LTspice 26.0.2.1 exits immediately after startup on Windows 11
Product Number: LTspice
Software Version: 26.0.2.1
Subject: LTspice 26.0.2.1 exits immediately after startup on Windows 11
System Information
  • LTspice version: 26.0.2.1
  • Windows version: 10.0.26200.8390
  • Graphics adapter: Intel(R) Iris(R) Xe Graphics
  • DisplayLink dock software installed (problem persists when disconnected from dock and using laptop display only)
  • LTspice previously worked on this machine
  • Other users in the company are currently using LTspice successfully
Problem Description
LTspice no longer launches. Clicking the Start menu shortcut or running LTspice.exe directly causes no visible response. No LTspice process remains running and no crash dialogs are displayed.
Installation Location
LTspice is installed in:
C:\Users\caldwellj\AppData\Local\Programs\ADI\LTspice
LTspice.exe properties:
  • File version: 26.0.2.1
  • Product version: 26.0.1.1
  • File size: ~65 MB
  • Digital signature appears valid
Observed Behavior
Initially:
  • Launching LTspice produced no visible response.
  • No process appeared in Task Manager.
  • Event Viewer showed no Application Error.
  • Reliability Monitor showed no application failures.
After deleting/renaming LTspice.ini:
  • LTspice displayed the "Anonymously Share LTspice Usage Data" dialog.
  • Clicking either "Yes" or "No" causes LTspice to exit immediately.
  • No main window ever appears.
  • No crash is logged in Event Viewer or Reliability Monitor.
  • ERRORLEVEL returned by the process is 0.
Troubleshooting Performed
Configuration Reset
  • Renamed/deleted:
C:\Users\caldwellj\AppData\Roaming\LTspice.ini
Result:
  • Telemetry dialog appears, then LTspice exits.
Local Data Reset
Renamed:
C:\Users\caldwellj\AppData\Local\LTspice
to:
LTspice_old
Result:
  • Same behavior.
  • No new Local\LTspice folder is recreated.
Reinstallation
  • Downloaded and installed latest version.
  • Rebooted system.
Result:
  • Same behavior.
Executable Tests
Executed directly:
C:\Users\caldwellj\AppData\Local\Programs\ADI\LTspice\LTspice.exe
Result:
  • Exits immediately with no error.
  • ERRORLEVEL = 0.
Graphics Tests
Set:
QT_OPENGL=software
before launching.
Result:
  • No change.
Problem also persists with:
  • DisplayLink dock disconnected
  • External monitors disconnected
Window Position Test
Tried Alt+Space, M to recover off-screen window.
Result:
  • No change.
Event Viewer
Checked:
  • Windows Logs → Application
  • AppLocker logs
  • CodeIntegrity logs
Result:
  • No LTspice errors or warnings generated.
Reliability Monitor
Result:
  • No LTspice application failures recorded.
Installation Contents
Folder contains:
  • LTspice.exe
  • updater.exe
  • Remove.exe
  • lib.zip
  • examples.zip
  • LTspiceHelp folder
Manually extracted:
  • lib.zip → lib folder
  • examples.zip → examples folder
Result:
  • No change.
Updater
updater.exe launches successfully and reports:
"Your software is up to date."
Hardware
Display adapters:
  • Intel(R) Iris(R) Xe Graphics
  • DisplayLink USB Device
Current Behavior
After deleting LTspice.ini:
  1. LTspice launches.
  2. "Share Usage Data" dialog appears.
  3. Clicking either Yes or No causes immediate exit.
  4. Main application window never appears.
  5. No new AppData\Local\LTspice folder is created.
  6. No crash logs are generated.
Please advise on additional diagnostic options or known issues with LTspice 26.0.2.1 on Windows build 10.0.26200.8390.
  • Hi  ,
    Sorry about that; very frustrating. Thank you for the clear explanation. It might help troubleshooting if you can produce a verbose log of the install using the following at the command line:
    msiexec /i "C:\MyPackages\LTspice64.msi" /L*V "C:\Logs\InstallerLog.log
    Graphics are rarely the problem. Are you on an ARM machine or x64? Did you have previous installations? What versions?
    thanks,
    mike
  • Hi Mike,
    Thanks for the quick response. I am using a x64 machine. I've uninstalled the program and then reinstalled and created the attached log files. The version I had previously installed that was working has been uninstalled, so I'm not sure of the specific version but it would have been downloaded in Feb 2025 with the latest at the time. 7713.InstallerLog.log
  • Feb 2025 with the latest at the time.
    Did you ever have LTspice XVII or 17.x installed? Would be circa 2023 or earlier.
    mike
  • Not on this machine. This was new to me in Feb 2025.
  • Hi Mike,
    The install appears to complete successfully with status 0. I do not see an MSI failure such as Return Value 3, 1603, or rollback.
    After the install, LTspice is present at:
    C:\Program Files\ADI\LTspice\LTspice.exe
    Launching that executable directly also does nothing visible. No main window appears, no LTspice process remains in Task Manager, and I do not see a new Event Viewer or Reliability Monitor crash entry.
    From the log/system info:
    • Machine appears to be x64, not ARM
    • Windows build: 26200
    • Graphics: Intel Iris Xe, DisplayLink devices also present
    • Antivirus detected: Windows Defender
    • Visual C++ runtime detected: 14.3
    • Previous LTspice installation existed, but version is unknown. Current installed version appears to be 26.0.2.1.
    One additional observation: when I delete/rename LTspice.ini and launch LTspice, the first-run diagnostic/usage-data dialog appears. After clicking either Yes or No, LTspice exits immediately. No new AppData\Local\LTspice folder appears to be created afterward.
    Please let me know if there is a command-line flag, startup log, registry location, or crash-dump setting I can enable to capture why LTspice is exiting after the first-run dialog.
    John
  • Hi  ,
    The behavior you describe is 99%-of-the-time related to the fact that LTspice cannot find the library files, because of an admin install, or an old ini is lurking and getting in the way. I did have a user where a new machine had files transferred from an old machine, where many program files existed in a liminal space created by MS off of the desktop. It took a about an hour of screenshare to find the lurking ini, which did not show up in search! In this case, I was able to help the user find it by looking at where the LTspice shortcut was pointing.
    Good chance this is the problem. The designer of the install here has told me several times that the solution is to find all of the ini files and get rid of them. It appears that that is not working for you. I'll see what I can find out.
    mike
  • Hi  ,
    Any chance you have an LTspiceXVII.ini in Roaming?
    mike
  • Hi Mike,
    I searched for LTspice INI files and only found:
    • C:\Users\caldwellj\AppData\Roaming\LTspice.ini
    • C:\Users\caldwellj\AppData\Roaming\LTspice_20260623_134713.ini
    • C:\Program Files\ADI\LTspice\updater.ini
    The newly generated LTspice.ini appears to be a default configuration with no custom library paths or old install references.
    I also verified that the LTspice libraries exist:
    • C:\Users\caldwellj\AppData\Local\LTspice\lib
    • C:\Users\caldwellj\AppData\Local\LTspice\examples
    and both contain the expected files.
    The current behavior is:
    1. Delete LTspice.ini
    2. Launch LTspice
    3. Usage-data dialog appears
    4. Select either Yes or No
    5. LTspice immediately exits
    No crash dialog appears, no Event Viewer error is logged, no Reliability Monitor failure is recorded, and the process exits with code 0.
    Is there a startup logging option, debug mode, or registry location that would show what LTspice is doing immediately after the usage-data dialog is dismissed?
  • Hi  ,
    Can you share the LTspice.ini file created when you attempt to start.
    mike
  • I have seen where LTspice is prevented from writing to the ini file.
