2,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=0)
    MSI (s) (C8:20) [10:47:01:409]: Executing op: DialogInfo(Type=0,Argument=1033)
    MSI (s) (C8:20) [10:47:01:410]: Executing op: DialogInfo(Type=1,Argument=LTspice)
    MSI (s) (C8:20) [10:47:01:411]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,,CleanupAction=RollbackCleanup,CleanupDescription=Removing backup files,CleanupTemplate=File: [1])
    MSI (s) (C8:20) [10:47:01:411]: Executing op: RegisterBackupFile(File=C:\Config.Msi\77b2d4.rbf)
    Action 10:47:01: Rollback. Rolling back action:
    1: Copying new files
    MSI (s) (C8:20) [10:47:01:415]: Executing op: ActionStart(Name=InstallFiles,Description=Copying new files,Template=File: [1],  Directory: [9],  Size: [6])
    MSI (s) (C8:20) [10:47:01:416]: Executing op: SetTargetFolder(Folder=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\)
    MSI (s) (C8:20) [10:47:01:417]: Executing op: ProductInfo(ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},ProductName=LTspice,PackageName=LTspice64.msi,Language=1033,Version=436207618,Assignment=0,ObsoleteArg=0,ProductIcon=ADI.exe,,PackageCode={39C828E8-EBEA-41FF-AC38-4A5921DF2236},,,InstanceType=0,LUASetting=0,RemoteURTInstalls=0,ProductDeploymentFlags=6)
    MSI (s) (C8:20) [10:47:01:418]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\AppData\Roaming
    MSI (s) (C8:20) [10:47:01:419]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\AppData\Roaming
    MSI (s) (C8:20) [10:47:01:421]: SHELL32::SHGetFolderPath returned: C:\Users\mtarr\AppData\Roaming
    MSI (s) (C8:20) [10:47:01:422]: Note: 1: 2318 2:
    MSI (s) (C8:20) [10:47:01:424]: Executing op: FileRemove(,FileName=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\Remove.exe,,)
    MSI (s) (C8:20) [10:47:01:425]: Executing op: SetTargetFolder(Folder=C:\Users\mtarr\AppData\Local\LTspice\)
    MSI (s) (C8:20) [10:47:01:426]: Executing op: FileCopy(SourceName=C:\Config.Msi\77b2d4.rbf,,DestName=C:\Users\mtarr\AppData\Local\LTspice\Remove.exe,Attributes=32,FileSize=0,PerTick=0,,VerifyMedia=0,ElevateFlags=1,,,,,,,InstallMode=4194304,,,,,,,)
    MSI (s) (C8:20) [10:47:01:427]: File: C:\Users\mtarr\AppData\Local\LTspice\Remove.exe;	Overwrite;	Won't patch;	REINSTALLMODE specifies all files to be overwritten
    MSI (s) (C8:20) [10:47:01:427]: Re-applying security from existing file.
    MSI (s) (C8:20) [10:47:01:428]: Note: 1: 2318 2:
    MSI (s) (C8:20) [10:47:01:430]: Verifying accessibility of file: Remove.exe
    MSI (s) (C8:20) [10:47:01:430]: Using source file security for destination.
    MSI (s) (C8:20) [10:47:01:430]: Note: 1: 2318 2: C:\Config.Msi\77b2d5.rbf
    MSI (s) (C8:20) [10:47:01:431]: Verifying accessibility of file: Remove.exe
    MSI (s) (C8:20) [10:47:01:438]: File will have security applied from OpCode.
    MSI (s) (C8:20) [10:47:01:441]: Executing op: FileRemove(,FileName=C:\Config.Msi\77b2d4.rbf,Elevate=1,)
    MSI (s) (C8:20) [10:47:01:443]: Note: 1: 2318 2:
    MSI (s) (C8:20) [10:47:01:444]: Executing op: SetTargetFolder(Folder=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\)
    MSI (s) (C8:20) [10:47:01:445]: Executing op: FileRemove(,FileName=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceChangeLog.txt,,)
    MSI (s) (C8:20) [10:47:01:446]: Executing op: FileRemove(,FileName=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspice.json,,)
    MSI (s) (C8:20) [10:47:01:447]: Executing op: FileRemove(,FileName=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\License.pdf,,)
    MSI (s) (C8:20) [10:47:01:448]: Executing op: FileRemove(,FileName=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\lib.zip,,)
    MSI (s) (C8:20) [10:47:01:451]: Executing op: FileRemove(,FileName=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\examples.zip,,)
    MSI (s) (C8:20) [10:47:01:453]: Executing op: FileRemove(,FileName=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\updater.exe,,)
    MSI (s) (C8:20) [10:47:01:454]: Executing op: FileRemove(,FileName=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspice.exe,,)
    MSI (s) (C8:20) [10:47:01:459]: Executing op: FileRemove(,FileName=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\License.txt,,)
    1: Creating folders
    MSI (s) (C8:20) [10:47:01:461]: Executing op: ActionStart(Name=CreateFolders,Description=Creating folders,Template=Folder: [1])
    MSI (s) (C8:20) [10:47:01:462]: Executing op: FolderRemove(Folder=C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\LTspice\,Foreign=0)
    MSI (s) (C8:20) [10:47:01:462]: Note: 1: 2318 2:
    MSI (s) (C8:20) [10:47:01:463]: Executing op: FolderRemove(Folder=C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\,Foreign=0)
    MSI (s) (C8:20) [10:47:01:464]: Note: 1: 2318 2:
    1: Updating component registration
    MSI (s) (C8:20) [10:47:01:466]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
    MSI (s) (C8:20) [10:47:01:467]: Executing op: ComponentUnregister(ComponentId={48869CD5-7A42-4C0A-888C-DE11DEC99F6E},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:469]: Executing op: ComponentUnregister(ComponentId={BDA382B3-0513-46B0-9850-96E535057739},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:471]: Executing op: ComponentUnregister(ComponentId={BF07C412-8C95-4F11-B8AA-FEC95A38A970},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:472]: Executing op: ComponentUnregister(ComponentId={66D5BB11-2A1D-4001-8A71-41172C861E9A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:473]: Executing op: ComponentUnregister(ComponentId={058477A1-DD21-48BD-9673-59A1A9979BB9},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:474]: Executing op: ComponentUnregister(ComponentId={91F12172-6A56-4F87-8903-9A09BED80B76},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:476]: Executing op: ComponentUnregister(ComponentId={913809D5-EE7B-47EE-BDA9-36F835577424},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:477]: Executing op: ComponentUnregister(ComponentId={2E5E7B2B-BD6C-45A7-98B4-4C2DED7D2329},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:478]: Executing op: ComponentUnregister(ComponentId={60A15659-6CA0-4A6A-A281-63DBBB1B812B},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:479]: Executing op: ComponentUnregister(ComponentId={B89E3541-151E-4E35-AD42-CBCBEFECF779},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:480]: Executing op: ComponentUnregister(ComponentId={2A9D7EFC-86C4-49CB-AE6B-D11F42EB42E7},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:482]: Executing op: ComponentUnregister(ComponentId={75117040-26F6-4ABF-ADD4-ECC227B5B862},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:483]: Executing op: ComponentUnregister(ComponentId={30FDBB42-A521-411C-9BB3-9C54482A047C},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:484]: Executing op: ComponentUnregister(ComponentId={A619D5DF-86B6-4658-B17D-D4F347D244EF},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:486]: Executing op: ComponentUnregister(ComponentId={52EF4959-8CA6-49D3-8F90-E4193A427CF9},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:487]: Executing op: ComponentUnregister(ComponentId={3F3FFD3D-D5CF-41A9-A250-1FF5BE395277},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:488]: Executing op: ComponentUnregister(ComponentId={5025C89E-376F-4E9A-924B-6D5F5A721426},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:490]: Executing op: ComponentUnregister(ComponentId={71FB5297-CC16-4CFC-A20A-D755E778BE71},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:491]: Executing op: ComponentUnregister(ComponentId={CDEEAB11-DF5C-4D7C-ACC4-3E9326121001},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:493]: Executing op: ComponentUnregister(ComponentId={D228B9CB-F7BD-437B-AE72-8332C8033D48},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:494]: Executing op: ComponentUnregister(ComponentId={8F75BFB3-35C2-4F9F-A94D-44A03E5CFA34},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:495]: Executing op: ComponentUnregister(ComponentId={5750A86F-07A9-4883-BBD4-6C83133D36E5},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:496]: Executing op: ComponentUnregister(ComponentId={8EB35842-5D14-4CA5-A849-7155CDC6635F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:498]: Executing op: ComponentUnregister(ComponentId={6A5FEBC4-35F7-43F6-85A9-E9A54A1163D8},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:498]: Executing op: ComponentUnregister(ComponentId={220EF083-A50C-41FC-93A2-179567DFF5FC},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:500]: Executing op: ComponentUnregister(ComponentId={45A2AC47-6F63-4248-97BD-2AB93D3ABBAE},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:501]: Executing op: ComponentUnregister(ComponentId={91630773-F890-4291-A91F-38A04388A5F7},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:503]: Executing op: ComponentUnregister(ComponentId={D984F04C-7EB6-4EB8-95AF-510B61E7C629},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:504]: Executing op: ComponentUnregister(ComponentId={7F10F73F-4335-482A-AECA-D40E86E82DE7},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:505]: Executing op: ComponentUnregister(ComponentId={21F8A718-5102-4096-8D80-1681AEA6AAD6},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:507]: Executing op: ComponentUnregister(ComponentId={144DAC7C-DA14-48EA-9CDE-B273B9DD6F63},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:508]: Executing op: ComponentUnregister(ComponentId={051688A0-931A-431D-8123-924DF19B68B2},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:510]: Executing op: ComponentUnregister(ComponentId={A5BA6983-5EF0-4CA6-A584-EDED2B98808A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:511]: Executing op: ComponentUnregister(ComponentId={4E026965-D599-4D72-9DA0-C489CDD919C0},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:512]: Executing op: ComponentUnregister(ComponentId={F964C53D-4174-44A8-A1EC-B1BA3C3043E6},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:514]: Executing op: ComponentUnregister(ComponentId={F84076F7-CC47-47E4-A01D-7F04BF182C8A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:514]: Executing op: ComponentUnregister(ComponentId={79F7E5B2-7C55-42CD-85F9-2B378E784506},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:516]: Executing op: ComponentUnregister(ComponentId={64D7C52E-7E37-40D1-A2D4-2BEE38104D7C},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:517]: Executing op: ComponentUnregister(ComponentId={0AC9FB5A-B7D3-44C7-8756-1FD9AA12E206},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:519]: Executing op: ComponentUnregister(ComponentId={20B5CF9E-8BF2-49D9-9E68-4E23211BDDE3},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:521]: Executing op: ComponentUnregister(ComponentId={1EC74E47-8CD8-4522-8A55-1AA146F85CD7},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:522]: Executing op: ComponentUnregister(ComponentId={C3B429CB-BEB1-485D-AB10-04AFD2D99422},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:523]: Executing op: ComponentUnregister(ComponentId={11CC4333-A6A9-4873-842E-EDA049FF1137},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:525]: Executing op: ComponentUnregister(ComponentId={499FD15F-9C17-4043-B9E1-586FC1BDAB61},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:526]: Executing op: ComponentUnregister(ComponentId={BEE9572D-68BB-45CF-B0ED-4F9D213BC362},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:527]: Executing op: ComponentUnregister(ComponentId={7C8FB99F-AEF9-4627-BCBA-6384CA5E7644},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:528]: Executing op: ComponentUnregister(ComponentId={63AA39E2-2C06-458E-97F6-4C45FE816B57},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:529]: Executing op: ComponentUnregister(ComponentId={79068E6B-2CF0-4CFB-94FC-E8F240C686DC},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:530]: Executing op: ComponentUnregister(ComponentId={C30162D7-D8CE-4764-9F59-4867AAABDFD8},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:532]: Executing op: ComponentUnregister(ComponentId={8233A0A9-66C6-438A-BA4D-0CF39FB1B8DB},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:533]: Executing op: ComponentUnregister(ComponentId={81051871-B414-49D4-A74D-1D8457FF6620},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:534]: Executing op: ComponentUnregister(ComponentId={93711E0B-3CB5-4019-8A6F-F59D16B77046},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:535]: Executing op: ComponentUnregister(ComponentId={6C0670FC-161E-4C5A-842D-7B64460FAF06},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:537]: Executing op: ComponentUnregister(ComponentId={BC7C3CE1-B7AB-4121-AE6D-57742D227961},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:538]: Executing op: ComponentUnregister(ComponentId={24E63589-8585-4262-9385-ABC9F6D43E6F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:540]: Executing op: ComponentUnregister(ComponentId={E4C2D004-307F-4A53-A5E9-5195D7F2C342},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:541]: Executing op: ComponentUnregister(ComponentId={BAB4B8FB-5D3B-4072-A285-272D36DFA84B},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:542]: Executing op: ComponentUnregister(ComponentId={A8C9C0BF-F93D-468D-B779-E169C8ABD8A9},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:544]: Executing op: ComponentUnregister(ComponentId={F1823343-CE58-450F-A0AC-C525BB529F2F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:545]: Executing op: ComponentUnregister(ComponentId={375AB294-6565-4741-8F58-7D06A6A0D179},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:546]: Executing op: ComponentUnregister(ComponentId={764F64CF-0E51-4654-82B5-500E01DAA2B4},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:547]: Executing op: ComponentUnregister(ComponentId={9B45D48A-EA19-4145-8C05-8A8CE010639D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:548]: Executing op: ComponentUnregister(ComponentId={406242BB-1716-492C-8722-67ACBD1A90F1},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:550]: Executing op: ComponentUnregister(ComponentId={254BB10C-45F3-4E4C-9052-70025F21B252},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:551]: Executing op: ComponentUnregister(ComponentId={8BEE4090-6273-4B09-8DE2-7EE345EFAD70},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:552]: Executing op: ComponentUnregister(ComponentId={0E5E28B6-E528-40BA-9209-25D621685601},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:554]: Executing op: ComponentUnregister(ComponentId={C412FDC0-7984-4BA4-8A0E-6FD0F9D1EEE9},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:555]: Executing op: ComponentUnregister(ComponentId={91DB12CA-2A53-4E61-AD82-BFBAA8EF8AEF},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:556]: Executing op: ComponentUnregister(ComponentId={DDDE011A-4BDB-4B3D-81DA-EFDAF8C14A2A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:558]: Executing op: ComponentUnregister(ComponentId={633BB8E5-B626-44C7-9B2F-1C0BB94C91F7},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:559]: Executing op: ComponentUnregister(ComponentId={0631A41D-3106-4BEC-8D41-40C7FF6F67C3},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:561]: Executing op: ComponentUnregister(ComponentId={799D2D9C-4EED-45BF-948E-422056251EFB},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:562]: Executing op: ComponentUnregister(ComponentId={13752981-087E-4A27-AB90-D8808ADCEE4F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:563]: Executing op: ComponentUnregister(ComponentId={266CB0B5-08AE-43F7-9DE0-F0BA6B75F63D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:564]: Executing op: ComponentUnregister(ComponentId={2F056D90-CD5F-4717-81BD-BBAD8EBE35D2},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:566]: Executing op: ComponentUnregister(ComponentId={52FBEFF6-3F58-4460-AFBC-9EF97B0BA414},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:567]: Executing op: ComponentUnregister(ComponentId={EA74892D-77A1-427F-83A3-F5FE31B08849},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:568]: Executing op: ComponentUnregister(ComponentId={12B54696-C689-463F-8677-ACD641553E5E},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:569]: Executing op: ComponentUnregister(ComponentId={8F245CC3-359A-4AEE-A7D2-2F19DF0AF726},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:571]: Executing op: ComponentUnregister(ComponentId={77B61787-B6C0-4DE0-BFEE-7000BC3E8FB4},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:572]: Executing op: ComponentUnregister(ComponentId={16EC5310-F5F7-45A9-8411-8C8D6841D69C},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:573]: Executing op: ComponentUnregister(ComponentId={9116EFAC-A60A-4FC0-BAC0-11A3426CE748},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:574]: Executing op: ComponentUnregister(ComponentId={5E9CB3A9-B42D-43C7-B93A-DDCA3F421E54},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:576]: Executing op: ComponentUnregister(ComponentId={5FB34078-1539-4C87-AF61-A45AB5F3B70C},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:577]: Executing op: ComponentUnregister(ComponentId={081FB790-EFEE-4591-9D73-E88F41E718C6},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:578]: Executing op: ComponentUnregister(ComponentId={CD71EBCD-8A0C-48FA-A356-C06FC66AED08},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:580]: Executing op: ComponentUnregister(ComponentId={4EDCF980-B18A-48DA-AFDB-B1DBFDE760F3},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:581]: Executing op: ComponentUnregister(ComponentId={A31C87B4-00F4-4712-A2B7-4CB3575CBDF4},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:582]: Executing op: ComponentUnregister(ComponentId={A555A2B8-6A3B-4C08-A330-9C631D85AF13},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:584]: Executing op: ComponentUnregister(ComponentId={AF66D3E3-5673-43A1-9BFB-A8A27776EA52},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:585]: Executing op: ComponentUnregister(ComponentId={BE42E4E2-D217-42A7-8FCE-C85D3B9363C1},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:586]: Executing op: ComponentUnregister(ComponentId={018B88D5-6D09-45B4-B330-0F8C47389789},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:588]: Executing op: ComponentUnregister(ComponentId={23CF4939-4F9B-4EE7-8D8C-319D0343546A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:590]: Executing op: ComponentUnregister(ComponentId={9001A068-2557-4A91-B7C4-972419B4E122},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:591]: Executing op: ComponentUnregister(ComponentId={95433358-567E-4E44-983A-D040CE5F3729},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:592]: Executing op: ComponentUnregister(ComponentId={B65C9DC5-15ED-4BB0-A633-286378A726DA},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:593]: Executing op: ComponentUnregister(ComponentId={2212CBE3-89B7-45C0-9AB8-A08F59F3B9E9},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:595]: Executing op: ComponentUnregister(ComponentId={DFD06974-1DA9-44AE-9407-C0E990B052A7},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:596]: Executing op: ComponentUnregister(ComponentId={5BC0D018-8F22-4C5E-BD1F-D9E55A9DA97A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:597]: Executing op: ComponentUnregister(ComponentId={7450D889-954E-4B65-B73C-EBC4DFC874B2},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:598]: Executing op: ComponentUnregister(ComponentId={69172882-FD62-4A8A-8B73-640DD5AD17E0},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:600]: Executing op: ComponentUnregister(ComponentId={B7C60A2C-9EF3-4C25-94F8-E1818EDAC2EA},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:600]: Executing op: ComponentUnregister(ComponentId={5BA7126C-F782-455B-BD33-B47610574386},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:602]: Executing op: ComponentUnregister(ComponentId={1E9FF258-A750-4026-9537-CAD9654D0F18},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:603]: Executing op: ComponentUnregister(ComponentId={A7E53037-1DEB-4E87-B0C9-59772E8258C8},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:604]: Executing op: ComponentUnregister(ComponentId={8B38660E-8FC4-4A27-BF3F-744DA18AB444},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:606]: Executing op: ComponentUnregister(ComponentId={38940200-D919-4857-938C-B91AF63590AC},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:607]: Executing op: ComponentUnregister(ComponentId={EFB1A1CD-A412-4A1C-BBA4-E83FDC23E4EB},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:608]: Executing op: ComponentUnregister(ComponentId={45AEF58B-7BA1-4078-BC7C-8B5CBCB6DDB7},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:610]: Executing op: ComponentUnregister(ComponentId={D83B5E46-34F6-4439-8F5D-DE2C8726705E},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:611]: Executing op: ComponentUnregister(ComponentId={05D98443-6352-45D3-A49E-0E623A553314},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:612]: Executing op: ComponentUnregister(ComponentId={936E52A9-4CEA-49F9-9647-EC65B1CED0BB},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:614]: Executing op: ComponentUnregister(ComponentId={653C807E-E260-4B68-8031-C8F7C86673C3},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:615]: Executing op: ComponentUnregister(ComponentId={2319B716-27AB-4D85-B993-58713ECA8BAE},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:616]: Executing op: ComponentUnregister(ComponentId={C12B47C4-E8A2-4DD6-9B8F-503DEBD9901D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:617]: Executing op: ComponentUnregister(ComponentId={14391CED-C057-4F02-957C-9AC676DAD6CD},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:618]: Executing op: ComponentUnregister(ComponentId={FBEDF49A-0C83-40F7-85C8-C46FF37C0E23},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:620]: Executing op: ComponentUnregister(ComponentId={8136B6D8-6C61-4D59-A36E-6DEBA2294AA8},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:621]: Executing op: ComponentUnregister(ComponentId={82A02097-F8C9-4DE8-B7AA-94C050287A86},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:623]: Executing op: ComponentUnregister(ComponentId={5282353B-2E2F-4E4E-9DD1-EB749FF84E88},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:624]: Executing op: ComponentUnregister(ComponentId={B33889D9-8ECD-458D-ABCF-4875478AA6C5},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:625]: Executing op: ComponentUnregister(ComponentId={6CAD4554-B930-42CB-882E-F1302C0C14EB},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:626]: Executing op: ComponentUnregister(ComponentId={F95CCD08-3780-43CD-A20C-740038C36E14},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:628]: Executing op: ComponentUnregister(ComponentId={0C891288-C8C3-4E0D-81B1-6CB6237DA51F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:629]: Executing op: ComponentUnregister(ComponentId={EE487B0A-8675-4B68-BD20-C90955ECC9A2},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:630]: Executing op: ComponentUnregister(ComponentId={0A6F43F4-6FEE-497E-B383-D1B864CD47AD},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:631]: Executing op: ComponentUnregister(ComponentId={571D1E48-12FE-4695-AA7B-B1562827134E},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:632]: Executing op: ComponentUnregister(ComponentId={B1F30BC1-182F-4200-813D-E2A35550C7C3},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:633]: Executing op: ComponentUnregister(ComponentId={32D85E5C-2B1D-4F61-A150-205F216091E8},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:634]: Executing op: ComponentUnregister(ComponentId={0B5DB171-6933-4B7C-A5A4-624FD7787896},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:636]: Executing op: ComponentUnregister(ComponentId={A7DDCBA6-37EF-4B3C-B8A9-28C4D896CB98},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:638]: Executing op: ComponentUnregister(ComponentId={320ACB34-CE48-4AC1-B396-756C63F83C3F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:640]: Executing op: ComponentUnregister(ComponentId={D71E7F05-4F51-4A2F-9EF2-CE8671B45DBE},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:641]: Executing op: ComponentUnregister(ComponentId={57B42DA1-C5AA-444C-8E59-0895FDA1818A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:642]: Executing op: ComponentUnregister(ComponentId={E0B572C7-F51E-4A20-BF6D-DA41E53DDC5D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:644]: Executing op: ComponentUnregister(ComponentId={4D78EE8D-4B69-4276-AF0C-E9E4A097AA18},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:645]: Executing op: ComponentUnregister(ComponentId={D6516555-0B3E-48D5-87EA-5050F9B05FCF},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:646]: Executing op: ComponentUnregister(ComponentId={0BCC1A74-B96F-4181-B190-B1CBC99996D0},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:648]: Executing op: ComponentUnregister(ComponentId={7086FDB6-45AA-40CD-8CAE-02D2A4086523},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:648]: Executing op: ComponentUnregister(ComponentId={B7F2B34F-2AF4-456A-A875-58902CAE2787},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:650]: Executing op: ComponentUnregister(ComponentId={FBB627B7-2159-4294-ABA2-3D678804848D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:651]: Executing op: ComponentUnregister(ComponentId={84A9DF80-012A-4096-9EDB-40D68061C6F1},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:652]: Executing op: ComponentUnregister(ComponentId={5F5AE69E-D0D8-4DE7-AA04-CEAF3E47F0B1},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:653]: Executing op: ComponentUnregister(ComponentId={394A4516-69E8-48D5-BE9D-81563E9489BC},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:655]: Executing op: ComponentUnregister(ComponentId={8FCB8732-5602-4847-97EF-3DAC95D92E4A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:656]: Executing op: ComponentUnregister(ComponentId={195C9A32-37FD-4E60-BB0F-85DDE345F274},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:657]: Executing op: ComponentUnregister(ComponentId={2B23016B-B6D2-4EE9-84D3-BEEE4457DF13},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:658]: Executing op: ComponentUnregister(ComponentId={A426813A-1B6F-4697-8FFE-0F3C60C98BE5},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:660]: Executing op: ComponentUnregister(ComponentId={7931F1E7-F753-4D18-87E6-2C23CD7AF5C9},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:661]: Executing op: ComponentUnregister(ComponentId={E98E3994-2F44-4B98-A4C0-AC595536A2E7},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:663]: Executing op: ComponentUnregister(ComponentId={C175D3EC-26DB-4E20-9C59-898B9FF483AF},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:664]: Executing op: ComponentUnregister(ComponentId={AF4D97F8-BD47-4381-9EE0-DD08F348023D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:665]: Executing op: ComponentUnregister(ComponentId={6458B593-8DEA-4789-8D77-679ABB179C7B},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:667]: Executing op: ComponentUnregister(ComponentId={FA7A399E-06E3-48AB-B7BE-E4D387999B22},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:668]: Executing op: ComponentUnregister(ComponentId={9E1E6AE3-1E00-4C2C-8A4F-11517305F060},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:668]: Executing op: ComponentUnregister(ComponentId={11495F8A-D41E-444E-BB74-F51A79A98097},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:670]: Executing op: ComponentUnregister(ComponentId={81AC7418-062C-4047-BB6D-DCE42FF36305},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:671]: Executing op: ComponentUnregister(ComponentId={79B49B00-6CD7-45AC-A364-FABD63E26D46},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:673]: Executing op: ComponentUnregister(ComponentId={C0A19093-C9E6-4752-9C7A-EE6840B3B439},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:674]: Executing op: ComponentUnregister(ComponentId={FFB70666-3C38-462C-BAC3-F0021E491E6A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:675]: Executing op: ComponentUnregister(ComponentId={8A604871-C1FE-4B43-9E9B-AB1FB46E652A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:676]: Executing op: ComponentUnregister(ComponentId={3BF182F5-CD2A-4AEA-9C55-C06413B42D3A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:678]: Executing op: ComponentUnregister(ComponentId={B1C016DA-BC5B-4118-9B2C-2CAD7EBEC8D4},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:679]: Executing op: ComponentUnregister(ComponentId={00EA5630-BED4-479C-B5EF-DCD489832662},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:681]: Executing op: ComponentUnregister(ComponentId={8DC666D2-882B-428C-B27E-C03E673A0BF1},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:682]: Executing op: ComponentUnregister(ComponentId={15053AF8-0D26-489A-9C7C-EB451A142A74},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:683]: Executing op: ComponentUnregister(ComponentId={6B0AF397-08EA-43C8-9CAC-61A7BA1C0991},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:684]: Executing op: ComponentUnregister(ComponentId={91D2574B-7E26-4B5A-B227-91D65CADB21D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:686]: Executing op: ComponentUnregister(ComponentId={16897C8E-C28E-40BA-BF27-991CA19ED047},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:687]: Executing op: ComponentUnregister(ComponentId={8603E2B0-0E36-47A2-AF89-6E24009B7DE9},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:688]: Executing op: ComponentUnregister(ComponentId={5D170A04-4548-467C-8E2F-EDED5C2C1134},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:689]: Executing op: ComponentUnregister(ComponentId={00B02534-CB61-49A7-B7AE-4C9745858105},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:690]: Executing op: ComponentUnregister(ComponentId={2845F6A6-E61F-4B7F-973C-0EE72AA7939C},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:692]: Executing op: ComponentUnregister(ComponentId={E0E59823-43F7-44AE-A845-844D3F769BDC},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:693]: Executing op: ComponentUnregister(ComponentId={0B55C988-71DD-4AE7-8D04-D3AD277BE69C},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:694]: Executing op: ComponentUnregister(ComponentId={5039AF29-862D-423E-BD78-C6F504021C89},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:696]: Executing op: ComponentUnregister(ComponentId={7F270750-DDFB-4CE2-8C64-2E78D2ECE682},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:697]: Executing op: ComponentUnregister(ComponentId={2573FC69-D4CA-43DC-8A4D-6553F79D5505},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:698]: Executing op: ComponentUnregister(ComponentId={463C00AE-C335-45B4-8FF4-BC3E939CD391},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:700]: Executing op: ComponentUnregister(ComponentId={7D14D2D1-BB02-4894-BFD7-554537F2EBA5},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:701]: Executing op: ComponentUnregister(ComponentId={86EE50AE-C1F8-4FC8-A3B4-64DEA77157C4},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:703]: Executing op: ComponentUnregister(ComponentId={FDAA1A58-C718-46CD-916E-40E0EAA999FC},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:704]: Executing op: ComponentUnregister(ComponentId={BB0796C2-479D-44A1-8664-CE4EE7620B03},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:705]: Executing op: ComponentUnregister(ComponentId={FBD7F6F6-629C-40C2-AFBF-AAE628EC7728},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:706]: Executing op: ComponentUnregister(ComponentId={5228D401-E598-4AA8-BE41-7A8E659170E3},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:708]: Executing op: ComponentUnregister(ComponentId={EE8C40AE-78C3-4176-BBC0-9911D33618F0},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:708]: Executing op: ComponentUnregister(ComponentId={4705C2A7-3C9A-460C-B827-D2C95BCBFE6F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:710]: Executing op: ComponentUnregister(ComponentId={F6FAD98B-6AC6-401B-A0F6-90C2A8A696CC},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:711]: Executing op: ComponentUnregister(ComponentId={6C9C44ED-D4B7-4A81-8F23-7D5FCAF31859},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:712]: Executing op: ComponentUnregister(ComponentId={96716349-45EF-45D2-B070-0B199D51CA89},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:714]: Executing op: ComponentUnregister(ComponentId={8E1AF220-3684-4350-879E-1962D17381CA},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:714]: Executing op: ComponentUnregister(ComponentId={0FA1977E-493D-4632-A4F3-81E3D7490DAD},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:717]: Executing op: ComponentUnregister(ComponentId={81CEB57E-1F0B-415C-91BF-DD92AA11D9DC},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:718]: Executing op: ComponentUnregister(ComponentId={5B0FB95C-8065-48B1-B5EB-40DFFF1733EE},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:719]: Executing op: ComponentUnregister(ComponentId={00E6C02F-785B-42DB-A0D1-3DE8729261B6},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:720]: Executing op: ComponentUnregister(ComponentId={294F3798-26CC-40CA-99A3-43317D1316B7},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:721]: Executing op: ComponentUnregister(ComponentId={903797B0-92D4-434B-86B6-91767EE31801},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:723]: Executing op: ComponentUnregister(ComponentId={E0A1E50C-30E2-46A1-979E-9D1C8D09BADF},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:724]: Executing op: ComponentUnregister(ComponentId={90F21B93-445A-41E9-897A-E2BCF0CC174B},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:726]: Executing op: ComponentUnregister(ComponentId={D1105F65-5FEB-433A-BB50-55190C62B568},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:728]: Executing op: ComponentUnregister(ComponentId={87B44728-D66C-4313-B520-CDD6D139230D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:729]: Executing op: ComponentUnregister(ComponentId={20FFF79E-1D8E-4A80-BD34-0FAB47332287},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:731]: Executing op: ComponentUnregister(ComponentId={E85E70C1-9F6F-4B31-84BF-6F1B49BBD6CC},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:732]: Executing op: ComponentUnregister(ComponentId={49285978-EFB9-4E4F-8540-7445D334D0DA},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:733]: Executing op: ComponentUnregister(ComponentId={E7C3E96E-EFEF-4B48-8C09-EE3AC54F01AC},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:734]: Executing op: ComponentUnregister(ComponentId={B5AF8FD5-F7C5-41DD-A0C2-A170C55BB2CD},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:736]: Executing op: ComponentUnregister(ComponentId={D2CC1819-7E91-4EF9-A83C-AD27080E8E0A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:737]: Executing op: ComponentUnregister(ComponentId={613BED9F-1B2D-450B-BB0E-9AB01AD37273},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:738]: Executing op: ComponentUnregister(ComponentId={7A33097F-868B-4803-95BE-D23026E9B2B4},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:739]: Executing op: ComponentUnregister(ComponentId={D3E44CA6-60D9-4BC7-A911-3DEE5752F42F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:741]: Executing op: ComponentUnregister(ComponentId={449EA348-AC60-400E-BFF9-B4C6D91FA09E},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:742]: Executing op: ComponentUnregister(ComponentId={E71DFACC-690D-4CB9-A0D4-144ECD80C716},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:743]: Executing op: ComponentUnregister(ComponentId={998B5251-C2A5-4F6D-82D6-763E99D1C136},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:744]: Executing op: ComponentUnregister(ComponentId={5CDDD432-69FE-4E45-B981-049560945262},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:746]: Executing op: ComponentUnregister(ComponentId={A921CB92-4942-4E16-BB83-6C6E478933DF},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:747]: Executing op: ComponentUnregister(ComponentId={43231C93-A6A4-4BC9-9A64-34F79ECE80F7},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:748]: Executing op: ComponentUnregister(ComponentId={ACF42134-168B-4658-835C-CC5A5ECA5216},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:750]: Executing op: ComponentUnregister(ComponentId={ED755C27-E28A-4837-AA91-49D4BA2D29C4},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:751]: Executing op: ComponentUnregister(ComponentId={F3C3A841-2B43-48F0-BAAD-D994E2D7FA2F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:753]: Executing op: ComponentUnregister(ComponentId={24393E47-5657-48F6-8D1E-FB212BB85E47},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:754]: Executing op: ComponentUnregister(ComponentId={F9131CE1-D5B8-4BE1-BC8B-16A601953D39},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:755]: Executing op: ComponentUnregister(ComponentId={91AAC297-773F-4456-ACF0-6830C39FF4D6},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:757]: Executing op: ComponentUnregister(ComponentId={05CBB9EE-B7F0-41E4-BB42-7165FBC3AF13},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:758]: Executing op: ComponentUnregister(ComponentId={71F33501-5C61-47AF-AAB8-E300F2910A78},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:759]: Executing op: ComponentUnregister(ComponentId={CAD1C9A8-76B9-426F-BCC3-DCE6AFD8825F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:760]: Executing op: ComponentUnregister(ComponentId={59A3013E-3E17-4313-8631-9082220B503F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:761]: Executing op: ComponentUnregister(ComponentId={6E7EC5DB-E878-45A3-A9B3-E1579DD945E8},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:762]: Executing op: ComponentUnregister(ComponentId={9C35E682-9332-4CD9-8F4A-AC5E56A04DFF},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:764]: Executing op: ComponentUnregister(ComponentId={A450BEE7-0EC2-464D-A2CD-CCB896C089DA},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:765]: Executing op: ComponentUnregister(ComponentId={27259558-E06D-4110-870D-A6D99BFA677D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:766]: Executing op: ComponentUnregister(ComponentId={88D13351-CA5F-4EE7-9851-F5E830A47B90},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:767]: Executing op: ComponentUnregister(ComponentId={253FAA55-CFE5-4995-87FC-099144CDB47F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:768]: Executing op: ComponentUnregister(ComponentId={6BABF391-5B9F-445E-8BBE-C0FF45A46043},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:770]: Executing op: ComponentUnregister(ComponentId={DA9EA323-368D-470F-9906-3E5D3D93D983},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:772]: Executing op: ComponentUnregister(ComponentId={13A685DC-E514-4132-9E4B-C86E837B28A8},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:773]: Executing op: ComponentUnregister(ComponentId={6220AA73-B8B9-494B-BCAD-3396349E43AA},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:774]: Executing op: ComponentUnregister(ComponentId={13A367BC-1F22-4C19-94D8-4D936D7B1DCF},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:775]: Executing op: ComponentUnregister(ComponentId={ECA52FE6-718F-43A9-8DB7-E158243DAB4B},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:777]: Executing op: ComponentUnregister(ComponentId={B8A2A299-378D-4EB2-A12C-E731ADF4F1F1},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:778]: Executing op: ComponentUnregister(ComponentId={EBB25E48-0403-4E3F-BD75-46D43BD62388},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:779]: Executing op: ComponentUnregister(ComponentId={AAEC6199-B9BE-456E-AD1F-3A0B2D2AE5AE},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:780]: Executing op: ComponentUnregister(ComponentId={84367478-7484-4B6E-B19F-7B954C346658},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:781]: Executing op: ComponentUnregister(ComponentId={979AA220-2175-4101-8B06-0B53A8E64E9D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:782]: Executing op: ComponentUnregister(ComponentId={F1DD57DB-2B77-4A80-B19E-89444BB4AB00},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:784]: Executing op: ComponentUnregister(ComponentId={3612E63E-1528-4477-A179-CEADCCC7FD8E},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:785]: Executing op: ComponentUnregister(ComponentId={4909D075-50C9-4EF2-9410-A4D51295611D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:786]: Executing op: ComponentUnregister(ComponentId={EC2C07AB-7383-456F-85CA-E66D8A9C9085},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:788]: Executing op: ComponentUnregister(ComponentId={42B159F2-27E8-48AB-BFB8-4EE9D8B01B3A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:790]: Executing op: ComponentUnregister(ComponentId={AC9A31EB-86D6-4DEC-B16A-90DEE2A122EC},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:791]: Executing op: ComponentUnregister(ComponentId={B3F7AA35-FDBB-4D51-ADFC-BB743D37D5C8},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:792]: Executing op: ComponentUnregister(ComponentId={1145E11B-ED15-44AE-B326-E500F931523D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:793]: Executing op: ComponentUnregister(ComponentId={93F73C4C-F15D-4904-BC45-34D31FC0616F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:795]: Executing op: ComponentUnregister(ComponentId={193B229E-702C-40F1-8114-4A4CF199EEF7},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:796]: Executing op: ComponentUnregister(ComponentId={2CF61007-3C65-4286-9CF4-220E3E9F6F11},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:797]: Executing op: ComponentUnregister(ComponentId={4B778392-A74F-4C7A-B901-66B98765A726},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:798]: Executing op: ComponentUnregister(ComponentId={828F944D-5FAA-4E6E-A0E8-878C4F587AED},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:799]: Executing op: ComponentUnregister(ComponentId={E699CC77-E472-4F21-8EFD-388BF8E34025},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:800]: Executing op: ComponentUnregister(ComponentId={62309EE1-38B2-4320-A0E1-AC40337E775F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:802]: Executing op: ComponentUnregister(ComponentId={A73548F5-4B43-4B18-8E56-E04CB04DC563},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:803]: Executing op: ComponentUnregister(ComponentId={FD545689-B968-4CC0-81B7-7ED89688F8A8},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:805]: Executing op: ComponentUnregister(ComponentId={F10D1C36-A79C-4CB0-B940-4DF8A51AE0D0},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:806]: Executing op: ComponentUnregister(ComponentId={81347EDA-509F-45E6-AACC-10912CA28D17},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:807]: Executing op: ComponentUnregister(ComponentId={D5A131F7-7AD2-411A-80C2-A350B70BC1E2},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:809]: Executing op: ComponentUnregister(ComponentId={45EFAA3F-3439-45A9-B188-FEBE15BF2EC5},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:811]: Executing op: ComponentUnregister(ComponentId={8DCDD5BC-CCAD-469C-A3EB-2749AC48CD97},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:812]: Executing op: ComponentUnregister(ComponentId={1C1E511D-D279-4B30-9052-F61B21EFDC21},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:813]: Executing op: ComponentUnregister(ComponentId={D90D95F3-6C8A-40B8-AA24-44C0E9CE0FAF},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:814]: Executing op: ComponentUnregister(ComponentId={4804CE3A-71AC-4BED-907F-00CEFFB9265F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:815]: Executing op: ComponentUnregister(ComponentId={C78ECBA3-7710-498A-A4B9-AAAE2850AFBC},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:816]: Executing op: ComponentUnregister(ComponentId={5201F320-5FED-49EB-98A6-3311ECD297D2},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:818]: Executing op: ComponentUnregister(ComponentId={1E73FB82-8B1A-4289-B1CA-B1A98C27E696},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:819]: Executing op: ComponentUnregister(ComponentId={201A50D6-CE1A-4781-9DB0-11E1E54A6879},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:821]: Executing op: ComponentUnregister(ComponentId={55B74F1E-522B-4299-B3A2-17625CFEB4AC},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:822]: Executing op: ComponentUnregister(ComponentId={43180CF0-C842-4DE3-B56B-9E18EE48754C},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:823]: Executing op: ComponentUnregister(ComponentId={E451D8B6-5B77-45EB-9BE7-D3D00FDB27E8},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:825]: Executing op: ComponentUnregister(ComponentId={F16CF952-1E97-4FCC-82E8-F7BA91DE5031},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:826]: Executing op: ComponentUnregister(ComponentId={3CAAFC13-5401-4BBE-87D0-54FB444DA321},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:827]: Executing op: ComponentUnregister(ComponentId={A841E7B3-49B2-4320-881C-783AAB853D2F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:828]: Executing op: ComponentUnregister(ComponentId={5A800F75-4DD6-4B2E-8338-296FBC46A430},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:829]: Executing op: ComponentUnregister(ComponentId={99DFC54F-1A1F-4E7A-B6BF-36B36C784F4F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:830]: Executing op: ComponentUnregister(ComponentId={1DD514EF-C790-48D1-A717-416F19CD529B},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:832]: Executing op: ComponentUnregister(ComponentId={351F2956-671B-43F1-82D5-7F02D97AE9CD},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:833]: Executing op: ComponentUnregister(ComponentId={DB8F8D92-BB7E-495B-A1B2-9FFAB40BFF19},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:834]: Executing op: ComponentUnregister(ComponentId={AC84102C-3F58-4CD0-A984-1C7FC13B362C},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:836]: Executing op: ComponentUnregister(ComponentId={44D2B41D-BA8A-4859-8F2B-EEC829B46288},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:837]: Executing op: ComponentUnregister(ComponentId={1E0E7686-5246-481F-98A5-082C33571F25},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:838]: Executing op: ComponentUnregister(ComponentId={29F85F94-B3FE-4BD3-B69C-5CACB4BDD0EA},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:840]: Executing op: ComponentUnregister(ComponentId={A4549B48-925C-4AEF-9BE9-E1E0CCD561EE},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:842]: Executing op: ComponentUnregister(ComponentId={FE7CAF48-0BFB-4813-B2B5-278CDE4CD864},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:843]: Executing op: ComponentUnregister(ComponentId={9D9092A9-7D83-4217-BB8A-615346EFC92A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:844]: Executing op: ComponentUnregister(ComponentId={E020F4EB-2142-401B-9AAB-EF9336639730},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:845]: Executing op: ComponentUnregister(ComponentId={53A574C7-2A75-4692-9A45-21855627FBCC},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:847]: Executing op: ComponentUnregister(ComponentId={F4A7C590-4AFF-4973-8517-28F51E82A526},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:848]: Executing op: ComponentUnregister(ComponentId={93577769-91BC-4377-A86A-E61543A20B40},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:849]: Executing op: ComponentUnregister(ComponentId={19402A61-E986-4822-AECD-1CC1FCDB208F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:850]: Executing op: ComponentUnregister(ComponentId={71288BE8-8B69-45DA-8566-43A78CCC2741},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:851]: Executing op: ComponentUnregister(ComponentId={9FE0C802-6841-4471-B6A1-10DC0058887C},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:852]: Executing op: ComponentUnregister(ComponentId={9948B1CE-7B23-471D-9301-182854A0C465},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:855]: Executing op: ComponentUnregister(ComponentId={03A91929-0307-4F2C-88CB-A0F437F58966},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:856]: Executing op: ComponentUnregister(ComponentId={60CAA7CE-99A8-4BFE-9DA1-D16F301E92B0},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:857]: Executing op: ComponentUnregister(ComponentId={A371EFDE-B219-4F46-AE6C-1463B864088E},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:859]: Executing op: ComponentUnregister(ComponentId={F0E7F1A9-2F62-4A4A-9865-C8457C0799B1},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:860]: Executing op: ComponentUnregister(ComponentId={57CBE549-B068-4FC8-B910-B3E4FF53F6C6},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:861]: Executing op: ComponentUnregister(ComponentId={0D90A7BA-8917-437C-8420-B85472F5175C},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:862]: Executing op: ComponentUnregister(ComponentId={F605A728-5847-43F4-B6E8-43E81058EDE2},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:864]: Executing op: ComponentUnregister(ComponentId={FFE133EE-6A27-413C-AD0E-A40DE5656751},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:865]: Executing op: ComponentUnregister(ComponentId={5CC70390-3EC5-4223-A778-F1FE8C12E133},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:866]: Executing op: ComponentUnregister(ComponentId={888E8F53-5906-4267-A5D8-E2CEE35EF619},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:867]: Executing op: ComponentUnregister(ComponentId={F1EE9586-DAA7-4D17-831D-A7369F1C1F4F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:869]: Executing op: ComponentUnregister(ComponentId={1AFE7E69-5CCF-4CF6-95A5-B469D7647AB8},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:870]: Executing op: ComponentUnregister(ComponentId={C8DAC918-5C93-4846-9B04-877E3489C0BD},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:871]: Executing op: ComponentUnregister(ComponentId={21D98A36-C6BB-4FEA-BA0B-B94A7DCBDDCB},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:873]: Executing op: ComponentUnregister(ComponentId={1BAAFD18-B7E1-4A84-92C4-0E807FD8CEF8},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:874]: Executing op: ComponentUnregister(ComponentId={0747D5FB-AAE3-4210-A278-07D543AF334B},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:875]: Executing op: ComponentUnregister(ComponentId={EEEB1FED-E73F-40FC-890B-2590CD15A192},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:876]: Executing op: ComponentUnregister(ComponentId={18FF2BF2-D2C5-4DDD-927A-19869442895F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:878]: Executing op: ComponentUnregister(ComponentId={D602267A-AC13-4015-B0AA-AF2E2DD4D8BE},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:879]: Executing op: ComponentUnregister(ComponentId={DEB9AE37-52E2-43F3-97A7-3EE5B8152E2F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:880]: Executing op: ComponentUnregister(ComponentId={09A1CC7F-7EBC-41E5-9EA1-82CF267D4C9A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:881]: Executing op: ComponentUnregister(ComponentId={7C42BC79-DE6D-40B1-BB9C-43BE0784A295},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:883]: Executing op: ComponentUnregister(ComponentId={63316C75-3CFA-4899-B514-FB4625968AB6},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:884]: Executing op: ComponentUnregister(ComponentId={F412E116-0CF4-4624-BADF-A44CBDD85C8F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:885]: Executing op: ComponentUnregister(ComponentId={F2B3176C-91A0-4007-AA88-D63C9849524D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:887]: Executing op: ComponentUnregister(ComponentId={22A476AD-8C38-4BD5-8DFD-9A590131E946},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:888]: Executing op: ComponentUnregister(ComponentId={1AD27F9F-F0BE-4E4F-BD47-B84E063A6983},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:889]: Executing op: ComponentUnregister(ComponentId={D6A96C75-5E51-4148-9F83-018DB16B81A2},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:890]: Executing op: ComponentUnregister(ComponentId={4710EB46-E9B1-44C4-94DE-04A4A6D0D8FC},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:892]: Executing op: ComponentUnregister(ComponentId={C0FE1AC1-AFB6-4BEA-8AD3-170F4264C1B4},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:893]: Executing op: ComponentUnregister(ComponentId={3161F121-1A2F-48AC-B5B8-1C1909F56816},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:894]: Executing op: ComponentUnregister(ComponentId={4EEF32D6-B415-4DBE-B8C8-CEA7526883B1},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:895]: Executing op: ComponentUnregister(ComponentId={7F87AD0B-FC09-45F6-87A3-5E47DD12E525},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:897]: Executing op: ComponentUnregister(ComponentId={34A9D4B8-E402-43FA-B57C-BDDD098C9740},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:898]: Executing op: ComponentUnregister(ComponentId={4C420888-0C1B-4344-AD74-FA70B3C9565A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:899]: Executing op: ComponentUnregister(ComponentId={4F94D1CC-8C7D-4199-B98C-1A05F23C3535},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:900]: Executing op: ComponentUnregister(ComponentId={3A6AF275-CD6F-41DC-81C0-CE310112AF4D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:901]: Executing op: ComponentUnregister(ComponentId={C229036C-E745-44DB-8996-E732AEE1E5E2},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:903]: Executing op: ComponentUnregister(ComponentId={6F08107C-F098-49B8-B8CE-25162ECAD384},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:904]: Executing op: ComponentUnregister(ComponentId={EF18D9D4-FD7D-4D6F-B028-90DB1629DDFD},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:905]: Executing op: ComponentUnregister(ComponentId={71CF204F-7327-4925-BA9F-B76BCF9EF46C},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:907]: Executing op: ComponentUnregister(ComponentId={8C1C8908-0AF7-41E4-9345-B421585CA3CB},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:908]: Executing op: ComponentUnregister(ComponentId={6B350A14-74E8-46DD-9973-35827EBCE35B},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:909]: Executing op: ComponentUnregister(ComponentId={5CCF0870-0764-47A5-A822-A054A8F7A9B6},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:910]: Executing op: ComponentUnregister(ComponentId={0EF759F5-E23B-4E7C-B87C-A15A783435EE},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:912]: Executing op: ComponentUnregister(ComponentId={CA299C09-A599-46FF-820F-60DD572789D9},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:913]: Executing op: ComponentUnregister(ComponentId={A42DFD3F-4570-4285-A348-FA96DF49C6D7},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:914]: Executing op: ComponentUnregister(ComponentId={1BDCF79A-99FC-49D2-B99D-1648EA7EE93E},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:915]: Executing op: ComponentUnregister(ComponentId={3F610D8A-7003-4520-B977-0FDD88A48397},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:916]: Executing op: ComponentUnregister(ComponentId={3F429910-740D-400F-BD5A-9010F874AE6A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:917]: Executing op: ComponentUnregister(ComponentId={EC3720E9-5725-4FBA-B185-73FB410074FC},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:918]: Executing op: ComponentUnregister(ComponentId={9691EE64-6D49-400A-85DE-019F69712B7F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:920]: Executing op: ComponentUnregister(ComponentId={B452E093-40B3-4A50-B291-65073A301817},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:921]: Executing op: ComponentUnregister(ComponentId={C688229F-45A0-4026-95BF-B46274BFA120},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:922]: Executing op: ComponentUnregister(ComponentId={746439C0-2591-4838-A734-04AA0C5C0676},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:924]: Executing op: ComponentUnregister(ComponentId={F429F4D5-AAC9-450D-A915-650896528FB2},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:925]: Executing op: ComponentUnregister(ComponentId={C5907CAC-DFA5-448C-B65F-3B354CFAAB85},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:926]: Executing op: ComponentUnregister(ComponentId={5D5611C8-3B7E-4DBD-A1A6-4E60723464F8},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:927]: Executing op: ComponentUnregister(ComponentId={382D383C-984F-43CE-AC59-1A63F2371EF4},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:929]: Executing op: ComponentUnregister(ComponentId={76E23619-EC21-4CAF-B69B-180C0BA70881},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:930]: Executing op: ComponentUnregister(ComponentId={939D4E79-779C-4E37-9592-03D5B8F07C5B},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:931]: Executing op: ComponentUnregister(ComponentId={E7774280-3E32-4986-89AA-BAC866FA903F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:932]: Executing op: ComponentUnregister(ComponentId={1FAFD273-9CA3-4C1E-8AE5-35D286E85F13},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:934]: Executing op: ComponentUnregister(ComponentId={B8B41A1F-315D-4D52-8968-249C21145811},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:935]: Executing op: ComponentUnregister(ComponentId={7628415C-8399-477F-AECD-7DC2B4F31383},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:936]: Executing op: ComponentUnregister(ComponentId={2750899B-3AA5-4983-B243-7CEA95728938},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:937]: Executing op: ComponentUnregister(ComponentId={76DBDF22-77D4-441E-A236-0389EAC4ED33},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:939]: Executing op: ComponentUnregister(ComponentId={3E081AE4-07BA-4264-AD3E-02D19996D0FA},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:940]: Executing op: ComponentUnregister(ComponentId={63D67883-8985-49CE-B5BE-5CB8DAB8846F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:941]: Executing op: ComponentUnregister(ComponentId={6BBFE547-F9C9-4318-BE3B-08CA62E73520},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:943]: Executing op: ComponentUnregister(ComponentId={62958C29-895D-4BB2-A793-58371E47B6D6},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:944]: Executing op: ComponentUnregister(ComponentId={8DA57C93-CE08-416E-BC18-C8C7D7749393},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:945]: Executing op: ComponentUnregister(ComponentId={D7261197-8082-4923-8474-82C417E960C2},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:946]: Executing op: ComponentUnregister(ComponentId={B16586E8-D92A-40F9-A0AE-5C4B10ABE075},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:948]: Executing op: ComponentUnregister(ComponentId={6E0FEF02-950A-41B7-94AE-451572166AD7},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:949]: Executing op: ComponentUnregister(ComponentId={F6F141AA-A669-4066-9C83-21D7689EBE6A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:950]: Executing op: ComponentUnregister(ComponentId={8545E0A4-BB05-44FE-A9BD-4AAFA477BDE0},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:951]: Executing op: ComponentUnregister(ComponentId={8635C764-B0A0-4D63-8261-47E3B3482784},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:953]: Executing op: ComponentUnregister(ComponentId={BA31B288-1274-44CC-A8F2-2012AEE91B9D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:954]: Executing op: ComponentUnregister(ComponentId={F67FA0FB-48D5-44EA-8600-F80B0A269642},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:955]: Executing op: ComponentUnregister(ComponentId={CC49BAAD-BB40-45C2-BA41-9C43425A1984},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:957]: Executing op: ComponentUnregister(ComponentId={499F0A05-4418-448F-969F-ECB6564429C5},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:958]: Executing op: ComponentUnregister(ComponentId={6B20C6D4-2261-4E91-A975-99915A32FDE0},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:959]: Executing op: ComponentUnregister(ComponentId={54403F9B-6631-44D4-A90B-EE10A26D6486},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:961]: Executing op: ComponentUnregister(ComponentId={454406F9-8F53-4593-BB1A-FEB7090B2749},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:962]: Executing op: ComponentUnregister(ComponentId={829089E7-B027-4DA8-BE0C-C5B003462BA8},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:963]: Executing op: ComponentUnregister(ComponentId={464070B7-AA1B-4B7D-AC93-3CB0B38A9D5A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:964]: Executing op: ComponentUnregister(ComponentId={8547428B-D1D9-44B8-B3AE-EE1A5064E54B},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:966]: Executing op: ComponentUnregister(ComponentId={41A4D699-EFED-4DF4-8158-E09FBCF1023F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:967]: Executing op: ComponentUnregister(ComponentId={62B71CA7-31C7-4466-89D1-97A9F071162C},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:968]: Executing op: ComponentUnregister(ComponentId={76A513D9-83A0-4024-AF83-BAFA3FCE00F7},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:969]: Executing op: ComponentUnregister(ComponentId={8674B507-54FB-44FB-8E6B-D29A6DDD396D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:971]: Executing op: ComponentUnregister(ComponentId={926FA588-2222-4115-82DB-EBD5CDA46456},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:972]: Executing op: ComponentUnregister(ComponentId={B1ED02E5-D286-4235-B250-5DE078D98563},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:973]: Executing op: ComponentUnregister(ComponentId={E5C9503B-09BE-42AF-AB83-D233343A9B1E},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:975]: Executing op: ComponentUnregister(ComponentId={98D4BDAB-025D-476B-B365-5BE5531E6459},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:976]: Executing op: ComponentUnregister(ComponentId={382EECAC-E633-4EE2-BB86-042BAF9B789E},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:977]: Executing op: ComponentUnregister(ComponentId={AC1C4DC6-424D-4748-A9D8-E33CF5D7E9AB},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:979]: Executing op: ComponentUnregister(ComponentId={42C10D5A-BFDC-478E-B580-C7918717BDAB},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:980]: Executing op: ComponentUnregister(ComponentId={4F33F4BA-7E87-46D7-80F6-3E2A06F8CA25},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:981]: Executing op: ComponentUnregister(ComponentId={12B4726D-3310-4F9F-9DCA-42EE875B6C24},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:983]: Executing op: ComponentUnregister(ComponentId={2237134C-5612-41D9-9BCE-D1D834E8B9BD},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:984]: Executing op: ComponentUnregister(ComponentId={75081D43-75CE-487A-9120-AA09EA23BFEA},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:985]: Executing op: ComponentUnregister(ComponentId={1770468C-8AC2-471D-8D5D-7FA40B0F05D6},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:987]: Executing op: ComponentUnregister(ComponentId={5E733333-C696-49BA-880D-E44156688920},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:988]: Executing op: ComponentUnregister(ComponentId={BC7971AA-7DED-4183-937E-3343B0041FCA},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:989]: Executing op: ComponentUnregister(ComponentId={9FFDCA30-26A1-46BD-BE6D-C22BCEF549DB},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:991]: Executing op: ComponentUnregister(ComponentId={E5F2B17A-D01C-4407-8428-33ADC0265F6F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:992]: Executing op: ComponentUnregister(ComponentId={38E9E59E-9C20-4A5F-88C2-54DCF8F62566},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:993]: Executing op: ComponentUnregister(ComponentId={2F915D73-B473-49EC-9D6E-54CC4DDAB85F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:995]: Executing op: ComponentUnregister(ComponentId={0208E7FD-64E1-4655-852C-E5D5C6D6CF7E},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:996]: Executing op: ComponentUnregister(ComponentId={C14EA385-D6C7-4573-B717-89F9B397EDE7},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:997]: Executing op: ComponentUnregister(ComponentId={DEF931DC-8C9C-4784-94DC-A678FCC47E36},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:01:999]: Executing op: ComponentUnregister(ComponentId={65351965-7066-43E6-B951-C5E7CBCC75F7},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:000]: Executing op: ComponentUnregister(ComponentId={B20E5C63-85A9-4117-9864-8940CA0CFF48},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:001]: Executing op: ComponentUnregister(ComponentId={F1441B42-8FEF-4959-BA95-873DE42E794A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:003]: Executing op: ComponentUnregister(ComponentId={5E9E9637-7B9D-4E02-BFAC-A8D5DAE0F8A2},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:004]: Executing op: ComponentUnregister(ComponentId={6CC5CEC3-7ADC-4297-8A26-9E1FF4FAE4D1},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:006]: Executing op: ComponentUnregister(ComponentId={0D958F65-A548-4A6E-B3E1-E79B3655B9FF},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:007]: Executing op: ComponentUnregister(ComponentId={C6595839-4C1E-4F68-BE0C-D9A9A5B51FFF},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:008]: Executing op: ComponentUnregister(ComponentId={A9D63524-35F7-474C-A035-FFC55B12923F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:009]: Executing op: ComponentUnregister(ComponentId={D1F62371-ECA0-4601-8CB6-6429D944024B},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:011]: Executing op: ComponentUnregister(ComponentId={56855FFA-1C24-4696-8A6A-D2EE235F95D5},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:012]: Executing op: ComponentUnregister(ComponentId={BF18A617-CAA3-428B-B046-85E178EC9D23},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:013]: Executing op: ComponentUnregister(ComponentId={2808B550-1E18-4F4A-8F41-0BEC07AD0D20},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:014]: Executing op: ComponentUnregister(ComponentId={9C043D23-0359-4702-AC8B-75204E2E68D5},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:016]: Executing op: ComponentUnregister(ComponentId={38C6A5D5-B1FA-4B2A-857D-47BD4343CDEF},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:017]: Executing op: ComponentUnregister(ComponentId={33D3CB27-287A-48E6-B659-6FDD69FDD481},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:018]: Executing op: ComponentUnregister(ComponentId={E23DC0EF-B13E-46EB-9C31-B2C3C2188C2F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:019]: Executing op: ComponentUnregister(ComponentId={566648CC-9C71-4443-BB80-76FA6950E5A6},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:021]: Executing op: ComponentUnregister(ComponentId={80ACE0B7-259C-41E3-88CD-F92FF19FB893},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:022]: Executing op: ComponentUnregister(ComponentId={6CC73FC9-8179-4C3B-9DA4-4D99E38984E0},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:024]: Executing op: ComponentUnregister(ComponentId={D1EC52D4-25A6-439D-B087-70969DCA9F59},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:025]: Executing op: ComponentUnregister(ComponentId={E8C31B56-1F18-4B5E-A2EE-81108491C09A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:026]: Executing op: ComponentUnregister(ComponentId={0A8E07FC-6072-4704-BD93-7D58A23076D0},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:027]: Executing op: ComponentUnregister(ComponentId={FD05E74F-371E-44B8-A11D-9FC8B2296BEE},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:029]: Executing op: ComponentUnregister(ComponentId={C5190242-F226-48FE-8EA2-C12415F2D49F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:030]: Executing op: ComponentUnregister(ComponentId={AA47C99C-9FF0-4183-B0B0-BAEC20679815},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:031]: Executing op: ComponentUnregister(ComponentId={2EC70844-200C-48C3-BAAF-F371BEC70E44},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:032]: Executing op: ComponentUnregister(ComponentId={C42D423C-BCAD-43CA-BE57-65FECACBB7CF},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:034]: Executing op: ComponentUnregister(ComponentId={151DBB4B-B5D3-42AD-9681-02C612CF4E3C},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:035]: Executing op: ComponentUnregister(ComponentId={FD18B2F9-2353-448F-8B56-0718AE908171},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:036]: Executing op: ComponentUnregister(ComponentId={4A30BEF3-7817-47E8-A9A1-9B78D6A668A0},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:038]: Executing op: ComponentUnregister(ComponentId={CC41AC38-6DAE-420D-BBDC-9AA383153E7B},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:039]: Executing op: ComponentUnregister(ComponentId={4ECD32AE-D67A-41A6-9AE3-4337E641907D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:040]: Executing op: ComponentUnregister(ComponentId={A166C9D0-6170-4AB6-9014-D668FD58540D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:041]: Executing op: ComponentUnregister(ComponentId={2C740AD6-7DE9-43F4-9209-F9660749C885},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:043]: Executing op: ComponentUnregister(ComponentId={0968D84A-C7DB-4E36-B9EA-019E2AAC0E0C},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:044]: Executing op: ComponentUnregister(ComponentId={E93778C6-98A3-4AC1-BAE1-2F6345F23C34},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:045]: Executing op: ComponentUnregister(ComponentId={51A00342-FE0C-4E3A-ABBC-87A1F8BB4E89},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:046]: Executing op: ComponentUnregister(ComponentId={4DD3D0D3-E85E-4652-ACA3-9DCAF226131B},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:048]: Executing op: ComponentUnregister(ComponentId={944A21BE-CF2C-447E-A6D6-3482AFB29341},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:049]: Executing op: ComponentUnregister(ComponentId={62A2F9D7-168A-407F-A886-4E3897D24B26},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:050]: Executing op: ComponentUnregister(ComponentId={9F830D4C-C518-4D08-B247-A608F7DCD06D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:051]: Executing op: ComponentUnregister(ComponentId={E7645E06-A844-4BF8-ADE7-56AC298970C7},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:053]: Executing op: ComponentUnregister(ComponentId={DF400699-DF0C-470E-B4EC-D4DBB0E7B4D0},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:054]: Executing op: ComponentUnregister(ComponentId={C7A59EF4-16F6-444A-996E-E371FC7F3680},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:055]: Executing op: ComponentUnregister(ComponentId={E7B7CB6E-FA16-418C-BD94-62D59781573F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:057]: Executing op: ComponentUnregister(ComponentId={ADCBB25F-FDED-4909-ACEE-D179A9ACBC0B},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:058]: Executing op: ComponentUnregister(ComponentId={A3BBF6AD-D985-4111-BEC2-844049E7B0CB},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:059]: Executing op: ComponentUnregister(ComponentId={22CC55AA-B047-4C88-8BF6-A6C3DD747FBE},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:060]: Executing op: ComponentUnregister(ComponentId={F4DAA88C-C02A-412E-8DB8-74F4F9AAC639},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:062]: Executing op: ComponentUnregister(ComponentId={80775919-072F-4E3A-9A70-990B288E7B9C},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:063]: Executing op: ComponentUnregister(ComponentId={49A6DD57-70CA-4CE1-B2E7-C10108C20FCF},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:064]: Executing op: ComponentUnregister(ComponentId={465A4419-873C-4954-B8B7-641740C5788F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:065]: Executing op: ComponentUnregister(ComponentId={8107C097-66FA-4F51-89DC-9E169F0E8D98},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:067]: Executing op: ComponentUnregister(ComponentId={7A4B9DEB-22F3-46C0-AB46-61F774342018},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:068]: Executing op: ComponentUnregister(ComponentId={2B59E025-4D5D-4BF6-BC3B-E45B223CC600},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:069]: Executing op: ComponentUnregister(ComponentId={40BB3F78-FAD9-4A9C-ACEC-F4105EA5FBF8},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:071]: Executing op: ComponentUnregister(ComponentId={824CEE24-E71F-4952-90B1-95C8576530BE},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:072]: Executing op: ComponentUnregister(ComponentId={8EB062AA-81CD-411E-A0C3-C4C79C599F69},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:073]: Executing op: ComponentUnregister(ComponentId={2BD2EA6B-C78C-4D90-9F40-26421A1A986B},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:075]: Executing op: ComponentUnregister(ComponentId={EE6B0559-FF1B-492F-AC39-8105FCDAA567},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:076]: Executing op: ComponentUnregister(ComponentId={B76492D4-1E1F-4CA1-97AD-D2C3B4A49BA0},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:077]: Executing op: ComponentUnregister(ComponentId={9C163C2B-5E25-4AA8-AD7F-3C2FC6822629},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:078]: Executing op: ComponentUnregister(ComponentId={D5444998-9150-4EE6-81EB-AC27C24EE7F3},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:079]: Executing op: ComponentUnregister(ComponentId={48B9D78B-D9CA-4721-814F-AFABD8A1B6C9},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:081]: Executing op: ComponentUnregister(ComponentId={339B6D52-EDCD-4B4C-912F-349B7A829F16},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:082]: Executing op: ComponentUnregister(ComponentId={2A78446B-E474-4AE5-A912-303573C6F128},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:083]: Executing op: ComponentUnregister(ComponentId={5FFEE53B-4C8A-45C8-8F3F-FA5ED702520A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:084]: Executing op: ComponentUnregister(ComponentId={EAE83FEE-5462-4581-85EA-5F7FCD18B575},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:086]: Executing op: ComponentUnregister(ComponentId={F5AE5EFB-5071-413E-910E-3DF6A9E20AA8},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:087]: Executing op: ComponentUnregister(ComponentId={A2C45796-510A-4913-8F5F-384D560F0503},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:089]: Executing op: ComponentUnregister(ComponentId={A24E82DE-9BBF-46F0-8156-7D9C4FDA5293},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:090]: Executing op: ComponentUnregister(ComponentId={A572318F-58C0-4415-885A-7CB9AECE0496},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:091]: Executing op: ComponentUnregister(ComponentId={73877CEC-1E21-40AF-B48C-D692D55EE194},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:092]: Executing op: ComponentUnregister(ComponentId={CFD02EE9-C83B-4314-98B8-5615EE086BF5},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:093]: Executing op: ComponentUnregister(ComponentId={0828D639-6ACE-4A91-824D-BC966210CB70},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:095]: Executing op: ComponentUnregister(ComponentId={A00E1075-AC97-4D2A-81F1-CF1347FE64E3},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:096]: Executing op: ComponentUnregister(ComponentId={DADFB0B1-30E5-47B1-8FDB-3B27BAF5C243},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:097]: Executing op: ComponentUnregister(ComponentId={6E0061F7-80B1-4B4F-8899-CAAA4452C4D9},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:098]: Executing op: ComponentUnregister(ComponentId={4768A9EE-C2C1-4CAE-9DFC-EE5F1E121163},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:100]: Executing op: ComponentUnregister(ComponentId={0CA33500-C515-4068-BE9B-D2198DC433C1},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:101]: Executing op: ComponentUnregister(ComponentId={4E139051-8C1D-43E5-89D7-92F81BF79F45},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:102]: Executing op: ComponentUnregister(ComponentId={02DBFD62-0675-4CFF-8275-E889F0E14252},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:103]: Executing op: ComponentUnregister(ComponentId={C60E27FB-E35D-4612-AD7B-E7B77F334FAB},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:105]: Executing op: ComponentUnregister(ComponentId={7922F958-4AA2-413C-9077-CF5F5CF47A3A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:106]: Executing op: ComponentUnregister(ComponentId={16C81420-2193-4857-855D-2CD87AFD5AAD},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:107]: Executing op: ComponentUnregister(ComponentId={7F60ABAF-C4D5-4457-8ACA-8BC66933CB0C},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:108]: Executing op: ComponentUnregister(ComponentId={75F385AC-6BEF-4434-AFBC-418A9164E8A1},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:110]: Executing op: ComponentUnregister(ComponentId={A77C76C7-185B-477F-90D5-29941B3747D8},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:111]: Executing op: ComponentUnregister(ComponentId={68847917-9251-4E1B-BC77-011D73FF1AAA},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:112]: Executing op: ComponentUnregister(ComponentId={76E73360-D3B8-48CA-B7D8-223B66370D0E},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:113]: Executing op: ComponentUnregister(ComponentId={02207C0D-BBF1-4A77-88BA-1A0F6316D464},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:115]: Executing op: ComponentUnregister(ComponentId={27426C22-050F-4284-A45F-0300AEBC9B42},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:116]: Executing op: ComponentUnregister(ComponentId={8B9C1562-EDCF-44BB-A714-DADF40EEA50B},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:117]: Executing op: ComponentUnregister(ComponentId={D4D3B064-DC1A-4F88-8E82-8C8D147C023A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:118]: Executing op: ComponentUnregister(ComponentId={D37BED57-7A21-457B-93CD-06473B23F8D9},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:120]: Executing op: ComponentUnregister(ComponentId={E90A9406-A840-4000-8B0A-6476BD778B23},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:121]: Executing op: ComponentUnregister(ComponentId={B0941684-4E06-4999-B9F4-BEFB0FDEF4C5},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:122]: Executing op: ComponentUnregister(ComponentId={71E1A8DF-434C-4FB8-B424-1695474290F6},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:124]: Executing op: ComponentUnregister(ComponentId={43B251EA-72B5-4DC1-AE46-1A999131E224},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:125]: Executing op: ComponentUnregister(ComponentId={801D4513-563D-4E54-88EE-74F106601B52},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:126]: Executing op: ComponentUnregister(ComponentId={37C9AEE0-C4AE-477F-9F3C-9D473D2F6DCC},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:127]: Executing op: ComponentUnregister(ComponentId={FAFE64ED-B927-433B-89BE-608CAA9556F3},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:129]: Executing op: ComponentUnregister(ComponentId={AEAE7586-50F5-4AD7-90E0-2B7AFEA8710D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:130]: Executing op: ComponentUnregister(ComponentId={A9244442-1615-498F-AACA-41DF048BA807},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:131]: Executing op: ComponentUnregister(ComponentId={5A55AC3C-AE94-42C0-93A9-6F0BE4179222},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:132]: Executing op: ComponentUnregister(ComponentId={09C440BC-FF40-41E7-84ED-F6532FB5A258},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:133]: Executing op: ComponentUnregister(ComponentId={4B62BCE1-182E-4639-A1DB-376D31FB7285},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:135]: Executing op: ComponentUnregister(ComponentId={CF0B25FE-DFCD-4577-B7A3-0E4C50ACA488},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:136]: Executing op: ComponentUnregister(ComponentId={B6E22E80-7AFC-44BC-B524-64455FA8F909},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:138]: Executing op: ComponentUnregister(ComponentId={7735B5D8-FBD2-4103-86CC-3B8084A4E313},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:139]: Executing op: ComponentUnregister(ComponentId={8513061B-D733-4474-93C0-03AE5975EC25},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:140]: Executing op: ComponentUnregister(ComponentId={8147004D-BC75-4419-B433-BD9E40BBA1FA},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:141]: Executing op: ComponentUnregister(ComponentId={9DC9992B-C6CE-448E-8024-7BF7CB146FF5},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:143]: Executing op: ComponentUnregister(ComponentId={ABF456D2-26E5-43D0-B5EC-6FEB04962D54},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:144]: Executing op: ComponentUnregister(ComponentId={EEDF6DE2-B637-4162-94B5-632712144405},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:145]: Executing op: ComponentUnregister(ComponentId={7314F8B9-248C-4C20-9D08-0FCBBCD056F2},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:146]: Executing op: ComponentUnregister(ComponentId={64B941CE-9422-4A19-B2D2-16AC40BF238F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:148]: Executing op: ComponentUnregister(ComponentId={774CC51A-6B41-47B3-9543-81A081FDEA03},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:149]: Executing op: ComponentUnregister(ComponentId={C01243F9-6C06-41E3-8F19-C5D945F1D0C3},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:150]: Executing op: ComponentUnregister(ComponentId={AD1FC3D0-A21D-4823-BC44-34FDDC2428EB},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:151]: Executing op: ComponentUnregister(ComponentId={8214FBC2-5C5B-43D0-8494-966384F1D142},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:153]: Executing op: ComponentUnregister(ComponentId={EAD1891B-CBFA-47CC-9614-BF33291AE9C0},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:154]: Executing op: ComponentUnregister(ComponentId={613BB469-D2CB-45A3-9FD8-552E14DE490E},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:156]: Executing op: ComponentUnregister(ComponentId={C36764CA-D80D-44B5-8E1B-1858DE5C9BA7},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:157]: Executing op: ComponentUnregister(ComponentId={672C40CB-AB8C-44B0-853B-4F00E7199AB7},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:158]: Executing op: ComponentUnregister(ComponentId={34C60D8F-0922-4A05-A385-B97CF255E11E},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:159]: Executing op: ComponentUnregister(ComponentId={1CFD0788-2620-4E9C-89D8-C41CDA28897F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:160]: Executing op: ComponentUnregister(ComponentId={1B684469-773B-4DD2-8BE0-1BE7B1E5ACE0},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:162]: Executing op: ComponentUnregister(ComponentId={D713E9E6-397F-4C3D-A187-5BE08911759B},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:163]: Executing op: ComponentUnregister(ComponentId={C1867933-BFBD-4B7C-AFA3-7814870B5F11},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:164]: Executing op: ComponentUnregister(ComponentId={E3AF26C5-C40D-450B-8370-DFD8DEFC7F7D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:165]: Executing op: ComponentUnregister(ComponentId={91E5725F-6A80-4C02-98B3-B99360934103},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:166]: Executing op: ComponentUnregister(ComponentId={659284BF-2641-461E-A8B5-C4EBD17A33A7},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:168]: Executing op: ComponentUnregister(ComponentId={0C759B7F-8DB8-4AE2-BC0C-B90FEB1273CD},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:169]: Executing op: ComponentUnregister(ComponentId={3644A333-0414-469E-BFD2-22586ADCC85A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:170]: Executing op: ComponentUnregister(ComponentId={B2825417-A0B7-44F2-ABAB-DAE056BC3136},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:172]: Executing op: ComponentUnregister(ComponentId={DB1B3AD0-DD9F-41DE-8CBF-0CB9F50D6661},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:173]: Executing op: ComponentUnregister(ComponentId={1769CC49-2934-4DA7-8C92-6ECE83704949},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:174]: Executing op: ComponentUnregister(ComponentId={8516D1D5-18CC-4BA4-817D-12A4420A96E2},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:176]: Executing op: ComponentUnregister(ComponentId={62EEF28E-DE57-475E-A8F8-1E2B8ECC3BA3},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:177]: Executing op: ComponentUnregister(ComponentId={D62CE6C1-DF16-4091-A1C0-3F1AAC94FCA1},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:178]: Executing op: ComponentUnregister(ComponentId={2610F5D7-9925-451E-BC13-1934AC02C9A1},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:179]: Executing op: ComponentUnregister(ComponentId={D74BBD64-67E5-4A65-B904-9B47235915A1},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:181]: Executing op: ComponentUnregister(ComponentId={D0795ABD-7A32-47B0-8ADF-98CF5C136CC5},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:182]: Executing op: ComponentUnregister(ComponentId={23082EFA-ED31-4CB1-A596-015EE1BBB57E},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:183]: Executing op: ComponentUnregister(ComponentId={27017601-B92D-4FDA-82CD-F21EC5B20A9E},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:184]: Executing op: ComponentUnregister(ComponentId={3EF43A42-7BE6-4C25-9C88-5128B084763E},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:186]: Executing op: ComponentUnregister(ComponentId={DC15304B-4B36-4113-A53E-CA1D8A8B4532},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:187]: Executing op: ComponentUnregister(ComponentId={B8DCA9BD-9163-4A51-B438-1866EF021F6B},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:188]: Executing op: ComponentUnregister(ComponentId={1EB720E0-57A1-4EAA-8C68-AE50A55C7CC1},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:190]: Executing op: ComponentUnregister(ComponentId={CA728C13-4036-4190-8CE4-4791F2ABC394},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:191]: Executing op: ComponentUnregister(ComponentId={6FE54118-A8AA-4519-87EC-B1B0C41173E2},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:192]: Executing op: ComponentUnregister(ComponentId={4CE6C98E-B376-4734-81A1-D57C9D7BEF4D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:193]: Executing op: ComponentUnregister(ComponentId={C8EC7BF4-588A-4818-93B8-916CF74B7D1D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:194]: Executing op: ComponentUnregister(ComponentId={9710AEE2-C789-4C85-BFD8-A4F2DB015726},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:196]: Executing op: ComponentUnregister(ComponentId={2C9C4B79-6583-42E0-8759-826119FB816A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:197]: Executing op: ComponentUnregister(ComponentId={D664F334-D501-402C-9C16-B10493EC087E},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:198]: Executing op: ComponentUnregister(ComponentId={1BA8C0A7-BF7A-48F5-8669-0909B9EA8D3B},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:199]: Executing op: ComponentUnregister(ComponentId={8B34CD89-2B94-46CB-889C-5FF739644D2B},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:200]: Executing op: ComponentUnregister(ComponentId={74222ECB-082C-4A57-8B21-4C92EFA24BF5},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:202]: Executing op: ComponentUnregister(ComponentId={DBDDFA57-EBA9-4E98-836D-7823CB40451C},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:203]: Executing op: ComponentUnregister(ComponentId={7E559C72-0345-41C7-94FD-3D54A9D30174},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:204]: Executing op: ComponentUnregister(ComponentId={F5E4F01E-F246-4645-B503-04B3E2350035},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:206]: Executing op: ComponentUnregister(ComponentId={66B977A9-4C49-498D-BD41-CCB05244DCF7},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:207]: Executing op: ComponentUnregister(ComponentId={1364079D-0D6C-43AD-8173-F38C2E4D5639},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:208]: Executing op: ComponentUnregister(ComponentId={A6C16AA2-3014-4A96-BC69-4023776ADC74},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:209]: Executing op: ComponentUnregister(ComponentId={5F058F9E-75E7-4782-84AC-99A65B12BC07},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:211]: Executing op: ComponentUnregister(ComponentId={EE4A5502-FE6A-4E6E-8A24-C5E2E0507206},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:212]: Executing op: ComponentUnregister(ComponentId={65D6D893-23B9-4C8D-A9B7-F90B0094C10A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:213]: Executing op: ComponentUnregister(ComponentId={8D678D55-C155-4BA5-9152-075F08C437BB},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:215]: Executing op: ComponentUnregister(ComponentId={2685F7BB-5122-43AF-89E6-96B271D221F6},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:216]: Executing op: ComponentUnregister(ComponentId={2F96279E-2718-4AF2-8F5D-781B4AEC96FE},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:217]: Executing op: ComponentUnregister(ComponentId={DD6AEB6D-BC6B-410A-A733-08D6B79D2C4B},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:218]: Executing op: ComponentUnregister(ComponentId={2C6D8866-0565-4787-B4B8-7F67F87883A9},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:220]: Executing op: ComponentUnregister(ComponentId={D6705DC9-5691-4609-8250-4EC2B47724EE},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:221]: Executing op: ComponentUnregister(ComponentId={2455E685-1357-420E-871E-7B689B6A5784},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:222]: Executing op: ComponentUnregister(ComponentId={BB22ADB7-E934-43B2-9D57-B525C7518C72},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:224]: Executing op: ComponentUnregister(ComponentId={54131D0C-BA20-4E5D-89C6-BE0272BDDE8F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:225]: Executing op: ComponentUnregister(ComponentId={953D3D06-573F-40F9-8B9A-D3D5E7EFC5C3},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:226]: Executing op: ComponentUnregister(ComponentId={804384D3-AB9B-4A77-8BB5-880A87D44DE8},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:227]: Executing op: ComponentUnregister(ComponentId={A67F2C94-3889-4E9F-B880-B0C32BC93C1E},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:229]: Executing op: ComponentUnregister(ComponentId={A5613B82-635E-41AE-AA81-799308F3BA76},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:230]: Executing op: ComponentUnregister(ComponentId={2C8EA69C-E33B-4152-9928-869C88F1AEE4},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:231]: Executing op: ComponentUnregister(ComponentId={F8FB3DEA-014B-4D4A-A40D-541C62872C1A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:232]: Executing op: ComponentUnregister(ComponentId={436A0530-DA15-4A34-AF17-A36FD7D6A14A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:234]: Executing op: ComponentUnregister(ComponentId={A739465C-67AF-470F-BCAC-C58A5D52CE8F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:235]: Executing op: ComponentUnregister(ComponentId={274CFC39-40E5-4084-9A19-9A8E962DF9C4},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:236]: Executing op: ComponentUnregister(ComponentId={3DF82B52-D250-4710-8262-BCD7EF964C06},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:238]: Executing op: ComponentUnregister(ComponentId={DF8ECD03-5B73-4A89-BDAC-2326177ABEE5},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:239]: Executing op: ComponentUnregister(ComponentId={39FA32D3-21FE-467F-97C3-2A51F37BEFEC},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:240]: Executing op: ComponentUnregister(ComponentId={026B9C14-DFEA-43FA-975A-8921AF939C28},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:242]: Executing op: ComponentUnregister(ComponentId={0D0F1106-9F89-4FAD-808F-985CC76D22D1},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:243]: Executing op: ComponentUnregister(ComponentId={BFE993AF-D86C-4C46-965B-7472E4C31779},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:244]: Executing op: ComponentUnregister(ComponentId={7C31E154-5CA4-4A30-A749-DF4713BE4E76},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:246]: Executing op: ComponentUnregister(ComponentId={06FCDD04-43FE-4ECC-A207-59CFA7EEF6FA},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:247]: Executing op: ComponentUnregister(ComponentId={0CA2A201-0303-4EEF-9C61-035266AA27B5},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:248]: Executing op: ComponentUnregister(ComponentId={A502884D-C9C7-444E-B532-CB8353058B0D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:249]: Executing op: ComponentUnregister(ComponentId={35BC06DB-B66D-498C-A6AD-B2C70ED402CB},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:251]: Executing op: ComponentUnregister(ComponentId={F07D8EDE-2C3A-4B1D-AF8D-E70AED80ACBD},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:252]: Executing op: ComponentUnregister(ComponentId={A092C594-93B4-49CB-A8C3-8BEF312BD2B7},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:253]: Executing op: ComponentUnregister(ComponentId={CBD6B2B9-F158-44A0-948A-8349F228B668},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:255]: Executing op: ComponentUnregister(ComponentId={CCAC269F-1F52-45DF-9336-563548B96237},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:256]: Executing op: ComponentUnregister(ComponentId={3EE17714-EFCA-420A-858A-8C5B4454F3CF},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:257]: Executing op: ComponentUnregister(ComponentId={18B6C686-9C83-454B-8FD9-305D7FA49250},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:259]: Executing op: ComponentUnregister(ComponentId={D3F5B478-29DB-4B6A-93CA-A1659CFD4464},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:260]: Executing op: ComponentUnregister(ComponentId={43CA2CAA-AC37-421A-9091-70A075B232E1},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:261]: Executing op: ComponentUnregister(ComponentId={B5D649B0-E7F6-4BC2-8775-FBA960DE1E35},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:262]: Executing op: ComponentUnregister(ComponentId={BA42F6FD-928D-4430-AD57-43FEA136D08D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:263]: Executing op: ComponentUnregister(ComponentId={CED1A160-443A-4C6D-B06C-DAE2C89160D3},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:265]: Executing op: ComponentUnregister(ComponentId={9D194141-4E4A-4E2D-B24A-7F5A06DA7044},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:266]: Executing op: ComponentUnregister(ComponentId={B1EF9154-18A6-45D9-B8E3-D70942E02D9A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:267]: Executing op: ComponentUnregister(ComponentId={5786FF3E-95AD-4D7F-8072-AB919C73F1EC},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:268]: Executing op: ComponentUnregister(ComponentId={DB68D579-B306-47B4-8D44-D3C1F60E989C},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:270]: Executing op: ComponentUnregister(ComponentId={01C107C7-36ED-4EAC-BDA2-5D3F975C7C52},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:271]: Executing op: ComponentUnregister(ComponentId={C67D2F7F-349D-49F7-8278-7FBE3EE8B65F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:273]: Executing op: ComponentUnregister(ComponentId={8F0AB6D9-52B3-4106-B518-BD4E55BE88B9},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:274]: Executing op: ComponentUnregister(ComponentId={A64550AF-C08B-4E25-94E2-E6CB0FF22C93},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:275]: Executing op: ComponentUnregister(ComponentId={0D4D5B81-9A21-4C6D-883C-A7A4F8F3620B},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:276]: Executing op: ComponentUnregister(ComponentId={81B1D1C1-9028-41A0-A2CA-C6252C6DCDB5},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:278]: Executing op: ComponentUnregister(ComponentId={9890E715-53D5-4B34-949C-E3C68ABA407C},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:279]: Executing op: ComponentUnregister(ComponentId={CF9C7BAB-F934-4249-9F99-6A55E9C2C888},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:280]: Executing op: ComponentUnregister(ComponentId={3D0F693A-4480-47D5-AAF1-65002E91153D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:282]: Executing op: ComponentUnregister(ComponentId={EA5028A1-6B68-413E-A637-8EDA9C9DBC61},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:283]: Executing op: ComponentUnregister(ComponentId={FC223C36-77CF-4FA3-AF53-0359D2CA187D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:284]: Executing op: ComponentUnregister(ComponentId={97975334-52C8-4A8C-8A6E-BD203D67AB23},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:285]: Executing op: ComponentUnregister(ComponentId={891F2BCE-324F-4535-8BC4-3EF7646FC68F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:287]: Executing op: ComponentUnregister(ComponentId={8DA12DF7-D0F8-4AD4-8C87-F1EDC636F44E},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:288]: Executing op: ComponentUnregister(ComponentId={81335983-F5E0-41F3-9843-11482AC06C95},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:289]: Executing op: ComponentUnregister(ComponentId={0DE81556-F29B-43F0-9ECE-707CD0B1510C},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:291]: Executing op: ComponentUnregister(ComponentId={70A16220-64A4-46A2-A787-001F45FE1483},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:292]: Executing op: ComponentUnregister(ComponentId={114D0B89-135F-4422-A1FF-BD3DD33B3A45},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:293]: Executing op: ComponentUnregister(ComponentId={AC982D11-D86E-4DEE-81F3-7D863F3FCE2E},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:294]: Executing op: ComponentUnregister(ComponentId={4F37288D-92E4-4B58-BB18-74D493A069F7},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:296]: Executing op: ComponentUnregister(ComponentId={ED1CD660-6A69-48D3-B5E0-EA57187C4F60},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:297]: Executing op: ComponentUnregister(ComponentId={0EEA3B5C-CF40-45F6-B516-F3B871FDC5BC},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:298]: Executing op: ComponentUnregister(ComponentId={D73AAA08-2B39-47C6-806E-2A6B3B6C623A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:300]: Executing op: ComponentUnregister(ComponentId={0980041E-3101-4ECB-AB77-DE21BD851BF7},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:301]: Executing op: ComponentUnregister(ComponentId={7B2942BB-6DCF-433D-A05F-72C594ACB635},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:302]: Executing op: ComponentUnregister(ComponentId={643B6154-3EC3-4A50-8356-6F280138C949},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:303]: Executing op: ComponentUnregister(ComponentId={62DD9A51-AD3C-4471-BAFC-877C9420F9A8},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:305]: Executing op: ComponentUnregister(ComponentId={AB2867B8-155D-4EF3-89AF-860B77F5957A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:306]: Executing op: ComponentUnregister(ComponentId={488FD3ED-ABB8-403D-966E-8C1310E40B48},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:307]: Executing op: ComponentUnregister(ComponentId={43F5E2B5-9AE3-4C7C-8FAC-4D26C05474C4},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:309]: Executing op: ComponentUnregister(ComponentId={F0C9EA37-0EFC-49B5-B0C2-AD133EA3FFC2},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:310]: Executing op: ComponentUnregister(ComponentId={82301F46-D400-4CD3-9073-AB9D83FDAD25},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:311]: Executing op: ComponentUnregister(ComponentId={30EC362A-61E0-44C4-A2E4-6DC99DCA4982},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:312]: Executing op: ComponentUnregister(ComponentId={97D864F2-3645-412C-9950-DCD38D56015F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:314]: Executing op: ComponentUnregister(ComponentId={10A7463C-586B-4072-BD99-4ECDF05115FB},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:315]: Executing op: ComponentUnregister(ComponentId={D758586A-F121-4687-85D2-95FCCCB306C0},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:316]: Executing op: ComponentUnregister(ComponentId={D58B4817-D645-47DC-B7A6-511CC2491690},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:317]: Executing op: ComponentUnregister(ComponentId={39A6A35B-E113-461B-ADB7-82B26E646816},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:318]: Executing op: ComponentUnregister(ComponentId={8CDBD7F5-B752-48D3-B594-42917ED15C34},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:320]: Executing op: ComponentUnregister(ComponentId={82649DD5-5EC6-48C8-9E03-3691E63B1D88},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:321]: Executing op: ComponentUnregister(ComponentId={2BC13C26-7261-49B8-8434-911347D79456},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:322]: Executing op: ComponentUnregister(ComponentId={3499B806-F906-463B-B3AD-36318AEC1AC9},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:324]: Executing op: ComponentUnregister(ComponentId={B0A3FE16-1704-4574-831E-30140A39DD52},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:325]: Executing op: ComponentUnregister(ComponentId={94FCA362-0725-4DEE-BCD2-15681D6D8523},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:326]: Executing op: ComponentUnregister(ComponentId={17B17C8D-2625-4936-8D01-A9B5D1A7200A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:328]: Executing op: ComponentUnregister(ComponentId={0682601A-AF3A-4B34-9E36-3CF25B392CA1},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:329]: Executing op: ComponentUnregister(ComponentId={43831726-95EE-472F-BCBA-CB898CC81553},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:330]: Executing op: ComponentUnregister(ComponentId={223B9163-D956-4088-BD28-319F60E3C794},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:331]: Executing op: ComponentUnregister(ComponentId={7527F98F-DA8A-4A92-9810-AF41DB4381BC},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:333]: Executing op: ComponentUnregister(ComponentId={00836444-9677-4FDD-8B0B-1D9BD1D7A613},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:334]: Executing op: ComponentUnregister(ComponentId={3DBA3BF3-80AC-4D67-8630-3346C743DD18},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:336]: Executing op: ComponentUnregister(ComponentId={E28280AE-B169-4DE3-A148-9D9506E40CCC},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:337]: Executing op: ComponentUnregister(ComponentId={0BCE9F47-6D79-4B62-96FE-1AF58AB6E2E9},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:339]: Executing op: ComponentUnregister(ComponentId={72AB219D-FBFE-45BC-AB47-5B894E3AD645},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:340]: Executing op: ComponentUnregister(ComponentId={55AC775A-FB68-40BB-AB91-C9FB46CFBF01},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:341]: Executing op: ComponentUnregister(ComponentId={407ABAA1-425A-4EF4-811B-0DEBBAE3DAA2},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:342]: Executing op: ComponentUnregister(ComponentId={52AF9F8E-453A-4999-8E82-F4C67DD54CF6},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:344]: Executing op: ComponentUnregister(ComponentId={9F772B9A-26DD-48B0-8B7B-8E8E9520460C},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:345]: Executing op: ComponentUnregister(ComponentId={37516611-10EE-4F28-9DE7-876B1420E396},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:346]: Executing op: ComponentUnregister(ComponentId={53F589A8-57A9-40E7-BE34-D037D7B7972B},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:348]: Executing op: ComponentUnregister(ComponentId={68D807EB-6F1E-4C05-80D3-492372F0A003},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:349]: Executing op: ComponentUnregister(ComponentId={1A460D27-6EE5-4A4B-9CCF-FAB5D650D0D5},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:350]: Executing op: ComponentUnregister(ComponentId={BD1BC827-E1F9-4792-9BB3-265C8F86CB35},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:351]: Executing op: ComponentUnregister(ComponentId={F0CDA7F6-D9AE-4688-9A05-D91E571F1C88},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:354]: Executing op: ComponentUnregister(ComponentId={51E1D355-183F-4D6F-931B-E5D22F3F481A},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:355]: Executing op: ComponentUnregister(ComponentId={83A0AADC-FFEF-46BD-B469-98BFD309F60D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:356]: Executing op: ComponentUnregister(ComponentId={F12FF1D4-7C6E-4B37-8067-425ADCF51D16},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:357]: Executing op: ComponentUnregister(ComponentId={1CCC6D30-A49E-4EFE-81B5-4079A21CB366},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:358]: Executing op: ComponentUnregister(ComponentId={84E2B1AB-6B8F-4811-8D9B-D7D3FA874E04},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:359]: Executing op: ComponentUnregister(ComponentId={2FFFFB11-14A2-48C1-A925-560242246926},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:360]: Executing op: ComponentUnregister(ComponentId={3EA39D02-5BBF-48E5-AC84-D2A6464DD6BC},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:362]: Executing op: ComponentUnregister(ComponentId={2C58A04A-B13F-4143-B331-D3CF033FE764},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:363]: Executing op: ComponentUnregister(ComponentId={BD55636A-900B-47AD-8905-FAE7FAF5FD61},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:364]: Executing op: ComponentUnregister(ComponentId={BB961D9D-7729-4AD3-80C4-5639AB765AB1},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:366]: Executing op: ComponentUnregister(ComponentId={8DB2C6B4-EF83-4B5C-AF28-C3AE42DEA374},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:367]: Executing op: ComponentUnregister(ComponentId={D71F4F65-52B4-4261-8962-6AB202FD4A77},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:370]: Executing op: ComponentUnregister(ComponentId={D2622822-7A6F-4E50-8D8F-6C8C0BD248A8},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:372]: Executing op: ComponentUnregister(ComponentId={807FA78F-7006-461C-92D3-61242C7D2914},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:373]: Executing op: ComponentUnregister(ComponentId={1CBF7692-9FCF-4177-9534-A5B46B576B85},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:374]: Executing op: ComponentUnregister(ComponentId={843C708A-AA5F-422F-8F55-4CD53549B717},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:376]: Executing op: ComponentUnregister(ComponentId={62516DBF-FF70-4A68-93C8-8AB84BBA6EA8},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:377]: Executing op: ComponentUnregister(ComponentId={007FD985-D1C2-4BBB-B21D-757F0EE8FF36},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:378]: Executing op: ComponentUnregister(ComponentId={5F02B101-9560-4BC4-84CC-EA9D1FE4C686},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:379]: Executing op: ComponentUnregister(ComponentId={B3473EFF-C8EB-41D2-92D5-1422AAC5641D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:382]: Executing op: ComponentUnregister(ComponentId={411D6869-4E2A-4164-A41E-F6F35B86F1BC},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:382]: Executing op: ComponentUnregister(ComponentId={072AF6AB-A873-4477-A854-8C2480290CB9},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:383]: Executing op: ComponentUnregister(ComponentId={A2C8F94B-05A0-4579-8779-B7EC4E0120FD},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:384]: Executing op: ComponentUnregister(ComponentId={8FBA317B-B72C-4795-9B13-E72FFB417244},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:387]: Executing op: ComponentUnregister(ComponentId={6802661F-6B88-41BC-B4A3-5E596C264B8E},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:388]: Executing op: ComponentUnregister(ComponentId={3AE471B2-0521-4EF3-9422-CCEEAC172395},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:390]: Executing op: ComponentUnregister(ComponentId={EE743147-1CD1-473C-9D07-11F5C36D700D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:390]: Executing op: ComponentUnregister(ComponentId={19F4A41E-C9E3-43A9-ABF7-7661FDCC05A7},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:391]: Executing op: ComponentUnregister(ComponentId={54209388-B65B-4E30-8C92-F75408305083},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:393]: Executing op: ComponentUnregister(ComponentId={F06DAA6A-7850-48AB-A04E-8B36EFBA12D4},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:394]: Executing op: ComponentUnregister(ComponentId={18BB1927-C92F-4094-8BB0-BCB34D5AA129},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:396]: Executing op: ComponentUnregister(ComponentId={EFF6D4DF-EA60-4F25-BB56-1BD5271BA078},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:397]: Executing op: ComponentUnregister(ComponentId={432019AC-F81A-4DE7-8FC3-053AD28E7B9B},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:399]: Executing op: ComponentUnregister(ComponentId={9725D56C-35AB-490B-89FC-733AB3E5A144},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:401]: Executing op: ComponentUnregister(ComponentId={010F0391-B85E-4EA8-8043-6665457E0789},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:402]: Executing op: ComponentUnregister(ComponentId={F0673798-3552-41E0-AB59-5E78522B0563},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:404]: Executing op: ComponentUnregister(ComponentId={98DC6DEF-2E40-44FA-A63B-7C1757B215A4},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:405]: Executing op: ComponentUnregister(ComponentId={6DF0F37A-B0C0-4C35-89DA-5DD1D2686706},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:406]: Executing op: ComponentUnregister(ComponentId={4378A082-8D02-4F71-913A-61913D3446CB},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:408]: Executing op: ComponentUnregister(ComponentId={1FE32170-0256-4070-8754-EBA52C669C1F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:408]: Executing op: ComponentUnregister(ComponentId={443AFABE-3733-4E18-B478-AA838CBAAB1D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:409]: Executing op: ComponentUnregister(ComponentId={BDA7F730-A83B-4B40-873A-B14B64E81803},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:411]: Executing op: ComponentUnregister(ComponentId={2DF29417-FF10-4358-889F-4FB6DE704A8B},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:412]: Executing op: ComponentUnregister(ComponentId={1B513739-C685-45C7-96B5-16B6C17CB00F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:413]: Executing op: ComponentUnregister(ComponentId={378E870E-F99A-4CC7-B13D-EA8F56503183},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:414]: Executing op: ComponentUnregister(ComponentId={F0AEDA55-8958-4827-A6F5-2053B29B4F0D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:416]: Executing op: ComponentUnregister(ComponentId={7A9E6C80-63B0-4F36-8F73-D721604DAC65},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:417]: Executing op: ComponentUnregister(ComponentId={8159CA9D-BDA6-4C72-8E80-449F6F4D2CC9},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:418]: Executing op: ComponentUnregister(ComponentId={6F0DEDE0-CA8B-4709-81A5-7888A6B10398},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:419]: Executing op: ComponentUnregister(ComponentId={46A56299-E243-48EC-8811-8F8379DB59F6},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:422]: Executing op: ComponentUnregister(ComponentId={4FAEAF8D-D93E-4DB5-8718-3691FFDC309D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:423]: Executing op: ComponentUnregister(ComponentId={ED098D35-A27D-4503-A2CC-0CD5F38FE39C},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:424]: Executing op: ComponentUnregister(ComponentId={2386C15C-A94F-428D-9DEB-5732F9051F6D},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:425]: Executing op: ComponentUnregister(ComponentId={053C271A-84E0-4B4C-8834-71D8FF477983},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:426]: Executing op: ComponentUnregister(ComponentId={5F9D59BB-4E7D-4629-B1F3-733F8B93E187},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:427]: Executing op: ComponentUnregister(ComponentId={FC96FA67-16FB-4D7F-9AF1-1F48D32BC4CC},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:428]: Executing op: ComponentUnregister(ComponentId={67AF4F7A-C3E8-46FB-99DA-2FEA24AFE5E4},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:430]: Executing op: ComponentUnregister(ComponentId={3C849469-3A80-4C23-B9F9-401F90C1A70E},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:431]: Executing op: ComponentUnregister(ComponentId={29D3F3CE-4A6F-4FC6-AEE3-ABAC4203F6E3},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=1,)
    MSI (s) (C8:20) [10:47:02:432]: Executing op: ComponentUnregister(ComponentId={0101E9EB-F08C-48D4-9EF4-AFD3F7058CB7},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=1,)
    MSI (s) (C8:20) [10:47:02:433]: Executing op: ComponentUnregister(ComponentId={FD41BAD8-F89A-4516-BFA8-CEA7A24B3CFD},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:435]: Executing op: ComponentUnregister(ComponentId={73683F70-5E6D-4238-AB8A-92B267CE282F},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:436]: Executing op: ComponentUnregister(ComponentId={2980BE88-9AF6-4849-8548-3FB07173BAD4},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:438]: Executing op: ComponentUnregister(ComponentId={EFD16A4C-1F33-49D7-A3BA-94E6C8A3168E},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=1,)
    MSI (s) (C8:20) [10:47:02:438]: Executing op: ComponentUnregister(ComponentId={0152C40D-0523-44EE-95A9-50610A247C16},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:440]: Executing op: ComponentUnregister(ComponentId={9FADEEF6-DB8F-4EAD-9AB1-B18975103694},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:441]: Executing op: ComponentUnregister(ComponentId={2C30A75F-6F0C-4C3A-8AEF-86AAA0506EF5},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=1,)
    MSI (s) (C8:20) [10:47:02:442]: Executing op: ComponentUnregister(ComponentId={64F39AD3-CFA0-4FEC-8A54-3D41DF5AA622},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=1,)
    MSI (s) (C8:20) [10:47:02:443]: Executing op: ComponentUnregister(ComponentId={E1633D3E-7125-431A-9054-2DBB68B05B5E},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:445]: Executing op: ComponentUnregister(ComponentId={0E93667D-D42D-47CE-9D9A-885BB84E5B56},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:446]: Executing op: ComponentUnregister(ComponentId={6EBF38EC-5219-4109-AD57-B7A9B7F2EE62},ProductKey={CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B},BinaryType=0,)
    MSI (s) (C8:20) [10:47:02:447]: Executing op: End(Checksum=0,ProgressTotalHDWord=0,ProgressTotalLDWord=0)
    MSI (s) (C8:20) [10:47:02:447]: Error in rollback skipped.	Return: 5
    MSI (s) (C8:20) [10:47:02:450]: Note: 1: 2318 2:
    MSI (s) (C8:20) [10:47:02:451]: Calling SRSetRestorePoint API. dwRestorePtType: 13, dwEventType: 103, llSequenceNumber: 230, szDescription: "".
    MSI (s) (C8:20) [10:47:02:452]: The call to SRSetRestorePoint API succeeded. Returned status: 0.
    MSI (s) (C8:20) [10:47:02:452]: Unlocking Server
    MSI (s) (C8:20) [10:47:02:455]: PROPERTY CHANGE: Deleting UpdateStarted property. Its current value is '1'.
    MSI (s) (C8:20) [10:47:02:455]: Skipping action: AI_IaLogPkgExitFatalError (condition is false)
    Action ended 10:47:02: INSTALL. Return value 3.
    MSI (c) (40!D4) [10:47:02:458]: Note: 1: 2205 2:  3: AI_PreRequisite
    MSI (c) (40!D4) [10:47:02:458]: Note: 1: 2228 2:  3: AI_PreRequisite 4: SELECT `Options` FROM `AI_PreRequisite`
    Property(S): APPDIR = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\
    Property(S): AI_INSTALLPERUSER = 1
    Property(S): AI_IA_ENABLE = 1
    Property(S): DiskPrompt = [1]
    Property(S): UpgradeCode = {D7D4C089-7B20-418E-BA5E-E0557C67F5D9}
    Property(S): LTspice_2_Dir = C:\Users\mtarr\AppData\Local\LTspice\
    Property(S): AI_APP_FILE = [#LTspice.exe]
    Property(S): AiFeatIcoFeature = ADI.exe
    Property(S): ButtonText_Install = &Install
    Property(S): IAgree = No
    Property(S): AI_IA_CUSTOM_PROPERTIES = ALLUSERS|,Privileged|,APPDIR|,SourceDir|,VersionMsi|,USR_GUEST|,USR_ADMINISTRATOR|,USR_ANONYMOUS|,AdminUser|,GRP_USERS|,GRP_ADMINISTRATORS|,COMPANYNAME|,WindowsBuild|
    Property(S): SecureCustomProperties = OLDPRODUCTS;AI_NEWERPRODUCTFOUND
    Property(S): AI_BITMAP_DISPLAY_MODE = 0
    Property(S): AI_PREDEF_LCONDS_PROPS = AI_DETECTED_ALL
    Property(S): WindowsTypeNT5X = Windows XP/2003
    Property(S): MSIINSTALLPERUSER = 1
    Property(S): AI_IA_SEND_HTTPS = 1
    Property(S): AI_IA_APPLICATION_ID = 63d14d904a6e51432bb45eee
    Property(S): WindowsTypeNT40 = Windows NT 4.0
    Property(S): AI_ThemeStyle = style5blue
    Property(S): ARPPRODUCTICON = ADI.exe
    Property(S): DialogBitmap = dialog.jpg
    Property(S): ButtonText_Yes = &Yes
    Property(S): ARPCOMMENTS = This installer database contains the logic and data required to install LTspice.
    Property(S): WindowsTypeNT60 = Windows Vista/Server 2008
    Property(S): ButtonText_TryAgain = &Try Again
    Property(S): ARPCONTACT = LTspice@analog.com
    Property(S): WindowsTypeNT40Display = Windows NT 4.0
    Property(S): ButtonText_Cancel = Cancel
    Property(S): AiEmbeddedUI = 1
    Property(S): ARPHELPLINK = https://LTspice.analog.com
    Property(S): ARPURLINFOABOUT = https://LTspice.analog.com
    Property(S): ARPURLUPDATEINFO = https://LTspice.analog.com
    Property(S): AiWinUI = 1
    Property(S): ButtonText_Remove = &Remove
    Property(S): CTRLS = 2
    Property(S): WindowsTypeNT5XDisplay = Windows XP/2003
    Property(S): MY_SPECIAL_MODE = 0
    Property(S): ButtonText_Finish = &Finish
    Property(S): Manufacturer = Analog Devices Inc.
    Property(S): ProductCode = {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B}
    Property(S): ButtonText_Repair = &Repair
    Property(S): ProductLanguage = 1033
    Property(S): ProductVersion = 26.0.2.1
    Property(S): WindowsType9XDisplay = Windows 9x/ME
    Property(S): ProductName = LTspice
    Property(S): WINEINSTALLATION = 0
    Property(S): WindowsType9X = Windows 9x/ME
    Property(S): ButtonText_Return = &Return
    Property(S): WindowsTypeNT = Windows 9x/ME/NT/2000/XP/Vista/Windows 7/Windows 8 x86/Windows 8.1 x86/Windows 10 x86
    Property(S): WindowsTypeNT50 = Windows 2000
    Property(S): WindowsTypeNT50Display = Windows 2000
    Property(S): WindowsTypeNT60Display = Windows Vista/Server 2008
    Property(S): PROMPTROLLBACKCOST = P
    Property(S): AppsShutdownOption = All
    Property(S): EnableUserControl = 1
    Property(S): WindowsTypeNTDisplay = 32-bit Windows versions
    Property(S): ButtonText_OK = OK
    Property(S): ErrorDialog = ErrorDlg
    Property(S): INSTALLLEVEL = 3
    Property(S): ButtonText_Browse = Br&owse...
    Property(S): ButtonText_Exit = &Exit
    Property(S): ButtonText_Accept = &Accept
    Property(S): ButtonText_Ignore = &Ignore
    Property(S): ButtonText_No = &No
    Property(S): ButtonText_Reset = &Reset
    Property(S): ButtonText_Resume = &Resume
    Property(S): ButtonText_Retry = &Retry
    Property(S): ButtonText_Decline = &Decline
    Property(S): ButtonText_Continue = &Continue
    Property(S): ButtonText_Abort = &Abort
    Property(S): CtrlEvtChanging = Changing
    Property(S): CtrlEvtRemoving = Removing
    Property(S): CtrlEvtRepairing = Repairing
    Property(S): CtrlEvtchanges = changes
    Property(S): CtrlEvtremoves = removes
    Property(S): CtrlEvtrepairs = repairs
    Property(S): InstallMode = Typical
    Property(S): InstallModeComplete = Complete
    Property(S): InstallModeCustom = Custom
    Property(S): InstallModeTypical = Typical
    Property(S): Setup = Setup
    Property(S): Wizard = Setup Wizard
    Property(S): Progress1 = Installing
    Property(S): Progress2 = installs
    Property(S): AiPrerequisitesColums = PrereqLabel,PrereqReq,PrereqFound,PrereqAction
    Property(S): Text_Next = Next
    Property(S): ButtonText_Back = < &Back
    Property(S): ButtonText_Next = &Next >
    Property(S): Text_Install = Install
    Property(S): AI_CommitButton = ButtonText_Install
    Property(S): CompleteSetupIcon = completi
    Property(S): CustomSetupIcon = custicon
    Property(S): DefaultUIFont = DlgFont8
    Property(S): DlgTitleFont = {\DlgFontBold8}
    Property(S): ExclamationIcon = exclamic
    Property(S): InfoIcon = info
    Property(S): InstallerIcon = insticon
    Property(S): RemoveIcon = removico
    Property(S): RepairIcon = repairic
    Property(S): UpDirIcon = Up
    Property(S): NewDirIcon = New
    Property(S): AI_CF_TITLE_TEXT_STYLE = {\CfTitleFont}
    Property(S): BannerBitmap = banner.jpg
    Property(S): AI_FrameColor = steelblue
    Property(S): AI_LOG_CHECKBOX = 1
    Property(S): TabBackground = tabback
    Property(S): AI_CURRENT_YEAR = 2026
    Property(S): AI_PACKAGING_TOOL = Advanced Installer 23.6 build 60bea727
    Property(S): AI_BUILD_NAME = MsiBuild
    Property(S): AI_EMBEDDED_FILES_LOCATION = 1
    Property(S): AI_BOOTSTRAPPERLANGS = 1033;
    Property(S): AI_BOOTSTRAPPERORIGINALLANG = 1033
    Property(S): AI_PACKAGE_TYPE = x64
    Property(S): LTspice_Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\
    Property(S): whxdata_Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\
    Property(S): LTspiceHelp_Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\
    Property(S): lib_Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\
    Property(S): text_Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\
    Property(S): images_1_Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\images\
    Property(S): css_Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\css\
    Property(S): images_Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\
    Property(S): __Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\2019\
    Property(S): LTspice_1_Dir = C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\LTspice\
    Property(S): scripts_Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\scripts\
    Property(S): math_Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\math\
    Property(S): js_Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\js\
    Property(S): styles_Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\styles\
    Property(S): TARGETDIR = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\
    Property(S): MsiLogFileLocation = C:\Logs\InstallerLog.log
    Property(S): AI_INSTALL = 1
    Property(S): ARPINSTALLLOCATION = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\
    Property(S): SHORTCUTDIR = C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\LTspice
    Property(S): template_Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\
    Property(S): assets_Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\
    Property(S): DesktopFolder = C:\Users\mtarr\Desktop\
    Property(S): LocalAppDataFolder = C:\Users\mtarr\AppData\Local\
    Property(S): ProgramMenuFolder = C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\
    Property(S): SystemFolder = C:\windows\SysWOW64\
    Property(S): SourceDir = E:\LT Spice\Installer 2026-08-24  v26.0.2\
    Property(S): VersionNT = 1100
    Property(S): RedirectedDllSupport = 2
    Property(S): MSICLIENTUSESEMBEDDEDUI = 1
    Property(S): PackageCode = {39C828E8-EBEA-41FF-AC38-4A5921DF2236}
    Property(S): ProductState = -1
    Property(S): PackagecodeChanging = 1
    Property(S): CURRENTDIRECTORY = C:\Windows\SysWOW64
    Property(S): CLIENTUILEVEL = 0
    Property(S): CLIENTPROCESSID = 7488
    Property(S): USERNAME = mtarr00@yahoo.com
    Property(S): COMPANYNAME = mmc
    Property(S): AIEXTERNALUI = 1
    Property(S): CHAINERUIPROCESSID = 17712Chainer
    Property(S): AI_CLIENTPROCESSID = 17712
    Property(S): PRIMARYFOLDER = APPDIR
    Property(S): AI_HWND_EUI = 200128
    Property(S): AI_SYSTEM_DPI = 144
    Property(S): AI_SYSTEM_DPI_SCALE = 150
    Property(S): VersionDatabase = 450
    Property(S): ACTION = INSTALL
    Property(S): EXECUTEACTION = INSTALL
    Property(S): IS_WINE = 0
    Property(S): AI_DETECTED_DOTNET_CORE_VERSION = 8.0
    Property(S): AI_DETECTED_DOTNET_CORE32_VERSION = 8.0
    Property(S): AI_DETECTED_DOTNET_CORE64_VERSION = 8.0
    Property(S): AI_DETECTED_DOTNET_VERSION = 4.8.1
    Property(S): AI_DETECTED_IE_VERSION = 11.0
    Property(S): AI_DETECTED_DIRECTX_VERSION = 12
    Property(S): AI_DETECTED_SQLSERVER_ODBCDRIVER_VERSION = 09.0
    Property(S): AI_DETECTED_SQLSERVER_ODBCDRIVER9_VERSION = 09.0
    Property(S): AI_DETECTED_VSTO_VERSION = 4.0
    Property(S): AI_DETECTED_WINDOWS_POWERSHELL_VERSION = 5.1
    Property(S): AI_DETECTED_POWERSHELL_VERSION = 7.2
    Property(S): AI_DETECTED_POWERSHELL32_VERSION = 7.2
    Property(S): AI_DETECTED_POWERSHELL64_VERSION = 7.2
    Property(S): AI_DETECTED_VISUALCPP_VERSION_PROP = 14.3
    Property(S): AI_DETECTED_VISUALCPP32_VERSION_PROP = 14.3
    Property(S): AI_DETECTED_VISUALCPP64_VERSION_PROP = 14.3
    Property(S): AI_DETECTED_OFFICE_ACCESS_VERSION = 2016
    Property(S): AI_DETECTED_OFFICE_ACCESS64_VERSION = 2016
    Property(S): AI_DETECTED_OFFICE_EXCEL64_VERSION = 2016
    Property(S): AI_DETECTED_OFFICE_EXCEL_VERSION = 2016
    Property(S): AI_DETECTED_OFFICE_ONENOTE_VERSION = 2016
    Property(S): AI_DETECTED_OFFICE_ONENOTE64_VERSION = 2016
    Property(S): AI_DETECTED_OFFICE_OUTLOOK64_VERSION = 2016
    Property(S): AI_DETECTED_OFFICE_OUTLOOK_VERSION = 2016
    Property(S): AI_DETECTED_OFFICE_POWERPOINT_VERSION = 2016
    Property(S): AI_DETECTED_OFFICE_POWERPOINT64_VERSION = 2016
    Property(S): AI_DETECTED_OFFICE_WORD_VERSION = 2016
    Property(S): AI_DETECTED_OFFICE_WORD64_VERSION = 2016
    Property(S): AI_DETECTED_OFFICE_MSFORMS_PIA_VERSION = 2010
    Property(S): AI_DETECTED_PHYSICAL_MEMORY = 32453
    Property(S): AI_DETECTED_OFFICE_MSFORMS2010_PIA_VERSION = 2010
    Property(S): AI_DETECTED_GRAPHICS_ADAPTERS = [{"Name":"NVIDIA Quadro P400","MemorySize":2147483648}]
    Property(S): AI_DETECTED_ADMIN_USER = 1
    Property(S): AI_DETECTED_COLOR_QUALITY = 32
    Property(S): AI_DETECTED_PRODUCT_ANTIVIRUS = Avast Antivirus;
    Property(S): AI_DETECTED_NOT_VIRTUAL_MACHINE = 1
    Property(S): AI_DETECTED_INTERNET_CONNECTION = 1
    Property(S): AI_DETECTED_SCREEN_RESOLUTION_X = 3840
    Property(S): AI_DETECTED_SCREEN_RESOLUTION_Y = 2160
    Property(S): ROOTDRIVE = G:\
    Property(S): SECONDSEQUENCE = 1
    Property(S): ADDLOCAL = LTspice,Feature,Libraries
    Property(S): VersionMsi = 5.00
    Property(S): VersionNT64 = 1100
    Property(S): WindowsBuild = 26200
    Property(S): ServicePackLevel = 0
    Property(S): ServicePackLevelMinor = 0
    Property(S): MsiNTProductType = 1
    Property(S): WindowsFolder = C:\windows\
    Property(S): WindowsVolume = C:\
    Property(S): System64Folder = C:\windows\system32\
    Property(S): RemoteAdminTS = 1
    Property(S): TempFolder = C:\Users\mtarr\AppData\Local\Temp\
    Property(S): ProgramFilesFolder = C:\Users\mtarr\AppData\Local\Programs\
    Property(S): CommonFilesFolder = C:\Users\mtarr\AppData\Local\Programs\Common\
    Property(S): ProgramFiles64Folder = C:\Users\mtarr\AppData\Local\Programs\
    Property(S): CommonFiles64Folder = C:\Users\mtarr\AppData\Local\Programs\Common\
    Property(S): AppDataFolder = C:\Users\mtarr\AppData\Roaming\
    Property(S): FavoritesFolder = C:\Users\mtarr\Favorites\
    Property(S): NetHoodFolder = C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
    Property(S): PersonalFolder = C:\Users\mtarr\Documents\
    Property(S): PrintHoodFolder = C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
    Property(S): RecentFolder = C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Recent\
    Property(S): SendToFolder = C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\SendTo\
    Property(S): TemplateFolder = C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Templates\
    Property(S): CommonAppDataFolder = C:\ProgramData\
    Property(S): MyPicturesFolder = C:\Users\mtarr\Pictures\
    Property(S): AdminToolsFolder = C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
    Property(S): StartupFolder = C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\
    Property(S): StartMenuFolder = C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\
    Property(S): FontsFolder = C:\windows\Fonts\
    Property(S): GPTSupport = 1
    Property(S): OLEAdvtSupport = 1
    Property(S): ShellAdvtSupport = 1
    Property(S): MsiAMD64 = 6
    Property(S): Msix64 = 6
    Property(S): Intel = 6
    Property(S): PhysicalMemory = 32452
    Property(S): VirtualMemory = 54731
    Property(S): LogonUser = mtarr
    Property(S): UserSID = S-1-5-21-2035054356-779003343-2671486986-1002
    Property(S): UserLanguageID = 1033
    Property(S): ComputerName = PC-3400
    Property(S): SystemLanguageID = 1033
    Property(S): ScreenX = 1024
    Property(S): ScreenY = 768
    Property(S): CaptionHeight = 28
    Property(S): BorderTop = 1
    Property(S): BorderSide = 1
    Property(S): TextHeight = 16
    Property(S): TextInternalLeading = 3
    Property(S): ColorBits = 32
    Property(S): TTCSupport = 1
    Property(S): Time = 10:47:02
    Property(S): Date = 9/25/2026
    Property(S): MsiNetAssemblySupport = 4.8.9221.0
    Property(S): MsiWin32AssemblySupport = 6.3.26100.9278
    Property(S): DATABASE = C:\windows\Installer\77b2d2.msi
    Property(S): OriginalDatabase = E:\LT Spice\Installer 2026-08-24  v26.0.2\LTspice64.msi
    Property(S): UILevel = 5
    Property(S): Preselected = 1
    Property(S): SavedGamesFolder = C:\Users\mtarr\Saved Games\
    Property(S): WindowsLibrariesFolder = C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Libraries\
    Property(S): PublicDocumentsFolder = C:\Users\Public\Documents\
    Property(S): PublicFolder = C:\Users\Public\
    Property(S): UserProfileFolder = C:\Users\mtarr\
    Property(S): IIsWWWRootFolder = C:\inetpub\wwwroot\
    Property(S): AI_UserProgramFiles = C:\Users\mtarr\AppData\Local\Programs\
    Property(S): CostingComplete = 1
    Property(S): OutOfDiskSpace = 0
    Property(S): OutOfNoRbDiskSpace = 0
    Property(S): PrimaryVolumeSpaceAvailable = 996775968
    Property(S): PrimaryVolumeSpaceRequired = 645511
    Property(S): PrimaryVolumeSpaceRemaining = 996130457
    Property(S): PrimaryVolumePath = C:
    Property(S): SOURCEDIR = E:\LT Spice\Installer 2026-08-24  v26.0.2\
    Property(S): SourcedirProduct = {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B}
    Property(S): ProductToBeRegistered = 1
    MSI (s) (C8:20) [10:47:02:703]: MainEngineThread is returning 1603
    MSI (s) (C8:78) [10:47:02:705]: RESTART MANAGER: Session closed.
    MSI (s) (C8:78) [10:47:02:710]: User policy value 'DisableRollback' is 0
    MSI (s) (C8:78) [10:47:02:710]: Machine policy value 'DisableRollback' is 0
    MSI (s) (C8:78) [10:47:02:710]: Incrementing counter to disable shutdown. Counter after increment: 0
    MSI (s) (C8:78) [10:47:02:710]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
    MSI (s) (C8:78) [10:47:02:711]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
    MSI (s) (C8:78) [10:47:02:712]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
    MSI (s) (C8:78) [10:47:02:712]: Destroying RemoteAPI object.
    MSI (s) (C8:54) [10:47:02:712]: Custom Action Manager thread ending.
    MSI (c) (40:B0) [10:47:02:713]: Back from server. Return value: 1603
    MSI (c) (40:B0) [10:47:02:714]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
    MSI (c) (40:B0) [10:47:02:714]: PROPERTY CHANGE: Deleting SECONDSEQUENCE property. Its current value is '1'.
    Action ended 10:47:02: ExecuteAction. Return value 3.
    MSI (c) (40:B0) [10:47:02:714]: Doing action: FatalError
    Action 10:47:02: FatalError.
    Action start 10:47:02: FatalError.
    MSI (c) (40!D4) [10:47:02:738]: Note: 1: 2205 2:  3: AI_ControlEx
    MSI (c) (40!D4) [10:47:02:738]: Note: 1: 2228 2:  3: AI_ControlEx 4: SELECT `Dialog_`,`Control`,`Type`,`Parent`,`Attributes`,`Data` FROM `AI_ControlEx` WHERE `Dialog_` = 'FatalError'
    MSI (c) (40!D4) [10:47:04:475]: PROPERTY CHANGE: Adding AiEmbeddedDirectCall property. Its value is '1'.
    MSI (c) (40!D4) [10:47:04:786]: PROPERTY CHANGE: Deleting AiEmbeddedDirectCall property. Its current value is '1'.
    Action ended 10:47:04: FatalError. Return value 2.
    Action ended 10:47:04: INSTALL. Return value 3.
    Action ended 10:47:04: AI_EmbeddedUiAsync. Return value 0.
    Property(C): APPDIR = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\
    Property(C): AI_INSTALLPERUSER = 1
    Property(C): AI_IA_ENABLE = 1
    Property(C): DiskPrompt = [1]
    Property(C): UpgradeCode = {D7D4C089-7B20-418E-BA5E-E0557C67F5D9}
    Property(C): LTspice_2_Dir = C:\Users\mtarr\AppData\Local\LTspice\
    Property(C): AI_APP_FILE = [#LTspice.exe]
    Property(C): AiFeatIcoFeature = ADI.exe
    Property(C): ButtonText_Install = &Install
    Property(C): IAgree = Yes
    Property(C): AI_IA_CUSTOM_PROPERTIES = ALLUSERS|,Privileged|,APPDIR|,SourceDir|,VersionMsi|,USR_GUEST|,USR_ADMINISTRATOR|,USR_ANONYMOUS|,AdminUser|,GRP_USERS|,GRP_ADMINISTRATORS|,COMPANYNAME|,WindowsBuild|
    Property(C): SecureCustomProperties = OLDPRODUCTS;AI_NEWERPRODUCTFOUND
    Property(C): AI_BITMAP_DISPLAY_MODE = 0
    Property(C): AI_PREDEF_LCONDS_PROPS = AI_DETECTED_ALL
    Property(C): WindowsTypeNT5X = Windows XP/2003
    Property(C): MSIINSTALLPERUSER = 1
    Property(C): AI_IA_SEND_HTTPS = 1
    Property(C): AI_IA_APPLICATION_ID = 63d14d904a6e51432bb45eee
    Property(C): WindowsTypeNT40 = Windows NT 4.0
    Property(C): AI_ThemeStyle = style5blue
    Property(C): ARPPRODUCTICON = ADI.exe
    Property(C): DialogBitmap = dialog.jpg
    Property(C): ALLUSERS = 2
    Property(C): ButtonText_Yes = &Yes
    Property(C): ARPCOMMENTS = This installer database contains the logic and data required to install LTspice.
    Property(C): WindowsTypeNT60 = Windows Vista/Server 2008
    Property(C): ButtonText_TryAgain = &Try Again
    Property(C): ARPCONTACT = LTspice@analog.com
    Property(C): WindowsTypeNT40Display = Windows NT 4.0
    Property(C): ButtonText_Cancel = Cancel
    Property(C): AiEmbeddedUI = 1
    Property(C): ARPHELPLINK = https://LTspice.analog.com
    Property(C): ARPURLINFOABOUT = https://LTspice.analog.com
    Property(C): ARPURLUPDATEINFO = https://LTspice.analog.com
    Property(C): AiWinUI = 1
    Property(C): ButtonText_Remove = &Remove
    Property(C): CTRLS = 2
    Property(C): WindowsTypeNT5XDisplay = Windows XP/2003
    Property(C): MY_SPECIAL_MODE = 0
    Property(C): ButtonText_Finish = &Finish
    Property(C): Manufacturer = Analog Devices Inc.
    Property(C): ProductCode = {CCB0713C-CC43-47F7-AB45-2E9ECBB5BA7B}
    Property(C): ButtonText_Repair = &Repair
    Property(C): ProductLanguage = 1033
    Property(C): ProductVersion = 26.0.2.1
    Property(C): WindowsType9XDisplay = Windows 9x/ME
    Property(C): ProductName = LTspice
    Property(C): WINEINSTALLATION = 0
    Property(C): WindowsType9X = Windows 9x/ME
    Property(C): ButtonText_Return = &Return
    Property(C): WindowsTypeNT = Windows 9x/ME/NT/2000/XP/Vista/Windows 7/Windows 8 x86/Windows 8.1 x86/Windows 10 x86
    Property(C): WindowsTypeNT50 = Windows 2000
    Property(C): WindowsTypeNT50Display = Windows 2000
    Property(C): WindowsTypeNT60Display = Windows Vista/Server 2008
    Property(C): PROMPTROLLBACKCOST = P
    Property(C): AppsShutdownOption = All
    Property(C): EnableUserControl = 1
    Property(C): WindowsTypeNTDisplay = 32-bit Windows versions
    Property(C): ButtonText_OK = OK
    Property(C): ErrorDialog = ErrorDlg
    Property(C): INSTALLLEVEL = 3
    Property(C): ButtonText_Browse = Br&owse...
    Property(C): ButtonText_Exit = &Exit
    Property(C): ButtonText_Accept = &Accept
    Property(C): ButtonText_Ignore = &Ignore
    Property(C): ButtonText_No = &No
    Property(C): ButtonText_Reset = &Reset
    Property(C): ButtonText_Resume = &Resume
    Property(C): ButtonText_Retry = &Retry
    Property(C): ButtonText_Decline = &Decline
    Property(C): ButtonText_Continue = &Continue
    Property(C): ButtonText_Abort = &Abort
    Property(C): CtrlEvtChanging = Changing
    Property(C): CtrlEvtRemoving = Removing
    Property(C): CtrlEvtRepairing = Repairing
    Property(C): CtrlEvtchanges = changes
    Property(C): CtrlEvtremoves = removes
    Property(C): CtrlEvtrepairs = repairs
    Property(C): InstallMode = Typical
    Property(C): InstallModeComplete = Complete
    Property(C): InstallModeCustom = Custom
    Property(C): InstallModeTypical = Typical
    Property(C): Setup = Setup
    Property(C): Wizard = Setup Wizard
    Property(C): Progress1 = Installing
    Property(C): Progress2 = installs
    Property(C): AiPrerequisitesColums = PrereqLabel,PrereqReq,PrereqFound,PrereqAction
    Property(C): Text_Next = Install
    Property(C): ButtonText_Back = < &Back
    Property(C): ButtonText_Next = &Install
    Property(C): Text_Install = Install
    Property(C): AI_CommitButton = ButtonText_Install
    Property(C): CompleteSetupIcon = completi
    Property(C): CustomSetupIcon = custicon
    Property(C): DefaultUIFont = DlgFont8
    Property(C): DlgTitleFont = {\DlgFontBold8}
    Property(C): ExclamationIcon = exclamic
    Property(C): InfoIcon = info
    Property(C): InstallerIcon = insticon
    Property(C): RemoveIcon = removico
    Property(C): RepairIcon = repairic
    Property(C): UpDirIcon = Up
    Property(C): NewDirIcon = New
    Property(C): AI_CF_TITLE_TEXT_STYLE = {\CfTitleFont}
    Property(C): BannerBitmap = banner.jpg
    Property(C): AI_FrameColor = steelblue
    Property(C): AI_LOG_CHECKBOX = 1
    Property(C): TabBackground = tabback
    Property(C): AI_CURRENT_YEAR = 2026
    Property(C): AI_PACKAGING_TOOL = Advanced Installer 23.6 build 60bea727
    Property(C): AI_BUILD_NAME = MsiBuild
    Property(C): AI_EMBEDDED_FILES_LOCATION = 1
    Property(C): AI_BOOTSTRAPPERLANGS = 1033;
    Property(C): AI_BOOTSTRAPPERORIGINALLANG = 1033
    Property(C): AI_PACKAGE_TYPE = x64
    Property(C): LTspice_Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\
    Property(C): whxdata_Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\
    Property(C): LTspiceHelp_Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\
    Property(C): lib_Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\lib\
    Property(C): text_Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\whxdata\text\
    Property(C): images_1_Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\images\
    Property(C): css_Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\css\
    Property(C): images_Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\
    Property(C): __Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\LTspice\2019\
    Property(C): LTspice_1_Dir = C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\LTspice\
    Property(C): scripts_Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\scripts\
    Property(C): math_Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\images\math\
    Property(C): js_Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\js\
    Property(C): styles_Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\styles\
    Property(C): TARGETDIR = G:\
    Property(C): MsiLogFileLocation = C:\Logs\InstallerLog.log
    Property(C): AI_INSTALL = 1
    Property(C): SHORTCUTDIR = C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\LTspice
    Property(C): template_Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\template\
    Property(C): assets_Dir = C:\Users\mtarr\AppData\Local\Programs\ADI\LTspice\LTspiceHelp\assets\
    Property(C): DesktopFolder = C:\Users\mtarr\Desktop\
    Property(C): LocalAppDataFolder = C:\Users\mtarr\AppData\Local\
    Property(C): ProgramMenuFolder = C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
    Property(C): SystemFolder = C:\windows\SysWOW64\
    Property(C): SourceDir = E:\LT Spice\Installer 2026-08-24  v26.0.2\
    Property(C): VersionNT = 1100
    Property(C): RedirectedDllSupport = 2
    Property(C): MSICLIENTUSESEMBEDDEDUI = 1
    Property(C): PackageCode = {39C828E8-EBEA-41FF-AC38-4A5921DF2236}
    Property(C): ProductState = -1
    Property(C): PackagecodeChanging = 1
    Property(C): CURRENTDIRECTORY = C:\Windows\SysWOW64
    Property(C): CLIENTUILEVEL = 0
    Property(C): CLIENTPROCESSID = 7488
    Property(C): VersionDatabase = 450
    Property(C): VersionMsi = 5.00
    Property(C): VersionNT64 = 1100
    Property(C): WindowsBuild = 26200
    Property(C): ServicePackLevel = 0
    Property(C): ServicePackLevelMinor = 0
    Property(C): MsiNTProductType = 1
    Property(C): WindowsFolder = C:\windows\
    Property(C): WindowsVolume = C:\
    Property(C): System64Folder = C:\windows\system32\
    Property(C): RemoteAdminTS = 1
    Property(C): TempFolder = C:\Users\mtarr\AppData\Local\Temp\
    Property(C): ProgramFilesFolder = C:\Users\mtarr\AppData\Local\Programs\
    Property(C): CommonFilesFolder = C:\Users\mtarr\AppData\Local\Programs\Common\
    Property(C): ProgramFiles64Folder = C:\Users\mtarr\AppData\Local\Programs\
    Property(C): CommonFiles64Folder = C:\Users\mtarr\AppData\Local\Programs\Common\
    Property(C): AppDataFolder = C:\Users\mtarr\AppData\Roaming\
    Property(C): FavoritesFolder = C:\Users\mtarr\Favorites\
    Property(C): NetHoodFolder = C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
    Property(C): PersonalFolder = C:\Users\mtarr\Documents\
    Property(C): PrintHoodFolder = C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
    Property(C): RecentFolder = C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Recent\
    Property(C): SendToFolder = C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\SendTo\
    Property(C): TemplateFolder = C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Templates\
    Property(C): CommonAppDataFolder = C:\ProgramData\
    Property(C): MyPicturesFolder = C:\Users\mtarr\Pictures\
    Property(C): AdminToolsFolder = C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
    Property(C): StartupFolder = C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\
    Property(C): StartMenuFolder = C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Start Menu\
    Property(C): FontsFolder = C:\windows\Fonts\
    Property(C): GPTSupport = 1
    Property(C): OLEAdvtSupport = 1
    Property(C): ShellAdvtSupport = 1
    Property(C): MsiAMD64 = 6
    Property(C): Msix64 = 6
    Property(C): Intel = 6
    Property(C): PhysicalMemory = 32452
    Property(C): VirtualMemory = 55071
    Property(C): LogonUser = mtarr
    Property(C): UserSID = S-1-5-21-2035054356-779003343-2671486986-1002
    Property(C): UserLanguageID = 1033
    Property(C): ComputerName = PC-3400
    Property(C): SystemLanguageID = 1033
    Property(C): ScreenX = 3840
    Property(C): ScreenY = 2160
    Property(C): CaptionHeight = 35
    Property(C): BorderTop = 1
    Property(C): BorderSide = 1
    Property(C): TextHeight = 25
    Property(C): TextInternalLeading = 5
    Property(C): ColorBits = 32
    Property(C): TTCSupport = 1
    Property(C): Time = 10:47:04
    Property(C): Date = 9/25/2026
    Property(C): MsiNetAssemblySupport = 4.8.9221.0
    Property(C): MsiWin32AssemblySupport = 6.3.26100.9278
    Property(C): AdminUser = 1
    Property(C): Privileged = 1
    Property(C): USERNAME = mtarr00@yahoo.com
    Property(C): COMPANYNAME = mmc
    Property(C): DATABASE = E:\LT Spice\Installer 2026-08-24  v26.0.2\LTspice64.msi
    Property(C): OriginalDatabase = E:\LT Spice\Installer 2026-08-24  v26.0.2\LTspice64.msi
    Property(C): AIEXTERNALUI = 1
    Property(C): CHAINERUIPROCESSID = 17712Chainer
    Property(C): AI_CLIENTPROCESSID = 17712
    Property(C): PRIMARYFOLDER = APPDIR
    Property(C): AI_HWND_EUI = 200128
    Property(C): AI_SYSTEM_DPI = 144
    Property(C): AI_SYSTEM_DPI_SCALE = 150
    Property(C): SOURCEDIR = E:\LT Spice\Installer 2026-08-24  v26.0.2\
    Property(C): VersionHandler = 5.00
    Property(C): TextHeightCorrection = 1.2000
    Property(C): UILevel = 5
    Property(C): ACTION = INSTALL
    Property(C): EXECUTEACTION = INSTALL
    Property(C): SavedGamesFolder = C:\Users\mtarr\Saved Games\
    Property(C): WindowsLibrariesFolder = C:\Users\mtarr\AppData\Roaming\Microsoft\Windows\Libraries\
    Property(C): PublicDocumentsFolder = C:\Users\Public\Documents\
    Property(C): PublicFolder = C:\Users\Public\
    Property(C): UserProfileFolder = C:\Users\mtarr\
    Property(C): IIsWWWRootFolder = C:\inetpub\wwwroot\
    Property(C): IS_WINE = 0
    Property(C): AI_DETECTED_DOTNET_CORE_VERSION = 8.0
    Property(C): AI_DETECTED_DOTNET_CORE32_VERSION = 8.0
    Property(C): AI_DETECTED_DOTNET_CORE64_VERSION = 8.0
    Property(C): AI_DETECTED_DOTNET_VERSION = 4.8.1
    Property(C): AI_DETECTED_IE_VERSION = 11.0
    Property(C): AI_DETECTED_DIRECTX_VERSION = 12
    Property(C): AI_DETECTED_SQLSERVER_ODBCDRIVER_VERSION = 09.0
    Property(C): AI_DETECTED_SQLSERVER_ODBCDRIVER9_VERSION = 09.0
    Property(C): AI_DETECTED_VSTO_VERSION = 4.0
    Property(C): AI_DETECTED_WINDOWS_POWERSHELL_VERSION = 5.1
    Property(C): AI_DETECTED_POWERSHELL_VERSION = 7.2
    Property(C): AI_DETECTED_POWERSHELL32_VERSION = 7.2
    Property(C): AI_DETECTED_POWERSHELL64_VERSION = 7.2
    Property(C): AI_DETECTED_VISUALCPP_VERSION_PROP = 14.3
    Property(C): AI_DETECTED_VISUALCPP32_VERSION_PROP = 14.3
    Property(C): AI_DETECTED_VISUALCPP64_VERSION_PROP = 14.3
    Property(C): AI_DETECTED_OFFICE_ACCESS_VERSION = 2016
    Property(C): AI_DETECTED_OFFICE_ACCESS64_VERSION = 2016
    Property(C): AI_DETECTED_OFFICE_EXCEL64_VERSION = 2016
    Property(C): AI_DETECTED_OFFICE_EXCEL_VERSION = 2016
    Property(C): AI_DETECTED_OFFICE_ONENOTE_VERSION = 2016
    Property(C): AI_DETECTED_OFFICE_ONENOTE64_VERSION = 2016
    Property(C): AI_DETECTED_OFFICE_OUTLOOK64_VERSION = 2016
    Property(C): AI_DETECTED_OFFICE_OUTLOOK_VERSION = 2016
    Property(C): AI_DETECTED_OFFICE_POWERPOINT_VERSION = 2016
    Property(C): AI_DETECTED_OFFICE_POWERPOINT64_VERSION = 2016
    Property(C): AI_DETECTED_OFFICE_WORD_VERSION = 2016
    Property(C): AI_DETECTED_OFFICE_WORD64_VERSION = 2016
    Property(C): AI_DETECTED_OFFICE_MSFORMS_PIA_VERSION = 2010
    Property(C): AI_DETECTED_PHYSICAL_MEMORY = 32453
    Property(C): AI_DETECTED_OFFICE_MSFORMS2010_PIA_VERSION = 2010
    Property(C): AI_DETECTED_GRAPHICS_ADAPTERS = [{"Name":"NVIDIA Quadro P400","MemorySize":2147483648}]
    Property(C): AI_DETECTED_ADMIN_USER = 1
    Property(C): AI_DETECTED_COLOR_QUALITY = 32
    Property(C): AI_DETECTED_PRODUCT_ANTIVIRUS = Avast Antivirus;
    Property(C): AI_DETECTED_NOT_VIRTUAL_MACHINE = 1
    Property(C): AI_DETECTED_INTERNET_CONNECTION = 1
    Property(C): AI_DETECTED_SCREEN_RESOLUTION_X = 3840
    Property(C): AI_DETECTED_SCREEN_RESOLUTION_Y = 2160
    Property(C): AI_ButtonText_Next_Orig = &Next >
    Property(C): AI_UserProgramFiles = C:\Users\mtarr\AppData\Local\Programs\
    Property(C): ROOTDRIVE = G:\
    Property(C): CostingComplete = 1
    Property(C): OutOfDiskSpace = 0
    Property(C): OutOfNoRbDiskSpace = 0
    Property(C): PrimaryVolumeSpaceAvailable = 998284360
    Property(C): PrimaryVolumeSpaceRequired = 993647
    Property(C): PrimaryVolumeSpaceRemaining = 997290713
    Property(C): CustomActionData = Libraries
    Property(C): AI_Text_Next_Orig = Next
    Property(C): PrimaryVolumePath = C:
    Property(C): ModalPerformed = WelcomeDlg
    MSI (c) (40:B0) [10:47:16:612]: Destroying RemoteAPI object.
    MSI (c) (40:E0) [10:47:16:613]: Custom Action Manager thread ending.
    MSI (c) (40:B0) [10:47:16:614]: FDeleteFolder: Deleting file 'C:\Users\mtarr\AppData\Local\Temp\MSI21813\App.xbf'
    MSI (c) (40:B0) [10:47:16:615]: FDeleteFolder: Deleting file 'C:\Users\mtarr\AppData\Local\Temp\MSI21813\embeddeduiproxy.dll'
    MSI (c) (40:B0) [10:47:16:615]: FDeleteFolder: Deleting file 'C:\Users\mtarr\AppData\Local\Temp\MSI21813\EnhancedUI.exe'
    MSI (c) (40:B0) [10:47:16:616]: FDeleteFolder: Deleting file 'C:\Users\mtarr\AppData\Local\Temp\MSI21813\HtmlHostControl.xbf'
    MSI (c) (40:B0) [10:47:16:616]: FDeleteFolder: Deleting file 'C:\Users\mtarr\AppData\Local\Temp\MSI21813\InstallerAnalytics.dll'
    MSI (c) (40:B0) [10:47:16:617]: FDeleteFolder: Deleting file 'C:\Users\mtarr\AppData\Local\Temp\MSI21813\Microsoft.Toolkit.Win32.UI.XamlHost.dll'
    MSI (c) (40:B0) [10:47:16:617]: FDeleteFolder: Deleting file 'C:\Users\mtarr\AppData\Local\Temp\MSI21813\Microsoft.UI.Xaml.dll'
    MSI (c) (40:B0) [10:47:16:618]: FDeleteFolder: Deleting file 'C:\Users\mtarr\AppData\Local\Temp\MSI21813\Microsoft.Web.WebView2.Core.dll'
    MSI (c) (40:B0) [10:47:16:619]: FDeleteFolder: Deleting file 'C:\Users\mtarr\AppData\Local\Temp\MSI21813\msvcp140.dll'
    MSI (c) (40:B0) [10:47:16:619]: FDeleteFolder: Deleting file 'C:\Users\mtarr\AppData\Local\Temp\MSI21813\msvcp140_app.dll'
    MSI (c) (40:B0) [10:47:16:619]: FDeleteFolder: Deleting file 'C:\Users\mtarr\AppData\Local\Temp\MSI21813\resources.pri'
    MSI (c) (40:B0) [10:47:16:622]: FDeleteFolder: Deleting file 'C:\Users\mtarr\AppData\Local\Temp\MSI21813\ucrtbase.dll'
    MSI (c) (40:B0) [10:47:16:623]: FDeleteFolder: Deleting file 'C:\Users\mtarr\AppData\Local\Temp\MSI21813\vcamp140_app.dll'
    MSI (c) (40:B0) [10:47:16:623]: FDeleteFolder: Deleting file 'C:\Users\mtarr\AppData\Local\Temp\MSI21813\vccorlib140_app.dll'
    MSI (c) (40:B0) [10:47:16:623]: FDeleteFolder: Deleting file 'C:\Users\mtarr\AppData\Local\Temp\MSI21813\vcomp140_app.dll'
    MSI (c) (40:B0) [10:47:16:623]: FDeleteFolder: Deleting file 'C:\Users\mtarr\AppData\Local\Temp\MSI21813\vcruntime140.dll'
    MSI (c) (40:B0) [10:47:16:624]: FDeleteFolder: Deleting file 'C:\Users\mtarr\AppData\Local\Temp\MSI21813\vcruntime140_app.dll'
    MSI (c) (40:B0) [10:47:16:624]: FDeleteFolder: Deleting file 'C:\Users\mtarr\AppData\Local\Temp\MSI21813\WinUiBootstrapperEui.dll'
    === Logging stopped: 9/25/2026  10:47:16 ===
    MSI (c) (40:B0) [10:47:16:625]: Note: 1: 1708
    MSI (c) (40:B0) [10:47:16:625]: Product: LTspice -- Installation failed.
    MSI (c) (40:B0) [10:47:16:626]: Windows Installer installed the product. Product Name: LTspice. Product Version: 26.0.2.1. Product Language: 1033. Manufacturer: Analog Devices Inc.. Installation success or error status: 1603.
    MSI (c) (40:B0) [10:47:16:626]: Grabbed execution mutex.
    MSI (c) (40:B0) [10:47:16:627]: Cleaning up uninstalled install packages, if any exist
    MSI (c) (40:B0) [10:47:16:629]: MainEngineThread is returning 1603
    === Verbose logging stopped: 9/25/2026  10:47:16 ===
  • Here's the log file inserted as code (too bad there's not an option to attach the file):
    You should be able to simply drag and drop the file to the Reply window, or choose Insert > Image/Video/File. If the file type is rejected, simply zip it up.
    I tried to insert the log file inline but the ADI words matter rejected it. Hopefully it is acceptable this way.
    Oh, also frustrated by this. Sorry. Nevertheless, this should be fine.
    mike
  • Hi  ,
    While we look through this log, would advise hand deleting all of the LTspice program files from Local and Roaming. Then, try the install again, though, download the new installer for version LTspice 26.1.1.
    Might as well do the same thing: use the command line with logging, just in case.
    mike
    26.1.1 also has a problem installing. Will send log shortly.
    Perhaps the developers can fix this?
    -Morty
  • Hi  ,
    Remove.exe should not be required to run LTspice, it is simply a program that cleans up models. Question: if you double-click LTspice.exe, does it run?
    mike
